(Thread Starter) | Not Ranked : 0 score Here is a diagram of the evap system on the fuel tank side: I was thinking about yanking #3 (charcoal canister) and #4 (evap system leak detection pump) and leaving the air filter like this: On the engine side, I would remove the purge solenoid valve and the line that goes to the intake manifold and plug the hole. Hopefully I can disable whatever codes pop out with the AP. Doable?
| The Following User Says Thank You to Code Monkey For This Useful Post: | derek13p (08-17-2014) |
![]() Join Date: Apr 2008 Location: Lutz, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 90
| Not Ranked : 0 score Have done it on past cars. Pulled a good 5-7 lbs off my 240sx years ago ripping out the various sensors and giant charcoal canister. Make sure you check the level of the open hose so that it has no ability to leak out any fuel, I had to tuck one up in a hole in the frame, and that worked well. It never really smelled like gas either and it was just open ended - still is actually. Definitely will need the AP because I can only imagine the slew of codes you'll get. I got 4-5 and that was from 1997 levels of OBD2 technology. Edit - ps you loaded the fuel tank diagram twice. Would like to see the engine side diagram for giggles.
__________________ Dan - '08 MS3, some kinda silver |
| The Following User Says Thank You to ispypsi For This Useful Post: | Code Monkey (07-21-2014) |
(Thread Starter) | Not Ranked : 0 score I posted two pictures to clearly show the before and after. On the engine side, there is nothing special going on, just remove #1 and #2 , and cap the IM with something. I think a vacuum cap with a ziptie should do, this is what I have on the TB.
| The Following User Says Thank You to Code Monkey For This Useful Post: | ispypsi (08-13-2014) |
![]() Join Date: Jun 2012 Location: Hickory NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 324
Groans: 106
| Not Ranked : 0 score only issue I see is passing state inspections from a visual stand point if the tech is actually paying attention. Also not sure in your state how many not readys montitors you are allowed to have either. In NC we are only allowed one not ready so gotta pick your poison. My next concern is you will still need a form of venting for the fuel tank to allow pressure out of the tank so that it will not possible go boom boom or something else.
__________________ go fast- atp gt2871r,3bar map sensor,3port ebcs,freektune 4" wp intake,,jbr trilogy mount, turbosmart bov,cpe tmic,cpe cbe, UR catless DP, UR catless TP, autotech internals cobb ap v2, aem meth controller and pump, custom meth tank,snow solenoid and aquamist nozzle suspension-c/s springs,c/s midbrace,jbr rsb, 235/40/18 nitto nt55 |
| The Following User Says Thank You to motherfnmonsta For This Useful Post: | Code Monkey (07-23-2014) |
(Thread Starter) | Not Ranked : 0 score It is a racecar so 0 fucks given about engine codes, etc. There are no visual or OBDII inspections where I live, and in a year or two I will most likely take the car off the streets anyway. The tank would still be vented via the stock air filter where I drew the red line.
| Approved MSF Vendor ![]() Join Date: Mar 2014
Rep Power: 2489 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,022
| Not Ranked : 0 score Definitely doable as long as the tank still has some sort of vent. Which it will. So you will be good. And yes we can delete every code associated with te evap system
__________________ Custom Tuning for Mazdaspeed, Ford, and Subaru ![]() Website- http://www.freektune.com/ PTE 6062 633HP/523TQ First gen2 in 10's- 10.93@137 Atco NJ 11/14/15 ![]() Quickest/Fastest Mazdaspeed First Gen 1 in the 9's 9.94@149.5 4/22/2017 New England Dragway |
| The Following User Says Thank You to Justin@Freektune For This Useful Post: | Code Monkey (07-24-2014) |
(Thread Starter) | Neutral : +1 score Ok, it is done. ![]() The proposed routing above is not possible without dropping the tank so I did it this way: The 1/2" (?) part is on the right side next to the diff and behind the axle and is a bitch to get to. There was no space to reach and clamp that green pain in the ass quick release connector so I just obliterated it (bottom of picture below). The hardline on that side is, I think, 1/2" -- I only had a 5/8" hose and a 5/8" to 3/4" heater hose adapter so I used them (top of picture below). The hardline you will connect to has no bead on the very edge, only like 3/4" down (for that green connector to hook) -- so I slid the 5/8" hose as far as I could so it went beyond the bead and put a constant pressure clamp hopefully right on the bead. The rest was simple, I ran a 3/4" heater hose from the hose adapter all the way to the air filter, clamps everywhere. Here is all the shit I pulled out, although the two brackets under the charcoal canister and the plastic shields went back in. I put electrical tape on the electrical connector and the thin evap line that runs all the way into the engine bay. I kept the brackets for now as I thought I could have a water-meth pump installed under the spare tire space, but looking at how dusty shit gets there I will be ripping the spare tire "inverted cup" piece out (could not remove it today, shit is spot welded) and we will weld a flat piece of metal there -- I am taking here about the stuff inside the trunk. On the engine bay side, I removed the purge solenoid valve and hose and capped the line with vacuum caps. This is how I have it on the IM now (with the loose end cut out), I have no idea if the cap will pop off at +20 psi of boost, the ones I have on the throttle body never gave me problems, I guess I will have to try it to see if it works. ![]() Last but not least, I got a P0443 code which I promptly disabled in the AP. For the record, the charcoal canister, evap system leak detection pump, and all the hoses I pulled on both the engine and rear side weigh 7 lbs.
| The Following 4 Users Say Thank You to Code Monkey For This Useful Post: |
| Not Ranked : 0 score Rafal, assuming you mean the section on the throttle body i have circled here, No pressure actually goes through that, its just a water jacket to heat up the air to aid cold start. However, in messing around with OCC set ups, we have capped off the main 5/8" bung on the front side of the manifold with a Vacuum cap and zip tie and not had any issues thus far. I imagine you will be fine as long as you got that zip tie snug on there.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. |
| The Following User Says Thank You to Voltwings For This Useful Post: | Code Monkey (08-11-2014) |
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned | |
| The Following User Says Thank You to Code Monkey For This Useful Post: | Voltwings (08-11-2014) |
![]() Join Date: Jun 2011 Location: Laurel, Maryland
Rep Power: 3780 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,647
Groans: 493
| Not Ranked : 0 score So @Code Monkey; I dont know if this is your most recent weight reduction project, but without the approximate weight of your cage, what would be your rough guesstimate of the current weight of the vehicle, as well as total weight lost thus far?
__________________ //KILLAH BUILT, SPEED PERF6RMANC3, TUNED BY THE SUPERSKATER// 700HP CLUB Former World Record Mazdaspeed 60' 1.603 11.479@124mph 10second car with an 11second driver #DIX -Builds 700hp MS6, buys miata, sells said MS6! |
Code: . di 3252-7-161 3084 Total weight lost so far would be then Code: . di 3589-3084 505
| The Following User Says Thank You to Code Monkey For This Useful Post: | Downmented (08-12-2014) |
Groans: 493
| Not Ranked : 0 score Where would you say the largest loss of weight came from?
| Not Ranked : 0 score Have you looked into lighter crash bars?
![]() Join Date: Jun 2012 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24,365
Groans: 171
| Not Ranked : 0 score Very nice job! Not just the weight reduction, but one step closer towards simplifying the car!
__________________ -Fearless vampire killers, banned in DC, how low can a punk get? -Delray/Grieco Mazda or Direct Auto Body, ask me why you should NOT take your car to either. ![]() -It is more fun to drive a slow car fast, than it is to drive a fast car slow |
| The Following User Says Thank You to Mauro_Penguin For This Useful Post: | Code Monkey (08-12-2014) |
![]() ![]() Join Date: Dec 2011 Location: San Marcos, TX
Rep Power: 691 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,138
Groans: 38
| Not Ranked : 0 score This inspired an idea for my build today, thank you!
__________________ 06 MS6 & 06 MS6 [SIGPIC][/SIGPIC] The beauty is the beast Daily driven |
| The Following User Says Thank You to derek13p For This Useful Post: | Code Monkey (08-17-2014) |
(Thread Starter) | Not Ranked : 0 score I got the car re-fueled first time today since I pulled the evap system, the tank is still vented so no problems with pumping gas in.
| The Following User Says Thank You to Code Monkey For This Useful Post: | Mauro_Penguin (08-18-2014) |
![]() Join Date: Mar 2008 Location: W. Suffield, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 674
| Not Ranked : 0 score So im sure you get the EVAP not ready from this right? No CEL but never comes ready.
__________________ MS6 - BNRs3 - Cobb AP - JBR Tru-3.0 - Spearco FMIC - MAC EBCS - Synapse BOV - DNP - CPE DP->MF - SU RRM - TTFMM - TT + CPE Diff Mounts - Mrlilguy HPFP - Projector HID fogs - TSX projector retrofit - LI jammers - Advan RZs w/ 245 PSSs - Koni - WL RSB |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score You will get a CEL, I just turned it off with the AP. And here's the latest picture of the IM, I had the shop remove the whole evap fitting, tap, and plug the hole.
| The Following User Says Thank You to Code Monkey For This Useful Post: | Vansquish (01-22-2016) |
![]() | | #20 | ![]() |
![]() Join Date: Mar 2019
Rep Power: 0 ![]() Thanks: 0
![]() | | #21 | ![]() |
![]() Join Date: Mar 2019 Location: South Mississippi
Rep Power: 0 ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score Pretty sure an evap issue will not cause a lack of engine power at all. Like it has nothing to do with it. Not sure, I am having evap problems on my 08 speed 3 and the canister and pump are behind the rear subframe. And I ain't messing with that anytime soon. |
![]() | | #22 | ![]() |
| How to: AC System Delete and Alternator Relocation | ABQ Speed6 | MazdaSpeed 6 - How-To's | 68 | 03-13-2018 01:24 PM |
| EVAP not ready and P0455 EVAP CEL issue | aviator79 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 35 | 03-04-2016 07:12 AM |
| Failed emiisions due to EVAP system not ready | aviator79 | Mazdaspeed3/6 General Discussion | 59 | 12-12-2014 11:46 AM |
| Evap system not complete? | ms6ms6 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 4 | 02-20-2014 04:34 PM |
| evap system delete | mrkdspd | MazdaSpeed 6 - Engine, Transmission & Driveline | 1 | 02-17-2011 10:22 PM |
