 Old 01-18-2011, 05:03 AM   #1
609speed6's Avatar
Posts: 466   (View Stats)
609speed6 has a reputation beyond repute609speed6 has a reputation beyond repute609speed6 has a reputation beyond repute609speed6 has a reputation beyond repute609speed6 has a reputation beyond repute609speed6 has a reputation beyond repute609speed6 has a reputation beyond repute609speed6 has a reputation beyond repute609speed6 has a reputation beyond repute609speed6 has a reputation beyond repute609speed6 has a reputation beyond repute
Default *HELP* Sucked in water
Hey guys was driving my car this mornig and sucked in water car stalled and would not start up. So I kept trying and I got it started but would not stay idle had to keep my foot on da gas. When drivig it would putter and try to stall but I rev the shit out of it. At red lights it stalls what should I do put the stock intake back on and thake it to Mazda.
609speed6 is offline   Reply With Quote
 Old 01-18-2011, 05:07 AM   #2
easy's Avatar
Posts: 539   (View Stats)
easy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the world
Groans: 27
maf sensor is wet and your filter is probably soaked. I say take sensor out and let it air dry. Your probably still sucking in water from the filter being soaked, so either change out to stock or let it dry or something. You should just use a short ram intake if your area experiences floods and heavy rain, to avoid hydrolock.
08 MS3
() Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, Autotech CDFP internals, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, NGK iridiums IX
() Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms
() Centric Slotted Rotors/ Posi-Quiet pad
() Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90
easy is offline   Reply With Quote
The Following User Says Thank You to easy For This Useful Post:
IshiKage (01-25-2011)
 Old 01-18-2011, 05:15 AM   #3
609speed6's Avatar
Ok thanks
 Old 01-18-2011, 05:41 AM   #4
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
SRI ftw.
Our cars see no benefit from a CAI.
Beanfab / Tuned by Nishan
The Following 11 Users Say Thank You to doubleflusher For This Useful Post:
Amazon (01-18-2011), clowncar (01-18-2011), ClutchEngaged (01-18-2011), Dash08 (01-18-2011), fishin53 (01-19-2011), gtarman77787 (01-18-2011), lyonsroar (01-18-2011), maxed_out_saloon (01-18-2011), Post pwned (01-18-2011), rigor (01-21-2011), _Toxic_ (01-18-2011)
 Old 01-18-2011, 07:17 AM   #5
609speed6's Avatar
Yeah now I know WTF I keep saying over and over in my head should of got a shortram I had this happen to my civic Si but I could not get the Si restarted had to tow it home and I change the oil and it was good. Now I put the stock intake back on and about to change the oil. CEL is off I let the car run for a long time to dry it out. Do you guys think the car will be ok. It runs it is not stalling like it was before and sounds ok.
 Old 01-18-2011, 07:53 AM   #6
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
The main reason you were sucking in water is because of you wheel!!! When it spins its throwing the water through those little slits in your fender well cover!!! If you cover those holes up your cai should do fine. If it does still wet from other sources it will not make that much a difference to cause your car to do this.. Your choice or go sri....
track weight 3220
street weight 3370
 Old 01-18-2011, 08:05 AM   #7
DSIT995's Avatar
Posts: 1,768   (View Stats)
When I ran a CAI, the 1st thing I did was cover up the slits in the wheel well to stop the water splashing in like Qtr said......
99 Miata NB - Stock for now
 Old 01-18-2011, 08:28 AM   #8
609speed6's Avatar
Yeah I took of the CAI I put back to the stock one
 Old 01-18-2011, 08:31 AM   #9
N118GT's Avatar
Posts: 347   (View Stats)
N118GT is the leader of the worldN118GT is the leader of the worldN118GT is the leader of the worldN118GT is the leader of the worldN118GT is the leader of the worldN118GT is the leader of the worldN118GT is the leader of the worldN118GT is the leader of the worldN118GT is the leader of the worldN118GT is the leader of the worldN118GT is the leader of the world
Groans: 56
Groaned at 25 Times in 13 Posts
Thats interesting, I had the MS intake on mine with the splash guard, and I drove through some heavy ass rain/bigass puddles with no problems. (Florida summer thunderstorms...fun) Did you drive into a lake?
2008 Evolution X
2008 CBR1000RR
N118GT is offline   Reply With Quote
The Following 2 Users Say Thank You to N118GT For This Useful Post:
predapio (01-24-2011), the_caruch (01-18-2011)
 Old 01-18-2011, 08:32 AM   #10
amoosenamedhank's Avatar
Posts: 1,368   (View Stats)
amoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the worldamoosenamedhank is the leader of the world
Groans: 53
Groaned at 31 Times in 22 Posts
I guess this might just be me... but if I suspected that I had sucked up water through my intake, I would probably stop trying to start the car. Or at a minimum, not try to rev the piss out of it to keep it running.
You know.... Moose stuff
amoosenamedhank is offline   Reply With Quote
The Following User Says Thank You to amoosenamedhank For This Useful Post:
Eyedea23 (01-24-2011)
 Old 01-18-2011, 08:48 AM   #11
609speed6's Avatar
Well I was thinking it would be ok because the turbo is hot as well as the motor so by the time it reaches either the water would have evaporated
 Old 01-18-2011, 08:49 AM   #12
SRTie4k's Avatar
Posts: 1,715   (View Stats)
SRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the world
Groaned at 68 Times in 44 Posts
Might want to check your plugs too and see if they're wet. If they are, you might want to compression check your motor.
08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's
253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune
97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup
89 Kawasaki 650SX Stand-Up Jetski
SRTie4k is offline   Reply With Quote
 Old 01-18-2011, 08:49 AM   #13
609speed6's Avatar
All I can say it is running the cel is off and stock intake is on it idles good and not puttering. So I think it should be good.
 Old 01-18-2011, 08:57 AM   #14
609speed6's Avatar
Yeah my buddy said to do a compression test but it is running good I think I probably took on enough water to freak out the maf but once I dried it and put stock intake on and it run fine think it is ok
 Old 01-18-2011, 11:16 AM   #15
maxed_out_saloon's Avatar
Posts: 689   (View Stats)
maxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the worldmaxed_out_saloon is the leader of the world
if ur going to keep the CAI atleast get a bypass filter for it
maxed_out_saloon is offline   Reply With Quote
 Old 01-18-2011, 11:42 AM   #16
609speed6's Avatar
yeah was thinking that.
 Old 01-18-2011, 01:02 PM   #17
sounds familiar... lol
AGAIN.... LOL just messing!!!
track weight 3220
street weight 3370
Last edited by qtrmile beast; 01-18-2011 at 01:02 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-18-2011, 01:03 PM   #18
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
SRI ftw.
And you make this assumption how?
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following User Says NO Thank You to 86AmishMs3 For This Un-useful Post:
zpele (01-18-2011)
 Old 01-18-2011, 01:03 PM   #19
well if he got water in there it would have dried by now. If they were still wet then his car would be idling poorly because the water would be drowning out the spark...
track weight 3220
street weight 3370
 Old 01-18-2011, 01:16 PM   #20
Groans: 1,443
Once the air enters the turbo, it gets heated up. The difference in air temps, at the filter, is so small that there is no benefit.
The Following User Says Thank You to doubleflusher For This Useful Post:
spoolin00 (01-19-2011)
 Old 01-18-2011, 01:47 PM   #21
zpele's Avatar
Posts: 1,654   (View Stats)
zpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the world
Groans: 354
Groaned at 213 Times in 109 Posts
Hmm I seem to remember a few threads talking about this.......
2012 Shelby GT500 - Roush Axleback ~ JLT Oil Separator ~ JLT 123mm intake ~ Ngauge ~ Lund Tuned ~ smaller pulley ~ xpipe (loud as fuck now)
2007 Mazdaspeed6 (SOLD) - COBB SRI ~ Gutted Stock Midpipe ~ HKS BPV ~ JBR RMM ~ AWR PMM ~ AWR TMM ~ Juggernaught Rear Diff Mount ~ Dreadnaught Rear Diff Mount ~ ACT Stage 2 Clutch ~ ITV22s ~ AP(self fucking tuned in a week fuckers) ~ Autotech Internals ~ eBay Downpipe ~ Poke Sub thingy
zpele is offline   Reply With Quote
The Following User Says NO Thank You to zpele For This Un-useful Post:
86AmishMs3 (01-18-2011)
 Old 01-18-2011, 01:47 PM   #22
super_pablo_'s Avatar
Posts: 1,648   (View Stats)
super_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the world
I havent had both to give argue if it makes a difference or not but... based on the fact that colder air will be away from the engine, and the fact that air doesnt really heat up significantly going through the turbo unless ur really pushing it...I would say there IS a benefit of having a CAI... I live in arizona and, heat is insane, i want all the "cold" air i can take.
if you look at the temperature raise in boosted air temps copared to air intake temps, you only see a big increase in boosted air temps when ur boosting to over 10psi...maybe if ur pushing the car on the track u wont see a difference, but.. on a daily drive, wouldnt u?
super_pablo_ is offline   Reply With Quote
 Old 01-18-2011, 02:11 PM   #23
86AmishMs3's Avatar
Groans: 338
There is a difference though, and if you know your compressor equations, you know that the temperature increase is not linear but exponential. Especially when you turn up the wick on the turbo, you start decreasing in efficiency and that gap becomes wider. Is it a billion degree gap, no, but easily a 10+ degree gap post turbo in most cases, and then some.
I would much rather be sucking in ambient air around the wheel well then suck in more turbulent air that has picked up heat from the engine bay. Plus I live in AZ, what the fuck is water.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
The Following 2 Users Say Thank You to 86AmishMs3 For This Useful Post:
spoolin00 (01-19-2011), super_pablo_ (01-19-2011)
 Old 01-18-2011, 02:25 PM   #24
easy's Avatar
Groans: 27
lol this thread is turning into another SRI vs. CAI ... great
08 MS3
N118GT (01-18-2011)
 Old 01-19-2011, 11:17 AM   #25
609speed6's Avatar
I don't care I'm down in Florida right now looking at a ISF
 Old 01-19-2011, 02:06 PM   #26
easy's Avatar
Groans: 27
????????????? ..... um at my neighbors house looking at a elise?
08 MS3
 Old 01-19-2011, 02:07 PM   #27
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
im just amazed at how low humans sink sometimes.....
 Old 01-19-2011, 02:14 PM   #28
easy's Avatar
Groans: 27
lol i think he hates the car now after he drove it into a lake ... but i think the car hates him more
08 MS3
 Old 01-21-2011, 09:42 PM   #29
609speed6's Avatar
Im keeping my speed
 Old 01-21-2011, 09:55 PM   #30
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
From a $25,000 car to a $65,000+ car. What am I missing?
 Old 01-24-2011, 02:56 PM   #31
Eyedea23's Avatar
Posts: 31   (View Stats)
Eyedea23 is a jewel in the roughEyedea23 is a jewel in the roughEyedea23 is a jewel in the roughEyedea23 is a jewel in the rough
the $40k in heroine he shipped in from cuba...
I hydro locked as hell, and in Vegas of all places. It doesnt rain much here but when it does it floods and worst of all, it could look like a perfectly fine day, then all of a sudden in 10 min it poors. Happened to me, came to an interesection that was completely flooded and couldnt go any other way. Tried to baby my way through it, but sucked a little water up. Car wouldn't start, but towed it home and gave it about 8 hours to dry out before I even attempted to turn it on. It turned on, held idle fine, and blew a little white smoke. Did compressions tests and everything turned out fine... I was lucky. Now I have an SRI so I dont have to worry Problem solved
2006 Black Mica Mazdaspeed 6 Sport
Mods: 2.5" Magnaflow Catback Exhaust, EBC Redstuff Brakes, Forged bpv, CP-E Triple Gauge Pod, Prosport Boost Gauge, AEM Wideband A/F ratio, Prosport Premium Exhaust Temp, ETS 3.25 TMIC, PG Turbo Inlet Pipe, NGK Step Colder Plugs, Sharkfin Antenna, Eyelids, SLS Test Pipe, RPM Street Springs, blacked out tails and badges, Cobb AP, Cobb SF
Eyedea23 is offline   Reply With Quote
 Old 01-25-2011, 02:08 PM   #32
brandonms3's Avatar
Posts: 110   (View Stats)
brandonms3 is just really nicebrandonms3 is just really nicebrandonms3 is just really nicebrandonms3 is just really nicebrandonms3 is just really nice
idle air control valve. if nothing else works
brandonms3 is offline   Reply With Quote
Who have you sucked into a corner today? Alpha Wolf CX-7 > General Lounge + New Member Welcome 20 11-26-2013 03:26 PM
COMPARISON: Labonte Stage 2 Water/Meth Kit vs. AEM Water/Meth Kit The Great NY Mazdaspeed Forums User Reviews 2 01-19-2013 08:48 AM
Ummm....this sucked kgb MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 7 02-22-2010 09:25 AM
Dyno day Sucked....or did it? Laloosh MazdaSpeed 3/6 - Turbo Induction 75 07-22-2008 06:28 AM
Page generated in 0.48548 seconds with 35 queries
