(Thread Starter) | Not Ranked : 0 score After all the cowl was removed we will still couldn't get the manifold back there. We then took some pliers and bend parts of the cowl up to give us even more room to get that manifold back there. Still no luck, so we removed the rmm bolt and put the jack under the motor and jacked it up so it would flex the motor forward to get the manifold in and sure enough that was the right combination to get that manifold on the manifold studs. After dropping the manifold back there we realized the nuts that that attach the manifold to the turbo wont screw on the studs because they were too big and running into the runners. We went out and bought some m10x1.50 allen cap bolts to try and clear the runners. After screwing with it for a while the manifold holes weren't matching up with the turbo. We took off the turbo bracket to give us some play to move the turbo around to line up with the manifold and get them threaded correctly and not at an angle to clear the runners. After much deliberation of keeping the stock turbo back there to do some manifold testing of several different manifolds available to us and after the hassle to get the manifold back there we just ended up saying lets put the bt in since installing the manifold was not an easy task. On to pictures and comments of what we had to do to get this set up to work. Here is what is going in the car at the start of the day Got all the lines attached to the new turbo. This is the coolant hard line you reuse from the k04 that has to be bent to fit. Make sure a prep the turbo and by prep I mean hook up all the lines prior to installing it. Side by side comparison stock/cpe Clamp your coolant lines before you pull your k04 so coolant does go every where. Now drop in the new turbo and put all four studs in prior to get the manifold to line up correctly. You can gently rest the turbo back there it will sit back there on plenty of stuff without being held up by hand. This pic shows it attached with the oil drain connected. This was the clearance issue we had with the cpe manifold. To get it to clear you have to rock the motor. (rmm removed) Here is another one of me pointing out where we were hitting the fire wall. Once the manifold is in had tighten the nuts but if the stud is to far up the nut wont go over the stud so you have to lower the pull the turbo up by tightening the studs. To get to these nuts you will need a stubby 15mm. Next is hooking up the oil/coolant lines. Here is a picture of the oil feed without the bolt in it. This bolt is a pain in the ass to get in sometimes so a small trick is take you 9/16 short socket and fill it with paper towels almost all the way to the top. This will help from letting that banjo bolt slide up in the socket and make it more difficult to get that bolt started. Dont forget to put one washer below the oil feed and one on top. You can take a screw driver slide the crush washer on it and use it as a guide to get it to slide down onto the turbo cause there is very little room to use your hands. Here is a picture with the oil feed installed. One thing on the cpe mani with the ewg runner it blocks the first 02 bung so we opted to use the second one to house the 02 sensor. This picture shows where the original bung was plugged. We just reversed them. After the turbo was in connect the coolant feed to the egr. Next up was going to do the ewg setup at the bottom of the car. Attach the low profile elbow before the turbo goes in the car but dont tighten it as you have to move it around to pass the dp. This low profile is only needed with cpe down pipes as they have a different design. Next take apart your ewg and put the correct springs to achieve desired spring pressure. All done plug all your holes that you dont need. We opted for the spring combo of 17.4. You can find the spring chart on tial.com Attach the ewg to the low profile in the car. To get it to clear it will look something like this. after that clamp the dump tube to the ewg this is running out the bottom of the car. Here is JP doing some work with a huge smile on his face. If you guys have any other questions or need anymore pictures let me know I took a bunch but feel free to ask any other questions! A big thanks to @mtnrunner for all the help man! |
| The Following 75 Users Say Thank You to EdgeAutosport.com For This Useful Post: | 06Speed6 (03-05-2012), 801MS3 (03-06-2012), Adam is so pro (03-08-2012), ak_spray (03-05-2012), Atlanta (03-06-2012), atvfreek (03-05-2012), AZSPEED3 (03-05-2012), BlueStreak (03-05-2012), bmylez (03-05-2012), BobbleHead (03-14-2012), breakfstincluded (03-05-2012), BrianB6 (03-15-2012), Broxer (03-05-2012), ckMS3 (03-05-2012), daafisch (03-05-2012), djuosnteisn (03-14-2012), Downmented (05-29-2012), essejkcamraw (03-05-2012), Fail_6 (03-05-2012), Fobio (03-05-2012), FreeFlyFreak (03-10-2012), GunGuru727 (03-06-2012), Hamilton69 (03-05-2012), helmetface (03-05-2012), i8urgti (03-09-2012), Ingle (03-06-2012), IshiKage (03-14-2012), jmhinkle (03-05-2012), josurr (03-05-2012), jracer (03-05-2012), justinspeed3 (03-06-2012), kgb (03-05-2012), KILLER_VIZ (03-05-2012), Lakespeed6 (03-05-2012), Manny3 (03-05-2012), MattJackson86 (03-11-2012), mayer (03-06-2012), memin (03-05-2012), mike0122 (03-06-2012), MS3-a(sore)ASS-rex (03-05-2012), ms3bamf (03-05-2012), mtnrunner (03-05-2012), Naaman (03-05-2012), nycMS3 (03-07-2012), Oliverms3 (03-05-2012), p057 (03-05-2012), PapaSmurf (03-05-2012), predapio (03-05-2012), Pseud0logik (03-05-2012), psychophyr (03-05-2012), QwkEVO (03-05-2012), RayRay (03-05-2012), RedBliss (03-05-2012), rghispanic88 (03-05-2012), RichieRichness (03-06-2012), rigor (03-05-2012), SarcasticOne (03-06-2012), Seaton (03-06-2012), skeurton (03-05-2012), SleeperHatch (03-10-2012), SLOWHATCH (03-05-2012), superskaterxes (03-05-2012), SweetJP (03-06-2012), taf0422 (03-05-2012), thehead (03-05-2012), thepatient77 (03-05-2012), TiGraySpeed6 (03-06-2012), triplejumper18 (03-05-2012), TRSpeed (03-05-2012), turbo test (03-05-2012), Vader (03-05-2012), wankular (03-05-2012), warlord (03-05-2012), xdm88 (03-05-2012), zpele (03-05-2012) |
![]() Join Date: Nov 2010 Location: Annapolis, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,335
Groans: 45
| Not Ranked : 0 score Why not GTX? |
| The Following 3 Users Say Thank You to Vader For This Useful Post: |
| The Following 9 Users Say Thank You to EdgeAutosport.com For This Useful Post: | 06Speed6 (03-05-2012), atvfreek (03-05-2012), BobbleHead (03-14-2012), DEVAST8R (03-06-2012), djuosnteisn (03-14-2012), IshiKage (03-14-2012), manelscout4life (03-05-2012), taf0422 (03-05-2012), Vader (03-05-2012) |
![]() Join Date: Jun 2009 Location: Denver Colorado
Rep Power: 2697 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,601
| Not Ranked : 0 score yay!! Turbos for everyone!!
__________________ 2008 MGM MS3 GT - HTA3586- - P.E.R.M Twisted Top Mount - - P.E.R.M. Fifth/Sixth Port Injection - - P.E.R.M. Tuning - |
| The Following 7 Users Say Thank You to JacksonMS30 For This Useful Post: | BobbleHead (03-14-2012), Ckmazdaspeed3 (03-06-2012), djuosnteisn (03-14-2012), EdgeAutosport.com (03-05-2012), manelscout4life (03-05-2012), MS3-a(sore)ASS-rex (03-05-2012), Vader (03-05-2012) |
![]() Join Date: Jul 2011 Location: Aurora, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,419
Groans: 81
Groaned at 30 Times in 25 Posts
| Not Ranked : 0 score wow. so the cp-e manny was not designed correctly? I mean from what i gather its a huge pain for it to be just a drop in manifold...
__________________ 2004 mazda 3-Daily 2008 mazda 6-Wife 2008.5 Mazdaspeed 3 totaled 1983- FB Rx-7 Soon to be boosted Carb epicness Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler |
| The Following 11 Users Say Thank You to J-Liss For This Useful Post: |
![]() Join Date: Jul 2010 Location: Lunenburg Mass
Rep Power: 2310 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,516
| Not Ranked : 0 score Great job. How long did the install take. Can't wait to get mine in!
__________________ 2006 Black MS6 531HP 486TQ FREEKBUILT -- FreekTune BW S300sx 62mm -- Twin TIAL 38mm EWG -- Perm Top Mount Twin Scroll Turbo Manifold -- Perm 4" Intake TR1035FMIC -- JBR TB and IM thermal spacers -- JBR OCC -- Bosch 3.5 Bar MAP -- Greddy BOV-- CP-E Injector seals Perm Downpipe -- 3" Magnaflow CBE -- Autotech Fuel Pump Internals -- Grimmspeed EBCS -- NGK Iridium Ported Head and Intake Manifold -- Snow Performance Meth Injection D10 and D12 -- balance shaft delete -- EGR delete ACT 6 Puck -- ISC Coilovers -- Sure Torq R6 -- Sure Juggernaught -- Sure Dreadnaught -- Sure Anchors -- Sure Shift Knob 2006 CWP MS6 313HP 319TQ FreekTune ATP GTX3076r -- TIAL 38mm EWG -- HTP 3" Intake System -- CPE Single Exit Exhaust-- ATP Catless Down Pipe CPE Differential Mount -- CPE Top Mount Intercooler -- JBR 80D Trilogy Mount Package -- Grimmspeed EBCS Autotech Internals -- Bosch 3 Bar Map Sensor -- Bit Wise Plug n Play -- GFB Hybrid BOV Bilstein Struts -- H&R Sport Lowering Springs -- Cobb v3 -- e85 1990 Nissan Skyline GTR ![]() 1991 White BMW 325ic Scorpion catback -- Short shifter -- Bilstein HD -- HR Springs -- Intake -- NRG Wheel -- Chassis and strut tower brace -- Sway bars |
| The Following User Says Thank You to Lakespeed6 For This Useful Post: | EdgeAutosport.com (03-05-2012) |
The install total was about 8-10 without running to the store for parts and other things.
__________________ ![]() Click here to check out some clearance items were getting out of here! There are some great deals in here! Last edited by EdgeAutosport.com; 03-05-2012 at 01:14 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following 4 Users Say Thank You to EdgeAutosport.com For This Useful Post: |
Groans: 224
| Not Ranked : 0 score Great write up Eric and congratulations to JP on BT!
| The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post: | EdgeAutosport.com (03-05-2012) |
![]() ![]() Join Date: Jul 2008 Location: Old Bridge NJ
Rep Power: 22834 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,276
Groans: 309
| Not Ranked : 0 score Who's 4 fingers McGee?
__________________ Dash08: I don't see the whole pedophile thing, But Predapio is a dirty old bastard. So, I wouldn't rule it out entirely. That's also why he fits in here. We're all a bunch of filthy, perverted, arrogant, pessimistic, self-righteous assholes who find entertainment at other peoples expense. What a lovable bunch we are!! |
| The Following User Says Thank You to predapio For This Useful Post: | EdgeAutosport.com (03-05-2012) |
![]() Join Date: Aug 2008 Location: Ashburn, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 305
| Not Ranked : 0 score Why won't someone run the tial flanged mani and turbo with this? I want to see that.
__________________ 2006 Black Mica MS6 - Sold 10/15 |
| The Following User Says Thank You to shadesofgray19 For This Useful Post: | EdgeAutosport.com (03-05-2012) |
(Thread Starter) | Not Ranked : 0 score @mtnrunner lol
__________________ ![]() Click here to check out some clearance items were getting out of here! There are some great deals in here! Last edited by EdgeAutosport.com; 03-05-2012 at 01:24 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following 3 Users Say Thank You to EdgeAutosport.com For This Useful Post: |
![]() Join Date: Nov 2008 Location: Fitchburg, Mass.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 118
| Not Ranked : 0 score Awesome write up! Especially cause i have this almost exact same combo coming in shortly from you guys and will be doing this install soon. That mani seems like its a big pain in the balls!
__________________ 2010. GTX3071R. CPE Fail Mani. Tial 44 EWG. CPE Xcelxl Big Intake. CPE FMIC. AT HPFP Internals. CPE DP. UR CBE. GS EBCS. Forge V2 BPV. Sure Shortcut. Sure AGS. H&R Springs. Prosport Boost Gauge. M'z Lip Kit. Plaid Interior. FREEKTuned. Daily Driver 1990 Rx7 T2. Custom GT3574R. Aspec Mani EWG Tial 44. 3mm Apex Seals. Full BDC Large Street Port. BDC TB. Aspec DP. Racing Beat TBE. Greddy FMIC. Haltech E6K Full Standalone. GM 3Bar Map. FD UIM. Greddy Elbow. Desmond Regamasters 17x8F 17x9R Weekend Warrior. |
| The Following User Says Thank You to RedBliss For This Useful Post: | EdgeAutosport.com (03-05-2012) |
![]() Join Date: Jul 2011 Location: Santa Fe, NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score Ha finally jp went bt! His face is priceless ha
__________________ [SIGPIC][/SIGPIC] 1992 miata, track beast here I come with 2 bride seats!! (current)3076r speed6 owner (traded) 2000 camaro 415rwhp thru midwest chassis fab (sold) |
| The Following User Says Thank You to ColonR For This Useful Post: | EdgeAutosport.com (03-05-2012) |
(Thread Starter) | Not Ranked : 0 score Its really not that bad but when you remove that center bolt in the rmm it does wonders to get it to fit. Its acutally really easy after that. |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | RedBliss (03-05-2012) |
(Thread Starter) | Not Ranked : 0 score Here are more pics of the entire build. |
| The Following 10 Users Say Thank You to EdgeAutosport.com For This Useful Post: | 801MS3 (03-06-2012), djuosnteisn (03-14-2012), jmhinkle (03-05-2012), Lakespeed6 (03-05-2012), Manny3 (03-05-2012), mayer (03-06-2012), Mortose (03-05-2012), TiGraySpeed6 (03-06-2012), wankular (03-05-2012), zpele (03-05-2012) |
![]() Join Date: Mar 2011 Location: Hampton, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28,760
| Not Ranked : 0 score Nicely done! Did you end up putting the turbo bracket back in? Or did you just leave it out?
__________________ 2011 MAZDASPEED 3 BNR: 352 hp / 342 ft-lbs K04: 296 hp / 343 ft-lbs BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges |
| The Following User Says Thank You to skeurton For This Useful Post: | EdgeAutosport.com (03-05-2012) |
![]() Join Date: Mar 2009 Location: Portlandia, Oregano
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,295
Groans: 196
| Not Ranked : 0 score Wow, a lot changed after I went home.
__________________ |
| The Following 2 Users Say Thank You to triplejumper18 For This Useful Post: | breakfstincluded (03-05-2012), EdgeAutosport.com (03-05-2012) |
![]() | | #19 | ![]() |
| Not Ranked : 0 score You have a final pic with it all back together?
| The Following User Says Thank You to JacksonMS30 For This Useful Post: | EdgeAutosport.com (03-05-2012) |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yup we missed you. Next time dont leave so early lol Like and engine bay shot? I dont but I will go get one here in a bit.
__________________ ![]() Click here to check out some clearance items were getting out of here! There are some great deals in here! Last edited by EdgeAutosport.com; 03-05-2012 at 02:00 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #21 | ![]() |
Groans: 196
| Not Ranked : 0 score If I would have left later I probably wouldn't have enjoyed my chat with the 5-0.
| The Following 2 Users Say Thank You to triplejumper18 For This Useful Post: | EdgeAutosport.com (03-05-2012), jmhinkle (03-05-2012) |
![]() | | #22 | ![]() |
or just a pic of yourself would be fine...
__________________ 2008 MGM MS3 GT - HTA3586- - P.E.R.M Twisted Top Mount - - P.E.R.M. Fifth/Sixth Port Injection - - P.E.R.M. Tuning - | |
| The Following 2 Users Say Thank You to JacksonMS30 For This Useful Post: | EdgeAutosport.com (03-05-2012), manelscout4life (03-05-2012) |
![]() | | #23 | ![]() |
(Thread Starter) | Not Ranked : 0 score Lol ok I will get it. The only thing we didnt finish was the cowl, it was late and we were tired I heard. that sucks I will see you this sat again at cascade
__________________ ![]() Click here to check out some clearance items were getting out of here! There are some great deals in here! Last edited by EdgeAutosport.com; 03-05-2012 at 02:06 PM. Reason: MSF Database - Automerged Doublepost |
| The Following 2 Users Say Thank You to EdgeAutosport.com For This Useful Post: | JacksonMS30 (03-05-2012), triplejumper18 (03-05-2012) |
![]() | | #24 | ![]() |
![]() Join Date: Jan 2012 Location: Laruel,MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,453
Groaned at 8 Times in 7 Posts
| Not Ranked : 0 score I had to remove the bolt to get my BT mani on as well I thought it was just a Genpu thing |
| The Following User Says Thank You to The Panda For This Useful Post: | EdgeAutosport.com (03-05-2012) |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score What bolt man? |
![]() | | #26 | ![]() |
![]() Join Date: May 2009 Location: Scottsdale, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,450
| Not Ranked : 0 score Are those color-coded sockets? Bitchin!
__________________ 2009 MS3 sport MGM |
| The Following User Says Thank You to wankular For This Useful Post: | EdgeAutosport.com (03-05-2012) |
![]() | | #27 | ![]() |
| Not Ranked : 0 score in for rainbow socket set. Manifold looks like a bitch to install.. I cant wait to start working on my car again.
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost |
| The Following 2 Users Say Thank You to PapaSmurf For This Useful Post: | EdgeAutosport.com (03-05-2012), Manny3 (03-05-2012) |
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score They are indeed. Gotta have my rainbow sockets ![]() It was tough but do able. Nothing like the twin scroll ahahaha
__________________ ![]() Click here to check out some clearance items were getting out of here! There are some great deals in here! Last edited by EdgeAutosport.com; 03-05-2012 at 03:14 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #29 | ![]() |
![]() Join Date: Jul 2011 Location: hesperia, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 295
| Not Ranked : 0 score Finally JP!! and damn everyone is going BT this month lol. Also I where is my turbo!!!! lol and I have the cpe dp withOUT a second bung, wtf do i do! This is ridiculous why would cpe make a mani that doesnt fit there own DP.
__________________ 2008.05 True Red Mazdaspeed3 Lex Tuned GTX3071r | 38mm Tial WG | Hallman MBC Cobb AP E85 30% |CPE Big MAF | CPE Big TIP | CPE FMIC | SS Ex Mani | CPE Catted DP | CNT CBE | CPE Triple Gauge Pod | Autotech HPFP Internals | Denso ITV22 | TS BPV | TWM ShortShifter | JBR Shifter Bushings | JBR 88 RMM | Razo Heavy Shift Knob | 20% Tint | DDM 55W HID | Hankook Ventus V12 | H&R Springs |
| The Following 6 Users Say Thank You to TRSpeed For This Useful Post: | 06Speed6 (03-05-2012), EdgeAutosport.com (03-05-2012), fishin53 (03-05-2012), Manny3 (03-05-2012), mayer (03-06-2012), triplejumper18 (03-05-2012) |
![]() | | #30 | ![]() |
| Not Ranked : 0 score Manifold wasent the issue...well kinda.. sanding down the EWG bungs was a bitch... so was bending that damn coolant hard line... lol
| The Following User Says Thank You to PapaSmurf For This Useful Post: | EdgeAutosport.com (03-05-2012) |
![]() | | #31 | ![]() |
![]() Join Date: Jan 2010 Location: charles co, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,295
| Not Ranked : 0 score The next time you guys do a manifold install take the manifold studs out. I think it is a torx 8-10 can't remember and then change them to bolts this way when you lift the manifold up you dont have to push it towards the firewall first then up. That way you dont bend or cut up the cowl doing any of this. If you dont want to pull the studs then you can just pull the RMM and the Passenger side mount (the bolts that bolt it to the body only) and slide the motor forward and you can get the manifold out that way. Good luck on your install. I am really thinking about selling my steedspeed top mount to get the CPE manifold but i have heard nothing but horror stories for the install so far..
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport |
| The Following 4 Users Say Thank You to qtrmile beast For This Useful Post: | Broxer (03-05-2012), Ckmazdaspeed3 (03-06-2012), EdgeAutosport.com (03-05-2012), TiGraySpeed6 (03-06-2012) |
![]() | | #32 | ![]() |
__________________ ![]() Click here to check out some clearance items were getting out of here! There are some great deals in here! Last edited by EdgeAutosport.com; 03-05-2012 at 03:50 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #33 | ![]() |
| Not Ranked : 0 score mmm slipped right in.
| The Following 2 Users Say Thank You to PapaSmurf For This Useful Post: | EdgeAutosport.com (03-05-2012), jmhinkle (03-05-2012) |
![]() | | #34 | ![]() |
| v8 convert ![]() Join Date: Sep 2009 Location: (actually in) Tampa, FL
Rep Power: 1203 ![]() Thanks: 2,634
Groans: 220
| Not Ranked : 0 score I have to install this weekend... by myself. How hard is it to bend that line?
| The Following User Says Thank You to p057 For This Useful Post: | PapaSmurf (03-05-2012) |
![]() | | #35 | ![]() |
![]() Join Date: Apr 2011 Location: Millsboro, De
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,597
| Not Ranked : 0 score Looks great!! That CP-e manifold is sex. They just need a top-mount now.
__________________ 2006 Mazdaspeed 6 GT-unDISI swap in progress 1969 Nova-540BBC-S400's-TH400-sitting on 29.5x10.5 Skreets be calling... [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to BobtailedSnail For This Useful Post: | EdgeAutosport.com (03-05-2012) |
![]() | | #36 | ![]() |
(Thread Starter) | Not Ranked : 0 score Your talking about the one that attaches to the turbo? That one is very very easy he is talking about the big coolant line that has to be bent for t3 setups.
__________________ ![]() Click here to check out some clearance items were getting out of here! There are some great deals in here! Last edited by EdgeAutosport.com; 03-05-2012 at 04:11 PM. |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | p057 (03-05-2012) |
![]() | | #37 | ![]() |
| Not Ranked : 0 score [QUOTE=eric@edgeautosport;1294766]Honestly get another bung welded in down stream where the dp isnt cast which would be my recommendation. If thats not an option get a full race manifold ![]() Full race is 1100 that's ridiculous. Even of its still 900 that's crazy. I know it great but its still able to get cracks especially with a ewg gtx30. Fuckin CPE. I already bought a ton of there shit now I have to modify there own dp or just get a different manifold Sent from my DROID4 using Tapatalk
| The Following User Says NO Thank You to TRSpeed For This Un-useful Post: | Snyeed (03-06-2012) |
![]() | | #38 | ![]() |
(Thread Starter) | Not Ranked : 0 score Wait why will you have to modify your cpe dp? |
![]() | | #39 | ![]() |
| Not Ranked : 0 score I was talking about the big coolant line that runs over the transmission. Not the lines off the turbo. My turbo sat so low that I couldnt fit my 3.5 inch intake on without bending the coolant that runs to the firewall.
| The Following 3 Users Say Thank You to PapaSmurf For This Useful Post: |
![]() | | #40 | ![]() |
| Not Ranked : 0 score I don't have 2 bungs on my DP Sent from my DROID4 using Tapatalk
| The Following User Says Thank You to TRSpeed For This Useful Post: | EdgeAutosport.com (03-05-2012) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/edgeautosport-shop-car-goes-bt-107114/ | ||||
| Going BIG - Page 5 | This thread | Refback | 03-05-2012 04:33 PM | |
| EdgeAutosport.com Demo Car | JP@edgeautosport.com | EdgeAutosport.com | 44 | 04-30-2012 12:40 PM |
| Thank-you EdgeAutoSport.com | NavySailorMS3 | EdgeAutosport.com | 15 | 03-16-2012 07:19 PM |
| EdgeAutosport | scorpiorc10 | Gen2 MS3 General Discussion | 24 | 03-03-2012 12:16 AM |
| EdgeAutosport.com!!!!! | neofandango | Gen2 MS3 General Discussion | 10 | 12-07-2011 06:11 AM |
