Rep Power: 7118 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,203
(Thread Starter) | Not Ranked : 0 score James Barone Racing Performance Aftermarket Parts & Accessories JBR Oil Catch Can Kits LINK TO PRODUCT PAGE Details: JBR Stage 1 Oil Catch Can Kit. During everyday engine operation, blow-by gases, as well as oil mist from the engines rotating components pass through the PCV valve and are routed back into the intake for the engine to burn off. However, some of that oil mist and other contaminates adhere to the intake and the valves. Over time a crust is formed reducing performance and potentially leading to a costly cleaning or repair. This is especially a problem for 2.3L DISI motor where there's no fuel passing over the valves to clean them. This is why an OCC is a must have for the Mazda 2.3L DISI community. As PCV gases enter the catch can they disperse and flow through a series of four filter screens. As the gases flow through the screens, heavy oil and gunk sticks and lighter gases reach the outlet tube at the top. Accumulated oil and gunk naturally run off the filter screens and collect at the bottom of the tank. Throughout the life of the catch can, the filter media will never break down or need to be replaced like catch cans with mesh filter material. The net effect is blow-by gases, oil and other impurities do not have a chance to reach critical components of your engine. Construction: Lids Press-Formed from 304 stainless Inlet & outlet fittings fabricated from straight 5/8" 304 stainless tubing Can fabricated from 304 stainless and CNC machined components Precision TIG welding on all components Internal filters machined from 6061 perforated aluminum 1/4" NPT quick drain Includes: Oil Catch Can 60" of 5/8" reinforced vacuum hose for numerous mounting locations Stainless steel hose clamps Stainless steel mount hardware Custom Mounting bracket All the necessary fittings to get the job done right Online installation instructions Details: JBR Stage 2 Oil Catch Can Kit Includes a 1/2" Check Valve. LINK TO PRODUCT PAGE Details: JBR Oil Catch Can Check Valve. So what’s wrong with the factory PCV valve? The short answer is… nothing; as long as the car is stock and everything is properly maintained. But if you are running anything more than stock boost or would prefer to not have oily residue in your intake and crud building up on your valves, read on. Since the PCV valve is the heart of the PCV system, let’s start there. This thing is notorious for not being able to completely close to prevent boost from entering the crankcase, even when brand new. Add a few thousand miles worth of crud flowing back and forth through it and it the worse it gets. And the more boost you run, the greater the problem becomes. The check valve included with the stage 2 OCC kit is designed to be closed 100% of the time unless vacuum is present. This check valve is oil, fuel and chemical resistant. It's constructed from solid brass, it has an incredibly low crack pressure and it's the largest check valve available so that normal flow isn’t impeded. Unfortunately the OEM check valve just can't close instantly under boost and therefore crankcase pressure and turbo spool times are increased. For higher boosting cars or those seeking the best possible performance out of their engine an OCC check valve is a must. Last edited by JBR; 08-29-2012 at 12:43 PM. |
| The Following 44 Users Say Thank You to JBR For This Useful Post: | ak_spray (03-06-2012), AZSPEED3 (03-06-2012), Broxer (04-18-2012), cbspd3flip (12-29-2012), Dahouse702 (03-05-2013), Dash08 (03-05-2012), daztdMS6 (03-04-2012), deadlandxtreme (02-28-2012), DISIindahead (04-28-2012), doubleflusher (03-26-2012), Easter Bunny (02-28-2012), evolizzee (05-06-2012), Fail_6 (04-15-2012), fishin53 (03-18-2012), fredricktsang (04-28-2012), Grumpyjap (03-07-2012), hartlch (04-30-2012), helmetface (03-02-2012), Ingle (02-28-2012), J'sSpeed3 (04-18-2012), josurr (06-05-2012), jracer (04-22-2012), kabobulate (09-03-2012), KevMS6 (03-18-2012), kgb (03-24-2012), leon78 (02-28-2012), mason (03-26-2012), mayer (02-28-2012), neotide87 (03-07-2012), nycMS3 (03-19-2012), Onelovesoccer (02-28-2012), PapaSmurf (03-07-2012), rikyrick87 (02-28-2012), ryno077 (03-19-2012), sidekick (02-08-2013), SKiZ0TT (04-18-2012), Speed_j23 (03-29-2012), Teethkikr (02-28-2012), TexasSpeed3 (03-04-2012), uncorked11 (05-24-2012), Walkman (03-01-2012), zatara (02-28-2012), zpele (03-06-2013), zxhoya (02-15-2013) |
![]() Join Date: Nov 2010 Location: Lake Carmel, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 773
| Not Ranked : 0 score Funny, I was wondering why the OCC kits didn't say out of stock when I went to your site about half an hour ago. This explains why
__________________ 2010 Mazdaspeed 3 Black Mica CorkSport SRI/ TIP-- CorkSport TMIC-- Cobb DP-- CorkSport CBE-- Cobb AP Stratified Lex Tune-- Autotech Internals-- Denso ITV22's-- JBR EGR Blockoff-- JBR OCC-- JBR 88 Chrome-Molly RMM-- JBR 80 PMM-- JBR 88 TMM-- Corksport Skidplate-- JBR RSB Red JBR shift knob-- VG Sharkfin--CS LED interior lights-- Hardwired Valentine 1 Radar detector-- 5K HID lows-- 3K HID Fogs-- 30% tint front, 20% tint rear |
| The Following User Says Thank You to zatara For This Useful Post: | JBR (02-28-2012) |
![]() Join Date: Dec 2011 Location: Holly Hill, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 42
| Not Ranked : 0 score Great instructions as always to Jamie!!! Now I just need to learn how to grow or shit money so I can buy more JBR products. Keep them coming...
__________________ I haz no Pu no mo!! Careful what you type, there a grammar Nazi's around. |
| The Following User Says Thank You to Proshop For This Useful Post: | JBR (02-28-2012) |
![]() Join Date: May 2009 Location: Huntsville, AL
Rep Power: 1431 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,522
| Not Ranked : 0 score Got mine in the mail on Wednesday, will be installing it tomorrow. Quality, as normal, is top notch.
__________________ True Red 2009 MS3 Damond Motorsports: RMM // Short Shift Plate Suspension: Koni Yellows // Swift Spec-r springs // Fatcat motorsports front bump stops // Rear Camber Arms Brakes: Hawk HPS pads // ATE Superblue fluid // Stainless Steel Brake Lines Other: CP-e Safe Seals // MattDamond shift plate // Masonvi shift knob // 3.5" WP w/recirc // RSB // IM + TB tigs // Synapse Engineering FMIC + BOV // Autotech internals Tune: hypnotic tuned Critical Stats: // 305whp/352tq // 13.34 @ 98 - Mason Dixon Dragway - 4/13/14 Titanium Gray 2006 Mazdaspeed 6 Damond Motorsports: OCC // Short shift plate // Turbo oil feed restrictor bolt Other: Autotech internals // Ebay M2 DP // Masonvi shift knob // |
| The Following User Says Thank You to nindoja For This Useful Post: | JBR (03-03-2012) |
![]() Join Date: Feb 2010 Location: Oklahoma City
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,213
| Not Ranked : 0 score Just ordered the stage 2
__________________ 09 CWP MS3 sold 15 DCB Mazda 6 |
| The Following User Says Thank You to Manny3 For This Useful Post: | JBR (03-05-2012) |
![]() Join Date: Nov 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 849
Groans: 82
| Not Ranked : 0 score Practice on your's and then it will be super easy when you help me bolt mine on!
__________________ 2010 Mazdaspeed3- Installed Mods:- GT 3071 (Ported,polished, and coated by Grimmspeed) Polished and coated throttle body (Grimmspeed)TWM Performance Full Replacement Short Shifter Kit, Corksport FMIC (Upgraded size and coated by Calico Coatings), HTP 4" SRI, Forge V2 BPV, Corksport coolant hoses, NGK Iridum, COBB AP, Full Race DP (ceramic coated), Corksport hangers,JBR EGR block off, Autotech HPFP internals. Glowshift triple gauge pod, Aeroforce Interceptor dual gauges, STRI Imperial boost gauge.Stratified EBCS.RSB and Rear Camber Arms ( JBR ). Tein EDFC kit - Tein Super Street Coilovers . Enkei Racing RPF1 .GTSPEC bracing (front to rear)Corksport FSB..StopTech SS Brake Lines-SportStop Cross Drilled and Slotted Rotors-StopTech Street Performance Brake Pads.. Stratified Boost dial and Guardian Angel. JMF Intake manifold. Full Race Exhaust Manifold (ceramic coated). Damond Motorsports CC. SSP CC. PERM PCV Plate. 3bar MAP. , CP-E Triton full exhaust(Tuning provided by Stratified Tuning) |
| The Following User Says Thank You to deadlandxtreme For This Useful Post: | Manny3 (03-20-2012) |
![]() Join Date: Aug 2010 Location: Cleveland, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 44
Groaned at 4 Times in 1 Post
| Not Ranked : 0 score Just ordered my Stage 2!! Along with EGR block off, thermal intake & TB gaskets. Doing it all at once. |
| The Following User Says Thank You to boostin08 For This Useful Post: | JBR (03-07-2012) |
![]() Join Date: Dec 2010 Location: Dayton, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,193
| Not Ranked : 0 score Who's running this with a CAI?
__________________ 07 MS3 Sport CPe: Stage2 RMM, XcelNANO Short Ram, Nviscid TIP, HPFP SURE: AGS ATOM Shift Knob, ShortCut, CounterShift, TB/IM TIG, Injector Halos (Coming Soon) JBR: RSB Cobb: Accessport Corksport: TMIC CNT: Catted Downpipe |
![]() Join Date: Nov 2009 Location: Tempe, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,225
Groans: 65
| Not Ranked : 0 score Awesome, another great product from JBR. I will be ordering mine soon. |
| The Following User Says Thank You to AZSPEED3 For This Useful Post: | JBR (03-07-2012) |
(Thread Starter) | Not Ranked : 0 score Needs to mounted on the passenger side if you have a CAI. |
| Not Ranked : 0 score What's the recommended mount point on the passenger side? I scouted it out last weekend and wasn't sure where I wanted to mount it. Any recommendations from you would be great!
| The Following User Says Thank You to nindoja For This Useful Post: | ak_spray (03-07-2012) |
It's a bit of a pain in the ass. The bracket needs to be bent a bit and the power steering lines are sorta in the way too but it's doable. I'm sure there are others that have done this so I hope they chime in with suggestions. Thanks, Jamie | |
![]() Join Date: May 2009 Location: Scottsdale, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,450
| Not Ranked : 0 score My only complaint is that it's sometimes hard to see the pictures, with the black parts in front of a black background. OCC looks good though. If I ever decide to run a second one I'd probably get it.
__________________ 2009 MS3 sport MGM |
![]() Join Date: Aug 2008 Location: Orange County NY
Rep Power: 2267 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,484
| Not Ranked : 0 score wow AND includes everything you need. Thumbs up. I'll be picking this up soon
__________________ cp-e-FMIC/cp-e-HPFP/cp-e-Xcel Nano Intake/cp-e-Nviscid TIP/cp-e-BOV Kit/cp-e-Stage2 RMM/cp-e-xFlex Passanger & Driver Motor Mounts/cp-e-catted DP/cp-e-Nexus cat-back exhaust/cp-e-tow plate/cp-e-Tripple Gauge Pod/Rally Armor-Mud Flaps/TWM-Base Bushings/TWM-Shift Weight/Street Unit-Washer Fluid Cap/Street Unit-Oil Cap/Konig-Milligram/Corksport-Rear Sway Bar/Corksport-Aluminum Skidplate/StopTech-Sport Brake Kit/GTSpec-rear v-brace/GTSpec-link reinforecement panel/GTSpec-rear lower tie bar/GTSpec-4 points ladder brace/Lamin-x-Headlight film/Lamin-x-Taillight film/TWM-Full replacement shifter/TWM-Big Type R knob & Hybrid Knob/TWM-Shift boot/3M-1080 Matte Dark Grey Wrap/3M-1080 Brushed Steel Wrap/Tial-BPV/DG Motorsports-CF front lip/DG Motorsports-CF Rear wing extention/Sonic Tuning-Coilovers/COBB Tuning-AccessPort/ |
(Thread Starter) | Not Ranked : 0 score I'll show them to you in April. |
![]() Join Date: Jan 2009 Location: Andover, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,936
Groans: 192
| Not Ranked : 0 score I definitely want to get this because JBR's stuff is too notch. Just need to justify the money right now. lol. I will have to mount this on the passengers side.
__________________ precision gen2 5862 coming soon [SIZE="1"]07 MS3 GT.. Engine:Cobb V3,GTX3076r EWG,Wiseco Pistons/Manley Rods, L19's,JMF, Bosch 3.5bar MAP,CS cat-back,M2 DP, full race manifold,FP internals,FREEK 4",CP-E flange HKS,DO Stage II ss lines,Cobb piping,TR8L,MD RMM&TMM,JBR RSB & FSB,JBR SST,JBR knob,ACT 6puck,JBR EGR delete,CPE Seals,Grimmspeed EBC,JBR BSD,MD Catch Can.Looks:yellow lamin-x fogs,chrome turn signals,side moldings removed,20% tint,CS wheelSuspension/Wheels:Enkei RPF1 17x9,Eibach 5mm spaces H&R springs,koni yellows. GTX3076r --- 479/412 S4-460/400 Highest HP BNR S3 BNR-S3 424/397 |
| Not Ranked : 0 score OCC, Intake mani and throttle body gasket arrived! Thanks Jamie
| The Following User Says Thank You to Manny3 For This Useful Post: | JBR (03-12-2012) |
| The Angry Goose ![]() Join Date: Jun 2008 Location: Villa Park, IL
Rep Power: 701 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,192
Groaned at 9 Times in 6 Posts
| Not Ranked : 0 score Hmmm need to look and see if my FMIC blocks any of this kit first!
__________________ Hector 2014 Mazda 3 2008 Mazdaspeed3-SOLD 1979 Mazda Rx7 |
| The Following User Says Thank You to Hectik1 For This Useful Post: | JBR (03-14-2012) |
![]() | | #19 | ![]() |
![]() Join Date: Nov 2011 Location: Your House
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
| Not Ranked : 0 score I did my OCC install today. It took me about 1.5 hours to do with about 30 minutes spent trying to get the hose off my PCV value. The clamp was slightly melted or glued to the hose, so it wasn't moving away from the valve - eventually I was able to keep the clamp open long enough to just slide the hose off the value. Anyways I just had one question about the install. On the OCC, does the hose from the PCV valve go on the top outlet, or does the one from the intake go on the top? Based on what I read, the one from the PCV valve should go on the top outlet and that's how I installed it. Here are some pictures of the final install - if there are any issues with what you see, please let me know Last edited by econman; 03-18-2012 at 03:19 PM. |
| The Following 2 Users Say Thank You to econman For This Useful Post: | flappypaddles (10-16-2013), Manny3 (03-26-2012) |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score You read right. Everything looks perfect. Good job!! |
![]() | | #21 | ![]() |
![]() Join Date: Aug 2011 Location: AUSTIN, TEXAS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 147
| Not Ranked : 0 score looking forward to giving you some more of my money James. BTW is that Parker hose you use in the kit? If it is, I have double reason to buy them since my dad has been working for Parker for over 30 years.
__________________ 2010 LSM MS3 w/ Tech: Cobb AP, CorkSport SRI/TIP, JBR 80d RMM, JBR SSP, JBR SSB, JBR heavy knob, RallyArmor mudflaps, DDM 5k HIDs, Lamin-X fogs. |
| The Following User Says Thank You to jimmy For This Useful Post: | backward_0 (03-20-2012) |
![]() | | #22 | ![]() |
| The Following User Says Thank You to JBR For This Useful Post: | backward_0 (03-20-2012) |
![]() | | #23 | ![]() |
| Not Ranked : 0 score Inatalled my stage 2 last night. Took about 45min, luckily the hoses came off with just a little twist and pull. Had to trim the hose from PCV to OCC a bit but everything else in the kit was perfect fit! Another great product from JBR!! -Weird thing tho, after install, cover plate back on and everything ready to go, turned key and no start!?! WTF!? No click no nothing... checked for codes with AP, nothing.. Disconneted battery, still nothing. Took cover plate off and inspected everything that i installed, nothing unplugged..No start.. Pulled hoses off OCC, turned key, fired up!? Put everything back together and starts fine everytime, everything back to normal.. Weird.... ?? |
![]() | | #24 | ![]() |
![]() Join Date: Oct 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
__________________ 2008 MS3 AEM CAI, COBB TIP, HKS CB, TURBOXS BPV, COBB FMIC, JBR RMM, JBR OCC, CP-E CATTED DP, TB TIG, SnailD Tune E85 | |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score That's weird! |
![]() | | #26 | ![]() |
![]() Join Date: Oct 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,795
Groans: 89
| Not Ranked : 0 score Out of curiosity, who makes the actual catch can? Good to see another option for OCC's! |
| The Following User Says Thank You to 08.5MS3 For This Useful Post: | JBR (03-26-2012) |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score We have them made to our spec by a custom fab shop here in the states. |
| The Following 2 Users Say Thank You to JBR For This Useful Post: | 08.5MS3 (03-26-2012), Sacrilicious (04-09-2012) |
![]() | | #28 | ![]() |
Groans: 89
![]() | | #29 | ![]() |
| Not Ranked : 0 score Just wanted to post an update... I checked the installation and catch can after about 3 weeks and I got about an ounce or two out of the catch can. Installation looked good too - no leaks or other issues that I could tell. Last edited by econman; 04-04-2012 at 05:26 PM. |
![]() | | #30 | ![]() |
Groans: 89
![]() | | #31 | ![]() |
![]() Join Date: Jun 2010 Location: Mirabel, Quebec
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 605
| Not Ranked : 0 score I will order my stage2 OCC this fall, thanks Jamie for making this kit. How do those OCC fair in winter? At -35celcius everything should freeze inside...
__________________ Sold 2010 Speed3 Black Mica tech pack, JBR RMM 80 duro, Cobb SRI, stupid horn fixed with low tone add on. New 2012 Mazda2 GS Aluminum Metallic Mica, Corksport rear torsion bar, Corksport H11 Led fog bulbs, Piaa H4 x-treme white bulbs, AWR rmm 70duro....more to come Wife's car 2011 Mazda2 True Red GS (Touring in the US), wifes car, no mods so far but she want a Corksport CBE, Corksport SRI and a drop in the futur. <----- ![]() [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to Scoobs For This Useful Post: | JBR (04-10-2012) |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score Everything will freeze but, it will thaw pretty quickly after driving for a bit. You'll want to check and/or drain after the car has been run for a while. Jamie |
![]() | | #33 | ![]() |
| Not Ranked : 0 score Good to know.
![]() | | #34 | ![]() |
![]() Join Date: Nov 2010 Location: Alhambra
Rep Power: 524 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 237
Groaned at 35 Times in 14 Posts
| Not Ranked : 0 score I took my OCC off for dealer work a couple months back and haven't put it back on yet. I'm pretty sure I had pre-detonation (I'm thinking it might be the gas in CA, lots of additives for smog laws and 91 is the highest octane we get) and the OCC helped, because it never happened when it was on, but I've had it a couple times since I took it back off. Do you have a bracket for the CX-7 OCC? |
| The Following User Says Thank You to bzwyatt For This Useful Post: | JBR (04-11-2012) |
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score I believe the bracket we currently include should work just fine for mounting on the CX-7 although I've never installed a kit on one. Have a look at the installation instructions in the support section of our website. Thanks, Jamie |
![]() | | #36 | ![]() |
![]() Join Date: Dec 2008 Location: Toledo OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 324
| Not Ranked : 0 score Alright I should be getting one of these soon. I have a question about something answered above already. From the PCV valve, should that hose not connect to the bottom of the OCC? My thought is if thats where its coming from, as its dripping (into the occ) from the top, couldnt air return some of that into the line heading into the manifold? Im sure the amount would be negligible even if it did make it all the way up there. Just curious as to why pcv>top hole is preffered. Thanks!
__________________ | CP-E 75 Duro RMM/TMM + TBE | Corksport SR/TI | Forge BPV | Cobb AP- DJ Tuned | NGK Plugs | Hotchkis RSB @ 140% | PTP IM Gasket/TB Coolant Delete + BSD | Autotech FPi | AEM Meth Injection | SU TMIC | JBR SSP + Stage2 OCC |PG Oil Filter Conversion | Toyota Injector Seals | Bizzerko PnP IM | Grimmspeed EBCS | Ingalls ETD | Sonic Tuning S3 Coilovers |Fluids Rotella T6 A lot Rislone Engine Treatment Motorcraft XT-M5-QS(trans) VP Methanol ~Splash of E85~ |
| The Following User Says Thank You to thatsmrgimp2u For This Useful Post: | JBR (04-16-2012) |
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score Oil will typically not drip from the upper line unless the car isn't running. When the car is running the oil and vapor will be blown across the can to the back wall. There are no hard angle surfaces inside the can so the oil is spun around the walls of the can through 4 screens and collects in the bottom. Is some oil vapor drawn out of the can in to the intake, yes. This is the case with every catch can but, the amount is so significantly less then with out the catch can. Thanks, Jamie |
| The Following 2 Users Say Thank You to JBR For This Useful Post: | econman (04-16-2012), thatsmrgimp2u (04-22-2012) |
![]() | | #38 | ![]() |
Groans: 89
| Not Ranked : 0 score While I don't have JBR's kit, I do have a catch can. If you're on the fence about it, just get it. I drained mine about 2 months ago and got so much shit. The containers I drained them into were then "eaten" by the gunk. Fucking disgusting. Last edited by 08.5MS3; 04-16-2012 at 09:39 AM. |
![]() | | #39 | ![]() |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
| Not Ranked : 0 score Silly question, does the OCC kit interfere with the Commifornia Smog BS equipment? Will the smog police have an issue with it? |
![]() | | #40 | ![]() |
| Not Ranked : 0 score I had mine on (Los Angeles) for a few months and had no problems with any CEL or other codes. It won't negatively effect the actual exhaust either, so no, it won't have any impact on passing smog. |
| The Following User Says Thank You to bzwyatt For This Useful Post: | JBR (04-17-2012) |
| JBR EGR Block Off Kits In Stock!! | JBR | JAMES BARONE RACING | 137 | 03-21-2015 07:33 PM |
| 06' - 2011 MAZDA 5 Short Shift Plate Kits In Stock!! | JBR | JAMES BARONE RACING | 4 | 06-18-2010 07:38 AM |
| 06' - 2011 MAZDA 3 Short Shift Plate Kits In Stock!! | JBR | JAMES BARONE RACING | 3 | 06-18-2010 07:38 AM |
| AEM Water/Meth Injection Kits In Stock | Performance Racing | Mazdaspeed3/6 General Discussion | 3 | 04-10-2008 05:09 PM |
