  • 1 Post By Vegasspeeed
 Old 10-09-2013, 08:21 PM   #1
Vegasspeeed's Avatar
Posts: 274   (View Stats)
Vegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond reputeVegasspeeed has a reputation beyond repute
Groaned at 8 Times in 7 Posts
Default $9 Lip
For all you folks ballin on a budget, decided to give the garage door weather stripping lip a try and I'm fairly impressed. Now I just hope it lasts haha
here's the how to I followed..takes takes some time and attention to detail! How-To: Home Depot (HD) Lip
File Type: jpg 1380105_634554616595610_1588472803_n.jpg (92.1 KB, 246 views)
sure test pipe, both resonators deleted, RL coilovers, XXR 521's machined silver, muteki gold lug nuts
Vegasspeeed is offline   Reply With Quote
The Following 3 Users Say Thank You to Vegasspeeed For This Useful Post:
Bolted6 (11-16-2013), LatinKraze (10-09-2013), Quigs (10-10-2013)
 Old 10-09-2013, 08:33 PM   #2
12blkms3's Avatar
Posts: 735   (View Stats)
12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world12blkms3 is the leader of the world
Groans: 68
Groaned at 62 Times in 29 Posts
Its actually pretty durable, I had one on my SI for 6months before scraped it off on a curb
[SIGPIC][/SIGPIC]2012 Black Mica
JBR WP intake// JBR RMM 80 duro// JBR Heavy knob// JBR Boost tubes + Recirc Hose// JBR Spacers// ETS Tmic// UR catless Dp// UR catless Tp// Custom 3in Catback// Go Fast Bits BOV 50/50// Autotechs// NGK one step colder// Megan Coilovers
324whp 368tq Vdyno CF 1.01
268whp 300tq AWD Mustang Dyno
3 GAL. E85 mix STRATIFIED
13.10 @ 108.1 (Nt05's) Auto Club Speedway
12blkms3 is offline   Reply With Quote
 Old 10-09-2013, 08:34 PM   #3
Format's Avatar
Posts: 130   (View Stats)
Format is the leader of the worldFormat is the leader of the worldFormat is the leader of the worldFormat is the leader of the worldFormat is the leader of the worldFormat is the leader of the worldFormat is the leader of the worldFormat is the leader of the worldFormat is the leader of the worldFormat is the leader of the worldFormat is the leader of the world
Looks good!
2013 GenPu
- There are no obstacles only opportunities for excellence.
Installed: CS TIP, SRI, Boost Tubes ¤ Cobb AP ¤ Cp-E RMM ¤ Block8Head Dual vent pod ¤ JBR SSP, SSB ¤ AT Internals ¤ GlowShift Boost/OP Gauges ¤ EGR Delete ¤ M2 DP ¤ Synapse DV
In the mail/awaiting install: NGK Plugs ¤ DM OCC ¤ Grimmspeed EBCS ¤ Bosch 3Bar ¤ Bitwise PNP ¤ TR6 FMIC core w/ CXracing pipe
Format is offline   Reply With Quote
 Old 10-09-2013, 09:03 PM   #4
Well I hope that doesn't happen to me haha but I have a feeling if it lasts till next summer the Vegas heat will end up cracking it
Originally Posted by Format View Post
Looks good!
Thank you sir!
Last edited by Vegasspeeed; 10-09-2013 at 09:03 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-10-2013, 01:52 PM   #5
Quigs's Avatar
Posts: 1,152   (View Stats)
I like it, well done! I may have to do that as well.
2009 Mazdaspeed3
2000 Mazda Miata MX-5
NASA TTE build ongoing
 Old 10-10-2013, 02:01 PM   #6
JgamB's Avatar
Posts: 2,566   (View Stats)
I paid $30 for something very similar if not the same from ezlip, and it's held on at 120+ mph just fine so far. I didn't use any fasteners because I didn't want the holes, just the pre-applied adhesive strip.
 Old 10-10-2013, 02:03 PM   #7
Worbit's Avatar
Posts: 2,552   (View Stats)
Worbit is the leader of the worldWorbit is the leader of the worldWorbit is the leader of the worldWorbit is the leader of the worldWorbit is the leader of the worldWorbit is the leader of the worldWorbit is the leader of the worldWorbit is the leader of the worldWorbit is the leader of the worldWorbit is the leader of the worldWorbit is the leader of the world
Groans: 142
Groaned at 58 Times in 37 Posts
Can you post some shots from above?
Zoom-Zoom-Coons on 05/10/16
2011 Mazdaspeed3 Celestial Blue Mica
BUILT BY CORKSPORT
CP-e Catted Downpipe || CP-e HPFP || Corksport Turbo || Corksport 3-bar Map Sensor || Corksport EBCS|| Corksport SRI || Corksport TIP || Corksport CBE || Corksport Boost Cut Killer || Corksport FMIC || Corksport SSP || Corksport MM Inserts || Corksport Blue Shift Knob || Corksport Injector Seals || DM Full EGR Delete Kit || Corksport License Plate Relocation Kit || Snyapse Engineering Synchronic BOV || Cobb V3 Accessport (PD Tune in progress)
Worbit is offline   Reply With Quote
 Old 10-10-2013, 06:24 PM   #8
dastpe's Avatar
Posts: 1,644   (View Stats)
dastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the world
ez lip is the same exact thing. its just a guy that cuts it for the car specific and puts a name on it...
that being said i had garage door weather strip on my car until snow drifts took it off and have one on my other car now. good stuff.
dastpe is offline   Reply With Quote
 Old 10-11-2013, 03:46 PM   #9
all I could get at the moment
MS6 Sanchez likes this.
 Old 10-11-2013, 03:47 PM   #10
ya I didnt want to either but the 3m tape I got wasnt working at all so I just did it
 Old 10-14-2013, 04:32 PM   #11
Quigs's Avatar
Decided to give this a try today after seeing this thread. I think it turned out pretty well.
2009 Mazdaspeed3
The Following 2 Users Say Thank You to Quigs For This Useful Post:
pstpolamalu43 (10-14-2013), Vegasspeeed (10-14-2013)
 Old 10-14-2013, 04:50 PM   #12
not bad! I would have had it stick out a little further but it still looks good man
 Old 10-14-2013, 04:54 PM   #13
Quigs's Avatar
Thanks! I originally had it out a little further, but then I decided that I wanted it to be more downward and a little less outward if you know what I mean. Yours looks nice and aggressive, so instead of copying you directly I tried to make it slightly more subtle.
2009 Mazdaspeed3
 Old 10-17-2013, 11:57 PM   #14
joseph.p05's Avatar
Posts: 121   (View Stats)
joseph.p05 has disabled reputation
i've had mine on my pu for about 3 months now, its just starting to look like hell lol. good job though, looks good for 9$
-ETS tmic -Autotech HPFP internals -SURE sri -SURE tip -Forge V1 bpv -Ultimate Racing downpipe -Corksport racepipe -Ultimate Racing cat-back exhaust -Corksport exhaust hangars -Corksport short shift plate -Corksport race RMM -Corksport OCC -Denso ITV22 spark plugs -10mm spacers-Continental DW 235/40-Eibach Pro-kit springs -Akebono Euro ceramic brake pads
-OEM mazda window visors -Rally Armor mud flaps -20% tint
TUNED BY:
joseph.p05 is offline   Reply With Quote
 Old 10-18-2013, 04:42 AM   #15
3Gee Tee's Avatar
Posts: 1,533   (View Stats)
How about some $9 side skirts and rear bumper lip?
The Following User Says Thank You to 3Gee Tee For This Useful Post:
TheRoyceWay (10-18-2013)
 Old 10-18-2013, 12:14 PM   #16
Nano91's Avatar
Posts: 286   (View Stats)
Nano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the worldNano91 is the leader of the world
I wonder how it would look on a gen pu
Sent from my Galaxy S4
Black Vue Dash Cam- Cobb AP V3 (Stratified tune 4 gal E85 mix) - M2 Downpipe - Swift Springs - HKS SSQV4 - Sure V2 SRI - JBR TIP - ACDelco Rear Camber Arms - West-End Custom Alignment - White Line Bump Steer - KMD Internals - Hankook Evo V12 245-40-17 -
Nano91 is offline   Reply With Quote
 Old 10-18-2013, 08:18 PM   #17
Format's Avatar
After reading this I went out that night or the next night and bought everything to do it on my silver genpu. Didn't look good with silver so I took it off. Probably just going to get the nextmod one or fiberglass my own.
2013 GenPu
 Old 10-18-2013, 08:22 PM   #18
blackms3_71's Avatar
Posts: 2,250   (View Stats)
cant you just paint it black? I know its rubber but as long as you don't scrape it or get it hit on a crub it should be fine no? this way it would be a deeper black to almost match the black ms3
 Old 10-24-2013, 07:15 PM   #19
Rob84's Avatar
Posts: 598   (View Stats)
Rob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the world
I did this on my ms6 today. Then drove it for about 40min. There was nothing left of it.
Rob84 is offline   Reply With Quote
 Old 10-24-2013, 07:28 PM   #20
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
Really couldn't hurt it
Looks good OP.... from the 1st pic, it seems to have "fell"
 Old 10-25-2013, 12:23 AM   #21
jeymz's Avatar
Posts: 163   (View Stats)
jeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond reputejeymz has a reputation beyond repute
Looks good. Nice job.
2011 LSM w/ Tech Pkg
Cobb AP - OTS Stage 2 | Ultragauge | Autotech HPFP Internals | DENSO ITV22s | Forge BPV v2 | CS TMIC | CS Boost and BPV Tubes | CPE Nano SRI w/ Amsoil filter | CS TIP | OBX race pipe | CPE Stage 2 RMM | JBR PSMM 80 | JBR TMM 80 | JBR Shift knob, weight, bushings | JBR RSB | JBR Rear camber arms | Sure SSP | MD OCC | Corksport Springs | Bilstein Sports | FCM Rear Bumpstops | FoMoCo tranny fluid | CS Tow Plate | CS LED Kit | CS Fog LEDs
jeymz is offline   Reply With Quote
 Old 10-25-2013, 12:32 AM   #22
just did this to my gen one. I think its okay for now. I plan on getting the sti lip tho
 Old 10-25-2013, 12:49 AM   #23
Matrix311's Avatar
Posts: 2,133   (View Stats)
Looks good! I just bought a lip from a local guy for $75 for the gen1 and now its in the autobody shop with my front bumper getting painted and installed for $300. Little more then I wanted to spend but its a high end shop and they will make it look great. For $9.00 damn, cost me more in gas to drive to this shop then it did you to buy this lip.
 Old 11-15-2013, 09:32 PM   #24
avesfan101's Avatar
Posts: 442   (View Stats)
avesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the worldavesfan101 is the leader of the world
I did this a few weeks ago before the motor went ZZB. I used multiple screws. Id say one every 6 inches and I didn't have it stick out a ton. For under $25 I am super happy with it.
Fuck MSF
avesfan101 is offline   Reply With Quote
 Old 11-16-2013, 06:52 PM   #25
Jkspeed's Avatar
Posts: 293   (View Stats)
Jkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond repute
Groaned at 6 Times in 4 Posts
Legit post
2008.5 Metro Grey MS3
Performance:
HTP 3.5" Intake | Autotech HPFP Internals | SU TMIC | EBay Catless DP | Stratified Tuned | JBR 88a Dogbone - Short shift plate | Eibach Pro-Kit | 18x8 MB Interline wheels | Conti DW's 235/40R18 | JBR Rear Sway Bar
Other fun:
Dashhawk | Single res delete | Corksport Interior LED light kit - Bypass valve hose | Vent pod boost gage | Custom Heated driver and passenger seats | Leather shift boot
Jkspeed is offline   Reply With Quote
Page generated in 0.45029 seconds with 36 queries
