![]() | | #81 | ![]() |
![]() Join Date: Mar 2012 Location: Cary NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
| Not Ranked : 0 score
__________________ 2010 - BMW 335i M-Sport - Lemans Blue Metallic 2005 - Kawasaki ZX-6R 636 - Magma Red Last edited by Volcom8190; 02-08-2013 at 06:03 PM. | |
![]() | | #82 | ![]() |
Rep Power: 7119 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,203
![]() | | #83 | ![]() |
![]() Join Date: Dec 2008 Location: Toledo OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 324
| Not Ranked : 0 score I just don't want to open it one day and it not want to close again. Sent from my Galaxy Nexus using Tapatalk 2
__________________ | CP-E 75 Duro RMM/TMM + TBE | Corksport SR/TI | Forge BPV | Cobb AP- DJ Tuned | NGK Plugs | Hotchkis RSB @ 140% | PTP IM Gasket/TB Coolant Delete + BSD | Autotech FPi | AEM Meth Injection | SU TMIC | JBR SSP + Stage2 OCC |PG Oil Filter Conversion | Toyota Injector Seals | Bizzerko PnP IM | Grimmspeed EBCS | Ingalls ETD | Sonic Tuning S3 Coilovers |Fluids Rotella T6 A lot Rislone Engine Treatment Motorcraft XT-M5-QS(trans) VP Methanol ~Splash of E85~ |
![]() | | #84 | ![]() |
| Banned ![]() Join Date: May 2011 Location: Rochester, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score when i drain it is like a dark green ish color when it comes out |
![]() | | #85 | ![]() |
Sounds pretty normal for this time of year. Last edited by JBR; 02-09-2013 at 09:58 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #86 | ![]() |
![]() Join Date: Sep 2012 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 287
| Not Ranked : 0 score I just went to drain my catch can and nothing came out. Is this normal? I have had it installed for about 4 weeks now. I got it during the black friday sale. I followed the instructions to the best of my knowledge. Anything I should look for? Maybe I put the hoses backwards?
__________________ Cobb AP (Stratified Tuned) Corksport Stage 2 intake+recirc tube Streetunit testpipe Autotech internals NGK LTR7Ix-11 Corksport RMM RX-8s--235/40/18 Bridgestone Potenza RE-760 Stoptech brake kit+Motul RBF600 Whiteline RSB+endlinks Dominant Engineering camber arms JBR stage 2 OCC+ EGR delete+intake manifold gasket HKS turbo timer Prosport boost gauge+ventpod Awaiting H&R springs/Koni yelows/ground control bumpstops |
![]() | | #87 | ![]() |
Thanks, Jamie | |
![]() | | #88 | ![]() |
![]() Join Date: Aug 2008 Location: Ashburn, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 305
| Not Ranked : 0 score Why not keep both directions posted? I have your OCC in the box still that I bought last summer and will need the old directions for whenever I finally get around to my installs.
__________________ 2006 Black Mica MS6 - Sold 10/15 |
![]() | | #89 | ![]() |
(Thread Starter) | Not Ranked : 0 score You'll wanna reconfigure you check valve and install it on the intake side if you have the stage 2 kit and use the current instructions. PM me if you need help when you're ready to install it. |
| The Following User Says Thank You to JBR For This Useful Post: | shadesofgray19 (02-24-2013) |
![]() | | #90 | ![]() |
| Not Ranked : 0 score I'm confused if I purchased mine last summer and its on do I need to reinstall a dif way? |
![]() | | #91 | ![]() |
![]() Join Date: Jan 2013 Location: South Boston, MA
Rep Power: 1402 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,475
![]() Edit: also-
__________________ 07 BLACK MICA MS3 PATTY/JEFF BUILT MOTOR BNRS3V2 349/344 VD 93 FREEKTUNE E25 382/375 GSD DynoJet 141020 STOCK BLOCK FREEK KORN TUNE 335whp/356wtq ENM 14 K04 ~ Ordnance, Droppn' Warheads of Foreheads Since 1922 ~ BOSTON STRONG | |||
![]() | | #92 | ![]() |
| Not Ranked : 0 score You mean just having the arrow on the valve pointing toward the manifold right? Quit using big words like reconfigured... Lol Sent from my Galaxy Nexus using Tapatalk 2
![]() | | #93 | ![]() |
If you bought and installed the kit before 12/25/12 there's nothing you need to do. | |
![]() | | #94 | ![]() |
| Not Ranked : 0 score Just to clarify, the check valve needs to be connected on the hose attached to the intake manifold? Once that is done, will i need to swap the hoses attached to the can? Swap the bottom, to the top. vice versa? Intake hose goes on bottom of the can?
![]() | | #95 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yes. Intake hose goes on the top. PCV hose Hose on the bottom. Arrow on the CV must be pointing towards the intake manifold. |
![]() | | #96 | ![]() |
| Not Ranked : 0 score So check valve on intake hose pointing towards the manifold. Most likely in the ^ position
![]() | | #97 | ![]() |
![]() Join Date: Sep 2011 Location: SCOTLAND
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 469
| Not Ranked : 0 score I presume it's fine to install this the way corksport suggests if we choose to?
__________________ Cpe tmic&sri, 3" HTP tip, 3" ebay downpipe, BNR stage1, Autotech internals, Snow stage 2 meth with Aqaumist jet/parts, GoFastBits Respons BOV, Grimmspeed ebcs 3-port, Turbinetech diff mount, Cpe diff brace, Whiteline rarb, Bilstein B8's, Eibach springs, NGK iridium IX plugs, Corksport Mods, JBR mods... 324whp 361lb/ft Tuned with by |
![]() | | #98 | ![]() |
You can do whatever you want but I would never suggest it. Pulling the oil that the OCC doesn't capture back in through your intake, turbo, then through the inter-cooler is NOT a good idea. | |
![]() | | #99 | ![]() |
| Not Ranked : 0 score Cheers Jamie - I'll stick to your instructions
![]() | | #100 | ![]() |
| Not Ranked : 0 score So just got around to fixing my catch can. Check valve points towards intake manifold nipple, just unscrew both sides and reverse it. Doing it a second time, made this pretty simple. Just hate the lack of space on our cars. Looking forward to the junk that comes out
| The Following User Says Thank You to jdm_mica For This Useful Post: | JBR (03-04-2013) |
![]() | | #101 | ![]() |
__________________ | CP-E 75 Duro RMM/TMM + TBE | Corksport SR/TI | Forge BPV | Cobb AP- DJ Tuned | NGK Plugs | Hotchkis RSB @ 140% | PTP IM Gasket/TB Coolant Delete + BSD | Autotech FPi | AEM Meth Injection | SU TMIC | JBR SSP + Stage2 OCC |PG Oil Filter Conversion | Toyota Injector Seals | Bizzerko PnP IM | Grimmspeed EBCS | Ingalls ETD | Sonic Tuning S3 Coilovers |Fluids Rotella T6 A lot Rislone Engine Treatment Motorcraft XT-M5-QS(trans) VP Methanol ~Splash of E85~ | |
![]() | | #102 | ![]() |
(Thread Starter) | Not Ranked : 0 score Doubtful. Looks like condensation to me. |
| The Following 2 Users Say Thank You to JBR For This Useful Post: | Rokusek (03-04-2013), thatsmrgimp2u (03-07-2013) |
![]() | | #103 | ![]() |
![]() Join Date: Oct 2012 Location: Ft. Huachuca, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,541
| Not Ranked : 0 score Either that or someone pissed in your oil
__________________ Stock as fook. |
![]() | | #104 | ![]() |
![]() Join Date: Nov 2010 Location: Alhambra
Rep Power: 524 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 237
Groaned at 35 Times in 14 Posts
| Not Ranked : 0 score I've always gotten a couple ounces when I drained my OCC every 5k miles, at oil changes. Last time I got like 20 oz! I use an 8 oz water bottle and usually it is 1/4 filled, but this time I filled it and drained it twice, and filled it again halfway. Not sure why the difference, I use the same oil, I don't think I missed draining last time and anyway it was like 5 times as much, not just twice. Anyway, lots of stuff in there, it works. Curious though, if there is a likely reason - is it normal to collect more/less at different times, and why might that be? |
![]() | | #105 | ![]() |
| Not Ranked : 0 score Ordered this with check valve and the EGR block off. I really think I would rather head off the dirty valves/oil in intake than wait till having to clean crap off and regret not doing this as soon as possible. I have 3000 miles now, hopefully they're still clean.
![]() | | #106 | ![]() |
![]() Join Date: Nov 2011 Location: Alberta, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 621
| Not Ranked : 0 score ^^ Same here. Just under 3000 miles and I'll be installing my JBR OCC asap.
__________________ | 2012 CWP | Cobb AP + AT Internals | HTP 3" Intake | 91oct + DO WMI (D07, 50/50) + 3gal E85 | UR Test Pipe | cp-e TMIC | JBR Trilogy, OCC, EGR Block, SSB | TBC Bypass | Freektuned - 313/351 - Stock DP |
![]() | | #107 | ![]() |
| The Following User Says Thank You to agentgordon27 For This Useful Post: | JBR (03-11-2013) |
![]() | | #108 | ![]() |
(Thread Starter) | Not Ranked : 0 score We have had such great success with our catch cans that sometimes we run out. Our apologies. I assure you it'll be worth the wait -Jamie |
![]() | | #109 | ![]() |
| Not Ranked : 0 score Oh I know, it's supposed to be a compliment, just throwing a "I want it now!" tantrum. *EDIT* I will say this though, a lot of companies would just leave me hanging and let it go until it shipped out, JBR is proactive and sends an email 'splaining everything and expected ship times.
__________________ Stock as fook. Last edited by agentgordon27; 03-11-2013 at 08:56 PM. |
![]() | | #110 | ![]() |
![]() Join Date: Feb 2009 Location: Crete, IL.
| Not Ranked : 0 score So, Jamie, when will you have them in stock again? And, any discounts available? Thanx |
![]() | | #111 | ![]() |
![]() As for "stock" can't speak for @jbarone; on that one.
![]() | | #112 | ![]() |
| Not Ranked : 0 score I got an email from him on the 11th of March saying expected ship date from then was 2-weeks: "Thanks for ordering with JBR! We are sorry to inform you that the Stage 2 Oil Catch Can Kit is currently out of stock. We are in the process of manufacturing more now. Expected ship date is about 2 weeks. You will be notified again when your order has shipped."
![]() | | #113 | ![]() |
(Thread Starter) | Not Ranked : 0 score That is correct about another week or so. I'd order now and take advantage of the sale though. They'll ship as soon as they are finished. |
| The Following 2 Users Say Thank You to JBR For This Useful Post: | agentgordon27 (03-31-2013), King Scumbag (03-15-2013) |
![]() | | #114 | ![]() |
| Not Ranked : 0 score Thanks for the lickity split shipping on the catch can and other shtuff, I have a question about the VTA setup. I am not fully bolted yet but will be there shortly along with an ethanol e-tune, will there be drive-ability issues with the VTA while still using a stage 1 OTS tune until then? @jbarone;
![]() | | #115 | ![]() |
-Jamie | |
| The Following User Says Thank You to JBR For This Useful Post: | agentgordon27 (04-01-2013) |
![]() | | #116 | ![]() |
![]() Join Date: Sep 2011 Location: New York City
Rep Power: 916 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 442
Groans: 93
Groaned at 27 Times in 16 Posts
| Not Ranked : 0 score @jbarone; how is stock of these units looking? I am toying with the idea of getting a Stage2 because of the check valve. I couldn't tell based on the images on your website, but is there a sight for how full the OCC gets? How difficult is the install? I'm basically a complete noob. TIS
__________________ TOTS 2012 Mazdaspeed3, CWP, Tech Package. COBB AccessPort V3, AUTOTECH HPFP Internals, JBR 3" Wide-path SRI+TIP, CP-E TMIC, UR 3" Test Pipe, CP-E Triton CBE, FORGE V2 BPV, DENSO ITV22 Plugs, JBR RMM 88a, JBR OCC, JBR RSB Kit, JBR Solid Shifter Bushings, CP-E Tow Plate, CorkSport ECU Relocation, TSW Nurburgring Bronze 18x7.5 ![]() alphasaur: "Fuck I just beat it to surprise tranny porn. Saw the dick right when I came fml" |
![]() | | #117 | ![]() |
-Jamie | |
![]() | | #118 | ![]() |
(Thread Starter) | Not Ranked : 0 score OCC's back in stock early. Here's a shot for ya...Our shop PU after about 800 miles. |
![]() | | #119 | ![]() |
| Not Ranked : 0 score MMmMmmm Yummmayyy. Do you drain it until the can is empty (Just the contents drain out). Or will oil continue to flow if you leave the drain valve open?
![]() | | #120 | ![]() |
(Thread Starter) | Not Ranked : 0 score Only the contents will drain out, nothing more. |
| JBR EGR Block Off Kits In Stock!! | JBR | JAMES BARONE RACING | 137 | 03-21-2015 07:33 PM |
| 06' - 2011 MAZDA 5 Short Shift Plate Kits In Stock!! | JBR | JAMES BARONE RACING | 4 | 06-18-2010 07:38 AM |
| 06' - 2011 MAZDA 3 Short Shift Plate Kits In Stock!! | JBR | JAMES BARONE RACING | 3 | 06-18-2010 07:38 AM |
| AEM Water/Meth Injection Kits In Stock | Performance Racing | Mazdaspeed3/6 General Discussion | 3 | 04-10-2008 05:09 PM |
