Like Tree22Likes
 Old 06-11-2014, 01:44 PM   #41
Puddin15's Avatar
Posts: 49   (View Stats)
Puddin15 has much to be proud ofPuddin15 has much to be proud ofPuddin15 has much to be proud ofPuddin15 has much to be proud ofPuddin15 has much to be proud ofPuddin15 has much to be proud ofPuddin15 has much to be proud ofPuddin15 has much to be proud of
Originally Posted by sho View Post
I wouldn't worry about excessive oversteer on the street unless you're driving way faster than you should be. I have an RSB that is a bit stiffer than this one, and I've daily driven it for the past 75k miles at 2030lb/in on the rear bar for that time.
The back end will kick out at autox on throttle lift, while turning hard... but even during aggressive driving on the street, it's nothing crazy as long as you stay on throttle.
I'm asking in regards to handling on a road course, not on the street. This bar is a bit overkill for someone that doesn't track their car.
Open track days is this Friday and I'm on the stock RSB, so I imagine I will be picking one of these up very soon.
Puddin15 is offline   Reply With Quote
 Old 06-12-2014, 06:09 AM   #42
Evan9999's Avatar
Posts: 75   (View Stats)
Evan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud of
Originally Posted by MOCO MS3 View Post
Evan you running slicks? Also are you going to change the setting to medium or full stiff?
Yep, I'm running those Hoosier slicks. I'm going to keep the bar on the least stiff setting for a little bit. I might change it after the Toledo autocross. The course is normally pretty fast at Toledo so I don't want too much oversteer. I would like to get the new JBR front sway bar once it's released and I'll probably use the stiffest setting on the rear sway bar with the front bar on there.
I agree, this bar is definitely overkill if you don't do any track/autocross. I'm hoping to do a track day at Mid-Ohio in a month or 2. So I'll be able to comment on the bar's track performance after.
2009 True Red Mazdaspeed3 GT
Mazdaspeed Coilovers, Cobb AP V2, Corksport SRI w/ TIP, Autotech HPFP, Red Line MT-90, TWM Big Type-R Shift Knob,
DBA 4000 T3 Rotors, Carbotech AX6 Brake Pads, Corksport SS Brake Lines, Wilwood EXP 600 Brake Fluid, Synapse BPV,
CXRacing FMIC, JBR Trilogy Mounts (80 duro), JBR .250 Competition Rear Sway Bar, JBR Short Shift Plate
Evan9999 is offline   Reply With Quote
The Following 2 Users Say Thank You to Evan9999 For This Useful Post:
Chief_Wiggum (06-13-2014), Mauro_Penguin (06-12-2014)
 Old 09-08-2014, 10:09 AM   #43
MOCO MS3's Avatar
Posts: 644   (View Stats)
Well finally had the opportunity to put the Fat Boy through it's paces this weekend @ Mid-Ohio at a PCA event where I was instructing. All I can say is that if you track your car, this bar is a MUST! Mid-Ohio is a very technical track, with high speed turns, elevation changes and this bar handled everything that the track trew at it.
I placed the bar in the middle setting for my sessions and it did not disappoint, actually exceeded my expectations. The car felt like it was on rails, throughout every section on the track! Coming thru turn #1 and heading into the Chicane ( turns #2 & #3 ), the car was firmly planted and rotated like a champ. Heading into the Keyhole, again, the car rotated perfectly and set me me up for the long back straight, where speeds hit between 130-140.........settng up for the entrance to Madness (esses), the car remained settled and balanced coming up and over, heading for the Honda Bridge and Thunder Valley.
Again, the car rotated perfectly, throughout the entire course and with every lap, I had more confidence in pushing the car, lap, after lap, session, after session. I would highly recommend this bar for anyone who spends any significant time auto-xing or particpates in HPDE's! If it can handle Mid-Ohio, it can handle any Road or Auto-X Course!
Well worth the money and stood up to a lot of hard driving!
The Following 6 Users Say Thank You to MOCO MS3 For This Useful Post:
Chief_Wiggum (09-08-2014), Evan9999 (09-08-2014), Gr8Speed (09-08-2014), NoRegrets (09-08-2014), Puddin15 (09-08-2014), RusianKid (12-30-2014)
 Old 09-08-2014, 12:29 PM   #44
Puddin15's Avatar
Thanks for the review MOCO MS3, this solidifies my decision. Are you running the stock end links with this bar?
MOCO MS3 likes this.
 Old 09-08-2014, 02:57 PM   #45
MOCO MS3's Avatar
I am running Tri-Points Adjustable End links. Tri Point has been sold, but I know the person that designed them, he may build more.
New Product Release - JBR Tru-Torsion Billet Sway Bar Brackets and Bushings JBR JAMES BARONE RACING 87 01-24-2015 05:35 PM
Product Release! CorkSport Mazdaspeed 6 Front Sway Bar CorkSport CorkSport 0 08-30-2012 12:10 PM
Product Release! CorkSport Mazda 2 Front Sway Bar CorkSport CorkSport 0 11-07-2011 11:00 AM
New Product release. Speed 6 rear mount medieval MazdaSpeed 6 - Engine, Transmission & Driveline 22 04-24-2009 09:12 PM
Page generated in 0.27386 seconds with 23 queries
