![]() | | #41 | ![]() |
| jbr makes fall-a-parts. ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 13536 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,744
Groans: 793
| Not Ranked : 0 score
No issue at all.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals Last edited by Tokay444; 08-07-2014 at 11:25 AM. Reason: MSF Database - Automerged Doublepost | |
| The Following User Says Thank You to Tokay444 For This Useful Post: | Easter Bunny (08-07-2014) |
![]() | | #42 | ![]() |
![]() Join Date: May 2013 Location: Chesapeake, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 166
| Not Ranked : 0 score Im definitely a fan of the design of these as opposed to the cp-e ones. It makes sense to me that an intentional and designed deformation will create a better seal than just a little cup. Really interested to see what the price point is going to be.
__________________ 2012 VRM Mazdaspeed 3 - “Claudia” Cobb v3 AP | Autotech HPFP Internals | UR Catback | Cp-e TMIC | Cp-e Stage 2 RMM | Cp-e Catted DP | TWM Full Replacement | CS Occ | CS Bpv | CS Hood Struts | JBR EGR delete | JBR Boost tubes and Recirc hose | HTP 3.5” Intake | 1 Step colder plugs | Blox 490 | BC Coilovers | Drag dr-49 Waiting for install CS Battery box 2008 Black Mica Mazdaspeed 3 - "April" (Totaled, may she rest in piece) |
![]() | | #43 | ![]() |
Groans: 793
| Not Ranked : 0 score Studs and nuts will not be an issue. CS will need to speak for the removal tool, but I've never personally needed one, and I've pulled some crusty injectors.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
| The Following User Says Thank You to Tokay444 For This Useful Post: | Mauro_Penguin (08-09-2014) |
![]() | | #44 | ![]() |
| Not Ranked : 0 score Are these going to be the exact same spec as the Tokay V2 seals? (One day I will get off my lazy butt and get my v2 installed.......one day).
![]() | | #45 | ![]() |
Groans: 793
| Not Ranked : 0 score They are going to be identical save for the overall length. All the distances from mating surfaces will remain the same. I shortened up on them in the interest of maximizing material, and not have the open end flare out on the radius of the injector body.
| The Following 2 Users Say Thank You to Tokay444 For This Useful Post: | magicka (08-07-2014), Mauro_Penguin (08-09-2014) |
![]() | | #46 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 492
Groaned at 20 Times in 11 Posts
maybe even as a loaner/rental i've had some that came out easy and some that are a bitch, the tool is just GREAT! | |
![]() | | #47 | ![]() |
![]() Join Date: Nov 2010 Location: Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 96
| Not Ranked : 0 score Inj removal tool would be nice but so long as its not compulsory in the kit, I've done plenty with out it fine |
| Injector seals - need to replace injector/fuel line O-rings? | TheRealDefman | 2010 MS3 - Engine, Transmission & Driveline | 3 | 03-02-2014 09:35 PM |
| CPE or PTP Injector Seals? | Matrix311 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 13 | 11-26-2011 03:12 PM |
| Injector seals... how do you know you need them? | MS3 Ventura | MazdaSpeed 3 - Engine, Transmission & Driveline | 2 | 03-09-2011 01:29 PM |
| Injector Seals! | ptperformance | Mazdaspeed3/6 General Discussion | 71 | 06-02-2010 10:13 PM |
