Who's tired of broken yellow zink sway bar brackets? Who wants inexpensive high quality replacement bracket and bushing kits that will never rust or break and carry a lifetime warranty? Look no further!! JBR now has our own line of replacement sway bar bushings and brackets for most all aftermarket front and rear sway bars. We also stock replacements for many OEM sway bars too!! Did we mention these are warrantied for life and guaranteed never to rust or break??!! If this wasn't already pretty awesome, these are now the standard bushings and brackets included with EVERY JBR sway bar kit. We know how tired everyone is having to replace broken sway bar brackets every year. NO MORE!! Details: No more cheap, rusted and broken yellow zinc coated sway bar brackets. JBR Sway Bar Bushings and Bracket kits are the toughest in the industry! http://www.jamesbaroneracing.com/sho...T-Brackets.JPG First, they're laser cut out of .180" thick stainless stainless steel which will never rust. This is nearly twice as thick as the typical bracket. They're then die formed using our own proprietary tooling that guarantees a perfect fit every time. http://www.jamesbaroneracing.com/sho...rackets_04.JPG After forming, each bracket is then tapped to accept a grease fitting making maintenance simple and easy. http://www.jamesbaroneracing.com/sho...rackets_03.JPG Included with every pair of JBR brackets are a set of 90a durometer bushings available in the most common OEM and aftermarket sizes. http://www.jamesbaroneracing.com/sho...rackets_05.JPG Once you have these installed, you'll never need to replace your sway bar brackets or bushings again. Available Applications:
Don't see your application? Contact us, we probably have it. Features:
The JBR Tru-Torsion Sway Bar Bracket Kit Includes:
Good price point. Will get these if my prothane brackets break. |
Nice! Ditto on what Rusty said. The sway bar has been squeaking lately, perhaps I should have a look down there. |
Thanks for making these standard with new purchases. |
Are you shitting my face right now...I just replaced the bushing/brackets Front and rear like a month ago..Doh! Looks good, will buy in future when my knuckles have healed from the last go around. |
What size should I order for: Rear Sway Bar Kit - Black Item# MS3RSB-BLK The 1.125"/28.5mm ones? |
Quote:
1 Attachment(s) Quote:
| All times are GMT -7. The time now is 02:13 AM. |
