Like Tree16Likes
 Old 12-24-2016, 12:24 PM   #161
MSMS3's Avatar
Posts: 2,832   (View Stats)
Originally Posted by Jaysspeeed3 View Post
so I've been doing so much research on building my mazdaspeed 3 safely. i want some nice gains but i don't want to run into any issues. motor mounts, transmission mount already bought. cobb sri, cobb tip, corksport fuel injector seals. nothing has been mounted on yet. gov has been my next approach including cobb ap. great write up on this thread. been thinking of the his bov. but as you were writing about bov's with maf. bov has to be mounted 12'' from the throttle plate and maf 6'' from bov. my question is are there any additional parts id need to make the install with those specs. or should i get rid of the maf. thanks in advance. I'm still new to this site.
jay
You read this entire thread? You didn't figure out that you do not want to fuck with your MAF location or learn that the boost diverter valve needs to be in recirc mode for your ECU to meter air properly on our cars? You should have figured out that long ago we learned that the best valve for our cars up to at least 20 psi of boost (well beyond the stock turbo) is the excellent OEM BPV already on your car.
Unless it is leaking, stick with stock BPV. And don't waste your money on noise makers that do not give you any more power, but can cause your engine to idle poorly and misfire when shifting. BOVs are for highly modified engines with much larger aftermarket turbos, manifolds, and for special tuning designed from the ground up to work in tandem with BOVs. They do nothing beneficial for the kind of mods you are describing, beyond shout "ricer." You are not driving a Honda.
My Christmas gift to you is for you to save your money for mods that actually make power. A BOV will not.
The Following 3 Users Say Thank You to MSMS3 For This Useful Post:
frothy (12-25-2016), g00s3y (12-24-2016), MD1032 (12-25-2016)
 Old 12-24-2016, 03:54 PM   #162
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
jay
Are your stock seals leaking? If not, there is no need to replace them.
Why do you need to replace your bpv? Because you want your car to make ricer sounds? If you haven't even started modding, there is no need to replace your stock valve unless it is not functioning properly.
And you clearly haven't read much if you are asking about having to move the location of the BPV. Not to mention, you say nothing about getting HPFP internals, which are the first thing that should be on your list of parts to buy.
frothy (12-25-2016), MSMS3 (12-25-2016)
 Old 12-24-2016, 06:29 PM   #163
Jaysspeeed3's Avatar
Posts: 8   (View Stats)
Jaysspeeed3 will become famous soon enoughJaysspeeed3 will become famous soon enough
Firstly you don't need to make me sound like a brainless goon. I'm asking about this. Not saying I'm moving ahead with it. I ask because I don't know. Also I said nothing about getting a bov for the sound. I could care less for the noise. I thought it would help with throttle response and boost lags. Obveously it's not worth it. Secondly I just started doing research oh hpfp. This site isn't the easiest to figure out and I don't have the time to spend hours every day as I have a busy work life. I'm doing the best I can. And I don't plan to install anything till I know exactly what the outcome will be. Be positive and a little less harsh. Thought this was a good communitie.
Jaysspeeed3 is offline   Reply With Quote
 Old 12-24-2016, 09:00 PM   #164
Tifosi42's Avatar
Posts: 179   (View Stats)
Off topic from this thread but, Cobb Accessport, Autotech HPFP internals, RMM to get you started. Make sure you really want to use a stock size intake, if you upgrade the turbo later you'll regret it, ask me how I know. Buy once, save money. Our sponsored forum vendors are fantastic. Also do yourself a favor and get an OTS tune from Freektune or Stratified, money well spent. My present to you, Merry Christmas!
BNR S3 - FREEKTUNED on E33
The Following 2 Users Say Thank You to Tifosi42 For This Useful Post:
 Old 12-25-2016, 04:36 AM   #165
frothy's Avatar
Posts: 1,067   (View Stats)
Our cars come equipped with bypass valves (BPV) -- the air that's vented is re-circulated into the intake system. A blow-off valve (BOV) vents the pressurized air to the atmosphere. The ONLY reason for purchasing a BOV over a BPV is exactly for the noise. If you're going to throw the term BOV around, by default it's assumed you're doing so for the sounds, because there's definitely no performance gain.
As for the seals... You have a stock car. The mods you're throwing at the car have minimal impact on power. So why are you buying CS seals? Save your money unless they're leaking...
Understand that EVERY response that you've received so far was done with good intent.
These folks are trying to prevent you from throwing your hard-earned money at needless mods and directing you towards the ones you DO need (HPFP) to operate safely. No need to get upset.
The Following 2 Users Say Thank You to frothy For This Useful Post:
Gerbilo (12-25-2016), MSMS3 (12-25-2016)
 Old 12-25-2016, 05:17 AM   #166
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Also, there's no requirement that the BPV be mounted 6" from the throttle body. You can mount it anywhere between the turbo outlet and the throttle body and it'll do its job. Just a question of running the air return piping back to the intake from wherever you mount it.
2007 Mazdaspeed3 GT
 Old 12-25-2016, 06:59 AM   #167
TheSixthSpeed's Avatar
Posts: 131   (View Stats)
TheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to behold
The bad idle with a BOV is caused by the adjustable ones. They have a screw that lets you adjust it to the point of leaking. If you set it too far from the leak point, the BOV won't work very well and you'll get compressor surge.
I don't think the car will misfire with a BOV. You will run very rich when the BOV vents which can cause your engine to drown in fuel which in turn shuts it down or you could also get afterfire(not to be confused with backfire), which is a flame or loud pop coming out your exhaust due to all the unburnt fuel.
What the OP... -well not really, -but the guy who is being attacked because BOV, should do is remove and plug the recic hose on the stock BPV, and then see how the car runs. You will have turned the stock BPV into a BOV so to speak. Just make sure the re-circulation hose is plugged well or you will have on hell of a leak that will run you lean and cause your engine to blow!
^ Yes this is stupid, but it's worth testing for those who want to see what the difference is.
TheSixthSpeed is offline   Reply With Quote
 Old 12-25-2016, 08:37 AM   #168
MSMS3's Avatar
This is the classic, proven way to begin. OP would be wise to follow this advice. I'd add a good cold air intake or short ram intake to that list. With a good tune he will pretty much max out the K04 turbo on pump gas. Add a race pipe in place of the second cat, and he's then maxed out for sure with a proper tune.
The high pressure fuel pump internal upgrade is absolutely essential. Without that, increased boost and increased air flow or exhaust side flow = zoom, zoom, boom on our engines, as the stock pump is marginal to begin with.
 Old 03-02-2018, 01:48 PM   #169
KooshaS's Avatar
Posts: 24   (View Stats)
KooshaS is on a distinguished road
Groaned at 6 Times in 3 Posts
Is the cobb bpv worth it? Thinking of that being my next mod
KooshaS is offline   Reply With Quote
The Following User Says NO Thank You to KooshaS For This Un-useful Post:
Db09ms3 (03-02-2018)
 Old 03-02-2018, 02:15 PM   #170
Db09ms3's Avatar
Posts: 536   (View Stats)
Just google that shit son.
silvapain likes this.
 Old 02-19-2019, 08:17 PM   #171
El Diablo's Master's Avatar
Posts: 5   (View Stats)
El Diablo's Master has a little shameless behaviour in the past
Can I install a BOV while running the COBB stage 2 tune? Just checking because I'd rather not damage my engine, turbo, etc.
El Diablo's Master is offline   Reply With Quote
The Following 2 Users Say NO Thank You to El Diablo's Master For This Un-useful Post:
Db09ms3 (02-20-2019), MSMS3 (02-19-2019)
 Old 02-19-2019, 08:23 PM   #172
Shouldn't make a difference as long as it is recirculating. If you have the hose to the Turbo Inlet Pipe disconnected(and blocked off hopefully), then you are Venting To Atmosphere and will run rich every time you let off the gas. I think a tune can help make it not so bad or fit it, not sure, by leaning out the AFR after letting off the gas, not really sure how to tune that in. I recommend you recirculate.
 Old 02-19-2019, 08:23 PM   #173
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
Its moments like these i miss.
*ahem*
Blue spring 2 shims.
Sent from my SM-G950U using Tapatalk
Mods: stock
 Old 02-19-2019, 08:34 PM   #174
MSMS3's Avatar
Almost a year old dead thread revived rather than simply reading it and following advice already given.
Dead thread and multiple prior answers notwithstanding, why in the world would you want an aftermarket BOV at all? Is there anything wrong with your stock valve?
 Old 06-20-2019, 05:53 AM   #175
allservice's Avatar
Posts: 61   (View Stats)
allservice is infamous around these partsallservice is infamous around these partsallservice is infamous around these parts
Groaned at 74 Times in 53 Posts
Fuck off, moron. BEat it
allservice is offline   Reply With Quote
The Following User Says NO Thank You to allservice For This Un-useful Post:
MSMS3 (06-20-2019)
 Old 06-20-2019, 06:51 AM   #176
Police - Grammarhead
Vansquish's Avatar
Chill out, dudebro. You're not as cool as you think you are.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/bov-boost-bypass-valve-thread-99892/
?????? This thread Refback 11-08-2013 09:22 AM
Blow off valve 2010 ms3 This thread Refback 06-13-2012 12:09 AM
Turbosmart dual port bov? - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Pingback 02-14-2012 08:35 AM
Page generated in 0.38849 seconds with 33 queries
