| Approved MSF Vendor ![]() ![]() Join Date: Mar 2008 Location: Vancouver, WA
Rep Power: 4731 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,820
(Thread Starter) | Not Ranked : 0 score Yes I know you all think WTF CorkSport, why do I need this? It's you all be dirty dirty on the valves with your Mazdaspeeds that is why. Instead of the duct tape and jury rigged attachments we wanted to make walnut blasting easier. We went with a 2 ply reinforced silicone which is sturdy for the task but has some give to seal against the cylinder head without having to be a body builder. We designed the kit for the Mazdaspeed 3, Mazdaspeed 6 and Cx7 turbo but it should work on any other direct injected vehicle but fitment is not assured. They are ready to rock and in stock. -Derrick |
| The Following 2 Users Say Thank You to CorkSport For This Useful Post: | Code Monkey (10-25-2018), Hush (10-28-2018) |
| Not Ranked : 0 score Look good!
![]() Join Date: May 2013 Location: CO
Rep Power: 2407 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,487
| Not Ranked : 0 score I thought it was a beer bong... Sent from my SM-N960U using Tapatalk |
Groans: 211
| Not Ranked : 0 score I thought it was a bong.
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles |
| The Following User Says Thank You to Thor Hammer For This Useful Post: | monkey.bones.007 (10-26-2018) |
Groans: 211
| Not Ranked : 0 score Yes indeed. Suck and blow.
| Not Ranked : 0 score Is that supposed to go in my pants?
| The Following 2 Users Say Thank You to Fstrnyou For This Useful Post: | monkey.bones.007 (10-27-2018), Thor Hammer (10-29-2018) |
| Not Ranked : 0 score To continue the serious conversation, I've been waiting on the 2 weeks away exhaust manifold. Tempted to just get the eBay V3 manifold. My luck, the new CS Mani would drop within days of buying that eBay one. That's what happened with Damond's TMM for the 6. I got tired of waiting and bought the AWR piece. A few days later, Damond releases it. UGH!!
| valve cleaning | Me2speed3 | Gen2 MS3 General Discussion | 30 | 12-25-2015 05:12 AM |
| Intake Valve Cleaning using valve overlap and DI injection window shift | Vansquish | MazdaSpeed 3/6 - ECU Computer Tuning | 33 | 05-06-2014 07:00 PM |
| EGR valve cleaning | desertrat | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 03-06-2010 09:17 AM |
