![]() Join Date: Jun 2019
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Hi guys, Since I bought my car I've noticed that when I left off the throttle in 1-3 (mainly 1st and 2nd) the car decelerates kind of jerky. I understand it's going to decelerate more when letting off gas than say an auto, but it's very jerky. I recently cleaned my CAI filter and after that the jerkiness stopped for a little bit and then started again. I also noticed after doing so most of the pop back from the exhaust had stopped, but again that is back as well. My car is 2008 with 80k and a Cobb CAI and a Freddy CBE. There's no AP, but I'm curious if the previous owner had one and was running a time. Any ideas? I've seen people complain of jerkiness when letting off and other recommend a RMM (which I plan to do) but cleaning the CAI has nothing to do with that and it helped. Any help is appreciated!! I should have titled it jerky deceleration not heavy...sorry Last edited by StopaOcean; 12-23-2019 at 03:27 PM. Reason: MSF Database - Automerged Doublepost |
![]() Join Date: Jun 2009
| Neutral : -1 score @StopaOcean; How much experience do you have with manual transmission cars? Is this your first? How long have you been driving it?
| The Following User Says Thank You to MSMS3 For This Useful Post: | danb (12-25-2019) |
(Thread Starter) | Not Ranked : 0 score @msms3 this is my first manual car, however, I've driven manual probably around 20 times before on friends cars. I know that isn't a whole lot though. I understand there is going to be heavy deceleration, I worded that kind of bad. My issue is just how jerky it is. I just feel like it's odd that as soon as I cleaned the intake the jerkiness disappeared for a bit. Maybe this is just how these cars are and I'm not that experienced. That's why I wanted to hear from others. |
| The Following User Says Thank You to StopaOcean For This Useful Post: | MSMS3 (12-28-2019) |
Given your explanation, I’m inclined to agree with the suggestion that you have a failed rear motor mount. It’s a relatively inexpensive part and easy to replace. There are how-to instructions on that here. If the car runs just fine, otherwise, your CAI filter cleaning has nothing to do with it. Just coincidence.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 550
| Not Ranked : 0 score Check your rear motor mount. If it's bad, you can actually rock the engine fore and aft by just grabbing the oil pan.
__________________ Stockish |
| Display Modes | |
| Excessive engine breaking/jerking when letting off throttle. | shawnmos | Mazdaspeed3/6 General Discussion | 12 | 09-12-2019 08:42 AM |
| HELP! P1680 code sputtering under heavy throttle | alphamfc1 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 17 | 01-31-2019 03:02 PM |
| High voltage now struggling under heavy throttle | njdurkin | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 8 | 11-24-2018 11:39 AM |
| Heavy Stumble Only After Prolonged Deceleration | Fulkrum | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 15 | 06-26-2018 06:19 AM |
| KR when letting off throttle | radioflyer | MazdaSpeed 3/6 - ECU Computer Tuning | 5 | 03-06-2012 10:39 AM |
