![]() | | #41 | ![]() |
![]() Join Date: Jul 2008 Location: Imperial MO
Rep Power: 581 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
| The Following 2 Users Say Thank You to Jarods7920 For This Useful Post: | djuosnteisn (07-06-2010), xcoldricex (06-30-2010) |
![]() | | #42 | ![]() |
![]() Join Date: Oct 2009 Location: Andersen AFB, Guam
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 717
Groans: 124
| Not Ranked : 0 score Awesome!! In for updates! |
![]() | | #43 | ![]() |
![]() Join Date: Jul 2009 Location: Duvall, WA
Rep Power: 0 ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score Lurking with interest. Cool project.
__________________ [ Alpine's MS3 ] [ Alpine's Photos ] |
![]() | | #44 | ![]() |
![]() Join Date: Sep 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
Groaned at 56 Times in 56 Posts
| Not Ranked : 0 score good luck
__________________ |
![]() | | #45 | ![]() |
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
| Not Ranked : 0 score it's too late, but hope you weighed the car before hand - would be interesting to see how much your awd system adds to the car. also did you think about upgrading the in-tank pumps while you had it off the car? I'm not sure if you needed special tools for the tank you used (i remember hearing it was a big PITA for our tank), but would've been something good to look into too. I know there's a bunch of other shit on your mind though! the meth kit is still waiting for you, would be good for your build! |
![]() | | #46 | ![]() |
(Thread Starter) | Not Ranked : 0 score No i did not get a chance to weigh the car before hand, however i do have a friend with the exact same car to the t so if need be i can weigh his and see in comparison to mine. As far as fuel pumps i am planning on running 2 in tank walbros. But i will only be running one most of the time. The second pump will run off a hobbs switch. Soon as i get the fuel system completed i will be buying you meth kit if its available still. Tonight i am going to finish closing off the hole, seam seal it and undercoat it all, then do the final assembly and installation of the rear end. or at least that is that plan. |
![]() | | #47 | ![]() |
![]() Join Date: Jun 2010 Location: Tulsa, OK
Rep Power: 10322 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,599
| Not Ranked : 0 score Wow I was about to do a search for something like this and here it is! haha Best of luck on this build, sounds awesome. I see everyone's point, all are valid. Two ways to look at this build, but in the end, it's YOUR car and your time and money, and in the end, it's you that has to be impressed, not anyone else. Keep it up and good luck! |
![]() | | #48 | ![]() |
| Zoom-Zoom Boom ![]() Join Date: Jul 2008
Rep Power: 166 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31
| Not Ranked : 0 score Question, are you going to cage the car or is this gonna be a daily driver? Whats the final goal here? Track whore or Grocery getter?
__________________ 2007 Black Mica Mazdaspeed 3 (SOLD) Blew: May 24 2009 |
![]() | | #49 | ![]() |
Groans: 78
| Not Ranked : 0 score Who says he can't treat the drive to the grocery store like its a racetrack?
__________________ [Precision 5557 T4 flanged Journal Bearing Turbo][Race Roots Ceramic Coated T4 Manifold][Race Roots 3" V-Band Catless Downpipe][Race Roots Under-Car FMIC kit][CXracing 18"x31"x3" IC Core][Tial 44mm EWG With 0.9Bar Spring][Cobb AP][Full Str33tunit Mount Set][Madvillain 4" Inlet/Intake][Cp-e xcelXL Maf Housing][Devilsown Meth Injection Kit][HKS Ignition Amplifier][Cp-e Catback Exhaust][HKS bov][PTP IM Spacer][Whoosh EGR Delete][AEM Digital Boost Gauge][Matt Damond OCC Kit][Trunk Mounted Optima Battery with KnuKonceptz Kit][Madvillain ECU box][TWM Short Shifter][BC Coilovers][Cobb Rear Sway Bar][Falken Azenis rt615's][Eibach Pro 25mm Spacers] |
![]() | | #50 | ![]() |
![]() Join Date: Dec 2009 Location: Fontucky, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,096
Groans: 1,364
![]() | | #51 | ![]() |
Definatly a daily driver. I already have a track car...i dont need another! Progress is comming along. I will make an update of the blog so you can see where i stand as of now. Jarod | |
| The Following User Says Thank You to Jarods7920 For This Useful Post: | djuosnteisn (07-28-2010) |
![]() | | #52 | ![]() |
(Thread Starter) | Not Ranked : 0 score Updates have been added. Hopefully so long as the heat doesnt kill me there will be more to follow this week. |
| The Following 2 Users Say Thank You to Jarods7920 For This Useful Post: | djuosnteisn (08-03-2010), Lex (08-03-2010) |
![]() | | #53 | ![]() |
![]() Join Date: May 2009 Location: Little Neck, NY
Rep Power: 3771 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,108
Groans: 326
| Not Ranked : 0 score good to hear, how are you controlling power distribution from front to rear? |
![]() | | #54 | ![]() |
| The Following 2 Users Say Thank You to Jarods7920 For This Useful Post: | 8.5MS3 (08-03-2010), djuosnteisn (08-03-2010) |
![]() | | #55 | ![]() |
| Banned ![]() Join Date: Jun 2008 Location: NY Baby!
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 48
| Not Ranked : 0 score good stuff man. been following your blog since you posted it. keep up the good work. cant wait to see the finished ride. cudos for doing something that no one else would. |
![]() | | #56 | ![]() |
![]() Join Date: May 2009 Location: N Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 523
Groans: 77
| Not Ranked : 0 score no updates?
__________________ 2008.5 MAZDASPEED3 GT TRUE RED ***GONE*** ![]() 2012 FORD MUSTANG GT >>> 400A Premium _ Performance White _ 6MT _ 3.73 _ HID & Security Pkg Koni Yellows _ Whiteline FSB & RSB _ FRPP K-Springs w/ Bump Stops, Boss 302 Strut Tower Brace, GT500 Strut Mounts, GT500 RCA, GT500-style AB J&M PHB _ Eibach Camber Bolts _ Avant Garde M510 Satin Silver 19x9.5 40ET _ Hankook Ventus S1 noble2 275/40/19 |
![]() | | #57 | ![]() |
(Thread Starter) | Not Ranked : 0 score There are some I am just lazy. I am waiting on the manifold still. But it is allegedly almost complete. Shocks I assume are done since billstien called mr Friday and front right axel should be done too, just waiting to hear from frank at dss! Other than than the exhaust, intercooler, and intake piping are to be finished. Then retune and enjoy for a bit. Unfortunaly it's been out of my hands as far as completion. I wish I had a time line but until I get the parts I can't really give one.
__________________ 2008 MazdaSpeed 3 AWD big turbo...blah blah blah |
| The Following 3 Users Say Thank You to Jarods7920 For This Useful Post: |
![]() | | #58 | ![]() |
(Thread Starter) | Not Ranked : 0 score AWD Mazdaspeed 3: Almost there.. Finally got around to posting and update today! Sorry its been so long and dont worry i havent quite!
| The Following 7 Users Say Thank You to Jarods7920 For This Useful Post: | ChimmyChong (12-05-2010), djuosnteisn (11-30-2010), IshiKage (11-30-2010), jracer (02-08-2011), madvillain (11-30-2010), PunjabiPlaya (12-03-2010), Speed3eak (11-30-2010) |
![]() | | #59 | ![]() |
| Two nuns and a pack mule ![]() Join Date: Jan 2010 Location: Virginia Beach, VA
Rep Power: 595 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 459
| Not Ranked : 0 score Holy shit!! I though for a while you abandoned the project, but wow!! Good shit! I'm anxious to see how it will all turn out. Good for you, man!! I wonder how lighter is it going to to be compared to the MS6?
![]() | | #60 | ![]() |
![]() Join Date: Sep 2009 Location: CREVE COUER, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 263
Groans: 75
| Not Ranked : 0 score Good stuff jarod, im looking forward to seeing it in action real soon... |
| The Following User Says Thank You to Fagwagon For This Useful Post: | 4G63 (12-02-2010) |
![]() | | #61 | ![]() |
![]() Join Date: Dec 2009 Location: Corona, CA
![]() | | #62 | ![]() |
![]() Join Date: Nov 2010 Location: Phoenix, AZ
Groaned at 11 Times in 1 Post
| Not Ranked : 0 score Cool stuff! Props man |
![]() | | #63 | ![]() |
![]() Join Date: Apr 2010 Location: Wadsworth, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 33
| Not Ranked : 0 score Wow this is some really good work. Props on taking the plunge!! |
![]() | | #64 | ![]() |
(Thread Starter) | Not Ranked : 0 score Updates are the car is at the fab shop getting the exhaust and intercooler pipes done. With that he will be completeing a custom intake, catch can, and blow through set up. I spoke with him at length about what i wanted and he is got some cool things in store, one being a dp back aluminum exhaust! I did discover that when i put the car on the ground i need new suspension for the car, so as soon as i hear from the people at Ksport, i will have that on its way. Hi-Tuned Performance | Photo Gallery If you check the link you can see his last project he did, just to give you and idea of what is coming!
| The Following 2 Users Say Thank You to Jarods7920 For This Useful Post: | 4G63 (01-18-2011), djuosnteisn (02-07-2011) |
![]() | | #65 | ![]() |
| Not Ranked : 0 score I"d say that guy knows how to fabricate! Wow, impressive. I can only imagine what he's got in store for your setup. |
![]() | | #66 | ![]() |
![]() Join Date: Nov 2008 Location: Sanford/Orlando/Daytona Beach FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,682
Groans: 278
| Not Ranked : 0 score how much different do you think the exhaust will sound being made out of alum compared to SS
__________________ 2015 Mazda 6 Pioneer Z2 DVD/Nav :|: Hifonics 800/4 & 1100/1 :|: Kicker Solo Classic 15" |
![]() | | #67 | ![]() |
Groans: 31
| Not Ranked : 0 score There is a guy with a crazy GT35r setup on his Focus running 4" aluminum exhaust. I'm personally not a fan. The resonance of aluminum is sooo much different than steel. To me, going aluminum isn't for sound, it's for weight savings.
![]() | | #68 | ![]() |
Groans: 278
| Not Ranked : 0 score how would you explain the sound of alum beyond that
![]() | | #69 | ![]() |
Groans: 31
| Not Ranked : 0 score Hmmm, they made the video private now. They used to have a vid up of it revving in neutral. Sounded like a very unspecial 4-banger and you couldn't even hear the turbo whistle.
![]() | | #70 | ![]() |
Groans: 278
| Not Ranked : 0 score i found it. hard to gauge being that its 4" with most are 3" so that right there changes sound. then its alum. i kinda like it though. sounds like a clean exhaust on vtak ok. i found a gst and evo with alum exhaust and i see what you mean. i dont like it. makes it sound ricer
![]() | | #71 | ![]() |
Groans: 31
| Not Ranked : 0 score You'd think that 4" would make it super deep...but instead it sounds like a Honda from the back. Meanwhile, he's putting down 540whp...still sounds like shit. My Racing Beat exhaust, on the other hand, sounds amazing to me. Jared/Top Speed (the car above) did the exhaust for weight savings.
![]() | | #72 | ![]() |
Groans: 278
| Not Ranked : 0 score yeah, i agree. alum def doesnt sound good. makes exhaust sound like honduhs
![]() | | #73 | ![]() |
![]() Join Date: Apr 2010 Location: Salt lake city, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 389
Groans: 30
| Not Ranked : 0 score Any updates? Blog apears to have stalled out.
__________________ 08.5 MS3- : ATP GT3071r: cp-e XL intake: cp-e big inlet: cp-e rmm 75 Duro: cp-e e-flex motor mounts : cp-e catted down pipe: cp-e cbe,: cp-e FMIC, cp-e HPFP: cp-e safe seals : DNP Manifold: COBB AP: COBB RSB: DO stg 2 meth kit ,: SURE TIG's, : KW V2 coilovers: Konig Milligram 18x8.5 +35, Hankook ventus evo's 235/40/18, Saitek adj endlinks :HKS BPV: TWM STS: 465whp 468 wtq Best e.t 11.9 Best trap 123mph |
![]() | | #74 | ![]() |
(Thread Starter) | Not Ranked : 0 score Not as of now. He is still working on the car. I am working with k sport to get a suspension set up that will work well for the car. I took dome pictures the day I dropped it off to post, but I have not been able to find my camera since then.
| The Following User Says Thank You to Jarods7920 For This Useful Post: | xcoldricex (02-22-2011) |
![]() | | #75 | ![]() |
(Thread Starter) | Not Ranked : 0 score Got an update today from matt. The drive shaft is done! They had to build a custom piece in order to balance it correctly. So, tomorrow he said he will get the exhaust done. Today I finalized things with Ksport for my suspension. This is the first set of coil overs they have done on an MPS car in the states. Plus my custom requirements. I got a great price on them as well. Very excited about this getting finished.
![]() | | #76 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
| Not Ranked : 0 score Caught on to this a little late but subbed
__________________ Merkzda Speed 3. |
![]() | | #77 | ![]() |
![]() Join Date: Feb 2011 Location: Clarksville, TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,200
Groaned at 29 Times in 12 Posts
| Not Ranked : 0 score hope to see updates soon, My interest is at a all time high. Great job so far, looking forward to an complete summary after completion! Parts/Prices/Stats/Dyno. one of a kind. |
![]() | | #78 | ![]() |
![]() Join Date: Nov 2010 Location: Hoffman Estates IL
Groaned at 7 Times in 2 Posts
| Not Ranked : 0 score thats incredible goodluck
__________________ 2006 ms6 titanium grey - sold 2006 ms6 liquid platnium - Sold Tmic, Intake, Inlet pipe, Test Pipe, BPV, H.I.D. Fogs, Cobb Ap 2006 ms6 velocity red mica - daily driver 2005 c6 corvette black - daily driver |
![]() | | #79 | ![]() |
![]() Join Date: Jan 2010 Location: Downers Grove, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,309
Groans: 76
| Not Ranked : 0 score cannot waitt!! subbed good luck my man
__________________ '12 speed 3 CWP w/tech: DIZZY Tuned by Phate!,cobb AP,Autotech internals, cp-e nano, cp-e TIP, JBR 88 dogbone, JBR SSP/bushings, JBR rear sway bar, UR test pipe RIP '08 speed 3 silver cp-e 75 duro RMM, cp-e intake, cp-e TIP, Jbarone SSP and bushings. |
![]() | | #80 | ![]() |
![]() Join Date: Apr 2011 Location: Ukraine, Lviv
| Not Ranked : 0 score I will introduce first. I'm owner of Mazda 3MPS (European speed3). I own workshop here and working on AWD kit that can accept 500+whp. So all calculations and custom parts I make at military aircraft repair facility. Its not main project and main priority is quality and strength, so its build speed is slow. I'm not native english speaker, so sorry for language. Found your project some time ago, and come here to give you some help ![]() At first... wanna say this... Also you need better bushing there, stock one don't designed to accept such loads, and will break. Also your mistakes in addition: -lack of rear stabilizer -dangerous rear engine mount, it will break 99.9% -rear brakes from CX7 -one mount from rear diff cut off, it will lead to destruction of other mounts Maybe there are more, but I see these right now. I usually don't care, but if you wanna sell it to somebody, you must fix these things. You will be responsible for possible death of person who will drive it. Also some of mine progress... car... Transmission with transfer case... Rear brakes on custom plates Rear suspension Point on body that will be pushed by rear wheels... solid bushing there... custom made... P.S. What part # of billstein shocks you used (also will be good its length damped and full out), their dealer here is asshole, need to buy them at USA and pay delivery here. Last edited by Koya; 04-02-2011 at 01:45 AM. |
| The Following 9 Users Say Thank You to Koya For This Useful Post: | Cataphract_40 (04-10-2011), dizwhoadayjohn (04-02-2011), djuosnteisn (04-01-2011), Docnox (04-02-2011), IshiKage (04-05-2011), labikesrcool (04-06-2011), rghispanic88 (10-17-2011), Speed3eak (04-02-2011), The Great NY (04-05-2011) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/pt-5857-awd-58072/ | ||||
| Mazdaspeed 3 conversion 4 roues motrices avec un dessous de volvo c30 - Mazda 3 Quebec | This thread | Refback | 01-08-2013 05:19 AM | |
| RWD or AWD Speed 3? | This thread | Refback | 01-13-2012 12:23 AM | |
| ALL WHEEL DRIVE MAZDASPEED3 Rallye Car Concept | AWR Racing News | This thread | Refback | 01-01-2011 04:09 AM | |
