 Old 04-05-2016, 08:44 PM   #1
Lex2007's Avatar
Posts: 574   (View Stats)
Default Anti-lock Brakes CAN U2023 Fault received from external node
Every day on my way home from work for the last week, in more or less the same area on the highway the loss of traction light comes on on the dash. It doesn't happen going to work. WEIRD.
I checked the error with Autoenginuity software and it shows Anti-lock Brakes CAN U2023 Fault received from external node .
If I restart the car the dash light is gone.
I checked all 4 wheel speed sensors and they all have clean connections and a clear view to the axle (front) or tone ring (back).
Any tips? 2007 with 107k miles. Only engine mod is CAI.
 Old 04-06-2016, 11:00 AM   #2
ALPINEST4RS's Avatar
Posts: 905   (View Stats)
Groaned at 8 Times in 3 Posts
A U2023 points towards a Keyless control module.
I have no records for a DSC/ABS module
 Old 04-06-2016, 11:28 AM   #3
Lex2007's Avatar
Alpine,
Why would a keyless control module trigger the loss of traction symbol on the dash?
 Old 04-06-2016, 07:31 PM   #4
SyntheticAtmosphere's Avatar
Posts: 193   (View Stats)
SyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond repute
Originally Posted by Lex2007 View Post
Alpine,
CAN BUS (Computer Area Network) is the digital network that car companies use to interconnect systems with less wiring. The ECU receives info from various modules (AWD, ABS, TSC, Keyless/SmartKey etc) to help it make calculations based on conditions.
I am just getting into learning about CAN myself, so I am not much help, but I believe there is no real problem with the TCS system, but you may have a bad or failing connection between CAN connected units. TCS might be getting confused or going into limp mode because of misinformation (possibly from keyless).
Clear as mud?
SyntheticAtmosphere
'06 Speed6 Whitewater Pearl (COBB AP v2, CS s2 SRI/TIP, Autotech HPFP, Cp-e RMM&RDM, Fidanza/LuK, homebrew Testpipe&OCC) next...meth habit
If it feels good, do it...Even if you shouldn't!
SyntheticAtmosphere is offline   Reply With Quote
 Old 04-06-2016, 07:41 PM   #5
"U2023 Fault Received From External Node RCM U2023 is set when a module receives invalid network data from another module with a faulted input."
Suggestion: Reset codes, then hit your TCS button (cancel system) and see if code reappears on your drive.
SyntheticAtmosphere
 Old 04-07-2016, 08:14 AM   #6
Lex2007's Avatar
S-A,
Thanks for your thoughts and info.
I am able to reset the codes with Autoenginuity, in fact the loss of traction light doesn't come on when I restart. But after a 5 - 10 miles its not coming back on. Faster than previously.
Why doesnt the system tell me which module is giving the bad input/signal?
Would the dealer just switch out the PCM or how is this issue addressed?
 Old 04-07-2016, 10:57 AM   #7
I believe because all of the info is piggy backed across the network at the same time, the PCM dosent have the ability to self diagnos
fapatalk
SyntheticAtmosphere
 Old 04-07-2016, 08:48 PM   #8
Lex2007's Avatar
Yo my car is buggin out. Its throwing the CEL light now and I could feel a slight hesitation at highway speed for a maybe 20 seconds.
I pulled the codes and its throwing a bunch codes. Some are old some are new.
I mean what the hell am I supposed to do with this info? Am I supposed to assume the computer itself is malfunctioning?
P0126 coolant temp too low when its reading 190 degrees?
U2023 Fault received from external node (instrument cluster CAN and ABS CAN)
U2064 Warning indicator received by another module
B1261 Sun load sensor short circuit to ground?! wha?
 Old 04-07-2016, 08:57 PM   #9
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
Do you have a remote start or alarm installed?
The interface modules tap into the medium speed and high speed can networks and can fuck shit up if its bad/miswired.
Check your wires going into the ecu by the intake. Unplug and re-seat the connectors for the ecu. Disconnect the battery then wait a while for the system to drain power out and reconnect.
MECP
2012 BM
Rfinkle tune in progress
 Old 04-08-2016, 03:59 AM   #10
Start by checking ground connections and battery connections.
fapatalk
I would also chase that sun load sensor short...that could be throwing things off...short circuit bad!
fapatalk
SyntheticAtmosphere
Last edited by SyntheticAtmosphere; 04-08-2016 at 03:59 AM. Reason: MSF Database - Automerged Doublepost
 Old 04-08-2016, 08:49 AM   #11
Lex2007's Avatar
Nope, no alarm or remote start. My radar detector (worthless noisemaker) is wired in to overhead light 12v and a Parrot Bluetooth connected to stereo but not spliced in. Those have been there forever.
I have had problems with wires going into the plug at the primary computer (PCM, or ECU) and have had to swap out a few. Protect your PCM the Wiring Harness from Corrosion
That sun load sensor short sounds like bullshit because the CEL was coming on before and I wasn't getting that code.
I'm gonna disconnect battery, check primary ground (which is right on top of body where the hood meets the body yes?). I do keep an eye on that connector and Deoxit intermittently as a result of my past issues.
 Old 04-12-2016, 12:11 PM   #12
Lex2007's Avatar
I do believe I figured out the cause of these random error codes. I of course suspected the harness near the computer because I've had issues with corrosion of terminals and plugs.
This time I found the band clamp for the cold air intake had rubbed against 4 of the harness wires enough to expose the wires and was shorting them causing random error codes.
I know I'm not the first person this has happened to.
You can see the worn insulation and exposed wires here:
In case you dont know where Im referring to, here is a different view:
Check your harnesses guys.
 Old 02-06-2018, 10:28 AM   #13
Pdobbin's Avatar
Posts: 1   (View Stats)
Pdobbin is an unknown quantity at this point
Default Mazda cx7 2007
What does the code mean U2023
Pdobbin is offline   Reply With Quote
Anti-Lift, so why not anti-squat? EvoFire MazdaSpeed 3/6 - Suspension & Brakes 12 08-22-2017 09:56 PM
Toyota class-action anti-lock brake lawsuit tossed out Haltech Automotive News 0 01-11-2013 04:10 PM
just received my AP, need help. titusdrake MazdaSpeed 3/6 - ECU Computer Tuning 8 11-11-2011 08:04 PM
2009 MS3 brakes vs. 2010 MS3 brakes Driver72 2010 MS3 - Suspension & Brakes 11 11-21-2009 10:34 AM
Page generated in 0.35316 seconds with 24 queries
