Like Tree12Likes
Closed Thread
 Old 10-09-2014, 05:17 PM   #121
Colder weather brings out the creaks. I use Green Grease, whenever my lazy butt wants to, and lubes my bars. 7 1/2 years on Hotchkis, if it matters. Oh, installed fronts wrong so cannot get to zirc so those make noise in cold.
Raider is offline
 Old 10-09-2014, 06:36 PM   #122
RACER_X's Avatar
Posts: 266   (View Stats)
RACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the worldRACER_X is the leader of the world
Groaned at 31 Times in 14 Posts
Well it was kinda cool today, only got to 90
Lol
ΜΟΛΩΝ ΛΑΒΕ
2014 Honda Grom 125cc's of FURY! now more furious w/ 181cc's
2015 F150 Platinum
2012 MS3 Liquid Silver
Autotech HPFP
Cobb AP & CBE
Corksport FTB
Enkei Raijin 18x8 et45
JBR 3.0WP, RSB, RMM & SSP II
Stratified Tune
TrackMasters hood prop and ecu reloc.
TurboSmart BOV
RACER_X is offline
 Old 10-09-2014, 09:33 PM   #123
div2's Avatar
Posts: 273   (View Stats)
div2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the world
Good quality full synthetic grease is a must with polyurethane bushings or noises will occur. The OEM end links are really not up to the job of larger sway bars.
This is the same grease included with the JBR bushings- and it's an excellent product:
Super Lube 41150 Synthetic GreaseSuper Lube 41150 Synthetic Grease
Cosmic Blue Mica 2007 MS3 GT- MSCAI, HT, E-Focus RMM, FSDs, JBR Rear ARB and billet mounts
Hellrot 1995 318ti Club Sport- Turner/Conforti chip, Turner SS clutch line, UUC Motorwerks pedal bushings, clutch stop, and RK II
Desert Sand Pearl 1999 Wrangler Sahara- Banks SS Exhaust manifold, Hella H4 E-Codes, Bilstein HDs
Fireball Orange 1996 Speed Triple 900- Alcon six-pot front calipers, Sebring 3 into 1 "Off Road" exhaust
div2 is offline
 Old 10-10-2014, 07:23 AM   #124
RACER_X's Avatar
i used
dunno if thats good/bad or ok
ΜΟΛΩΝ ΛΑΒΕ
2015 F150 Platinum
Autotech HPFP
Cobb AP & CBE
Corksport FTB
Stratified Tune
TurboSmart BOV
RACER_X is offline
 Old 10-10-2014, 08:00 AM   #125
^^That is a lithium complex grease and it's not good for polyurethane. It's good grease though.
The best grease to use is silicone grease that contains no lithium like the super lube mentioned above.
JBR is offline
 Old 10-10-2014, 08:32 AM   #126
RACER_X's Avatar
so remove the stuff and reapply w/ better?
is it ok for the new ball joints i have coming in?
ΜΟΛΩΝ ΛΑΒΕ
2015 F150 Platinum
Autotech HPFP
Cobb AP & CBE
Corksport FTB
Stratified Tune
TurboSmart BOV
RACER_X is offline
 Old 10-10-2014, 08:42 AM   #127
If you can, if not just use the better. It'll be fine for the links.
JBR is offline
 Old 10-10-2014, 08:47 AM   #128
RACER_X's Avatar
ok, ordered super lube!
ΜΟΛΩΝ ΛΑΒΕ
2015 F150 Platinum
Autotech HPFP
Cobb AP & CBE
Corksport FTB
Stratified Tune
TurboSmart BOV
RACER_X is offline
The Following User Says Thank You to RACER_X For This Useful Post:
Raider (10-13-2014)
 Old 10-12-2014, 06:46 PM   #129
RACER_X's Avatar
Did the endlinks, initially no noise
I'll say the lower ball is at quite an angle even in the middle bolt position.
ΜΟΛΩΝ ΛΑΒΕ
2015 F150 Platinum
Autotech HPFP
Cobb AP & CBE
Corksport FTB
Stratified Tune
TurboSmart BOV
RACER_X is offline
 Old 10-12-2014, 08:19 PM   #130
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
Neutral  +1 score
Attached pics.
The top bolt on this side wasn't amazingly tight, but it also wasn't stripped enough to pop out. It's still been banging the bottom of the car.
2012 Velocity Red Mica
Dimenus is offline
The Following User Says Thank You to Dimenus For This Useful Post:
Nliiitend1 (10-13-2014)
 Old 10-13-2014, 09:19 AM   #131
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
Originally Posted by Dimenus View Post
Attached pics.
Ryan, come on. You have stripped out holes and you know that. No sway bar is going to perform as designed if you can't torque the bolts down to spec. Whether it's tight enough that the bar can't pop out or not, it still can shift. That bar is not designed to shift like that. The reason you may be seeing issues with the JBR bar over the stock bar probably lies in the fact that you using a stiffer bar. It's going to bring out the worst of the issues.
I understand you are probably going to go back to a less stiff bar as your coilovers help with stiffness enough for your liking, but please be completely transparent when you are posting about the issues you have. The issue isn't the bar- it is likely the inability to properly secure the bar because of a hardware issue with the car.
Gr8Speed is offline
 Old 10-13-2014, 09:32 AM   #132
Dimenus's Avatar
Groans: 33
I wasn't blaming Jamie at all. Someone asked me to post pics.
Calm the fuck down.
There still is a lot of leeway on the brackets with a small amount of clearance. The stock brackets do not have that kind of range even with a much smaller diameter bar.
Dimenus is offline
 Old 10-13-2014, 09:39 AM   #133
Gr8Speed's Avatar
Calm the fuck down.
I'm not trying to attack you or anything. I just want to build the context around your situation so people aren't jumping to conclusions without all the facts.
Gr8Speed is offline
 Old 10-13-2014, 09:41 AM   #134
Dimenus's Avatar
Groans: 33
This bar has still either creaked or clunked since I've gotten it. It used to creak which was mostly my fault (using shitty grease) and since It's been swapped on and off quite a few times, the nuts don't have the kind of threads they had originally.
However, I do want to know why collars that allow the bar to slide up and down are included with the kit if there's a tiny bit of clearance on especially the driver's side. Jamie even said it himself that you should move the bar down as low as possible to avoid it.
Dimenus is offline
 Old 10-13-2014, 09:42 AM   #135
Evan9999's Avatar
Posts: 75   (View Stats)
Evan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud of
I bought the original JBR rear sway bar back in 2011. I put over 80k miles on it, tracked it many times, and never had any issues.
I upgraded to the JBR .250 competition sway bar back in April of this year. No issues with the new bar either.
My buddy has a GenPu and is using my old JRB rear sway bar. He accidentally stripped out the holes for the bushing brackets and it was making a lot of noise. I don't remember exactly what he did, but he ended up fixing it. I think he either used something like a Helicoil or re-tapped the holes to a slightly larger size.
2009 True Red Mazdaspeed3 GT
Mazdaspeed Coilovers, Cobb AP V2, Corksport SRI w/ TIP, Autotech HPFP, Red Line MT-90, TWM Big Type-R Shift Knob,
DBA 4000 T3 Rotors, Carbotech AX6 Brake Pads, Corksport SS Brake Lines, Wilwood EXP 600 Brake Fluid, Synapse BPV,
CXRacing FMIC, JBR Trilogy Mounts (80 duro), JBR .250 Competition Rear Sway Bar, JBR Short Shift Plate
Evan9999 is offline
 Old 10-13-2014, 09:43 AM   #136
Dimenus's Avatar
Groans: 33
It's only noticeable when you turn going up an incline (into an alleyway for example). Because that's when it's applying all the pressure on to the brackets. It doesn't clunk at all while going over bumps or holes in the road.
Dimenus is offline
 Old 10-13-2014, 09:52 AM   #137
Gr8Speed's Avatar
Collars or brackets? I'm confused. The collars don't control upward/downward movement.
Gr8Speed is offline
 Old 10-13-2014, 09:54 AM   #138
Dimenus's Avatar
Groans: 33
Brackets I meant. Sorry.
Dimenus is offline
 Old 10-13-2014, 09:55 AM   #139
They are brackets not collars.
The brackets are slotted, just like all the brackets every other manufacture supplies because, they are off the shelf. Custom brackets and bushings would push the cost of the bar too high.
Now, if you would address the issue with your sub-frame, this would be the end of this discussion no? The bar WILL NOT make contact if you can get it tight. It will not move AT ALL if you can get it tight.
I as well as several other people have tried to help you. I'm not sure what more can be done to help.
JBR is offline
Dimenus (10-13-2014)
 Old 10-13-2014, 09:58 AM   #140
Gr8Speed's Avatar
If you torque the bolts attaching the collars to spec they don't move.
Following your logic, I could strip out my crank and then blame Mazda's design when I jump timing since I only torqued the crank bolt to 40ftlbs.
Gr8Speed is offline
 Old 10-13-2014, 09:59 AM   #141
Dimenus's Avatar
Groans: 33
And you answered my question about the brackets. Thanks.
I know most of my issue is related to my own fail at this point. No problems here. Thank you for following up.
No, that's not what I said at all. I was just asking why jamie included brackets of that type. Which he already answered.
Last edited by Dimenus; 10-13-2014 at 09:59 AM. Reason: MSF Database - Automerged Doublepost
Dimenus is offline
 Old 10-13-2014, 10:03 AM   #142
I think we've gotten to the bottom of the issue and what steps need to be taken to correct it.
OK let's all hug now.
JBR is offline
Gr8Speed (10-13-2014)
 Old 10-13-2014, 06:42 PM   #143
RACER_X's Avatar
Wife says no more noise from rear
ΜΟΛΩΝ ΛΑΒΕ
2015 F150 Platinum
Autotech HPFP
Cobb AP & CBE
Corksport FTB
Stratified Tune
TurboSmart BOV
RACER_X is offline
 Old 02-05-2015, 05:59 PM   #144
license2ill's Avatar
Posts: 313   (View Stats)
license2ill is infamous around these partslicense2ill is infamous around these parts
Groans: 30
Groaned at 132 Times in 57 Posts
Is the stock sway bar the same on both gen-1 and gen-2?
I saw somewhere that the rear is narrower diameter than the front bar, so am questioning how it will change the cornering dynamics with a significantly thicker-than-front rear bar.
license2ill is offline
 Old 02-05-2015, 06:03 PM   #145
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
Yes. I'm not 100% bur I wanna say it's like that stock wise as well in regards to size.
Mods: stock
faeker is offline
license2ill (02-05-2015)
 Old 02-05-2015, 06:07 PM   #146
Groans: 30
You think Mazda left it narrower to maintain a "safe" amount of plow?
I'm just wondering how making rear stiffer than front affects turn-in, midcorner grip, or exit behavior.
 Old 02-06-2015, 07:50 AM   #147
Neutral  -1 score
The front and rear bar of both GEN's are 1".
JBR is offline
license2ill (02-06-2015), Raider (02-06-2015)
 Old 02-06-2015, 07:55 AM   #148
faeker's Avatar
Groans: 731
there's your answer. i was just going by when I pulled my shit apart last summer. the regular 3 is the one with a difference but it's only by 1mm.
Mods: stock
faeker is offline
 Old 02-06-2015, 05:24 PM   #149
Groans: 30
Thanks, I saw it listed as like 26 rear and 28 front somewhere...should have known it wasn't correct. I can't seem to find confirmed spring rates either.
How does the increased rear roll stiffness affect wet and emergency lane change behavior?
 Old 02-09-2015, 01:37 PM   #150
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
They're actually 26 mm, not 1".
I realize that a 0.6 mm difference isn't a big one, but it is still a difference.
silvapain likes this.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
Nliiitend1 is offline
Deldran (02-09-2015), silvapain (02-09-2015)
 Old 02-09-2015, 01:38 PM   #151
Gr8Speed's Avatar
Neutral  -1 score
I am willing to bet that bar is manufactured with close to a .020" tolerance.
Gr8Speed is offline
 Old 02-09-2015, 01:49 PM   #152
Nliiitend1's Avatar
Like I said: The OEM bars are 26 mm.
A millimeter increase at that size (on a solid bar) is good for a 16-17% increase in torsional rigidity:
http://www.whiteline.com.au/docs/bulletins/BL-281.pdf
Take it for what it's worth.
2008 MS3 GT
2016 MX-5 Club
Deldran (02-09-2015), phate (02-09-2015), WetzMS3 (02-09-2015)
 Old 02-09-2015, 01:56 PM   #153
I'm staying with 1".
JBR is offline
Gr8Speed (02-09-2015)
 Old 02-09-2015, 02:26 PM   #154
Nliiitend1's Avatar
How thick is that paint?
...(and how Chinese is that caliper? )
*EDIT*: ...and yes, I realize that if the paint was contributing significantly to thickness, then the picture would actually show MORE than 1" with the bar being 26 mm thick... Regardless, I trust the accuracy of that caliper/mic about as much as I trust the durability of Energy Suspension's swaybar brackets when used with a JBR swaybar.
silvapain and WetzMS3 like this.
2008 MS3 GT
2016 MX-5 Club
Deldran (02-09-2015), silvapain (02-09-2015), WetzMS3 (02-09-2015)
 Old 02-09-2015, 02:27 PM   #155
Gr8Speed's Avatar
Neutral  -1 score
Not -.023 thick. I'm sure of that
Gr8Speed is offline
 Old 02-09-2015, 02:37 PM   #156
If you'd like I can go back measure it with my Starrett? Its still going to be 1".
JBR is offline
 Old 02-09-2015, 02:44 PM   #157
Nliiitend1's Avatar
Yeah, you guys are probably right. Mazda probably decided to forgo the metric system and use inches on this particular part.
2008 MS3 GT
2016 MX-5 Club
Deldran (02-09-2015), WetzMS3 (02-09-2015)
 Old 02-09-2015, 03:47 PM   #158
zenit's Avatar
Posts: 1,364   (View Stats)
I can confirm rear bar is 26mm.
Not an inch.
-feejay
-wetzel
zenit is offline
The Following 3 Users Say Thank You to zenit For This Useful Post:
Deldran (02-09-2015), Nliiitend1 (02-09-2015), phate (02-09-2015)
 Old 02-09-2015, 04:03 PM   #159
Not an inch.
Got pics?
Because only 1 person has shown pics in this unnecessary pissing contest.
Raider is offline
jdmage_mx5 (02-09-2015)
 Old 02-09-2015, 04:31 PM   #160
Nliiitend1's Avatar
Call it unnecessary all you want, but I've yet to see ANY source other than JBR claiming that the MS3's OEM bars are 1" vs. the published size of 26 mm.
I'm just trying to make sure that misinformation doesn't spread...
2008 MS3 GT
2016 MX-5 Club
Closed Thread
JBR Rear Sway Bars In Stock!! JBR JAMES BARONE RACING 37 12-02-2010 04:57 PM
Sway Bars SnoXRacer183 2010 MS3 - Suspension & Brakes 62 05-05-2010 06:36 PM
Sway Bars glocK23 MazdaSpeed 3/6 - Suspension & Brakes 4 05-22-2009 07:32 PM
Page generated in 0.59602 seconds with 31 queries
