![]() | | #81 | ![]() |
![]() Join Date: Jul 2008 Location: Houston
Rep Power: 472 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
| Not Ranked : 0 score Last edited by Speedie6; 04-03-2009 at 09:28 PM. |
![]() | | #82 | ![]() |
(Thread Starter) | Not Ranked : 0 score That has nothing to do with the BS lol, thats from the rod smacking it like it was a 2 cent whore.
![]() | | #83 | ![]() |
![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,174
Groans: 45
| Not Ranked : 0 score i find it pretty funny that thats the one that went though. say what you want, BSD FTW. |
![]() | | #84 | ![]() |
![]() | | #85 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: Gaithersburg, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 335
| Not Ranked : 0 score We should try (for discussion sake) assuming that the BSD is not the culprit...and try to see if we can find anything else that would make cylinder 3 (and its associated parts) to have issues. Is cylinder 3 getting a different distribution of air/fuel, or different exhaust flow then the other cylinders? On the mazda 6, the shape of the manifold, and the stock EGR piping, caused the rear cylinder bank to recieve slightly more air then the front cylinder bank, so anyone who tried to spray a dry shot of nos, would lean out the rear, and knock out the engine. The wideband didn't indicate this, because it was taking the A/F off the average of the cylinders. We almost need someone to setup one of these manifolds with some sort of A/F monitoring FOR EACH CYLINDER to see if the cylinders are matching up. If the BSD is not to blame, then it has to be something else in terms of air or fuel delivery, or maybe exhaust pressure (stock manifold maybe flowing differently around cylinder #3?) |
![]() | | #86 | ![]() |
![]() Join Date: Nov 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,325
| Not Ranked : 0 score Wow...that's amazing how bad it fucked up.
__________________ 2011 Mustang GT |
| crank case breather filter | bombdotcom | MazdaSpeed 3/6 - Turbo Induction | 39 | 10-17-2017 10:28 PM |
| Any Info? | babcockxmx | Mazdaspeed3/6 General Discussion | 13 | 01-11-2009 06:30 PM |
| Notching the 2.3L DISI Crank and Timing Gear. | y2kc0wb0y | MazdaSpeed 3 - Engine, Transmission & Driveline | 35 | 10-19-2008 04:35 PM |
| More info on NBC's plans for Top Gear USA | Haltech | Automotive News | 0 | 05-16-2008 01:40 PM |
| Eton Arc FR250 3-in-1 Crank Radio, Flashlight and Cell Phone Charger - $31.99 + Free Shipping | Haltech | Hot Deals Section | 0 | 03-27-2008 01:10 PM |
