Like Tree3Likes
  • 1 Post By MS3Shadow
  • 1 Post By GT Snail
  • 1 Post By Tuff Gong
 Old 01-11-2017, 09:17 PM   #1
Tuff Gong's Avatar
Posts: 153   (View Stats)
Tuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant futureTuff Gong has a brilliant future
Default Bnr4 vs corksport turbo
Hey guys so I'm torn on Which is the better turbo in terms of ease install and overall quality, only looking to put down about 380whp since I don't pan to build internal and want my engine to last. Since I think both of these can reach that goal easily what would you guys say is the pros and cons of both...... So far my only pro to the corksport is that it will still fit my 2.5in intake, so what do you guys think
Cobb V3, Cobb XLE, Corksport TIP/Sri, Cp-e Tmic, SU Test Pipe, Denso ITV22, Autotech hpfp, Dizzy Tuned, Muffler Delete for race car sounds
Tuff Gong is offline   Reply With Quote
 Old 01-11-2017, 09:28 PM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
My opinion, lower your goals a bit since you're a speed 6. I'm shooting for 350whp.
2nd: you shouldn't pick a turbo based on whether it fits your current intake or not. That's like buying a queen size bed because you already have the sheets, when deep down you really want the king.
My pick is Corksport. But I have read about boost creep issues with high flow intakes and exhausts. Might not have that problem with BNR.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 01-11-2017, 09:57 PM   #3
Tuff Gong's Avatar
Lol it was mainly because I figured that with that turbo the 3 inch intake wouldn't be a must to make that power figure. I see what you saying about the power tho since its a speed 6, Geez I feel like I would crush my spirits if I dynod her at this current set up.
Also heard about ppl having problems with boostcreep when they first came out @CorkSport; has there been any revisions or anything to remedy this.
The Following User Says Thank You to Tuff Gong For This Useful Post:
Jonb82 (02-11-2017)
 Old 01-11-2017, 10:24 PM   #4
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
CS still creeps...more than I expected on a stock DP but still safe.
2018 Audi RS3
2007 Acura TSX 6MT
 Old 01-12-2017, 08:27 AM   #5
dale_gribble's Avatar
Posts: 4,720   (View Stats)
BNR S4. I guess the S4 v2 if it's coming out soon. Listen, you don't want to get a turbo where the turbo still has to get to the edge of its efficiency/high boost to hit your power goals. Get a higher flowing turbo that makes the same airflow at lower boost.
The S4 is still spooled around 3600, so it's comparable to the CS, and it flows more. I have a BNR S3 and I'll be swapping in an S4 soon. S3 is fine, but I don't like boosting to 26-27psi with higher BATs to hit my flow/power goals.
Considering the boost creep issues I read about on CS, it's kind of a no brainer to me.
MINI H1 6.0 - CAR LED TAILS
ChaunceyM (01-12-2017), Thor Hammer (01-16-2017), WAMBUSHHHH! (01-12-2017)
 Old 01-16-2017, 04:10 PM   #6
There have been changes made to the turbos since they have release initially.
-Derrick
 Old 01-16-2017, 06:05 PM   #7
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
BNR S4 V2 FTW!
 Old 01-19-2017, 07:22 PM   #8
mach69's Avatar
Posts: 79   (View Stats)
mach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond repute
-Derrick
Care to elaborate?
2008 Mazdaspeed 3 - True Red
Engine: CPE Nano, CPE TIP, CPE TMIC, CPE HPFP, CS BeCuse Injector Seals, SU Boost Tubes, Forge BPV V1, ITV-22, AQ Motorsports DP, Dashhawk, Spin-on Oil filter conversion, Saikou Michi OCC, Cobb AP Self-tuned, VTCS Delete, EGR Delete, TB Coolant Bypass, DFDD VVT, 3 bar map
Drivetrain: Southbend Clutch Stage 3 DD, JBR Short Shift Plate, SU Shifter Bushings, CPE Stage 2 RMM, CPE TMM
Suspension: Koni Yellows, Eibach Springs, Cobb RSB, MOOG Swaybar Endlinks, Energy Suspension FSB Bushings
mach69 is offline   Reply With Quote
 Old 02-11-2017, 09:35 AM   #9
GT Snail's Avatar
Posts: 23   (View Stats)
GT Snail will become famous soon enough
-Derrick
I like your company. I like your customer service. But damn, I gotta say you guys are incredibly hesitant to share details which would most likely help your sales. It's certainly a point of frustration for me.
To OP,
I recently bought a CS turbo and have nothing but good things to say about it. I will mention, I have a small intake, though, so I can't really speak to the potential boost creep. Only boosting to 21 and tapering off a bit towards redline.
The car is much better than stock and the turbo sound is fairly intoxicating. However, given your power goal, I would suggest S4 if I had to choose between the two. For a more relaxed, fun daily driver, I'd pick the CS every time.
memin likes this.
2006 Speed 6 GT 300ish AWHP Daily
Corksport Turbo, EBCS, 3.5 Map, Cobb SRI/TIP, Forge V1 BPV, Slightly Chilly Densos, CPE TMIC, eBay DP, Autotech HPFP, Freektuned, AWR mounts (ask me about their shit customer service!), 1400 dollar timing chain, questionable stock turbo (....any day now) Yeah, I'm not removing that last part there, bet you can tell what happened.
GT Snail is offline   Reply With Quote
 Old 02-11-2017, 12:46 PM   #10
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
S4 and CS seem to be similarly sized. They're hand in hand both in therms of spool and flow. So I'm not sure how one can recommend one over the other apart from purely subjective preferences.
For 380 crank HP you will need to max out a Cobb SRI which is 5-6% larger than the stock MAF housing size CS SRIs. You'd be better off with a 3"ID actually.
Also, on pump gas you'll need quite a lot of boost for 380 crank HP. So you have to add meth for more and reach your 380 wHP goal. And even at 380 crank HP, the heat will not make your ringlands happy at all. They will last for a while though, depends how you use the car (if you'll use those 380 HP often or just build the car and then cruise around knowing you can have 380 at your disposal).
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
Last edited by mituc; 02-11-2017 at 12:47 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-12-2017, 05:23 PM   #11
Tuff Gong's Avatar
Thanks... Honestly I would just upgrade my intake i was just being cheap... Also I pretty much run a 3 gallon mix
 Old 01-20-2017, 09:37 AM   #12
TheSixthSpeed's Avatar
Posts: 131   (View Stats)
TheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to beholdTheSixthSpeed is a splendid one to behold
I've seen that you can properly tune the S4 to safely run almost 500WHP with methanol/E85 on the stock internals. I would have gotten that but I got a good deal on a used S3 and didn't really want to have to rev up my car more to get into boost + I liked the broader power-band of the S3 even thought the S4 power-band is still broader than the K04.
I know BNR announced a new turbo being developed for the Mazdaspeed platform, is that the S4 V2? I thought it was going to be an S5 that was only for built engines.
TheSixthSpeed is offline   Reply With Quote
 Old 01-20-2017, 09:51 AM   #13
It's an S5.
The S4v2 is just an revision.
Sent from my Pixel XL
TheSixthSpeed likes this.
Tomas (02-27-2017)
 Old 01-20-2017, 10:21 AM   #14
Blk_pu's Avatar
Posts: 190   (View Stats)
Blk_pu has a reputation beyond reputeBlk_pu has a reputation beyond reputeBlk_pu has a reputation beyond reputeBlk_pu has a reputation beyond reputeBlk_pu has a reputation beyond reputeBlk_pu has a reputation beyond reputeBlk_pu has a reputation beyond reputeBlk_pu has a reputation beyond reputeBlk_pu has a reputation beyond reputeBlk_pu has a reputation beyond reputeBlk_pu has a reputation beyond repute
S5 will have an anti surge compressor housing according to BNR. The S4 v2 they removed the taper inside the compressor housing. My question is since they removed the taper on the updated version does that mean they changed the size of the compressor wheel for the v2?
Cobb AP V3 - HTP 3" intake system - UR axleback - Depo catted downpipe - Forge Black BPV - ADD W1 oil catch can - JBR cylindrical shit knob - JBR shit plate - JBR solid shit bushings - JBR 88d RMM - JBR RSB
Blk_pu is offline   Reply With Quote
 Old 01-20-2017, 10:36 AM   #15
The S4v2 will have an 3.5" compressor.
 Old 01-20-2017, 01:25 PM   #16
tek_88's Avatar
Posts: 93   (View Stats)
tek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to behold
Groaned at 13 Times in 2 Posts
You won't reach your power goals with a 2.5" intake, I suggest upgrading to 3" or bigger.
2006 Titanium Grey MS6
Power
BNR S3 // Stock downpipe (hollowed) // Test pipe // Magnaflow CBE // Cp-e Tmic // 3" HTP // JBR Boost Tubes // JBR Thermal Gaskets // 3Bar Map // Corksport BPV // Egr Block-off // VTCS Disabled // AEM 100% meth (1000cc nozzle) // Cobb Ap V3 // Autotechs // GS 3-port // NGK 6510 // CA 91 oct
PurpleDrank Tuned by Will
Hardware
Cp-e Rear Diff Mount // SURE Juggernaut Front Diff Mount // AWR PMM // Cp-e RMM // Corksport TMM Inserts // DSS Axles // ACT 6-puck w/ Streetlite FW
Cosmetics
TRS Retrofit Bi-Xenon Projectors // 18x8.5 +35 XXR 557 // H&R Lowering Springs // S204 Lip
tek_88 is offline   Reply With Quote
 Old 01-21-2017, 02:50 PM   #17
Tuff Gong's Avatar
Yeah I figured I would have to do that. It would be like tryna eat good pussy through a straw
 Old 02-11-2017, 11:26 AM   #18
sharksinspace's Avatar
Posts: 766   (View Stats)
Groans: 126
I plan to swap in the CS that i just snagged yesterday from P2K at some point this summer, to add some moar powar to my DD. It's been suggested that porting the wastegate will likely help with the creep issue...anyone have any thoughts on that? It's something I'm considering having done before installing since we get cooold winters in WI and i know low temps will exacerbate the issue. Running 3" intake and catless RP but will most likely replace that with a Speed Daddy/M2/ebay DP to put in at the same time as the turbo.
Genpoo stuff
 Old 02-12-2017, 11:05 AM   #19
Tuff Gong's Avatar
Lol btw you became my instant nemesis when I saw you snagged that turbo
sharksinspace likes this.
The Following 3 Users Say Thank You to Tuff Gong For This Useful Post:
Fstrnyou (02-12-2017), KiwiFlavor (02-12-2017), sharksinspace (02-12-2017)
 Old 02-11-2017, 11:52 AM   #20
Fstrnyou's Avatar
Between now and when I get some puppy power, I'll have a tubular manifold made with an EWG. Any possibility of boost creep will be gone.
Other rides:
History:
 Old 02-12-2017, 01:35 PM   #21
Groans: 126
Haha, sorry dude! I think I saw his post about a minute after he put it up and I knew that shit wasn't going to stick around for long.
Ol' moosey is the one who's really mad at me for not trying to put him in contact with P2K. Sorry 'bout it, moose; Sharks don't owe you shit in life, boyo.
Genpoo stuff
The Following 2 Users Say Thank You to sharksinspace For This Useful Post:
KiwiFlavor (02-12-2017), Tuff Gong (02-12-2017)
 Old 02-27-2017, 06:09 AM   #22
Tuff Gong's Avatar
Ok guys decided to go with the corksport turbo and 3 inch intake, 3.5bar sensor.... Is 330awhp on 93 and 350awhp on e85 realistic with those mods (other mods in sig)or am I aiming too high on the stock block. What should I really aim for on a stock block if I want it to last a while before I get internals. I really don't beat on the car much in really just an onramp highway puller.
P.s. does anyone know if they have fixed the boost creep
 Old 08-05-2017, 10:31 AM   #23
Analytical's Avatar
Posts: 42   (View Stats)
Analytical will become famous soon enough
Groaned at 6 Times in 2 Posts
Have you bought &/or installed your upgrades yet? If so were our goals met?
Tricks get applause, style gets respect.
Analytical is offline   Reply With Quote
 Old 08-05-2017, 12:33 PM   #24
Fstrnyou's Avatar
My results....with mods in sig.
Note I'm still using the stock TMIC, stock cat-back, and just shy of 18psi on pump 93.
Also note, the attached vDyno log was taken in relatively cold May weather of 54 degrees.
Tuff Gong's CP-e TMIC and muffler delete should help out quite a bit. Add a few more PSI than what I'm running and I think his goals are easily attainable.
Other rides:
History:
The Following 2 Users Say Thank You to Fstrnyou For This Useful Post:
Analytical (03-31-2018), MPS-06 (12-10-2018)
So, about the new Corksport turbo... dale_gribble CorkSport 1859 08-01-2017 01:32 AM
Corksport Turbo EWG Jester2552 CorkSport 60 12-03-2015 06:53 PM
Corksport Turbo Xxblinddzxx Mazdaspeed3/6 General Discussion 9 08-25-2015 08:06 PM
Corksport Turbo Set Up 406Speed6 CorkSport 7 07-15-2015 11:29 AM
Page generated in 0.44662 seconds with 35 queries
