 Old 08-24-2011, 07:08 PM   #1841
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
This is easy to do in the car if you are wondering. I took off the intake, disconnected the DP and unbolted the turbo bolts only. I picked the turbo up and set it as far to the right by the master cylinder out of the way without disconnecting any feed lines. Some rags, a shop vac with the small hose connector and a real bit for your air grinder will knock this out pretty quick.
The Following 2 Users Say Thank You to jmhinkle For This Useful Post:
crazyp (08-24-2011), djuosnteisn (08-25-2011)
 Old 08-25-2011, 04:13 PM   #1842
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
top mount
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 08-26-2011, 01:17 AM   #1843
ReD BoY's Avatar
Posts: 523   (View Stats)
ReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the worldReD BoY is the leader of the world
Groaned at 32 Times in 15 Posts
Props, this thread was going last summer when I left for college and now you all have a setup!
---Stupid kid can haz car.
ReD BoY is offline   Reply With Quote
The Following User Says Thank You to ReD BoY For This Useful Post:
djuosnteisn (08-26-2011)
 Old 08-26-2011, 11:49 AM   #1844
MSP611's Avatar
Posts: 2,291   (View Stats)
so wats the problem with the flanges??? is it the mani is too big for the turbo?? or opposite?
In progress:
 Old 08-26-2011, 04:18 PM   #1845
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
Looks like the opposite. Basically doing a port job on the mani for more flow
The Following User Says Thank You to crazyp For This Useful Post:
 Old 08-26-2011, 04:45 PM   #1846
Captain
If you do this porting..... be 100% certain no shavings fall into the manifold. And i suggest cleanup with a vacuum before putting the turbo back on.
But yeah, certainly looks like a lot of material can be taken out. Def a helpful mod.
www.permtuning.com
 Old 08-26-2011, 10:28 PM   #1847
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Turbo goes on top.
The Following User Says Thank You to dougefresh_ For This Useful Post:
djuosnteisn (08-30-2011)
 Old 09-11-2011, 01:14 PM   #1848
steedspeed's Avatar
Posts: 582   (View Stats)
steedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the world
I measured a T3 turbo here and the flanges are a perfect match so I guess the turbos vary by quite a bit. I'd rather leave the manifold slightly smaller rather than the other way around though.
steedspeed is offline   Reply With Quote
The Following 2 Users Say Thank You to steedspeed For This Useful Post:
djuosnteisn (09-11-2011), wolly6973 (09-12-2011)
 Old 09-11-2011, 10:18 PM   #1849
Captain
Yup. I guess Rob's turbo actually matched the original dimensions pretty close. Must just be a casting variance or something. But it's great to know some can port match if needed
www.permtuning.com
 Old 09-17-2011, 11:04 AM   #1850
steedspeed's Avatar
I'm working with someone right now on a top mount for the 3. He just sent pictures and it looks like it will work with some changes to the manifold.
The Following 6 Users Say Thank You to steedspeed For This Useful Post:
Dano (09-17-2011), djuosnteisn (09-19-2011), feldm4n (09-17-2011), mason (09-17-2011), Mazdanspeed3 (09-17-2011), wolly6973 (09-17-2011)
 Old 09-17-2011, 11:06 AM   #1851
manelscout4life's Avatar
Posts: 1,781   (View Stats)
Groans: 661
@#$%$ so now that my setup is done you come up with this!?
O well, can't wait to see results. And I'm still loving your mani
 Old 09-17-2011, 01:37 PM   #1852
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
Shit....fuck...oh well.
2007 CTS-V - Trying to sell
 Old 09-17-2011, 03:47 PM   #1853
crazyp's Avatar
Groans: 68
I know someone with a speed 3 that saw my setup and wanted to do it. I had to tell him he couldnt. Id be happy to tell him im wrong
 Old 09-17-2011, 04:22 PM   #1854
bmylez's Avatar
Groans: 31
None of my fail was related to being bottom mount turbo, so I don't know if it's worth the trouble of switching, haha. If I had not gone Steed t3 already, I would be all over this. Seeing that I can remove the turbo and manifold together and it only takes 20 min to undo the manifold bolts, it's not the worst thing in the world.
 Old 09-17-2011, 11:10 PM   #1855
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
What?????
What magic is this you speak of?
Tappin
 Old 09-18-2011, 01:06 AM   #1856
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Please tell me this will work for the EFRs.
Pretty please with sprinkles of unicorn on top.
 Old 09-18-2011, 08:46 AM   #1857
steedspeed's Avatar
All I got so far was pictures of a 3076 placed between the engine and firewall in what looks like a viable location.
Docnox (09-24-2011), Realgib3 (09-19-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/top-mount-turbo-setups-61011/
Bosch 3 Bar MAP - ATR values This thread Refback 04-05-2012 07:59 PM
Mazda MPS Owners Club • View topic - New Turbo me thinks ! This thread Refback 03-20-2011 03:57 PM
Gauge setups TheNewGuy MazdaSpeed 6 - Engine, Transmission & Driveline 8 03-14-2011 06:56 PM
Top Mount Turbo Manifold aminzer Mazdaspeed3/6 General Discussion 25 02-06-2010 08:19 PM
AP & Forge setups. 08cosmic3
Cobb Access Port/Maps
0 08-08-2009 06:52 PM
TRZ Transmission Mount/ Mazda3online turbo inlet installed and review! Raider Mazdaspeed Forums User Reviews 0 06-29-2009 06:40 AM
Page generated in 0.36888 seconds with 31 queries
