 Old 04-29-2019, 04:23 PM   #1
Speed403's Avatar
Posts: 4   (View Stats)
Speed403 is an unknown quantity at this point
Default Corksport turbo boost creep
I'm looking to get the cst4 turbo, does anyone know for sure if the boost creep issue has been fixed or is it still a problem for some people. Thanks!
Speed403 is offline   Reply With Quote
 Old 04-29-2019, 04:54 PM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Doubt it.
My Corksport turbo was part of the "2nd batch" that supposedly was revised to solve the boost creep, but that wasn't the case. I imagine if I had an upgraded exhaust manifold, it would be even worse.
I have not see any discussion, documentation or claims stating the the newly named CST4 has received revisions to address boost creep...aside from the EWG housing option/upgrade.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 04-30-2019, 06:32 AM   #3
LenSpeed6's Avatar
Posts: 164   (View Stats)
LenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud of
I havent noticed any boost creep with my CS turbo
06 Speed6
White/Black interior
Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts
To think... this is suppose to be my winter car... because,
'72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far
'12 1/2 Triumph Daytona 675R stock some how
'79 AMC Spirit AMX, 4.6L stroker I6
LenSpeed6 is offline   Reply With Quote
 Old 04-30-2019, 06:51 AM   #4
Fstrnyou's Avatar
What intercooler are you using?
Other rides:
History:
 Old 04-30-2019, 09:34 AM   #5
LenSpeed6's Avatar
stock for now because im weaksauce, hoping to run the rerelease of the fmic from CS if that ever happens.
06 Speed6
 Old 04-30-2019, 09:43 AM   #6
Fstrnyou's Avatar
stock for now.
There it is.
Have fun with boost creep later.
BUT, the boost creep isn't as bad as I've led on. Wastegate is about 12psi or so and it creeps to 18ish psi. And 18 isn't unusually high, so it's manageable.
Other rides:
History:
 Old 04-30-2019, 09:56 AM   #7
LenSpeed6's Avatar
I'm pushing around 23-24psi threw that shit stock top mount and a small intake. Already maxed out the intake and I'm sure the IC isnt very happy. I am running the EBCS in factory bleed set up rather than interrupt, thinking about changing that in the near future.
As always I learn more when you post @Fstrnyou;
06 Speed6
 Old 04-30-2019, 10:08 AM   #8
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
at 23-24psi it is why you didn't notice any creep if it is below 18 psi lol
Why would you install a BT and run it below 18psi ?
Stock bloc can handle 18 all day if properly tuned and if you are still afraid, add meth and a larger IC
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 04-30-2019, 04:37 PM   #9
Fstrnyou's Avatar
When I was still on stock TMIC with 3.5" intake and turbo-back exhaust, I didnt have any creep and ran 20psi.
My WGDC was flat all the way to redline even if I targeted lower boost.
However, when the CP-e TMIC went on, it was just enough increase in intake flow to overpower a full open wastegate. 0% WGDC would get to 12psi pretty quickly and was flat for a very short while before tapering smoothly to about 18psi at redline.
Now, I was originally targeting 20psi with the stock TMIC anyways, so all I had to do was play with the WGDC table to get back to targets. But what I ended up with was a negative taper WGDC to result in a flat boost curve.
I don't have it in front of me, but as an example, the WGDC might be at 50% at 3500 and taper to 15% at 6500.
The real issue with boost creep is you now have no way to limit boost on the top end other than throttle control... via your foot or some tricky business with the throttle tables in the tune.
To continue, if you want to run higher boost, that's obviously not an issue. Just increase the WGDC. But you will find as you increase boost targets that there comes a point you start to notice the WGDC isn't tapering off as fast as before to achieve targets. And if you turn it up high enough, the WGDC will be flat again. The reason for this is because you are getting closer to the choke point of the CS turbine housing. My current tune has the WGDC very near 100% near redline trying to hold 28psi. I emailed Corksport about it and they told me that's all she's got in her. Oh well.
Other rides:
History:
Oshiguru (05-03-2019)
 Old 04-30-2019, 04:46 PM   #10
Speed403's Avatar
Thanks guys. So it seems for about the same price and same Power the bnrs3 would be the way to go?
 Old 04-30-2019, 05:01 PM   #11
Fstrnyou's Avatar
A buddy of mine had an S3 and loved it.
Changed to a PT5558 and loved that too but wasn't as fun for a daily.
Was going to go back to the S3 but found a sick deal on an S4.
Short version, you'll probably really enjoy the S3.
Other rides:
History:
 Old 04-30-2019, 05:05 PM   #12
Speed403's Avatar
I'm not going to be using e85 or meth, so I figured the s3 would be the best turbo to take advantage of the stock fuel system. Probably aim for 350whp give or take
 Old 04-30-2019, 05:24 PM   #13
Fstrnyou's Avatar
Yep. You'll be all set with S3
Other rides:
History:
 Old 04-30-2019, 05:36 PM   #14
Speed403's Avatar
Awesome. Thanks for the advice!
 Old 05-01-2019, 06:42 AM   #15
LenSpeed6's Avatar
According to Cork, the now CST4 can do 28psi but happier at around 25-26 which is probably the max of what I'd do for my particular car (for now). I wish that the CST5 was available when I was building my car, who knows what I'll end up doing in the future but upgrading the manifolds would be priority over a different turbo for me.
Unless its a chinese knock off it doesnt seem like you can go wrong with either CS or BNR.
06 Speed6
Boost creep after installing Corksport Turbo vesestilldrumming 2010 MS3 - Troubleshoot/Diagnostics 205 01-21-2016 09:26 PM
Fuel Cut, Over Boost, Turbo Creep Ms6_Guy MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 04-08-2014 03:29 PM
GTX3071R boost creep/boost spike! Need help! MS3 Ventura MazdaSpeed 3/6 - Big Turbo Builds 20 05-11-2013 11:44 AM
Boost creep 86AmishMs3 MazdaSpeed 3/6 - ECU Computer Tuning 11 12-21-2011 05:30 PM
Boost creep? psmith22 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 07-24-2011 11:47 PM
Page generated in 0.33751 seconds with 23 queries
