Like Tree13Likes
 Old 06-23-2014, 11:26 AM   #1
Arrow New Product Release!! JBR Reverse Lock-Out Gate Guide (07’-09’) MAZDASPEED 3
The JBR Reverse Lock-Out Gate Guide is essential if you own a GEN 1 Mazdaspeed 3. After only a few thousand miles the OEM plastic gate guide will show wear from dragging the reverse lock-out peg. This wear is caused by the sharp reverse lock out peg being dragged against the guide during normal shifting from 1st to 2nd gear. Once the wear begins slop in the shifter becomes even worse than when the shifter was new! 1st and 2nd gears are the two most often used gears and wear happens fast.
Significant wear of the OEM guide can lead to there being no reverse lock-out. This can lead to a dangerous situation for the driver as well as accidental costly damage to the transmission.
The JBR Reverse Lock-Out Gate Guide is constructed out of .125" indestructible stainless steel plate to protect the OEM plastic guide. The sharp OEM peg has no chance of digging in and wearing through it!
The added .125" also reduces the side to side slop in the shifter and makes shifting in to 1st and 2nd buttery smooth again.
The cost of replacing the whole shifter cage runs hundreds of dollars. Now, there's a inexpensive solution that comes with added performance.
Includes:
Mounting Hardware
NO CEL Guarantee
Installation instructions are available in our support section
Shipping is free in the US & our Hassle Free Lifetime Warranty is included
Mauro_Penguin, BigO and andrewz17 like this.
The Following 24 Users Say Thank You to JBR For This Useful Post:
aaron88 (06-23-2014), Addikted To Boost (06-23-2014), BigO (06-23-2014), BruhhWill (06-23-2014), btstarcher (06-23-2014), chaser27 (10-06-2014), Chief_Wiggum (06-23-2014), Cirruslydakota (06-23-2014), Code Monkey (06-23-2014), FenixTX717 (11-23-2014), franz (06-23-2014), gigliotti175 (06-23-2014), himurax13 (06-23-2014), jack_hammer (06-30-2014), Johnasaurus (06-23-2014), juxt3r (06-28-2014), kgb (08-22-2014), Mauro_Penguin (06-23-2014), mxlplx71 (06-27-2014), redMS308 (07-02-2014), rymanmazda (06-23-2014), speed3 britz (06-23-2014), SpeedNess (06-23-2014), thepatient77 (06-24-2014)
New Product Release !! Big Brake Caliper Kit for the Mazdaspeed 6 CorkSport CorkSport 57 05-31-2014 07:21 AM
Product Release! CorkSport Mazdaspeed 3 and Mazdaspeed 6 Brake Pads CorkSport CorkSport 54 03-07-2014 07:50 PM
Page generated in 0.60159 seconds with 45 queries
