![]() Join Date: Nov 2010 Location: COLORADO SPRINGS, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
Groaned at 33 Times in 13 Posts
(Thread Starter) | Not Ranked : 0 score 2.electronic boost controller 3.grimmspeed boost solenoid i've looked all over the forums, but everywhere i look i am just finding mixed reviews about everything..so pretty much i am asking what would be the best way to control boost now for me...i am running the halloman mbc, but i am ntoa fan of it |
![]() Join Date: Oct 2009 Location: Andersen AFB, Guam
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
Groaned at 32 Times in 11 Posts
| Not Ranked : 0 score make sure you donate!! but this is the best solution just use the Cobb Ap to control your boost. it's got that capability and more!
__________________ RichTuned Ultimate Racing DP V2 flange\35W 6000k DDM HID's\HKS SSQV3 VTA\GTX2867R\Tanabe STB\HTP 3.5" intake\PTP HPFP\UR FMIC\Ultimate Racing turbo-back exhaust\JBR RSB\JBR 80Duro Trilogy mounts\Cobb AP v3\Stage 2\22.5PSI \Sonic Tuning Coilovers\TWM full replacement shifter and SSP\PnP Intake Manifold/CP-e EWG Exhaust Manifold/Tial 44mm EWG 11/10/2012 NATOR DC DYNO day 304Whp/356 FT lbs Tqe Uncorrected 4/13/2013 Mega NATOR Meat Dyno Day 300WHP/ 344ft lbs/wtqe Corrected |
| The Following 2 Users Say Thank You to BlueDmnSpeed For This Useful Post: | manelscout4life (05-29-2011), Raider (06-07-2011) |
(Thread Starter) | Not Ranked : 0 score well when the people i went to put on my bigger turbo for me while i was in the field, they took my boost solenoid off and put the mbc on id donate but usually when i ask something i get stupid replys 95% of the time Last edited by reconbygod12; 05-28-2011 at 09:41 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says NO Thank You to reconbygod12 For This Un-useful Post: | manelscout4life (05-29-2011) |
Groans: 60
| Not Ranked : 0 score A good tuner could make any one of those three control your boost just fine.. If you've got an AP get the grimmspeed or a perrin EBCS and let the AP/ECM do the work...
(Thread Starter) | Not Ranked : 0 score with the grimmspeed can i keep my pro tune that was made prior to it? even though i used a mbc with the pro tune that i have now |
![]() Join Date: Nov 2010 Location: California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,454
Groans: 142
| Neutral : -1 score
Why should we, the contributing members of this forum, help out someone who hasn't contributed to this forum? In case you haven't figured it out yet, this forum is supported by its members not vendors or advertisments. Did you think a forum of this magnitude is free to run??? We will give a fuck about you once you become a contributing member of OUR forum! Cheers!
__________________ ~My Mod List: ETS TMIC; CP-E SRI; COBB TIP; CP-E DP; CP-E RMM; CP-E Safe Seals; ITV-22's; GHL SS CBE; TWM STS w/bushings; Autotech HPFP Internals; AP (Stratified by Lex); Matt Damond OCC; CP-E Triple Gauge Pod w/ Prosport Premium Boost, AFR, and Oil Pressure Gauges; JBR Eliminator Shift Knob~ | |
| The Following 4 Users Say Thank You to Whiteboy For This Useful Post: |
| Fuck sushi rolls ![]() Join Date: May 2008 Location: Los Angeles
Rep Power: 12764 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,168
Groans: 356
| Neutral : -1 score i run a 3071 , ap, and hallman pro mbc.... i can make boost do w/e the fuck i want it to do.... but seriously u need to donate jew
__________________ 2007 Ms3 3071r fully bolted , retired and sold after 110k miles of abuse 2014 Black Track Pack premium , NA 4lyfe ...AED dyno tuned on E85 466.6whp / 406.8 TQ SAE |
| The Following User Says Thank You to rodrigo For This Useful Post: | manelscout4life (05-29-2011) |
![]() Join Date: Feb 2010 Location: Houston, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 644
| Not Ranked : 0 score I'm having issues controlling boost and believe I have a damaged OEM boost control solenoid. Does the Grimmspeed EBCS fit the genpu's?
__________________ SOLD on 08/2013 2010 Black Mica MazdaSpeed3 Performance: BNR S3 - Sure Full 3" Aeros - Bosch 3 Bar Map - DDM HID Kit 6k 35w - Hella Super Tones - CorkSport LED Light Kit - Cobb Knob (Red) - VG Sharkfin Antenna - Sure Anchors - Jbarone 88duro Dog Bone RMM - Black CorkSport SRI/TIP (Powder Coated Black) - Ultimate Racing Race Pipe & CBE - KMD Internals - CorkSport Cold Air Box w/ Carbon Fiber Top - Turbosmart SU Blacked Out BPV - Cobb AccessPort Stage 2 (Nataphen Tuned) - JBarone RSB - CP-E TMIC |
(Thread Starter) | Not Ranked : 0 score the genpu has the same port to plug in...if that doesnt fit there is a perrin taht is offered and considered universal |
| The Following User Says Thank You to reconbygod12 For This Useful Post: | 2010Speed3 (06-07-2011) |
The directions for the grimmspeed on on their site, in pdf form, for both 2 and 3 port mode hook-ups. If you decide to use the grimmspeed in 3 port mode, it will need to be tuned for. | |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | 2010Speed3 (06-07-2011) |
![]() Join Date: Dec 2010 Location: Delanco, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 897
| Not Ranked : 0 score Lol sorry? I didn't really mean to, but I'm not sure if you're happy or not. I didn't feel like this thread was going anywhere anyway... haha
Wonderful, thanks for the confirmation.
__________________ SOLD on 08/2013 2010 Black Mica MazdaSpeed3 Performance: BNR S3 - Sure Full 3" Aeros - Bosch 3 Bar Map - DDM HID Kit 6k 35w - Hella Super Tones - CorkSport LED Light Kit - Cobb Knob (Red) - VG Sharkfin Antenna - Sure Anchors - Jbarone 88duro Dog Bone RMM - Black CorkSport SRI/TIP (Powder Coated Black) - Ultimate Racing Race Pipe & CBE - KMD Internals - CorkSport Cold Air Box w/ Carbon Fiber Top - Turbosmart SU Blacked Out BPV - Cobb AccessPort Stage 2 (Nataphen Tuned) - JBarone RSB - CP-E TMIC | |
![]() Join Date: May 2010 Location: Gulfport, MS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,199
Groans: 84
| Not Ranked : 0 score My car didn't like the Grimmspeed EBCS. I switched to a Turbosmart MBC... car performs much better. Just my personal experience. I'd prolly keep the manual, man. Less margin for error imo.
__________________ 2007, Bolted, 3076, Pu powered, Hiroshimian Ford with an e25 !!TUNE OF PHATE!! ![]() "Yeah *smiles*... Yeah, this motherfckr pulls!" - Clint Griest |
![]() Join Date: Feb 2011 Location: Somerset, PA
Rep Power: 145 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 70
Groaned at 3 Times in 1 Post
| Not Ranked : 0 score Turbosmart dual stage MBC FTW!! I really liked mine. The boost is rock solid with no spikes and def holds better/longer. ...and its for sale here: http://www.mazdaspeedforum.org/forum/foru...age-mbc-82769/
__________________ 2006 Mazdaspeed 6 - Velocity Red Mica - #5129 - Totaled 2006 Mazdaspeed 6 GT - Titanium Gray Metallic - #3820 |
![]() Join Date: Dec 2013 Location: Central Florida
Rep Power: 0 ![]() Thanks: 231
Groaned at 5 Times in 2 Posts
Sent from my VS835 using Tapatalk
__________________ Future Gen1 Owner,... Hopefully! lol | |
| The Following 2 Users Say NO Thank You to sarm1084 For This Un-useful Post: | Db09ms3 (09-04-2018), KiwiFlavor (09-04-2018) |
![]() Join Date: Apr 2013 Location: Somersworth, NH
Rep Power: 878 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,570
| Not Ranked : 0 score Way to resurrect a damn 7 year old thread bro. Apparently your forums skills are great.
__________________ 2012 NASA Spaceship Gray MS3 BNR S3 - JBR Tru 3.0" - CP-E TMIC - Corksport catless DP - Corksport catted race pipe - Forge V2 - Autotech internals + AP v3 - Swift springs - Enkei RPF1 17x9 + 45 (5mm JBR spacers in the front) - Freektune 320/346 |
![]() Join Date: Jul 2017
Rep Power: 33 ![]() ![]() Thanks: 9
__________________ 2010 Gen 2 Velocity Red - Freektuned ![]() - AP V3 - HPFP - Cobb RMM - Damond PMM - Turbo Back Custom SS Race Pipe - K&N Drop in Air Filter - Bov - Raiden by Lenso Forge Type Monoblock 18 x 8 ET/ 35 Wheels - Falken Azenis FK510 235/40 Tyres - Webasto Sunroof. |
| BT boost control | zx2man | MazdaSpeed 3/6 - Big Turbo Builds | 16 | 11-16-2010 09:14 PM |
| Possible to control boost with... | demonspeed | MazdaSpeed 3/6 - Turbo Induction | 6 | 02-04-2010 12:09 AM |
| Wastegate control, Boost spikes, PID control | FreeFlyFreak | Cobb ATR Support | 83 | 11-05-2009 12:40 PM |
| sb boost control problem | speed_3 | MazdaSpeed 3/6 - ECU Computer Tuning | 20 | 07-01-2009 04:53 PM |
| AP + Map clamp + Boost control | ccann26 | MazdaSpeed 3/6 - ECU Computer Tuning | 19 | 08-15-2008 08:11 PM |
