Like Tree67Likes
 Old 05-07-2015, 05:54 PM   #561
AequitasVeritas's Avatar
Posts: 289   (View Stats)
AequitasVeritas is the leader of the worldAequitasVeritas is the leader of the worldAequitasVeritas is the leader of the worldAequitasVeritas is the leader of the worldAequitasVeritas is the leader of the worldAequitasVeritas is the leader of the worldAequitasVeritas is the leader of the worldAequitasVeritas is the leader of the worldAequitasVeritas is the leader of the worldAequitasVeritas is the leader of the worldAequitasVeritas is the leader of the world
191k. Just lost my oil pump chain. Motor is intact. Rebuild with internals time. 15k on BT.
2007 Mazdaspeed3 | GT2871R | HTR 3.0 | Cobb AP | GS ECBS | 3 Bar MAP | JBR EGR block | KW V1 | Stop-Tech Rotors | Stop-Tech Pads | Stop-Tech SS Brake Lines | HKS Hi-Power | ATP Long Catless Downpipe | JBR Trilogy | ACT 6 Puck Sprung Kit | CXRacing FMIC | AutoTech HPFP | Cobb STS | Denso ITV-22 | Cobb Shifter Weight |
FreekTuned
AequitasVeritas is offline   Reply With Quote
The Following User Says Thank You to AequitasVeritas For This Useful Post:
BackRoads (05-07-2015)
 Old 05-07-2015, 06:00 PM   #562
BackRoads's Avatar
Posts: 575   (View Stats)
BackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the world
Very interested to hear about this! Doing a build thread?
2007 Sunlight Silver MazdaSpeed3 Sport | BNR S3v2 | Autotech Internals | Cobb TIH | 3BAR MAP Sensor | Denso itv-22's | MSCAI | ETS 3.5" TMIC | Synchronic DV | Stratified EBCS | Guardian Angel | UR Test Pipe | Cobb AP | Koni Yellows | JBR RMM | CORN YEAH! | 265,000m | Tuned by STRATIFIED!!!
To install: CPE SafeSeals
2012 Velocity Red MazdaSpeed3 w/Tech | Autotech Internals | Sure Aeros V2 | 98,000m
BackRoads is offline   Reply With Quote
 Old 05-07-2015, 08:33 PM   #563
I might. I rarely have time with school, work and all that.
FreekTuned
 Old 05-07-2015, 08:40 PM   #564
Killer95GT302's Avatar
Posts: 198   (View Stats)
Killer95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond repute
I just turned 100K on my MS6 this past weekend. Knock on wood - this car has been good to me. After the many horror stories I've read, I was beginning to doubt it would ever make it!
2006 Mazdaspeed6 - Bone Stock!
1995 Mustang GT - Turbocharged / Motor work
Killer95GT302 is offline   Reply With Quote
 Old 05-10-2015, 07:12 PM   #565
Atticaz's Avatar
Posts: 621   (View Stats)
123456!!
2007 MAZDASPEED3 - SOLD
The Following 5 Users Say Thank You to Atticaz For This Useful Post:
Cataphract_40 (05-16-2015), kehbleh (05-14-2015), predapio (05-17-2015), RusianKid (05-10-2015), sxman (05-29-2015)
 Old 05-14-2015, 10:02 PM   #566
kehbleh's Avatar
Posts: 46   (View Stats)
kehbleh is a glorious beacon of lightkehbleh is a glorious beacon of lightkehbleh is a glorious beacon of lightkehbleh is a glorious beacon of lightkehbleh is a glorious beacon of light
2009 MS3 checking in here with just under 84k on the clock.
Haven't had to do much. Rear shocks like 15k miles ago (and lived on a dirt road for a year or two, they took a beating). Overfilled my gas because the damn pump didn't shut off, had to replace whatever valve that was to fix the stumbling post-fill-up. Other than that, no complaints really. Got a funky noise coming from the front right suspension I need to get checked out though. Planning to clean the valves soon and do OCC + EGR delete. Pondering on a HPFP + downpipe + stage 2 flash for extra funsies...
CP-e intake, TIH, COBB AP stage 1 flash, JBR RMM.
2009 GT
JBR shifter bushings, JBR shift knob, CP-E RMM, CP-E Nano SRI, CP-E TIH, COBB AP
kehbleh is offline   Reply With Quote
 Old 05-17-2015, 07:10 AM   #567
ItsNox's Avatar
Posts: 3,076   (View Stats)
How appropriate; I rolled 100k on a run through the Tail of the Dragon at ENM with my Nator homies. Good. Fucking. Times. Mods in sig.
Sent via Tapafail
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
The Following 5 Users Say Thank You to ItsNox For This Useful Post:
Atticaz (05-17-2015), BackRoads (06-15-2015), predapio (05-17-2015), sho (07-03-2015), simply_pandora (05-17-2015)
 Old 06-29-2015, 07:59 PM   #568
Skierdood's Avatar
Posts: 3,847   (View Stats)
Skierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the world
Hit a milestone today! Cars gonna need VVT and front wheel bearings soon. Just got a quote from speed performance today.
2007 True Red MS3
AP V2 • CPE Xcel Nano • COBB TIP • UR TP • Autotech Internals • CS RMM Inserts • FD Wheels • Freek Tuned 3/9 E85 315whp/352wtq •
Skierdood is offline   Reply With Quote
The Following User Says Thank You to Skierdood For This Useful Post:
Finchee (06-30-2015)
 Old 06-29-2015, 08:15 PM   #569
blam1's Avatar
Posts: 359   (View Stats)
blam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the world
Originally Posted by beachshoer View Post
Rolled 180k miles today in the marathon PU.
Still kickin.
I always wonder who's the closest genpu to me in mileage.
Damn son. I have an 07 and still only at 96k. Good job!
FYHN except Odyssey's. Ody's are bad-ass
1996 Acura Integra HB Sold
1998 Acura Integra GSR Sedan Sold
2008 Honda Pilot Sold
2006 Honda Accord Sold
2008 Honda Odyssey
2007 MS3 Silver Sport
Cobb AP SRI TIP // CNT DP // JBR SSP Bushings Knob RSB // CPE TMM // SU TMIC // AT INTERNALS // MD OCC RMM // NGK // Bilstein B8 // Swift Springs // Evo 9 wheels // SPC camber arms
Freek tuned 91 and 3 gal E85
blam1 is offline   Reply With Quote
 Old 07-01-2015, 11:39 PM   #570
HaXiR's Avatar
Posts: 315   (View Stats)
HaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud of
Got my Gen 1 in march of 08 with only a couple miles on it and it's just past 87k. I'm going to be sad when I pop 100k, car feels so old now. But ill drive it until it blows up or catches on fire
HaXiR is offline   Reply With Quote
 Old 07-02-2015, 12:03 AM   #571
2eatV8everyday's Avatar
Posts: 302   (View Stats)
2eatV8everyday is the leader of the world2eatV8everyday is the leader of the world2eatV8everyday is the leader of the world2eatV8everyday is the leader of the world2eatV8everyday is the leader of the world2eatV8everyday is the leader of the world2eatV8everyday is the leader of the world2eatV8everyday is the leader of the world2eatV8everyday is the leader of the world2eatV8everyday is the leader of the world2eatV8everyday is the leader of the world
Groaned at 6 Times in 2 Posts
2006 MS6, and I'm at 178k. Still running original motor, trans, and diff/rear end. Fresh OEM clutch 5k miles ago. However, the VVT actuator is bad. Replacing all of that in the next two weeks or so.
Stocked Out with my Cock out
2eatV8everyday is offline   Reply With Quote
 Old 07-03-2015, 10:31 AM   #572
wmjosiah's Avatar
Posts: 22   (View Stats)
wmjosiah will become famous soon enough
I've got ~122K on my 2008 MS3. Original everything except brakes, tires, shocks, swaybar bushings, rear motor mount, and some of the front end plastic bits, along with one of the headlights and a fender, but that's because I hit a bear, not because anything wore out. I've been very impressed with how well everything has held up, especially since I autocross and track it from time to time. Best car I've ever owned, in many ways. Certainly the most reliable car I've ever owned, by far, but it's also the newest, and the only one that wasn't German, so it's a low bar
'08 MS3 GT Bilstein HD's, extra sound deadening, StreetUnit RMM
'96 K2500 6.5L NV4500 converted to DB2/4911
'04 SV650
wmjosiah is offline   Reply With Quote
 Old 10-23-2015, 02:46 PM   #573
Skierdood's Avatar
Getting closer to the 200k milestone!
2007 True Red MS3
tbcota25 (09-17-2016)
 Old 10-23-2015, 02:53 PM   #574
Police - Grammarhead
Vansquish's Avatar
A little part-throttle knock notwithstanding, the car is still running like a top at a relatively safe 'n solid 320/340.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/100-000-miles-club-122358/
2007 MS3 reliability? : mazda This thread Refback 01-19-2015 10:23 AM
Buying used 2007 MS3 with 130k? : mazda This thread Refback 01-15-2015 05:43 AM
If car is relatively taken care of, how many km's on average can a Mazda last? This thread Pingback 11-30-2014 12:22 AM
How reliable has your Speed 3 Been? : mazda This thread Refback 11-08-2014 12:35 PM
What mileage is your MPS on? This thread Refback 05-19-2014 09:20 PM
Want to buy a Speed3, worried about engine reliability. : mazda This thread Refback 02-11-2014 01:53 PM
?????3 MPS!!!))) This thread Refback 03-25-2013 05:41 AM
????? 3 MPS This thread Refback 02-21-2013 09:08 AM
What mileage is your MPS on? ? Mazda MPS Owners Club This thread Refback 02-10-2013 02:12 AM
???????? ? ??????(?) This thread Refback 01-31-2013 02:51 AM
Need Carfax on MSM Mx-5 '04 with CAI, DP w/29k miles, Trying to join the MS club richbutler1 Miata - General Questions 8 08-08-2012 07:20 PM
Video: Mustang Club of Poland inspires Mustang Club of Parana to make video Haltech Automotive News 0 04-17-2012 06:00 PM
Poor gas mileage from 260-280 miles on a tank down to 200-220 miles per tank? Matrix311 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 18 08-27-2011 07:59 PM
Columbia House DVD Club Membership 7 DVDs for $.49 Each at Columbia House DVD Club Haltech Hot Deals Section 0 04-16-2008 09:40 AM
Page generated in 0.37092 seconds with 32 queries
