Like Tree12Likes
Closed Thread
 Old 08-12-2011, 02:18 PM   #41
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Just submitted an order...
I had a bit of panic thinking I may have selected the wrong one, so I went back to look at my order detail. My order detail says '07-2010+, which has me a bit perplexed...
I just want to make sure I get the Black bar that is for a Gen 1 MS3. Thanks!
The email associated with the order (if you haven't already figured it out) is: nliiitend1 (at) hotmail (dot) com
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
Nliiitend1 is offline
JBR (08-12-2011)
 Old 10-18-2011, 09:12 AM   #42
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
@jbarone ... RSB on full stiff rocks.. Can't believe I waited 6 months to change the setting.
specvspeedfreak is offline
JBR (10-18-2011)
 Old 10-18-2011, 06:23 PM   #43
It's the shit ain't it!
JBR is offline
kritz (10-19-2011)
 Old 10-19-2011, 06:05 AM   #44
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Yes it is, changed mine at the auto cross on 10/15. I had developed some understeer with the new tires and the Cork Sport front bar. Now it is gone!
Nator is what it does.
kritz is offline
 Old 10-19-2011, 03:18 PM   #45
Cpt_Rum-bo's Avatar
Posts: 897   (View Stats)
Cpt_Rum-bo is the leader of the worldCpt_Rum-bo is the leader of the worldCpt_Rum-bo is the leader of the worldCpt_Rum-bo is the leader of the worldCpt_Rum-bo is the leader of the worldCpt_Rum-bo is the leader of the worldCpt_Rum-bo is the leader of the worldCpt_Rum-bo is the leader of the worldCpt_Rum-bo is the leader of the worldCpt_Rum-bo is the leader of the worldCpt_Rum-bo is the leader of the world
Just ordered one because the understeer when I'm doing AutoX is horrible, hoping this improves it
Had: 2011 Black Speed3 - In speed heaven
Sold: 05 Miata MX-5 LS
Current: 2010 135i - bit of mods, tuned by me
Cpt_Rum-bo is offline
 Old 10-19-2011, 03:21 PM   #46
Nliiitend1's Avatar
It will.
2008 MS3 GT
2016 MX-5 Club
 Old 10-20-2011, 07:35 PM   #47
Ms3_Miami's Avatar
Posts: 3,185   (View Stats)
Ms3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the world
Groans: 55
ordering a chrome-molly rmm and the RSB as a christmas present for my ms3
08 Black Mica Ms3~full bolt ons/Nishan Tuned-Sold
NATOR FL
Ms3_Miami is offline
The Following User Says Thank You to Ms3_Miami For This Useful Post:
JBR (10-21-2011)
 Old 10-20-2011, 08:43 PM   #48
Jake5713's Avatar
Posts: 1,775   (View Stats)
Hmm maybe I should put it on stiffest right away when I get it
I am here: http://maps.google.com/maps?ll=44.739818,-93.107882
-Jake
Jake5713 is offline
 Old 10-20-2011, 09:36 PM   #49
Cpt_Rum-bo's Avatar
I am here: Google Maps
-Jake
I'm putting it on stiffest from the get-go, going to an autox the next weekend after installing it
 Old 11-02-2011, 09:34 AM   #50
Cpt_Rum-bo's Avatar
So on Sunday I decided to install the JBR Sway Bar, everything was going smoothly until I got to the left side Sway Bar end link nut, I could not get the shit out no matter what. Everything I did caused pieces of the nut to just ring off. Started with a breaker bar, when I saw it slipping, I stopped before it got too bad, decided to try an Impact Wrench, same thing (nut was rounding out).
After hours of failing, I decided to go by a friend with a torch to heat the bolt up to help get it off (took the bar off with the left side endlink attached). At this point the nut is completed round out, so I used the biggest Vice Grip I could find after heating to try and get it out. Still got pieces of nut since the Vice Grip was slipping. Next we decided to cut of as much bolt as possible without damaging the end link's thread, that still failed, after all this the bolt hasn't moved at all.
Ended up having to buy a new end link, installed the bar yesterday (took 20 minutes). Will see how much it helps this weekend at the autocross (bar set to the innermost hole, stiffest setting).
 Old 11-02-2011, 10:12 AM   #51
Those end link nuts can be a bitch! I usually bump them with and impact gun then use a closed end wrench and an allen to get them off.
JBR is offline
 Old 11-27-2011, 10:36 PM   #52
Cpt_Rum-bo's Avatar
I read the instructions on the site before installing the sway bar and I believe i have the setting right, but is the stiffest setting the one closest to the front of the car? I was expecting a bit more oversteer than what I'm getting now. Could it be the stock tyres? I'm already ordering a pair of rs3's for the fronts.
 Old 02-29-2012, 11:41 AM   #53
sick_role's Avatar
Posts: 815   (View Stats)
sick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the world
Groaned at 6 Times in 3 Posts
just ordered Black RSB. The benefit of going with SenSen & not getting H&R Coils to replace my blown shocks.
"Also you cannot do anything "like a boss" in a srt4. If you ever get a job where the boss drives a neon, go somewhere else. Apparently that job has no future." - themytb
Oh you mean dogs. Yeah I like dogs. I drive a Hyundai.
sick_role is offline
The Following User Says Thank You to sick_role For This Useful Post:
JBR (02-29-2012)
 Old 03-30-2012, 03:27 PM   #54
asidrive's Avatar
Posts: 46   (View Stats)
asidrive is a name known to allasidrive is a name known to allasidrive is a name known to allasidrive is a name known to allasidrive is a name known to allasidrive is a name known to all
Scca ds now allows a rsb for autocross...that means I'll be sure to pick one up very soon. So should everyone else, maybe the rule change will help your sales
asidrive is offline
 Old 04-13-2012, 07:25 AM   #55
asidrive's Avatar
Install was super easy, sway bar is awesome.
Thanks jbr
asidrive is offline
The Following User Says Thank You to asidrive For This Useful Post:
JBR (04-14-2012)
 Old 05-15-2012, 04:37 AM   #56
outshined's Avatar
Posts: 423   (View Stats)
outshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the worldoutshined is the leader of the world
After much deliberation, I have placed an order for a red RSB.
Just please, don't tell my wife!
Originally Posted by James Madison
[The Constitution preserves] the advantage of being armed which Americans possess over the people of almost every other nation...(where) the governments are afraid to trust the people with arms.
outshined is offline
The Following User Says Thank You to outshined For This Useful Post:
JBR (05-15-2012)
 Old 05-15-2012, 05:49 AM   #57
I think you made a good choice.
Thanks,
Jamie
JBR is offline
 Old 05-16-2012, 10:05 AM   #58
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
Looks like I'll be ordering one of these today (hopefully). Been looking at them since I got the car, finally getting around to redoing the suspension. I guess the big question is...red or black?
Blue Pu.
anavrinIV is offline
 Old 05-16-2012, 03:13 PM   #59
anavrinIV's Avatar
Groans: 63
Decided on red and ordered. Also got an EGR block-off finally, and a TB TIG since I'll have to pull it anyway, and for the coolant bypass. Can't wait for some new parts!
Blue Pu.
JBR (05-16-2012)
 Old 05-16-2012, 03:25 PM   #60
Thanks!! Ships shortly, tracking will follow.
Jamie
JBR is offline
 Old 05-16-2012, 03:40 PM   #61
anavrinIV's Avatar
Groans: 63
I know your shipping is super fast, so no worries. I'm looking forward to putting this bar through its paces during my first race on 5/26
Blue Pu.
JBR (05-17-2012)
 Old 05-18-2012, 01:59 PM   #62
jamesr242's Avatar
Posts: 725   (View Stats)
jamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the worldjamesr242 is the leader of the world
Got my RSB installed the other day, set to full stiff. LOVE IT! Probably my favorite mod so far! Going around corners it is so much more balanced now. You can very predicatbly slide out the back end with some throttle lift off if you are so inclined. Fun stuff! I didn't really notice any harshness in ride quality on full stiffness either.
2011 MS3 - SOLD
2000 Miata LS, Flyin Miata Turbo'd (GT2560R), 3" TBE, Megasquirt EMS, 650cc injectors
jamesr242 is offline
 Old 05-19-2012, 04:12 AM   #63
exentix's Avatar
Posts: 1,568   (View Stats)
Groans: 46
Same here. Just got it in yesterday. Those endlinks are mother loving whores... Wish I would have had time to do it sooner. Hard to explain, but it feels as if the back end follows you now, and doesn't bully you around and push you
exentix is offline
 Old 05-25-2012, 10:08 AM   #64
alien_sporez's Avatar
Posts: 1,199   (View Stats)
alien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the world
I got mine in several weeks ago, but just installed it this morning, and all I can say is: FAAHH-KMEEEE!!!
On the middle setting there is ZERO understeer... maybe a hint of oversteer. Absolutely neutral handling. Turns flat. Fantastic.
Installation was a breeze. I had to loosen the top nut of the end link to get enough play to get the end link into the bar, but no biggie. It took longer to get my tools and get my car on jack stands that it did to do the actually install. Total time, start to finish, 30 minutes (including getting the car up in the air).
Next JBR purchase: Catch Can.
2011 Jaguar XFR Full Resonator Delete Mina Cat-Back Exhaust Staggered Giovanna Portofinos
2010 Mazdaspeed 3 - GONE
alien_sporez is offline
The Following User Says Thank You to alien_sporez For This Useful Post:
JBR (05-30-2012)
 Old 05-26-2012, 08:01 PM   #65
anavrinIV's Avatar
Groans: 63
toss that thing to full stiff, it's gravy
Blue Pu.
alien_sporez (05-27-2012)
 Old 09-17-2012, 12:44 PM   #66
BBartley's Avatar
Posts: 166   (View Stats)
BBartley has a reputation beyond reputeBBartley has a reputation beyond reputeBBartley has a reputation beyond reputeBBartley has a reputation beyond reputeBBartley has a reputation beyond reputeBBartley has a reputation beyond reputeBBartley has a reputation beyond reputeBBartley has a reputation beyond reputeBBartley has a reputation beyond reputeBBartley has a reputation beyond reputeBBartley has a reputation beyond repute
I just ordered my RSB. Cant wait!
2008 Silver MS3: Cobb AP - Corksport SRI & TIP - AT Internals -JBR 88 RMM -JBR SSP & Solid Bushings-JBR Rear Sway Bay -TurboXS Downpipe & Racepipe -ITV22's
BBartley is offline
The Following User Says Thank You to BBartley For This Useful Post:
JBR (09-20-2012)
 Old 01-07-2013, 12:56 PM   #67
mazda dude's Avatar
Posts: 51   (View Stats)
mazda dude has much to be proud ofmazda dude has much to be proud ofmazda dude has much to be proud ofmazda dude has much to be proud ofmazda dude has much to be proud ofmazda dude has much to be proud ofmazda dude has much to be proud ofmazda dude has much to be proud of
Groaned at 5 Times in 2 Posts
Just installed my JBR RSB and was very impressed with the quality of the bar, fast shipping, and included hardware. I had a simular rear sway on my '08 3 but this one is definately better quality than most I've seen. Just started on the middle setting and can tell the difference. Thanks!
JBR likes this.
mazda dude is offline
The Following User Says Thank You to mazda dude For This Useful Post:
JBR (01-08-2013)
 Old 06-08-2013, 06:37 PM   #68
dixie789456's Avatar
Posts: 635   (View Stats)
dixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the worlddixie789456 is the leader of the world
Groaned at 25 Times in 15 Posts
rsb is still running strong on my ms3!!!
dixie789456 is offline
 Old 12-06-2013, 03:53 PM   #69
Jamie, I installed your rear sway this afternoon. Great product and it only took around 20 minutes to install on ramps. Zero clunking. Zero issues. Keep up the good work!
neganox is offline
 Old 01-08-2014, 10:38 AM   #70
kolosok17's Avatar
Posts: 1,104   (View Stats)
Installed the RSB a few weeks ago on the middle setting. I was recently able to take the car out to some mountain roads and all I have to say is !
The handling has improved tremendously! I am now able to take turns at a higher speed than before while being more confident that I have full control of my car. Thanks for the awesome product, Jamie!
EDIT: Oh yeah, and no weird noises are present!
2012 CWP Non-Tech MS3
kolosok17 is offline
The Following User Says Thank You to kolosok17 For This Useful Post:
King Scumbag (01-08-2014)
 Old 01-08-2014, 10:47 AM   #71
Alittle Faster
bioevolve's Avatar
Posts: 3,522   (View Stats)
Ordered mines, gotta ketchup on all JBR parts!
bioevolve is offline
The Following User Says Thank You to bioevolve For This Useful Post:
 Old 01-25-2014, 03:04 PM   #72
johnheer's Avatar
Posts: 45   (View Stats)
johnheer will become famous soon enoughjohnheer will become famous soon enough
James Barone Racing
Performance Aftermarket Parts & Accessories
JBR 3-Way Adjustable Rear Sway Bars
$195.00 shipping included!! (Domestic Only)
International Shipping Also Available
Constructed out of 32mm 4130 Chromoly tubing with 13mm thick solid steel arms, Tig welded inside and out with capped ends.
Powder coated in either Red or Black for ultimate corrosion resistance.
The JBR Sway Bar Kit Includes:
-New Greasable Polyurethane Mounting Bushings & Brackets
-Grease
-Loctite
-2 12mm Lock Washers
-Lifetime Warranty
-Online Installation Instructions
Everything you need to get the job done right with confidence!!
Applications Available:
07'-2012 MAZDASPEED 3
04'-2012 MAZDA 3 Sedan and 5 Door
06'-2012 MAZDA 5
Specifications Simulating 1" of body roll:
Stock Sway Bar setting:
MAZDASPEED 3 is 479 lbs/in
MAZDA 3 & 5 is 228 lbs/in
JBR 3-Way Adjustable Sway Bar Settings:
Stiff setting is 593 lbs/in
Stiffer Setting is 718 lbs/in
Stiffest Setting is 901 lbs/in
Thanks,
Jamie
Jamie,
I sent you an email, but never heard back.
John
John Heer
07 Mazdaspeed3
johnheer is offline
 Old 01-25-2014, 03:13 PM   #73
Originally Posted by johnheer View Post
Jamie,
John
I replied to your email last week John. Please check your spam folder. Thank you.
JBR is offline
 Old 01-25-2014, 08:24 PM   #74
Sinister_Speed3's Avatar
Posts: 180   (View Stats)
Got mine installed with a set of camber arms and the car is so much more fun to drive now and I am only on the middle setting. Such an easy install and it just feels quality built.
@jbarone; what is the easiest way to keep the rsb lubed? Should I take the brackets off and refill the bushing or is that what the little nipple is for on the bracket? I ask because it seems like I am getting a creak in the rear so i want to re lube it all to make sure.
nick
Sinister_Speed3 is offline
 Old 01-26-2014, 07:58 AM   #75
aaron88's Avatar
Posts: 277   (View Stats)
Use the grease fitting on the bracket to lube it up.
'08.5 CWP MS3 GT
aaron88 is offline
 Old 01-26-2014, 07:18 PM   #76
nick
Use a grease gun loaded with synthetic grease. You can get one at Wal-Mart pretty cheap. Also, apply some grease to the collars and brackets to keep them from rusting.
Thanks,
Jamie
JBR is offline
Agent_Orange (01-26-2014), Sinister_Speed3 (01-26-2014)
 Old 03-19-2014, 12:34 PM   #77
sailorjerry12's Avatar
Posts: 60   (View Stats)
sailorjerry12 has a reputation beyond reputesailorjerry12 has a reputation beyond reputesailorjerry12 has a reputation beyond reputesailorjerry12 has a reputation beyond reputesailorjerry12 has a reputation beyond reputesailorjerry12 has a reputation beyond reputesailorjerry12 has a reputation beyond reputesailorjerry12 has a reputation beyond reputesailorjerry12 has a reputation beyond reputesailorjerry12 has a reputation beyond reputesailorjerry12 has a reputation beyond repute
Did you just rename the sway bar or is there actually a difference?
-88 RMM
-Heavy Shift knob
Corksport
-Stage II CAI/TIP
-SSP
sailorjerry12 is offline
 Old 03-19-2014, 01:13 PM   #78
Actually, we just gave it a name to be in line with the other suspension products recently released and some that have yet to be.
-Jamie
JBR is offline
 Old 03-19-2014, 05:35 PM   #79
Kid_dynamite93's Avatar
Posts: 10   (View Stats)
Kid_dynamite93 is just really niceKid_dynamite93 is just really niceKid_dynamite93 is just really niceKid_dynamite93 is just really niceKid_dynamite93 is just really nice
Just purchased one in black!! Super stoked it will be my first mod!!!
Kid_dynamite93 is offline
The Following User Says Thank You to Kid_dynamite93 For This Useful Post:
He Hate Me (03-19-2014)
 Old 03-19-2014, 05:43 PM   #80
aaron88's Avatar
Pick up a RMM from JBR for your next mod.
'08.5 CWP MS3 GT
aaron88 is offline
Closed Thread
JBR Rear Sway Bars In Stock!! JBR JAMES BARONE RACING 37 12-02-2010 04:57 PM
Sway Bars SnoXRacer183 2010 MS3 - Suspension & Brakes 62 05-05-2010 06:36 PM
Sway Bars glocK23 MazdaSpeed 3/6 - Suspension & Brakes 4 05-22-2009 07:32 PM
Page generated in 0.57626 seconds with 45 queries
