Rep Power: 7118 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,203
(Thread Starter) | Not Ranked : 0 score Did we mention these are warrantied for life and guaranteed never to rust or break??!! If this wasn't already pretty awesome, these are now the standard bushings and brackets included with EVERY JBR sway bar kit. We know how tired everyone is having to replace broken sway bar brackets every year. NO MORE!! Details: No more cheap, rusted and broken yellow zinc coated sway bar brackets. JBR Sway Bar Bushings and Bracket kits are the toughest in the industry! First, they're laser cut out of .180" thick stainless stainless steel which will never rust. This is nearly twice as thick as the typical bracket. They're then die formed using our own proprietary tooling that guarantees a perfect fit every time. After forming, each bracket is then tapped to accept a grease fitting making maintenance simple and easy. Included with every pair of JBR brackets are a set of 90a durometer bushings available in the most common OEM and aftermarket sizes. Once you have these installed, you'll never need to replace your sway bar brackets or bushings again. Available Applications:
Don't see your application? Contact us, we probably have it. Features:
The JBR Tru-Torsion Sway Bar Bracket Kit Includes:
| The Following 4 Users Say Thank You to JBR For This Useful Post: | Code Monkey (12-28-2016), mazdaspeedmyk (12-30-2016), redneck4Christ (12-29-2016), [R]usty (12-28-2016) |
![]() Join Date: Sep 2012 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,205
| Not Ranked : 0 score Good price point. Will get these if my prothane brackets break.
__________________ 2010 Mazdaspeed3 w/tech Cobb AP V3 ║ JBR Tru 3" Wide Path ║ JBR Boost Tubes & BPV Hose ║ Cobb XLE BPV ║ CP-E TMIC ║ UR Racepipe ║ Magnaflow CBE ║ AutoTech Internals ║ GrimmSpeed EBCS ║ JBR RSB ║ SPC Camber Arms ║ KW V3 Coilovers ║ JBR IM+TB TIGs & TB Bypass ║ JBR SSP ║ E - Focus RMM ║ StopTech Slotted Rotors and EBC Yellow Stuff Pads ║ Techna-Fit SS Brake Lines |
| The Following User Says Thank You to [R]usty For This Useful Post: | kolosok17 (12-28-2016) |
![]() Join Date: Oct 2012 Location: Sunnyvale, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,206
| Not Ranked : 0 score Nice! Ditto on what Rusty said. The sway bar has been squeaking lately, perhaps I should have a look down there.
__________________ 2012 CWP Non-Tech MS3 JBR SSB, Mazda Rear Bumper Guards, JBR Mud Flaps, JBR 88a RMM, Mazda All-Weather Floor Mats, COBB AP V2B, JBR RSB with Tru-Torsion brackets, Autotech Internals, CorkSport SRI+TIP, JBR Stage 2 OCC, Mazda Rear Cargo Tray, Stratified S-OTS+ Stage 1 Map, NATOR NorCal Sticker |
![]() Join Date: May 2012 Location: FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 62
| Not Ranked : 0 score Thanks for making these standard with new purchases.
__________________ 12' black mica w/tech: BNR S4 V2; CM STG 2 WMI; DAMOND TB SPACER; GUARDIAN ANGEL V3; KOZMIC OCC; CP-E SAFE SEALS; DAMOND EGR DELETE; WHITEWIDOW INTAKE GASKET; Cobb AP V3 CP-E Xcel XL SRI; CP-E 4" TIP; CP-E Catted DP; CP-E Cat-back exhaust; CP-E TMIC; Cobb BPV; JBR EBCS; Cobb RMM; CorkSport HPFP internals; JBR turbo hoses; NGK (6510) LTR7IX-11 Iridium IX Spark Plugs; JBR short shifter; JBR Small battery tray; Optima 51r Battery Rice--CorkSport interior lights and carbon fiber hood scoop ETH/METH tune by Stratified in progress |
| The Following User Says Thank You to flyhigh For This Useful Post: | JBR (12-29-2016) |
![]() Join Date: Jul 2011 Location: Virginia Beach, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 473
| Not Ranked : 0 score Are you shitting my face right now...I just replaced the bushing/brackets Front and rear like a month ago..Doh! Looks good, will buy in future when my knuckles have healed from the last go around.
__________________ Speed 6 Gone for 3+ years and still not happy about it 2007 Speed 3. JBR 3" WP. AP. Autotechs. Full Maize. CP-E Stage 2 RMM, Rubber Filled OEM TMM, Nator'd TP, Moog's and DM SSP Enki - "High mixes of corn = all the wastegate all the time for great justice." |
| Not Ranked : 0 score What size should I order for: Rear Sway Bar Kit - Black Item# MS3RSB-BLK The 1.125"/28.5mm ones?
(Thread Starter) | Not Ranked : 0 score No, our rear sway bar is 1.25"/32mm as indicated in the drop down. |
| Not Ranked : 0 score Thanks, Jamie! Going to put in an order. The original ones finally failed.
| Display Modes | |
| New Product Release - JBR Tru-Torsion Billet Sway Bar Brackets and Bushings | JBR | JAMES BARONE RACING | 87 | 01-24-2015 05:35 PM |
| JBR Rear Sway, Brackets, MOOG End-Link Fitment Issue | Teal | JAMES BARONE RACING | 9 | 09-23-2014 06:39 PM |
| How many MS6's are tired of broken axles? | 2nr | MazdaSpeed 3 - Engine, Transmission & Driveline | 13 | 10-25-2008 07:29 AM |
