  • 1 Post By mrmonk7663
 Old 06-29-2013, 07:05 PM   #1
MechEnix's Avatar
Posts: 186   (View Stats)
MechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond reputeMechEnix has a reputation beyond repute
Default Stripped sub-frame nut during RSB install
So as the title suggests, I stripped the bastards, the two closer to the ground. (Jamie I already e-mailed you in a panis fyi). I had the torque wrench set to 50, and it never clicked so I kept pushing and then bam, no resistance. I got the one out but there is still one stuck in there, so i need to figure out how to get that out. I'm pretty bitter I flubbed up a car with 3500 miles on it.
I'm thinking I need to get a helicoil kit, and maybe two new bolts, I've hear their M8 grade 8 with pitch 1.25 threads/mm? Does anyone know what spec they are, and what helicoil kit to get for the nuts. Or should I pay someone to grind it off and weld a new nut on?
% Current Mods = JBR 88 RMM // Ultimate Racing Axleback // JBR RSB // Corksport Internals // JBR Stage II SRI // Cobb AP V3 // UR Race Pipe
% Next up = Custom Tune
MechEnix is offline   Reply With Quote
 Old 06-29-2013, 07:12 PM   #2
motherfnmonsta's Avatar
Posts: 2,308   (View Stats)
Groans: 106
picture of said fail
 Old 06-29-2013, 07:14 PM   #3
Kamaril's Avatar
Posts: 909   (View Stats)
Kamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the worldKamaril is the leader of the world
Groans: 77
Use an extractor imo and replace bolts. I just replaced a RSB bracket bolt today. M10 1.25 x30mm bolt should do
2011 MS3 BLACK MICA W/TECH PACKAGE
BNRSv3 - COBB 3 Port Boost Controller - BOSCH 3 Bar MAP Sensor - HTP 3" Intake (Candy Red)- CS Downpipe - CS LED Fog Lights - CS Interior LED Kit - CS Hood Strut Kit - COBB AccessPORT - JBR Adjustible Rear Sway Bar - JBR Solid Shifter Bushings - SURE Flow M3 W/ Res Delete - MangnaFlow 4x3.5" Stainless Exhaust Tips - AutoTech Internals - JBR 88a Dogbone RMM - H&R Lowering Springs - NGK Iridium Step Colder - Beachshoer's Pnp Intake Manifold W/ VTCS Delete - TurboSmart Plumb Black BPV - CX Racing FMIC - 18x8 Bronze MB Motoring Battles - Nitto Motivo 235/40/18 - Hawk HPS Brake Pads - Block8head Dual Gauge Pod - Prosport Evo Boost and Coolant Temp Gauges - Autodvdgps Touch Screen DVD Player W/ Navigation - CS Radiator Cover - CS Exhaust Manifold Cover - CS OCC
Stratified Tune In Progress
SCCA Member# 450495
Class - SMF
TRMotorsport C3 17x9 Hancook 255/245 RS-3
LIQUOR AND WHORES
Kamaril is offline   Reply With Quote
 Old 06-29-2013, 07:20 PM   #4
Got your email...are the nuts stripped, bolts broke or both?
 Old 06-29-2013, 07:21 PM   #5
Kamaril's Avatar
Groans: 77
stirpped nuts? ouch!
SCCA Member# 450495
Class - SMF
LIQUOR AND WHORES
 Old 06-29-2013, 07:21 PM   #6
MechEnix's Avatar
Here's the pic, and I think it's the nut that's stripped, not the actual bolt. I'll post a bolt pic in a minute too.
 Old 06-29-2013, 07:27 PM   #7
MechEnix's Avatar
And here are the 3 bolts I managed to remove, I may need to replace the two. But, judging from the one I was able to remove, it is most likely the nuts that are stripped not the bolts, unfortunately. A quick glance at the shop manual said to torque these bolts between 30 and 40 ft lb, any reason why the aftermarket RSBs say 50?
 Old 06-29-2013, 07:31 PM   #8
Kamaril's Avatar
Groans: 77
That top bolt looks like the threads are crushed
SCCA Member# 450495
Class - SMF
LIQUOR AND WHORES
 Old 06-29-2013, 07:32 PM   #9
If it's the bottom 2, I think you can drill them and use a nut and a longer bolt.
 Old 06-29-2013, 07:39 PM   #10
MechEnix's Avatar
There may be enough bolt sticking through, that a nut and washer could suffice, I'd have to go out and check first. However, it would probably be wise just to just bolts with some grip length. A helicoil seems like the most legit way, are you sure they're M10 bolts?
 Old 06-29-2013, 07:42 PM   #11
Kamaril's Avatar
Groans: 77
i used the bolt and thread pattern at ricezone(autozone) to make sure the bolt was correct. Matched mine perfectly. M10-1.25 x30mm fit like stock
SCCA Member# 450495
Class - SMF
LIQUOR AND WHORES
 Old 06-29-2013, 08:17 PM   #12
MechEnix's Avatar
So helicoil it is, anything I need besides two new bolts, a helicoil set, tap wrench, thread lube, drill bit?
What would be the best way to get this bolt out?
 Old 06-29-2013, 08:29 PM   #13
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
This happened on a friends car. There was enough room to put a bolt, a lock washer, and a nut on there...we didn't have to do anything to the thread. We screwed the bolt in with whatever remaining thereads were left in the stock welded nut, then put a lock washer and nut on it with some blue Loctite. This is a permanent fix and cost a whopping $2. I don't know what length bolt we use...we just got a few from Lowes.
Kamaril likes this.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 06-29-2013, 08:36 PM   #14
MechEnix's Avatar
Maybe I'll just do this for now, and go with a more "stock" looking fix when it's time to trade in. Now I just need to figure out how to get this last bolt out.
 Old 07-03-2013, 07:32 AM   #15
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
Judging by that shaving, it appears if you in fact cross threaded that specific bolt. Be careful when doing tightening any bolts, and make sure not to cross thread them or you will end up like this.
700HP CLUB
11.479@124mph
#DIX
 Old 07-03-2013, 10:14 AM   #16
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
Groans: 56
I did the exact same when I tightened mine. Set the wrench at 40 lb/ft and they stripped before it clicked; The original owner may have fucked them though. In my case it was the bolts, not the nuts.
I'm going to simply try new bolts first; if they don't hold I'll put nuts behind the welded ones.
Needed: Driver mod
 Old 07-03-2013, 10:19 AM   #17
MechEnix's Avatar
I don't think I crossthreaded them, I started them by hand and they were nice and flush when tightening them down. I think it was simply a matter of overtorquing and crushing the threads.
BigRed: unfortunately for me the car only has 3500 miles on it, so there was no other retard to mess it up before hand, just myself. I wish I had waited for a nice used MS3 instead of going new, cheaper and allows me to have no qualms over modding.
 Old 07-03-2013, 10:19 AM   #18
Kamaril's Avatar
Groans: 77
Last night I checked and torque the replacement bolt I installed to @jbarone; recommended 50ftlbs. Felt like they were going to snap but they didn't. (thank fuck).
SCCA Member# 450495
Class - SMF
LIQUOR AND WHORES
 Old 07-03-2013, 10:24 AM   #19
Groans: 56
Anything that can be rectified by adding two new nuts is pretty damn low on the Fuck-Up-O-Meter. Consider it a learning experience.
Needed: Driver mod
 Old 07-03-2013, 10:52 AM   #20
MechEnix's Avatar
True, but I like things to be perfect.
 Old 04-24-2014, 02:13 PM   #21
manila's Avatar
Posts: 1,767   (View Stats)
Any luck? My dumbass just did this. @MechEnix;
'12 MS3 Black Mica w/ Tech
trancehead (04-25-2014)
 Old 04-24-2014, 04:09 PM   #22
MechEnix's Avatar
Yea, just grab a new locking but and throw that sucker over the other nut. Hopefully you have enough threads. One of these days I'm going to get under there and take a grinder to the welded nut.
Sent from my Galaxy Nexus using Tapatalk
 Old 04-24-2014, 05:24 PM   #23
manila's Avatar
Shit should have got a locking nut instead...
 Old 04-25-2014, 10:13 AM   #24
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
Nylon locking nuts are the best damn thing ever invented for shit like this ... and red loctite
I would not even consider helicoils as removing the old nut and putting a new one or even putting it over the old nut will hold much much stronger, i would not want a helicoil that can break free
 Old 04-25-2014, 10:22 AM   #25
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
I drilled and retapped the top one. I had a locking nut up there but it was a huge PITA to maintain for someone who lives in the Midwest with our stupid weather patterns (and salt). Also AutoX seems to make it squeak faster.
2012 Velocity Red Mica
 Old 04-25-2014, 10:37 AM   #26
manila's Avatar
Thanks man! I'm def going to pick some up.
The top left RSB bolt is restricting me to get a nut behind. Not too much room to work with and hold a nut while getting the bolt in.
*Forgot to mention I stripped more than one of the welded nuts
 Old 04-25-2014, 06:15 PM   #27
Dimenus's Avatar
Groans: 33
Thats why I drilled and re tapped it. Much swearing occurred to even get a nut up there.
Tappin'
 Old 04-25-2014, 07:03 PM   #28
manila's Avatar
Tappin'
Did you have to drop the rear springs and control arm to get enough room to get a drill in there?
 Old 04-25-2014, 09:21 PM   #29
Dimenus's Avatar
Groans: 33
Nope.
 Old 11-15-2014, 03:59 PM   #30
Tweaek's Avatar
Posts: 319   (View Stats)
Tweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the worldTweaek is the leader of the world
Tappin'
My bracket broke and the bolt was a bitch to get out. I ordered new brackets from @jbarone; (great customer service again). Well went to install them today and sure enough putting the bolt back in was tight, them get towards the end and I stripped the bolt and the nut. @Dimenus;, did you use a heli-coil to repair yours? Of course mines the top one as well.
Tweaek is offline   Reply With Quote
 Old 11-17-2014, 10:38 AM   #31
Dimenus's Avatar
Groans: 33
No. I just drilled it to 12MM. I don't think a helicoil will hold that kind of force tbh.
 Old 11-17-2014, 09:16 PM   #32
Tweaek's Avatar
Thanks. I was thinking that would be the case.
@jbarone;, can your brackets handle a 12mm or am I going to have to drill that out as well?
 Old 11-18-2014, 10:41 AM   #33
Brackets will need to be drilled.
Tweaek (11-18-2014)
Stripped Transmission Stud? SubyGF 2010 MS3 - Engine, Transmission & Driveline 13 08-12-2016 09:12 AM
M2 downpipe install stripped bolt going to mani Chicagospeed6 MazdaSpeed 6 - Engine, Transmission & Driveline 3 11-09-2012 09:15 PM
Subframe threads stripped for RMM 09ms3gt MazdaSpeed 3 - Engine, Transmission & Driveline 5 03-19-2011 07:22 PM
Fix for a stripped RMM holding nut BeeZaa 2010 MS3 - Engine, Transmission & Driveline 7 02-23-2011 09:47 PM
stripped bolt haskms3 MazdaSpeed 3 - Engine, Transmission & Driveline 6 12-20-2010 04:23 PM
Page generated in 0.51761 seconds with 31 queries
