Like Tree54Likes
 Old 09-07-2015, 02:27 AM   #201
EmPeEs6's Avatar
Posts: 642   (View Stats)
EmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the world
That would mean a theoretical capacity of 480 bhp. My S3 is able to flow enough for 370-380 awhp/450 bhp, so the power gains wouldn't be huge. Moreover it spools ~1000 rpm later and may require additional fueling. It's a great deal for those wanting to upgrade from stock to some GT30 turbo, but where's the great benefit comparing to the S3 (considering the long development period for the S4 and the fact that a GTX3076 gererates significant more airflow)?
Mods: BNR S4, 3" Ray cb, CP-E catted dp, CS 3" intake, CP-E tmic, D06-wmi, itv22/NGK IX plugs, Forge bov, hpfp-upgrade, JBR ebcs, 3 bar map sensor, egr block off kit, ACT 6 pad clutch with SL flywheel, Wiseco oem compression pistons, Manley H-Beam connecting rods, reworked head, CP-E SafeSeal injector seals, no E85, Cosworth thermostat
EmPeEs6 is offline   Reply With Quote
The Following User Says Thank You to EmPeEs6 For This Useful Post:
74te27 (08-09-2016)
 Old 09-07-2015, 02:40 AM   #202
RPM
RPM's Avatar
Posts: 1,149   (View Stats)
There's something wrong with either the chart or your calculations. It's already been proven to produce ~475hp (at the wheels) at 27 PSI, spooling to 20 PSI by ~3700 RPM.
SamiChicago likes this.
The Following 5 Users Say Thank You to RPM For This Useful Post:
BackRoads (09-07-2015), bigspender (02-01-2016), EmPeEs6 (09-07-2015), ItsNox (09-07-2015), joeyspeed3 (09-07-2015)
 Old 09-07-2015, 02:56 AM   #203
EmPeEs6's Avatar
Thank's for the clarification! In this case it's a real improvement over the S3.
 Old 09-07-2015, 09:19 AM   #204
joeyspeed3's Avatar
Posts: 82   (View Stats)
joeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant futurejoeyspeed3 has a brilliant future
It looks like a great turbo. I might sell my s3 and get one of this
2013 CWP Mazdaspeed3
Bnr S3 v2//Cobb AP//Autotech internals//3 BAR MAP sensor//3 port EBCS//CNT catback//Ebay catless DP//Tr8 core with cxracing piping kit//Hks bpv//Jbr True 3.5" intake//Jbr ssp//Jbr shift knob//Jbr Trilogy//XXR 527 habanero 18x8.75 +35//H&R springs//385/370 AWD mustang dyno
joeyspeed3 is offline   Reply With Quote
 Old 09-07-2015, 05:13 PM   #205
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
370awhp ~ 463bhp
380awhp ~ 475bhp
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
 Old 09-08-2015, 02:23 AM   #206
EmPeEs6's Avatar
370awhp ~ 463bhp
380awhp ~ 475bhp
I always use this calculator for the conversion:
Wheel Horsepower to Crankshaft Horsepower Guestimator
BTW: Why do you make "only" 370 whp on a GTX3076 - knock limitations due to poor fuel quality or insufficient fuel supply?
I would really like to try out this S4 turbo, but I without port injection (which makes another 2-3k including suitable intake manifold and installation) I will probably end up at the same power level as now (S3+E85) and just suffer from the much later spool...
 Old 09-08-2015, 02:48 AM   #207
Groans: 33
I'm still on stock block and stock fueling system lol. Was knock limited at 23psi and 13* timing on 25/75 E85/91. I would recommend a 5/6th port aux fuel system. Then you don't need an expensive PI manifold. They are around $900 for two injectors. Stratified will hopefully release their setup soon! @Lex; ???
Mazdaspeed6 -06
290 AWHP / K04
Alpha (09-08-2015)
 Old 09-08-2015, 04:33 PM   #208
Alpha's Avatar
Posts: 3,711   (View Stats)
Nice! Seems close to the EFR7163 flow wise then... Just with a 1000 rpm more lag to hit 20 psi. Sounds killer for stock style manifold guys.
 Old 09-17-2015, 04:16 PM   #209
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
Who needs traction? Not fun trying to hold the phone. Lol. Didnt have the gopro on me at the time
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
The Following 3 Users Say Thank You to taf0422 For This Useful Post:
BackRoads (09-17-2015), MD1032 (09-17-2015), SpeedRebirth (09-17-2015)
 Old 09-17-2015, 04:19 PM   #210
BackRoads's Avatar
Posts: 575   (View Stats)
BackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the worldBackRoads is the leader of the world
Looks like, what, about a 5-sec 0-60?
Without hardly trying?
2007 Sunlight Silver MazdaSpeed3 Sport | BNR S3v2 | Autotech Internals | Cobb TIH | 3BAR MAP Sensor | Denso itv-22's | MSCAI | ETS 3.5" TMIC | Synchronic DV | Stratified EBCS | Guardian Angel | UR Test Pipe | Cobb AP | Koni Yellows | JBR RMM | CORN YEAH! | 265,000m | Tuned by STRATIFIED!!!
To install: CPE SafeSeals
2012 Velocity Red MazdaSpeed3 w/Tech | Autotech Internals | Sure Aeros V2 | 98,000m
Last edited by BackRoads; 09-17-2015 at 04:19 PM. Reason: MSF Database - Automerged Doublepost
BackRoads is offline   Reply With Quote
 Old 09-17-2015, 10:29 PM   #211
taf0422's Avatar
Groans: 192
Lol. It goes by quickly. Need to grab with a go pro and actually give it a legit shot. Just noticed that was with the traction control on too.
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 10-04-2015, 11:28 AM   #212
EmPeEs6's Avatar
@RPM; Any news about the current production state, i.e. when will the pre-ordered turbos be ready to ship?
 Old 10-04-2015, 11:49 AM   #213
RPM
RPM's Avatar
He said he'd be working on them this week, so I expect all of the pre-orders to make it out by the end of the week.
The Following 4 Users Say Thank You to RPM For This Useful Post:
EmPeEs6 (10-04-2015), MS3Shadow (10-04-2015), SamiChicago (10-21-2015), The Nut (10-04-2015)
 Old 10-04-2015, 03:26 PM   #214
The Nut's Avatar
Posts: 1,571   (View Stats)
Unless i misread the timer on the video, it was in the 4's. And that was with wheelspin.
2012 BLACK MICA w/TECH
91 & Corn diagnostics by:
 Old 10-21-2015, 07:09 AM   #215
SamiChicago's Avatar
Posts: 289   (View Stats)
SamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the world
Looks like I'll be ordering the S4 since my S3 have some metal shavings inside thanks to my busted motor.
'07 MS6: HTP 3 Inch Intake.Cobb AP.CorkSport CBE.ATP DP.FMIC.AutoTech Internals.Bosch 3 Bar map sensor.GRIMMSPEED 3 PORT EBCS. BNR S4.WISECO 9:5 pistons. Manley H-Beam rods. Keyed Crank by APEX. SouthBend Stage 3 clutch kit. Bilstein shocks. H&R Springs.
SamiChicago is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/bnr-s4-159450/
My first build. - Page 3 - DFW Mazdas This thread Refback 07-23-2015 09:46 AM
Page generated in 0.37497 seconds with 28 queries
