Mazdaspeed Forums
-   Mazdaspeed3/6 General Discussion (http://www.mazdaspeedforum.org/forum/forum/f505/)
-   -   Help identifying mods and exhaust system (http://www.mazdaspeedforum.org/forum/forum/f505/help-identifying-mods-exhaust-system-222030/)
LoveToCamp 09-02-2019 09:56 AM
Just bought a 2013 gen 2 speed 3. I need help identifying whether it has anything done to the exhaust. I'm not sure because I never got this far on my old one other than simple bolt on mods.
Also need some help identifying mods. I haven't had a speed in a bit over 2 years but I think I got most of them down. Previous owner was a big fan of cobb, it seems.
All the mods I've identified are as follows. Did I miss anything else? Pics below in link, [IMG] tags aren't working with imgur.
1. HPFP Internals <-- I'm asumming it has this, pretty sure it would have blown up by now if it didn't.
2. Cobb SRI+ Intake
3. Cobb FMIC
4. CS RMM
5. GFB BOV
6. Cobb DP (didn't take a pic behind heat shield, but I clearly saw the big COBB letters)
https://imgur.com/a/2GpKkGJ
JSmith 09-02-2019 12:12 PM
CS shift plate as well from the pictures.
Check for a rear motor mount and rear sway bar too.
lazza151 09-02-2019 03:40 PM
Regarding the HPFP I would still advise you to check.. or take your fuel pressure readings with a AP.
Really you need to confirm that your fuel pressure gets into the 17 or 1800's and does not drop below 1600 at WOT
Bertospeed3 09-03-2019 11:20 AM
i would recommend physically pulling hpfp and look at them to confirm
Vansquish 09-03-2019 06:07 PM
There is no way to confirm whether you have upgraded HPFP internals except physically removing and examining the pump internals.
You should definitely do this, as you are at risk of blowing your motor without them.
Page generated in 0.17119 seconds with 11 queries
