![]() Join Date: May 2009 Location: Clw/ NPR Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,516
Groans: 89
(Thread Starter) | Not Ranked : 0 score I know mazda uses some funky coolant.. can you mix it with other brands ? or does ALL mazda the coolant need to be flushed out ? before adding normal stuff... 116k miles on my speed on stock coolant. any option other than the mazda coolant . I know ford has a coolant that basically the same as mazdas......
__________________ [SIGPIC][/SIGPIC] 2013 EVO X GSR Wicked White w/Areo H&R springs/H&R 15mm spacers MAP modified 3" Magna Flow cat back MAP catless testpipe MAP UICP Grimmspeed 3 port Cosworth filter SSP relay kit TWM Desert Eagle shift knob AEM wideband gauge Prosport boost gauge EvoX piller pod 30%Tint Slowpoke Tuned 339hp/336tq **** SOLD ***** 2006 speed6 " A woman's asshole is like a 9-volt battery..U know its wrong, but sooner or later ur gonna put ur tongue on it !! " Last edited by jracer; 10-25-2012 at 10:00 AM. |
![]() Join Date: Mar 2011 Location: Gillette, Wy
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 782
Groans: 64
Groaned at 18 Times in 6 Posts
| Not Ranked : 0 score We use fl 22, Google its compatibility, I'm on my phone or I'd help more.
__________________ COBB AP, CPE STAGE 2 RMM, CS SRI/TIP, AT HPFP INTERNALS, CNT CATTED DP, CP-E TRITON, JBR RSB, SWIFT SPRINGS, CS CAMBER ARMS |
![]() Join Date: Mar 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 895
| Not Ranked : 0 score Mazda FL-22 Coolant Information - Mazda3Forums.com tl/dr go to http://ricartmazdaparts.com/ put in 0000-77-508E-20 in the parts search box and select mazda and there you go |
![]() Join Date: Nov 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 849
Groans: 82
| Not Ranked : 0 score Unicorn jizz with a dash of leprechaun blood (for color of course). Just make sure you use the right ratio on anything you use.
__________________ 2010 Mazdaspeed3- Installed Mods:- GT 3071 (Ported,polished, and coated by Grimmspeed) Polished and coated throttle body (Grimmspeed)TWM Performance Full Replacement Short Shifter Kit, Corksport FMIC (Upgraded size and coated by Calico Coatings), HTP 4" SRI, Forge V2 BPV, Corksport coolant hoses, NGK Iridum, COBB AP, Full Race DP (ceramic coated), Corksport hangers,JBR EGR block off, Autotech HPFP internals. Glowshift triple gauge pod, Aeroforce Interceptor dual gauges, STRI Imperial boost gauge.Stratified EBCS.RSB and Rear Camber Arms ( JBR ). Tein EDFC kit - Tein Super Street Coilovers . Enkei Racing RPF1 .GTSPEC bracing (front to rear)Corksport FSB..StopTech SS Brake Lines-SportStop Cross Drilled and Slotted Rotors-StopTech Street Performance Brake Pads.. Stratified Boost dial and Guardian Angel. JMF Intake manifold. Full Race Exhaust Manifold (ceramic coated). Damond Motorsports CC. SSP CC. PERM PCV Plate. 3bar MAP. , CP-E Triton full exhaust(Tuning provided by Stratified Tuning) |
| The Following User Says Thank You to deadlandxtreme For This Useful Post: | Raider (10-25-2012) |
| v8 convert ![]() Join Date: Sep 2009 Location: (actually in) Tampa, FL
Rep Power: 1203 ![]() Thanks: 2,634
Groans: 220
| Not Ranked : 0 score John, if you need FL-22, i have like 3 jugs of it. you only need about 1 1/2 to fill your car up. let me know.
__________________ |
![]() Join Date: Oct 2011 Location: Murrieta, CA
Rep Power: 2715 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,575
| Not Ranked : 0 score You haz FL22 badge on coolant tank? If not does it get hot? if so Engine Ice High Performance Coolant - 64oz. 1/2 GAL |
| Not Ranked : 0 score Prestone pre-mix and done. Got it on sale. It's great stuff for the lazy. |
| The Following 3 Users Say Thank You to Raider For This Useful Post: |
Groans: 220
| Not Ranked : 0 score From @TiGraySpeed6 on the mazda6club forums MS6 Fluid Notes & DIY Pictures - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum > Coolant '06 MS6 Manual - 8.5 us qts (2.25 us gallons) Type- Mazda FL22 Mazda OEM - part# 0000-77-508E-20 Ford Specialty Green Coolant - Motorcraft part # VC-10-A or VC-10-A2 - $27.59 gallon 50/50 mix Zerex Asian Vehicle Coolant - NAPA Part # ZRX 675130 - $13.99 gallon of 50/50 mix It seems that only Mazda has coolant called "FL22" - - Well, OK then, just WTF is FL22, and is this going to be a PITA? Some clarity, compliments of the BobIsTheOilGuy forums, and a poster named ponderosaTX:
__________________ | ||
| The Following 2 Users Say Thank You to p057 For This Useful Post: | jracer (10-25-2012), TiGraySpeed6 (10-25-2012) |
yes, just like engine oil, it gets dirty over time and loses its effectiveness | |
Groans: 89
(Thread Starter) | Not Ranked : 0 score so does coolant ever wear out ?? not cool as well as new coolant ? so i guess if i just drain it ALL out and flush it a few times i should be good adding Prestone or some other normal coolant ..
__________________ [SIGPIC][/SIGPIC] 2013 EVO X GSR Wicked White w/Areo H&R springs/H&R 15mm spacers MAP modified 3" Magna Flow cat back MAP catless testpipe MAP UICP Grimmspeed 3 port Cosworth filter SSP relay kit TWM Desert Eagle shift knob AEM wideband gauge Prosport boost gauge EvoX piller pod 30%Tint Slowpoke Tuned 339hp/336tq **** SOLD ***** 2006 speed6 " A woman's asshole is like a 9-volt battery..U know its wrong, but sooner or later ur gonna put ur tongue on it !! " |
Groans: 220
After i put brand new fluid in, i can get it down to 169 on a cold day, mid 170's in the evening with 70ish degree weather on the interstate cruising at 60-75 mph 6th gear. Those few degrees Fahrenheit may not sound like much, but it's proof there is a difference.
| Not Ranked : 0 score Thanks @p057 - that one is here on MSF too - MS6 Fluid Notes & DIY Pictures Coolant does/can wear out- that is the protective additives will lose their effectiveness. The big trick, really, is how the coolant's additive package behaves with an all aluminum engine over an extended period of time. Bad reactions can cause build up and block passages or not properly lubricate bits like the coolant impeller, or even cause the thermostat to seize open or closed. Mazda blocks work well with Zerex Asian Vehicle Coolant. 50/50 mix jugs available at the local parts joint for about $13 a gallon, you need 2 of em. Distilled water for any balance needed. Remember to set heater as hot as it'll go to cycle that core too. Winter at least 50/50. Summer a lot of folks run a jug of 50/50, and the rest distilled water- plain water cools the best.
![]() Join Date: May 2009 Location: Chicago, IL
Rep Power: 10249 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,116
Groans: 136
I didn't read closely through the thread, so I apologize if it has already been said, but FL22 comes premixed and should not be diluted. Tapadatass Also, straight distiller water is very corrosive and will quickly eat away at the Aluminum block. Part of the additives in antifreeze are chemicals to reduce the reactivity of water. Tapadatass
__________________ Last edited by silvapain; 10-25-2012 at 12:00 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following User Says Thank You to silvapain For This Useful Post: | jax ms3gt (08-30-2015) |
![]() Join Date: Feb 2011 Location: Pepsicola, FL
Rep Power: 374 ![]() Thanks: 557
| Not Ranked : 0 score Shouldn't need to do a coolant flush until about 30k miles BTW. Along with that manual flush. Do them both at the same time so its easier to remember for the next service/time.
__________________ JBR SSP . Turbosmart BOV . Autotech Internals . 88d JBR RMM . JBR Spherical Shift knob . H & R springs . JBR rear sway bar |
Groans: 220
| Not Ranked : 0 score Oh shit! I had tea in my mouth when I read that, bout spit it out. Just a wee bit overdue is right.
Groans: 136
Tapadatass
| The Following User Says Thank You to silvapain For This Useful Post: | jracer (10-25-2012) |
| Not Ranked : 0 score Noted. Still overdue regardless.
![]() | | #19 | ![]() |
![]() Join Date: May 2009 Location: Russellville, AR
Rep Power: 1975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,199
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress | |
| The Following 3 Users Say Thank You to btstarcher For This Useful Post: |
![]() | | #20 | ![]() |
![]() Join Date: Nov 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 194
| Not Ranked : 0 score 80% Steam Distilled water(70 cents a gallon @ Walmart), a bottle of water wetter and topped off with 50/50 Runs cooler, cools quiker Just make sure the bottle says no minerals added on it
__________________ Long Block Built by GPwerks and Loose Screw Motor Sports https://www.gp-werks.com/ http://www.crossoverauto.com ^Any Parts, Great Prices^ |
![]() | | #21 | ![]() |
![]() Join Date: Jan 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 975
| Not Ranked : 0 score Yea, Fl-22 is good for about 100k. I flushed it when i bought my car this january just because i didn't know. I'm at 55k miles. the fl-22 is premixed and is not cheap. about $30 a gallon! Based on what TI said, I went with mazda's shit instead of anything else.
__________________ Black Mica 2006 Speed6 GT | 62,000 Miles Cobb AP | Stratified Tune Stage 1 OTS | JBR Stage II Intake | cp-e 3'' Straight Exhaust | JBR RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Redline Fluids | Shell T6 | Forge V1 ms6db.com I'm Registered. Are You? |
![]() | | #22 | ![]() |
| Not Ranked : 0 score Our cars are not good with water wetter. I've read 2 cases here it ended in head gasket issues. |
![]() | | #23 | ![]() |
![]() Join Date: Sep 2009 Location: Rosemead, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 717
Groans: 27
| Not Ranked : 0 score i tired water wetter and it stains the hell out of the overflow tank and when i replaced a hose it had residue left inside ... never going to use it again, 70%distilled/30% coolant is what im using now ...
__________________ 08 MS3 () Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, Autotech CDFP internals, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, NGK iridiums IX () Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms () Centric Slotted Rotors/ Posi-Quiet pad () Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90 |
![]() | | #24 | ![]() |
| Not Ranked : 0 score WW was designed to be used with little to no coolant, which is why it's used at tracks when antifreeze is not allowed. They make a version for mixing with greater than 33% coolant blends labelled for diesel use. look it up on redline's site, and references all over, including the bobistheoilguy site
![]() | | #25 | ![]() |
Groans: 27
| Not Ranked : 0 score i remember seeing on the bottle that it said you can add it to your existing coolant and being that majority of people will have a 50/50 mix, that shouldn't have been an issue.
![]() | | #26 | ![]() |
| Not Ranked : 0 score Below is just one of many similar bits that are out there. Running just Redline Water Wetter and H20 summer - Bob Is The Oil Guy
__________________ Was a Mazdaspeed6 GT #3476 TiGray slicktop Now in a BMW 135i - double the turbos, double the fun! E82.N54 2009 / BSM / A/T / Drop-in / PR CP / Berk Street / MHD / xHP 340hp / 371tq | |
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | easy (10-26-2012) |
![]() | | #27 | ![]() |
Groans: 27
__________________ 08 MS3 () Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, Autotech CDFP internals, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, NGK iridiums IX () Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms () Centric Slotted Rotors/ Posi-Quiet pad () Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90 | |
![]() | | #28 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score For whatever its worth, I asked ZEREZ customer support, and they stated: "...thank you for contacting Zerex Product Support. Valvoline would recommend Valvoline Maxlife Anti-freeze/Coolant, Zerex Asian Vehicle Anti-freeze/Coolant or Zerex Dex-Cool Anti-freeze/Coolant. All are compatible with your 2007 Mazda 3." Then I asked "Are any of your coolants Type FL-22 compatible?" and the answer was: "Thank you for contacting Zerex Product Support. Unfortunately, we do not rate our products against other product, rather we rate them based on the OEM specifications of the vehicle which the previously mentioned meet for your 2007 Mazda 3." "The 2007 Mazda Speed3 & 3 have the same OEM Coolant specification. If FL-22 is the OEM recommendation for this vehicle and Valvoline Maxlife Anti-freeze/Coolant, Zerex Asian Vehicle Anti-freeze/Coolant or Zerex Dex-Cool Anti-freeze/Coolant all meet the OEM specification for your vehicle, then they would have to be compatible." Last edited by Lex2007; 07-31-2015 at 01:25 PM. |
![]() | | #29 | ![]() |
| Not Ranked : 0 score Last edited by Lex2007; 11-04-2019 at 03:21 PM. |
![]() | | #30 | ![]() |
| Neutral : +1 score According to Mazda parts counter (Dan at Ourisman Mazda in MD) any Speed3 produced *after* December 17, 2007 uses FL-22. Before that it *does *not use FL22. AllData contradicts this, and states I need FL-22. AllData isnt incorrect but there is a caveat. As per the TSB 01-033/07 in the above post, you CAN use FL-22 on older Speed3 but dont mix it with orange coolant because it will turn black. Dan sent me this Mazda Fluids Chart updated March 16 2019 is as follows: ![]() Pentonsin PENTOFROST A2 (GREEN) Antifreeze Specially Formulated For Asian Vehicles — CONCENTRATE- HOAT technology but does not have FL-22 according to the rep I spoke to at PENTOSIN but it does cross reference with Mazda 0000-77-501E-02. http://www.pentosin.net/specsheets/Pentofrost_A2.pdf Pentofrost A3 (BLUE) does have FL-22, according to the same guy at Pentosin but is only available in 50/50 mix but does NOT cross reference with Mazda 0000-77-501E-02 (confusing). http://www.pentosin.net/specsheets/Pentofrost_A3.pdf I had little trust in the expertise of the guy at Pentosin...he knew nothing about what FL-22 specs included, only that MAZDA had no cut off date for the need to use FL-22 or not. He was wrong about the cut off date. Pentofrost A1 (RED) is FOR ASIAN vehicles, CONCENTRATED, HOAT technology but isnt listed for MAZDA. http://www.pentosin.net/specsheets/Pentofrost_A1.pdf An inexpensive FL-22 coolant CONCENTRATE is RAVENOL J4D2092 Coolant Antifreeze - HJC Hybrid Japanese Coolant Protect FL22 Concentrate (5 Liter. $27 on Amazon. Last edited by Lex2007; 11-07-2019 at 08:16 AM. |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/engine-coolant-128395/ | ||||
| Mazda FL-22 Coolant Cross-Reference_Wiki Searcher | This thread | Refback | 04-26-2015 08:19 PM | |
| Coolant in engine bay | KillerAngel | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 21 | 05-23-2011 05:03 PM |
| Coolant boiling over exhaust in coolant | bcmurphy87 | MazdaSpeed 6 - Engine, Transmission & Driveline | 12 | 12-15-2010 02:39 PM |
| Video: Prestone melts GM 3.6-liter engine block with blowtorches to show importance of coolant | Haltech | Automotive News | 1 | 06-30-2010 11:13 AM |
| coolant | phillyb | MazdaSpeed 3 - Engine, Transmission & Driveline | 26 | 03-13-2010 06:24 PM |
