 Old 11-27-2017, 12:31 AM   #1
Marcus's Avatar
Posts: 777   (View Stats)
Marcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the world
Default Another Black Friday whatddya get thread.
Since my suspension is needing one shock to be replaced, I just ordered H&R coilovers (Thanks Edge!) very hesitantly as I already have their springs and I'm not super impressed with the fronts (freaking ridiculous front end rebound at low speed and speed bumps.. could be the Bilstein b6's mated to lowering springs... apparent no no). But I figured I could use the adjustable ride height to keep my winter tires which should've been 40s instead of 45s. It was between the b8's and eibachs or H&R.
Feel free to rag on me but I picked up some replacement urethane for the SURE dread and juggernaught. No indication I need to replace them yet after 170,000km but while she's on the lift, might as well.
I'm deciding on end links.
Also, can anyone confirm if this upper rear control arm from Moog would also be known as an adjustable rear camber arm? Looks like identical to the SPC just with slightly better structural casting. Because if it is, I'll go with these over the SPC's in a heart beat.
moog-rk100171 - Rear Upper Control Arm made by MOOG
So anyone else pick up some gifts for their Mazda?
2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km
Leakdown results was 50% or more across all four. slow rebuild in progress
Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses.
Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB.
SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate.
Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs.
To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters
Marcus is offline   Reply With Quote
 Old 11-27-2017, 01:09 AM   #2
Marcus's Avatar
Or at least I thought I ordered the H&Rs.
I be having checkout problems... sigh.
 Old 11-27-2017, 02:20 AM   #3
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
I picked up AIDS.
94 M
MS6
IS350
 Old 11-27-2017, 03:16 PM   #4
Marcus's Avatar
I picked up AIDS.
That shit came with my cars years ago.
Car AIDS is the only thing that makes sense with the amount of repairs this dirty bitch throws down.
Black Friday! EdgeAutosport.com EdgeAutosport.com 5 11-19-2018 05:31 PM
Black Friday? LowFlyin Cobb Tuning 0 11-22-2017 07:56 AM
BLACK FRIDAY JP@edgeautosport.com EdgeAutosport.com 42 11-25-2011 07:01 PM
Page generated in 0.25621 seconds with 21 queries
