 Old 12-22-2008, 08:37 AM   #1
y2kc0wb0y's Avatar
Posts: 808   (View Stats)
y2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the world
Default How to bleed MazdaSpeed 3 clutch slave cylinder
To bleed the clutch slave cylinder you will need.
The car up on jacks/lift and the belly plate off...
9mm box wrench
Dot3 or better brake fluid.
Shop Rag or drain line and bucket.
A friend
Notice: the brake/clutch reservior on the firewall is a dual baffle design. Meaning, the fluid for the brakes and the clutch are found in the same reservior and likewise filled at the same location. If you look at this reservior, the fluid for the brakes is found in the front of the reservior and the fluid for the clutch slave cylinder is found in the back of the reservior. To fill the clutch slave cylinder reservior, one will need to OVERFILL the brake reservior to get fluid in that rear baffle..
Once sufficent fluid is in the rear baffle the process can begin. Otherwise, you'll be pumping air and fustrated.
Have a friend pump and hold the clutch pedal to the floor. Using the 9mm box wrench, crack the bleeder valve on the clutch slave cylinder. Have a shop rag handy to cover the port when it is cracked to catch any fluid or you can attach a 1/4" hose to the bleeder valve nipple and re-route the brake fluid to a bucket. When you crack the valve air and some fluid will escape. Tighten the valve back. At this point your friend will need to manually pull the clutch pedal from the floor.
This process will repeat until there is no air left in the line and only fluid squirts out. Once all air has been bled and the clutch pedal manually pulled back to postion. Test the system. The clutch pedal should start moving the slave cylinder and the spring in the slave cylinder will move the pedal back to the up position...DONT FORGET TO TOP OFF FLUIDS WHEN YOU FINISH THIS PROCESS. This might mean you'll need to remove fluid from the brake section of the reservior.
y2kc0wb0y is offline   Reply With Quote
The Following 5 Users Say Thank You to y2kc0wb0y For This Useful Post:
Darksun280 (12-22-2008), nybe0010 (05-09-2013), Phantom (01-07-2009), SharkDiver (01-28-2009), superskaterxes (12-22-2008)
 Old 12-22-2008, 08:48 AM   #2
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
Don't even attempt this by yourself. I wasted alot of time attempting that.
Carry on citizens....
10.7 @ 133 auto 1G DSM
 Old 11-26-2017, 08:37 PM   #3
krimsonviper's Avatar
Posts: 61   (View Stats)
krimsonviper is a jewel in the roughkrimsonviper is a jewel in the roughkrimsonviper is a jewel in the rough
For those who are looking to do this job for the first time in their life, I keep reading about buying a power bleeder.
Now that I’ve attributed to this, time to ask a question. Is it bad just to change the clutch fluid and not the entire system? I searched, but didn’t see anything in particular to this question.
Fuck me, just found my answer. I used different keywords.
The correct procedure for bleeding brakes
If I’m asking a question:
1. I searched and my question is a little unique to my situation.
2. My search-fu is weak.
3. The answer might have gone over my head and I need clarification.
Not modding just to mod. If something in maintenance comes up and aftermarket offers me something I’ll probably take it.
krimsonviper is offline   Reply With Quote
 Old 11-27-2017, 04:19 PM   #4
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
You might catch hell for resurrecting a 9 year old thread, so hold on.
Anyhow, this weekend I replaced my master, slave, and rubber line with braided steel on my clutch system. It was totally void of hydraulic fluid once installed. I sucessfully bled it in 20 minutes with this by myself.
https://www.amazon.com/Allstar-Perfo...00F9XHVKA?th=1
krimsonviper (11-27-2017)
 Old 11-27-2017, 07:11 PM   #5
I don’t care much for age when it comes to how-tos. I’m going to catch flak for asking questions, and I’m going to catch flak for resurrecting a thread. Damned if you do, damned if you don’t. I’d rather piss off a few people rather than spend money on a fuck up. At least I added something for future readers on a how-to they might happen across.
Next-gen Boxster to get a four cylinder? Haltech Automotive News 0 11-03-2008 12:20 PM
Rumormill: BMW considering four-cylinder 3-series for U.S. Haltech Automotive News 0 09-04-2008 10:40 AM
Cadillac considering four-cylinder sedan for 2010 Haltech Automotive News 0 08-25-2008 08:10 AM
Page generated in 0.27983 seconds with 23 queries
