![]() | | #41 | ![]() |
![]() Join Date: Dec 2009 Location: camas valley
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,720
Groans: 40
| Not Ranked : 0 score and i don't think he even wound it up to 7000 did you do a vvt delete? good luck man
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan |
![]() | | #42 | ![]() |
| Not Ranked : 0 score I think the chain failures have more to do with the fuel pump being on the other side of the block and driven by the cam. That is a lot of torque to put on something so small.
__________________ |
![]() | | #43 | ![]() |
| Not Ranked : 0 score In for results. I want to play with higher rpms too.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
| The Following 3 Users Say Thank You to djuosnteisn For This Useful Post: |
![]() | | #44 | ![]() |
![]() Join Date: Jun 2010 Location: Ottawa
Rep Power: 617 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 526
| Not Ranked : 0 score Subs (This thread will either be Epic Win or Epic Fail) Either way, I like the project and really like how high you have set the bar.
![]() | | #45 | ![]() |
| Not Ranked : 0 score I guess the real risk comes in on whether or not you'll have interference the instant a valve floats.... When a valve floats... the power will fall off pretty damn fast, and it'll be easily noticeable on the dyno. So if / when i plan on playing with higher revs... i'm going to do it in like 100 rpm increments on a dyno.... and hope i simply just float a valve without doing any damage. Personally, i think 7500 is doable without any modification... but i have absolutely no factual info to back that claim up. It's 99% hopeful thinking.
| The Following User Says Thank You to djuosnteisn For This Useful Post: | xcoldricex (01-24-2011) |
![]() | | #46 | ![]() |
![]() Join Date: Nov 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 61
(Thread Starter) | Not Ranked : 0 score the tuner is going to go as high in the rpm as it will allow without breaking something. 8000rpm is too much for the work we are doing. we will take it to the limit before boom, will post up results, see what we get too .. this is a standard rebuild with bottom end balancing, valve springs.
__________________ Fuck the cunts, I make dreams come true... Last edited by Wilksy; 01-22-2011 at 06:10 PM. |
| The Following 2 Users Say Thank You to Wilksy For This Useful Post: | FreeFlyFreak (01-22-2011), xcoldricex (01-24-2011) |
![]() | | #47 | ![]() |
, so with valve springs and balancing this will be safe maybe 7200-7500rpm?
__________________ Fuck the cunts, I make dreams come true... Last edited by Wilksy; 01-22-2011 at 06:45 PM. | |
![]() | | #48 | ![]() |
Groans: 40
| Not Ranked : 0 score i dont think valve float will be a problem will the injectors be able to keep up? open and close 8.333 times per sec is that right?
| The Following User Says Thank You to rigor For This Useful Post: | FreeFlyFreak (01-23-2011) |
![]() | | #49 | ![]() |
![]() Join Date: Feb 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,452
Groans: 82
| Not Ranked : 0 score curiosity sub |
| The Following User Says NO Thank You to Speed3eak For This Un-useful Post: | mituc (03-17-2011) |
![]() | | #50 | ![]() |
| Miembro ![]() Join Date: Jun 2008 Location: Puerto Rico
Rep Power: 420 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,095
Groans: 27
| Not Ranked : 0 score when are you planning on testing these unknown waters?
__________________ 2008.5 MS3 Metro Gray...slow |
![]() | | #51 | ![]() |
![]() Join Date: Dec 2010 Location: Rio Rancho
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 496
| Not Ranked : 0 score in for win or fail!
__________________ ^^^My fail boats^^^ 2006 mazdaspeed 6: fujita CAI, PG TIP, Turbosmart dual BOV, ITV22, Corksprt TBE, Cobb AP, SURE front/rear diff mounts(FTW), whiteline RSB 1978 280z(s30): currently needs some love....and going turbo o.0 1990 300zx: 850cc injectors, 300degree fuel rail, aeromotive FPR, garrett gt 28's twin turbo upgrade(@19psi), stillen IC's, CZP's 3in dp and mid pipe, Selin dual intakes, GTR R32 brakes, Nismo clutch, HKS hi-power exhaust, megan coil-overs, SPL full titanium suspension parts, z1 boost tubes, 2 AEM AFR's, AEM boost guage RWHP:???? RWTRQ: 475@4500 rpm. needs new clutch(blown). 2008 350z HR: Greddy dual Ti-C, Carbonetics LSD, Nismo diff, GTM TP's, Stillen CAI's ![]() (waiting on full metal CSC and carbonetic clutch and light wieght flywheel, then it's TT time!) currently on hold due to needing new clutch and flywheel/metal csc and master. wanting skyline manifold. |
![]() | | #52 | ![]() |
(Thread Starter) | Not Ranked : 0 score cars at tuners now. hope to have it back 30th jan
__________________ Fuck the cunts, I make dreams come true... |
| The Following 4 Users Say Thank You to Wilksy For This Useful Post: |
![]() | | #53 | ![]() |
![]() Join Date: May 2009 Location: Clw/ NPR Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,516
Groans: 89
| Not Ranked : 0 score so the build is done ?? any pictures ?
__________________ [SIGPIC][/SIGPIC] 2013 EVO X GSR Wicked White w/Areo H&R springs/H&R 15mm spacers MAP modified 3" Magna Flow cat back MAP catless testpipe MAP UICP Grimmspeed 3 port Cosworth filter SSP relay kit TWM Desert Eagle shift knob AEM wideband gauge Prosport boost gauge EvoX piller pod 30%Tint Slowpoke Tuned 339hp/336tq **** SOLD ***** 2006 speed6 " A woman's asshole is like a 9-volt battery..U know its wrong, but sooner or later ur gonna put ur tongue on it !! " Last edited by jracer; 01-24-2011 at 06:31 PM. |
![]() | | #54 | ![]() |
| The Following 21 Users Say Thank You to djuosnteisn For This Useful Post: | AndyMS3 (06-10-2011), bombdotcom (02-01-2011), Chriscote (05-24-2011), DaleNixon (03-18-2011), Docnox (01-24-2011), doubleflusher (03-17-2011), Enki (01-24-2011), FreeFlyFreak (01-24-2011), I Love Brownies (01-24-2011), jracer (01-24-2011), jwilkins88 (03-18-2011), madvillain (01-24-2011), mdl3v8 (05-03-2011), MS3-a(sore)ASS-rex (03-18-2011), psychophyr (01-24-2011), rigor (02-01-2011), Scynfewl (03-27-2011), Snotrocket (05-15-2011), Speed3eak (01-24-2011), turd burglar (01-24-2011), WRX_Fan_0717 (04-22-2011) |
![]() | | #55 | ![]() |
Groans: 89
| Not Ranked : 0 score Hahahahaha.. Thanks DJ ..
__________________ [SIGPIC][/SIGPIC] 2013 EVO X GSR Wicked White w/Areo H&R springs/H&R 15mm spacers MAP modified 3" Magna Flow cat back MAP catless testpipe MAP UICP Grimmspeed 3 port Cosworth filter SSP relay kit TWM Desert Eagle shift knob AEM wideband gauge Prosport boost gauge EvoX piller pod 30%Tint Slowpoke Tuned 339hp/336tq **** SOLD ***** 2006 speed6 " A woman's asshole is like a 9-volt battery..U know its wrong, but sooner or later ur gonna put ur tongue on it !! " |
| The Following User Says Thank You to jracer For This Useful Post: | djuosnteisn (01-25-2011) |
![]() | | #56 | ![]() |
(Thread Starter) | Not Ranked : 0 score Car not ready yet, had trouble getting turbo delivered but will be taking it there tomorrow myself, parts from the machinists are coming soon has been a delay there as well. Like all mods not everything goes 100% to plan
| The Following 2 Users Say Thank You to Wilksy For This Useful Post: | djuosnteisn (02-01-2011), rigor (02-01-2011) |
![]() | | #57 | ![]() |
(Thread Starter) | Not Ranked : 0 score Turbo is at the workshop, parts form the machinist still delayed .
| The Following 3 Users Say Thank You to Wilksy For This Useful Post: |
![]() | | #58 | ![]() |
| Not Ranked : 0 score I've been saying that for a year now lol.
![]() | | #59 | ![]() |
Groans: 111
| Not Ranked : 0 score VVT delete + forged internals and you can probably do 8000-8200rpm. If you have a turbo that spools around 4000rpm and is breathless up until, say, at least 7500 - WIN.
![]() | | #60 | ![]() |
(Thread Starter) | Not Ranked : 0 score Had a set back with the bore being to worn for the stardard pistons. Oversize pistons will be here this week
![]() | | #61 | ![]() |
(Thread Starter) | Not Ranked : 0 score Update, engine will be back tomorrow, in the hands of the perfectionist Aaron at MPSG. Aaron will start putting it together.
![]() | | #62 | ![]() |
| Not Ranked : 0 score I just helped a local (jmhinkle) with his bt build, and we set his rev limit to 6900 rpm. He's been routinely bouncing off it several times since then. We'll probably keep walking it up to at least 7200 when we dyno tune. Stock block / stock valve train. Can't wait for some updates, Wilksy.
| The Following 4 Users Say Thank You to djuosnteisn For This Useful Post: |
![]() | | #63 | ![]() |
![]() Join Date: Oct 2008 Location: Greenbackville, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,927
| Not Ranked : 0 score K sub'd now awaiting more info
__________________ CP-E HPFpump™ CP-E 3" SS Cat Back Exhaust System CP-E 3" SS Downpipe System CP-E Rear Engine Mount CP-E XcelNANO™ Air Intake CP-E Nviscid™ Pipe CP-E Triple Gauge Pod Cobb AccessPORTv2 Cobb Anti Sway Bar(rear) Corksport TMIC PERM TUNED Forge bpv Eibach ProKit Prosport Wideband AFR Boost Oil Temp Oil Pressure JBR Shift Knob SunTek CarbonXP 30% around 2002 Mazda Protege5:AEM sri KYB gr2's DDM hid RIP |
| The Following User Says NO Thank You to jax ms3gt For This Un-useful Post: | mituc (03-17-2011) |
![]() | | #64 | ![]() |
(Thread Starter) | Not Ranked : 0 score Engine rebuilding will start tomorrow, should be all done by next weekend. The 1000k run in period will start after that ...
![]() | | #65 | ![]() |
![]() Join Date: May 2009 Location: Melbourne, Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
| Not Ranked : 0 score subn for interest here too edit: plus you should drive down to VIC for the bedding in process
__________________ 06 Black MPS3 Sport Pack - Australia edition Cobb AP (RichTune e85 / 98 maps) - Autotech HPFP Internals, JBR WP, CorkSport DP, Catback, Forge v1 BPV, Denso ITV22, PG FMIC Pipes JDM Core - TWM SS, PG Shift Weight, JBR Heavy Knob - JBR 88 Trilogy - JBR Rear Sway bar, Yellowspeed Coilovers, Centric Slotted/Drilled Rotors, Hawk HP+ pads, RX8 gen1 wheels - HTP Battery Tray - JBR EGR delete, JBR TB TIG - Spin-on oil convert - Polarised HU Screen EXE-Crew Last edited by KRNAGE; 03-17-2011 at 04:21 PM. |
| The Following User Says NO Thank You to KRNAGE For This Un-useful Post: | mituc (03-17-2011) |
![]() | | #66 | ![]() |
Groans: 111
| Not Ranked : 0 score For all those nutheads that are replying to a thread "subbing for .ick", please subscribe to the damn thread from the Thread Tools section that you can find at the top of EACH thread. I think that's mentioned in the forum rules too!
![]() | | #67 | ![]() |
__________________ Fuck the cunts, I make dreams come true... | |
![]() | | #68 | ![]() |
| Not Ranked : 0 score i best sign up to that then so i can see this beast............it will be finished by then right ![]() ![]()
__________________ 06 Black MPS3 Sport Pack - Australia edition Cobb AP (RichTune e85 / 98 maps) - Autotech HPFP Internals, JBR WP, CorkSport DP, Catback, Forge v1 BPV, Denso ITV22, PG FMIC Pipes JDM Core - TWM SS, PG Shift Weight, JBR Heavy Knob - JBR 88 Trilogy - JBR Rear Sway bar, Yellowspeed Coilovers, Centric Slotted/Drilled Rotors, Hawk HP+ pads, RX8 gen1 wheels - HTP Battery Tray - JBR EGR delete, JBR TB TIG - Spin-on oil convert - Polarised HU Screen EXE-Crew |
![]() | | #69 | ![]() |
![]() Join Date: Jun 2010 Location: li, merrick, new york
Rep Power: 2273 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,757
| Not Ranked : 0 score I'm also going to be high reving as well with my big turbo. Good to se u are doing it , It's the only way to run a real time in the car once u go big turbo, because even if u make the power on a dyno u move the power band up so high in the rpm that your power band isn't long enough to run a real time in the 1320. 4200 to 6700 isn't much of a power band considering if power starts to come in at 42 your not make good power till almost 5k . I think once people start reving these things they will be a force not to be messed with. |
![]() | | #70 | ![]() |
| Not Ranked : 0 score Baby steps too... big turbos like fuel.... and DI does not lend itself lightly to high rpm's. Increased fuel pressure will be key... and hopefully one day we'll have larger injectors... but til then... baby steps
| The Following 5 Users Say Thank You to djuosnteisn For This Useful Post: | Docnox (05-27-2011), i8urgti (04-15-2011), kmac (03-18-2011), madvillain (03-19-2011), MS3-a(sore)ASS-rex (03-18-2011) |
![]() | | #71 | ![]() |
| Not Ranked : 0 score I'm looking into the injectors with someone as we speak. The fuel pressure increase should be fine for now with meth or pick up injectors our biggest limitations as of now is not fuel. |
| The Following User Says Thank You to kmac For This Useful Post: | djuosnteisn (03-19-2011) |
![]() | | #72 | ![]() |
Groans: 31
| Not Ranked : 0 score Man, you guys are crazy, wanting stuff that flows this much. Cageyvet is already at about 500whp with stock in-tank pump and all that. So greedy, heh. Gimme 380 and I will be happy for a long time.
| The Following 2 Users Say Thank You to bmylez For This Useful Post: | kmac (03-18-2011), madvillain (03-19-2011) |
![]() | | #73 | ![]() |
| Not Ranked : 0 score Lol , I agree I luv how u are content with 380 considering in a speed3 what can u do with all that on the street anyhow . |
![]() | | #74 | ![]() |
Groans: 31
| Not Ranked : 0 score Well I think I'm barely at 300 at the moment. I'm already becoming discontented because 2nd gear doesn't always break loose that much. 380 would hit the spot. 3rd would spin most of the time. Over 500 is cool, but I'm realizing more and more how little you can use that power, haha.
![]() | | #75 | ![]() |
| Banned ![]() Join Date: Nov 2010 Location: Valley Park, Missouri
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26,461
Groans: 126
| Not Ranked : 0 score I'm also interested in this because I think that I'm going to be upping my rev limit. After I put my 35r on, I'll start raising it, me thinks. No point in doing it now since my turbo is maxed out |
| The Following User Says Thank You to jwilkins88 For This Useful Post: | djuosnteisn (03-19-2011) |
![]() | | #76 | ![]() |
(Thread Starter) | Not Ranked : 0 score Waiting on a call this week to let me know its running .. than its a 1000k run in and on the dyno ... not sure what rpm the first run will be? i feel they may keep it at 7000rpm. than get me to take it back after a few more k's are racked up for a lift in the rpm ( will know more later )
![]() | | #77 | ![]() |
Groans: 82
So... Wouldn't a t3 hotside help raise the limits? Or you just wanna go 35R because you're a G unit warrior and you want 550 on the stock internals? | |
| The Following User Says Thank You to Speed3eak For This Useful Post: | jwilkins88 (03-28-2011) |
![]() | | #78 | ![]() |
![]() Join Date: Mar 2010 Location: STL, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,038
Groans: 123
| Not Ranked : 0 score Awesome man very good stuff. Nice to someone doing this!
__________________ 2003 Evo VIII BUILD PLANS: LR 2.0/2.4, 6466, 800+whp. Shooting for 9s at full weight. Time is on my side, gonna take forever. Old: 2009 White MS3. Fully bolted and tuned. Sold |
![]() | | #79 | ![]() |
Groans: 126
| Not Ranked : 0 score Yes. I want to see where the stock block will pop, but I don't think I'll be able to do it on my turbo |
| The Following User Says Thank You to jwilkins88 For This Useful Post: | Speed3eak (03-28-2011) |
![]() | | #80 | ![]() |
Groans: 31
| Not Ranked : 0 score Well, I'm sure you could pop the block if you really wanted to...but I get what you're saying. I actually forgot that you were on ATP housing. That's very impressive. After weighing my options, I'm very tempted to get an ATP 3076, slap it on the stock manifold and see where 25psi gets me. I'm not that power hungry, but the k04 is just, bleh, up top.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/high-rpm-big-turbo-69185/ | ||||
| Race Cams!!! | This thread | Pingback | 06-30-2012 07:34 PM | |
| High RPM, Big Turbos - Page 2 | This thread | Refback | 02-20-2012 05:43 PM | |
| High RPM, Big Turbos | Post #1 | Pingback | 01-10-2011 04:15 AM | |
| Geneva 2010: Citroen DS High Rider rides in on its high horse | Haltech | Automotive News | 0 | 03-03-2010 07:30 AM |
| High Speed, High Fashion: Izod secures deal as IndyCar title sponsor | Haltech | Automotive News | 0 | 11-08-2009 03:40 PM |
| High strength studs for turbo (manifold to head and manifold to turbo) | bnoon | MazdaSpeed 3/6 - Turbo Induction | 4 | 03-11-2009 10:26 PM |
| Rumormill: Turbo & High-Tech Performance Magazine gets the axe | Haltech | Automotive News | 0 | 10-31-2008 06:30 AM |
