Like Tree6Likes
  • 3 Post By Cobb Tuning
  • 1 Post By Monotonous ONE
  • 1 Post By MSMS3
  • 1 Post By Vansquish
 Old 07-12-2012, 05:36 PM   #1
Cobb Tuning's Avatar
Posts: 1,192   (View Stats)
Default COBB Adjustable Internal Wastegate Brackets Now Available
COBB Tuning is proud to announce the availability of an innovative new pair of Internal Wastegate (IWG) Brackets for Subaru and MAZDASPEED vehicles in short and long bracket styles. The COBB Tuning Adjustable IWG Bracket is the first of its kind, and the most versatile and reliable way to keep a turbocharger’s internal wastegate closed when using an external wastegate setup. The Adjustable IWG Bracket can be installed quickly, adjusted for perfect fitment on many different turbos, and can be removed just as easily to return a turbo to its original configuration.
The COBB Adjustable IWG Bracket replaces the internal wastegate actuator and locks the wastegate in a fully closed position. This is a superior solution to welding the wastegate door closed, which is a time-consuming, expensive and irreversible process. The COBB Adjustable IWG Bracket is easy to install and bolts into place and adjusts quickly using simple hand tools.
Not all turbos are made exactly the same, and there can be variations in housings, center cartridges, clocking, etc. A single position internal wastegate bracket may not accommodate these variations and fail to close the wastegate completely, which will result in poor turbo response and lower maximum boost. The COBB Adjustable IWG Bracket takes the worry of turbo-component variance out of the equation and allows proper adjustment, every time, on a variety of different turbos that a non-adjustable internal wastegate bracket simply cannot match.
The COBB Adjustable IWG Bracket’s advantage lies in its unique adjustable rod-end linkage. The turnbuckle center section features right-hand and left-hand threads to make adjustment as easy as rotating it one direction or the other to shorten or lengthen it. The rod-end linkage and through-bolt allow high misalignment for maximum adjustability. The bracket itself is made from a single piece of 11-Gauge steel and incorporates slotted bolt holes for additional adjustability and turbo compatibility. The custom spade-bolt that connects to the wastegate arm, the bracket, and the turnbuckle are black zinc coated for an attractive finish that is corrosion resistant. All hardware for install is included in this kit.
The COBB Tuning Adjustable IWG Bracket offers maximum turbo compatibility, simple installation and is easily adjustable to ensure complete wastegate closure to get the maximum performance from your specific setup. In the familiar words of our dads, “Make sure you shut the ****ed door!”
Part #: 512273
MSRP: $39.00
Applications: Click Here
Part #: 512274
MSRP: $39.00
MAZDASPEED EXPERT GROUP
- ADAM HILL | MIKE MCGINNIS | RYAN LAMBERTH | CHRIS MOUNTAIN | MARSHALL GLASGOW
COBBTUNING.COM | LIKE US ON FACEBOOK | SEARCH KNOWLEDGE BASE | EMAIL CUSTOMER SERVICE
The Following 19 Users Say Thank You to Cobb Tuning For This Useful Post:
Black Metal (08-10-2012), breakfstincluded (07-12-2012), ckMS3 (09-07-2012), Coaststarlight (07-14-2012), daafisch (07-13-2012), EdgeAutosport.com (07-13-2012), jracer (07-12-2012), Monotonous ONE (07-12-2012), mtnrunner (07-13-2012), Realgib3 (07-14-2012), rfinkle2 (07-13-2012), RichieRichness (07-13-2012), silvapain (07-12-2012), skeeter149 (07-12-2012), SleeperHatch (07-13-2012), SLOWHATCH (07-12-2012), superskaterxes (07-13-2012), themytb (07-13-2012), Vader (07-13-2012)
 Old 07-12-2012, 05:44 PM   #2
Snyeed's Avatar
Posts: 743   (View Stats)
Groaned at 8 Times in 4 Posts
I could have used this 5 months ago! killer piece.
417whp 428tq 12.037@117.2mph
 Old 07-12-2012, 06:35 PM   #3
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Will Cobb ever bring some exhaust manifolds to the market?
I keep hearing Cobb wants to step away from mechanical parts which is a shame. Most mechanical parts you put out are better than the ebb and flow ghetto shit other vendors spew out. And MSF has had a few of those.
I don't think you can go wrong bringing out complete bolt on kits with EWG manifolds and V-band downpipes for GT30 series turbos. No reputable vendor makes that.
The Following 4 Users Say Thank You to Tomas For This Useful Post:
breakfstincluded (07-12-2012), Dano (07-13-2012), Nliiitend1 (07-12-2012), Stormtrooper6 (07-12-2012)
 Old 07-13-2012, 01:52 AM   #4
SleeperHatch's Avatar
Posts: 3,138   (View Stats)
Subbed...I need this bad buying very soon
Sent from my Evo LTE
2009 CWP Speed3
 Old 07-13-2012, 02:03 AM   #5
COOL STORY BRO
Hamilton69's Avatar
Posts: 2,418   (View Stats)
Hamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the world
Groans: 179
Groaned at 179 Times in 30 Posts
fucking sick! very inovative part guys, great idea!
JBR 3.5" WHALE PENIS-su tmic- sure track urethane rmm- corksport catless 3" downpipe- ultimate racing tp-OBX 3" cat back -rally armor urethane flaps-Cobb Accessport FINKLE TUNED-sure shift anchors-autotech hpfp internals-HKS BOV VTA -jbr heavy shift knob- 245-40-r18 Falken 329's-paint matched uber smiley
ZOOM ZOOM BOOM
Hamilton69 is offline   Reply With Quote
 Old 07-13-2012, 02:17 AM   #6
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Wow nice thinking Cobb! This is why I love Cobb!
Sent from my iPhone using lame ass Tapatalk
 Old 07-13-2012, 04:19 AM   #7
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
remember when everyone hated cobb? lol
they fucking kick ass now
The Following 2 Users Say Thank You to Monotonous ONE For This Useful Post:
rfinkle2 (07-13-2012), trf5000 (07-13-2012)
 Old 07-13-2012, 05:52 AM   #8
mason's Avatar
Posts: 946   (View Stats)
COBB ROCKS!
 Old 07-13-2012, 09:58 AM   #9
Master of Hard Parts
Evan@COBB's Avatar
Posts: 240   (View Stats)
Evan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the world
Groaned at 8 Times in 2 Posts
Whaaa? You never hated COBB. Don't lie
Hard Parts Engineer - Mazda Expert Group
2009 MS3 Sport - Built Motor//Twinscroll 35R//Everything Else - SOLD!
2008 Toyota Tacoma TRD Sport 4x4 - Current Daily Until Next Turbo Car
Evan@COBB is offline   Reply With Quote
 Old 07-13-2012, 10:00 AM   #10
Groans: 819
everyone did when cobb was like "yo...you guys are meanies...so were gonna stop supporting the platform now"
Dano (07-13-2012)
 Old 07-13-2012, 11:58 AM   #11
We certainly learned a lot from that experience. We are thrilled that the MAZDASPEED community has allowed us to move past that and get back to making great parts and happy customers.
- Gary
The Following 4 Users Say Thank You to Cobb Tuning For This Useful Post:
Black Metal (08-10-2012), Dano (07-13-2012), dton13 (07-16-2012), mason (07-16-2012)
 Old 07-13-2012, 12:15 PM   #12
ORDERED! Can't wait to get it on
2009 CWP Speed3
 Old 07-13-2012, 12:18 PM   #13
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
We still hate Gary.
Beanfab / Tuned by Nishan
The Following 3 Users Say Thank You to doubleflusher For This Useful Post:
Dano (07-13-2012), I<3Groceries (07-13-2012), Monotonous ONE (07-13-2012)
 Old 07-13-2012, 12:22 PM   #14
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
looks way better than a coat hanger...lol..not that I have ever done that....
 Old 08-10-2012, 04:24 PM   #15
The COBB Tuning Adjustable IWG Bracket is the best way to keep your wastegate door closed when running an EWG setup. We have confirmed fitment on many popular turbo options, but you can help us grow that list! First, just order the Adjustable IWG Bracket for your application directly from us and install it on your turbo. If the bracket doesn't fit, just take advantage of our 30 Day Satisfaction Guarantee.html for a full refund. If the bracket does fit, just be the first person with your turbo fitment confirmation to email IWGfitment@cobbtuning.com with a few pictures, your shipping address, and shirt size for a complimentary COBB Tuning Tee. If you have any other questions, just email us or call 866-922-3059.
 Old 09-05-2012, 02:21 PM   #16
ckMS3's Avatar
Posts: 1,112   (View Stats)
Going to try this out with the bnr. Hopefully all goes well.
Edit: This product worked great keeping the iwg closed. Great product thanks Cobb !
348tq/367whp -21.5 psi
The Following User Says Thank You to ckMS3 For This Useful Post:
atvfreek (09-05-2012)
 Old 08-02-2019, 08:08 AM   #17
pieceofpuu's Avatar
Posts: 19   (View Stats)
pieceofpuu is on a distinguished road
Anyone installed this yet on the BNRS3? Making sure fitment is 100% before purchase
pieceofpuu is offline   Reply With Quote
The Following User Says Thank You to pieceofpuu For This Useful Post:
MSMS3 (08-10-2019)
The Following User Says NO Thank You to pieceofpuu For This Un-useful Post:
Vansquish (08-02-2019)
 Old 08-02-2019, 08:10 AM   #18
Police - Grammarhead
Vansquish's Avatar
Seriously? Did you read the post immediately before your own?
MSMS3 (08-10-2019)
 Old 08-02-2019, 08:43 AM   #19
pieceofpuu's Avatar
He just said 'BNR' that could mean any BNR turbo lol.. not all turbo housings are the same...
The Following 3 Users Say NO Thank You to pieceofpuu For This Un-useful Post:
Db09ms3 (08-02-2019), MSMS3 (08-10-2019), Vansquish (08-02-2019)
 Old 08-02-2019, 08:52 AM   #20
Vansquish's Avatar
You clearly can't read.
LOOK IN HIS FUCKING SIGNATURE.
Last edited by Vansquish; 08-02-2019 at 08:52 AM. Reason: MSF Database - Automerged Doublepost
MSMS3 (08-10-2019)
 Old 08-02-2019, 08:54 AM   #21
pieceofpuu's Avatar
What does it say????? GTX? I can't see!
Calm down keyboard warrior
The Following 2 Users Say NO Thank You to pieceofpuu For This Un-useful Post:
MSMS3 (08-10-2019), Vansquish (08-20-2019)
 Old 08-02-2019, 10:20 AM   #22
Db09ms3's Avatar
Posts: 536   (View Stats)
You could easily navigate to their website you keyboard princess
Stockish
The Following 2 Users Say Thank You to Db09ms3 For This Useful Post:
 Old 08-02-2019, 10:03 PM   #23
pieceofpuu's Avatar
keyboard princess checking in
I did research it actually, Cobb mentions it fits most turbo housings for the mazda/subaru. If some fucker in here said 'Yes, it works with the S3', i'd call myself out for asking lol.
Classic MSF community though, somebody asks a non retarded question about an IWG bracket and someone's asshole tightens up, classic. Night ladies
 Old 08-10-2019, 07:43 AM   #24
MSMS3's Avatar
Posts: 2,826   (View Stats)
Reading comprehension impaired “non-retard” retard throws down in epic battle with forum moderator! “Keyboard warrior”?
What is it about “BNR S3” in the sig and “this product works great” that you can’t see or read after mod points it out twice?
This ought to be interesting. Let’s get out the popcorn!
Db09ms3 likes this.
 Old 08-10-2019, 08:52 AM   #25
Db09ms3's Avatar
Bless your heart
Stockish
The Following User Says Thank You to Db09ms3 For This Useful Post:
 Old 08-20-2019, 01:53 PM   #26
pieceofpuu's Avatar
a forum moderator.. am I supposed to be afraid?
1) his post was old, could've been using a different turbo at the time, so boo hoo I asked if it worked
2) nobody mentioned it worked on an s3
3) smd
 Old 08-20-2019, 02:18 PM   #27
Vansquish's Avatar
Sure, why not?
His post specifically said he was going to try it with "the bnr." The S3 is mentioned specifically in his signature, and the S3 is by far the most commonly swapped aftermarket BNR turbo for this platform. Sure, the post was old. The last time ckMS3 was even on the forum was 3+ years ago. If you'd bothered to take a beat, read, and learn, you wouldn't have ended up being such a pretty pretty princess on here.
In effect, ckMS3 did, as we've been pointing out to your reading-comprehension-challenged ass.
3) smd
Agreed. Why not drop this idiocy? You keep dredging up inane bullshit instead of actually doing anything useful for yourself or the forum.
MSMS3 likes this.
monkey.bones.007 (08-20-2019), MSMS3 (08-21-2019)
Is my internal wastegate broke? jiveturkey MazdaSpeed 3/6 - Troubleshoot/Diagnostics 28 07-22-2012 02:28 PM
COBB Adjustable Internal Wastegate Brackets Now Available Cobb Tuning 2010 MS3 - Big Turbo Builds 8 07-13-2012 10:38 AM
Adjustable Wastegate SRHTX Gen2 MS3 General Discussion 6 04-09-2012 12:18 PM
can you utilize and internal AND external wastegate? TWOptSL0W MazdaSpeed 3/6 - Big Turbo Builds 2 07-14-2011 09:29 PM
the ultimate internal wastegate cbspeed3 MazdaSpeed 3/6 - Turbo Induction 2 09-12-2008 02:40 PM
Page generated in 0.46708 seconds with 35 queries
