 Old 08-13-2018, 07:18 AM   #1
Thurmannn's Avatar
Posts: 2   (View Stats)
Thurmannn is an unknown quantity at this point
Default Oil pressure gauge HELP!
I’m fairly new to the MS3 community, I have a 2010 MS3 but the weird thing is, is that my engine is from the Gen 1 MS3 because my oil filter is not a spin on it’s a paper filter, so I was wondering if it was possible to run the conversion kit for a spin off oil filter with the adapter that CorkSport makes so I can tap the oil pressure gauge into the adapter. Unless there is another spot you can tap the engine for a oil pressure gauge?
Thurmannn is offline   Reply With Quote
 Old 08-13-2018, 07:47 AM   #2
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
Yes you can run the gen2 spin-on housing and that adapter.
2012 NASA Spaceship Gray MS3
 Old 08-13-2018, 11:50 AM   #3
Thurmannn's Avatar
Thank you for the feedback, and is the CorkSport sandwich plate compatible with the oil filter conversion kit because I can only find that people are using the pro sport sandwich plate, was just wondering I’ve had bad luck with pro sport gauges and would rather not buy there product but if it’s the only one compatible then I will settle.
 Old 08-13-2018, 12:13 PM   #4
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
What's the adapter for?
Just get the OEM Mazda Gen 2 oil filter housing from Edge and put a T-fitting at the stock oil pressure sensor location for your gauge.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 08-13-2018, 12:19 PM   #5
KiwiFlavor's Avatar
I'm guessing he's talking about a andwich plate.
@Thurmannn; yes it will work. I'm running a Mishimoto sandwich plate on my spin-on housing.
 Old 08-13-2018, 12:21 PM   #6
Fstrnyou's Avatar
Oh, for external oil cooler?
Hmm, I must not be making enough power yet to need such things. I'll figure it out soon enough though. Just waiting on intercooler cores to show up, and fabrication, and installation, and testing......
Other rides:
History:
KiwiFlavor (08-13-2018)
 Old 08-13-2018, 12:23 PM   #7
KiwiFlavor's Avatar
It looks like this. Pretty nice if you want to run oil pressure, oil temp and some other sensors lol
https://corksport.com/support/instru...-6-321-WEB.pdf
 Old 08-13-2018, 12:29 PM   #8
Fstrnyou's Avatar
Oh, that's just craziness. But ya, a t-fitting will only work for a pressure sensor. Temp sensors need to be in the flow, so I guess a sandwich plate is the only option for now.
Other rides:
History:
KiwiFlavor (08-14-2018)
 Old 07-30-2019, 01:21 PM   #9
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
as said above for pressure reff, you just need a T with the oem pressure sensor
but conversion to gen2 hosing and filter is a peace of mind upgrade that everyone should have with a gen1 speed.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 07-30-2019, 07:06 PM   #10
Police - Grammarhead
Vansquish's Avatar
Don't get fooled. You're responding to a spam bot. It took part of a post farther up in this thread and used it.
 Old 07-31-2019, 06:09 AM   #11
Jeff23spl's Avatar
i missed it ,
They want to look real...
Wife drive 2010 CX7
Vansquish (07-31-2019)
Oil Pressure Gauge... issues.. pls help :: Gusto :: MazdaSpeed 3/6 - ECU Computer Tuning 16 04-18-2011 07:07 PM
Fuel pressure gauge? drknyte MazdaSpeed 3/6 - ECU Computer Tuning 4 07-30-2010 05:47 PM
Tire Pressure Gauge gordita720 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 01-18-2010 09:59 AM
Page generated in 0.31119 seconds with 24 queries
