 Old 05-15-2019, 01:45 PM   #1
san1234's Avatar
Posts: 20   (View Stats)
san1234 is an unknown quantity at this point
Default CS Turbo preload
I am needing to adjust the preload on my CST4 turbo, while it's on the car. . . What is the easiest way to get at it, would it be from underneath the car or from the top? Thanks.
san1234 is offline   Reply With Quote
 Old 05-17-2019, 05:13 PM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
I adjust mine from the top. You can get it done with two 10mm combo wrenches.
If you don't mind me asking, why are you adjusting it?
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 05-17-2019, 07:11 PM   #3
san1234's Avatar
Sure, my tuner said it's not building enough PSIs and I need to increase the preload on the wastegate.
 Old 05-18-2019, 07:19 AM   #4
Police - Grammarhead
Vansquish's Avatar
Define, "not enough PSIs". What boost pressure are you targeting? Are you sure that everything is buttoned up properly and that you don't have a leak somewhere in the system?
 Old 05-18-2019, 02:00 PM   #5
san1234's Avatar
Ive triple checked all my connections, no leak
 Old 08-23-2019, 01:18 PM   #6
pacunning's Avatar
Posts: 3   (View Stats)
pacunning is an unknown quantity at this point
Bump, did you get this resolved? I’m also having issues, I’m at 80%WGDC and only able to hit 24.5 psi. Checked 2 times for boost leaks, none found. I feel kinda odd adjusting the preload to be honest. I have a CS EBCS set up in bleed mode and CSt4
pacunning is offline   Reply With Quote
 Old 05-18-2019, 01:22 PM   #7
san1234's Avatar
I'm getting 19.5 psi, looking for more than that.
 Old 05-18-2019, 07:13 AM   #8
Fstrnyou's Avatar
My preload is factory set and I can get 28psi. What boost are you aiming for? Lol.
Other rides:
History:
 Old 05-18-2019, 01:43 PM   #9
Fstrnyou's Avatar
Hell, my boost creeps to almost that with 0% WGDC.
Other rides:
History:
MS6 AWD trans bearings / preload question Boltz MazdaSpeed 6 - Engine, Transmission & Driveline 15 01-25-2014 04:25 AM
Adjusting preload IWG shawn. MazdaSpeed 3/6 - Big Turbo Builds 7 08-05-2013 09:02 AM
Adjusting WG spring preload on turbo? p057 MazdaSpeed 3/6 - Turbo Induction 10 10-30-2012 05:55 PM
Page generated in 0.28404 seconds with 23 queries
