 Old 10-06-2011, 08:03 PM   #1
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Default JBR SSP vs TWM short shifter
I just tossed my TWM short shifter because I was having 2nd gear grinding issues because it wasnt going all the way into gear. My understanding is that the Jbr ssp goes on the trans end of thethe cables and doesnt mess with the shifter at all. Does the Jbr ssp fully go into all gears out of the box or am I going to have to spend all afternoon dicking with it like I apparently have to do with the twm?
Thanks Jamie, im really not up on my short shifter stuff.
2006 Mazdaspeed 6
 Old 10-07-2011, 11:21 AM   #2
I think you'll be very pleased with the kit.
06Speed6 (10-08-2011), breakfstincluded (10-10-2011)
 Old 10-07-2011, 12:24 PM   #3
atvfreek's Avatar
Posts: 7,787   (View Stats)
Bolts up in 10min. No adjustments needed.
Sent from my Desire HD using Tapatalk
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
 Old 10-07-2011, 12:25 PM   #4
TRex's Avatar
Posts: 3,139   (View Stats)
^not exactly....it bolts up in 10 min
but it is still recommended that you adjust your shifter...granted it is far less complicated from what i have seen than the twm....look up the vids on jamies site regarding the adjustment to see how long it takes....not bad at all
The Following 3 Users Say Thank You to TRex For This Useful Post:
06Speed6 (10-08-2011), silvapain (10-10-2011), SLOWHATCH (10-08-2011)
 Old 10-08-2011, 01:06 AM   #5
Speeeeeed
06Speed6's Avatar
Thanks guys, ill check it out
2006 Mazdaspeed 6
 Old 10-08-2011, 01:20 AM   #6
asall667's Avatar
Posts: 1,017   (View Stats)
asall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the world
Groans: 56
Groaned at 37 Times in 18 Posts
I'm prolly the only one to say this and get flamed for it but oh well....
I hated my SSP it caused grinding and missed shifts alot!!! I fine tuned it to my liking and still grinding happened. That's why I sold it and I have yet to grind a gear stock!
The shorter throws were great improvement when your daily driving shifting normal but when you start shifting fast, that where it will get you. That's just my experience.
2007 CBM MS3 GT 66K
Mods:
--Cobb SF SRI--Corksport TIP-- Speed Daddy FMIC Piping w/ TR8 Core--CPE 75A RMM--Test Pipe--Both res delete--TWM Short Shifter--Custom Fabric wrapped A pillars & Side Pillars--Gunmetal PC Genpu Wheels--Mazdaspeed Red Calipers (front & rear)--Laminx Fog Overlays--Foglight Mod--3M Gloss Black Roof--Custom Mudflaps--Evil Flying M--CPE Triple Gauge Pod--Propsort Boost-Oil Temp-Oil Pressure Gauges--Prosport Sammich Plate--SU Oil Spin On Conversion--Magnetic Drain Plug--Raceland Coilovers--SPC Rear Camber Arms--15MM H&R Spacers--Hawk HPS pads--Turbosmart Plumb Back BPV----
New VVT as of 50K miles Thanks Young Mazda
New K04 Turbo as of 57K miles Thanks Young Mazda
asall667 is offline   Reply With Quote
The Following 2 Users Say Thank You to asall667 For This Useful Post:
06Speed6 (10-09-2011), TRSpeed (10-09-2011)
 Old 10-08-2011, 03:23 PM   #7
TRex's Avatar
^i did have some issues but i switched from the heavy weight that jamie sends with the ssp and went back to the stock weight....has worked real well for me
The Following User Says Thank You to TRex For This Useful Post:
 Old 10-08-2011, 03:47 PM   #8
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Mine worked like a charm, go stage two and pick up the bushings and the SSP, you won't regret it.
And if you aren't looking for the "shortest" throw, get the adjustable plate and you can back it off a bit.
Good luck, JBR ftw
 Old 10-09-2011, 03:43 PM   #9
Speeeeeed
06Speed6's Avatar
Ive been looking into the adjustable one, the shift weight im still on the fence because i dont really understand why and how it makes shifting better.
Ide buy a weighted knob but they wont make a ceramic coated version. I cant imagine trying to cool off a 140* shift knob with twice the mass of the stock one.
2006 Mazdaspeed 6
 Old 10-10-2011, 07:07 AM   #10
TRex's Avatar
^i see it like this
you are using the shifter to push a rod with a weight on the end of it....so the lighter the weight on the end of the rod the easier it is going to be to push that rod...however i believe the weight on the end also helps with getting it into gear (i am not 100% positive on that) so i think it is probably a fine line between too heavy and too light
 Old 10-10-2011, 07:25 AM   #11
Vater's Avatar
Posts: 1,004   (View Stats)
Vater is the leader of the worldVater is the leader of the worldVater is the leader of the worldVater is the leader of the worldVater is the leader of the worldVater is the leader of the worldVater is the leader of the worldVater is the leader of the worldVater is the leader of the worldVater is the leader of the worldVater is the leader of the world
I wasn't a fan of the weighted knob. The stock one feels better in my hand and the shifts feel notchier.
I definitely recommend getting the solid bushings, though--they really complete the whole short shift package. The shifter has too much play in it otherwise.
NoVA's first pu
2010 Mazdaspeed3 Sport | Black Mica w/ Tech Package
__________________________________________________ _______________________________________________
| JBR SSP Stage 2 | JBR 88 duro RMM | Sure Aeros SRI | HTP TIP | DDM HID lows | Corksport LED fogs |
| FIAMM low tone Freeway Blaster | Kumho Ecsta LE Sport (stock wheels) | Black 16x7 Flik FTDs (winter) |
______________________________| 215/55/R16 Falken Eurowinters (winter) |____________________________
Vater is offline   Reply With Quote
 Old 10-10-2011, 08:49 AM   #12
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Shift weighting is a preference. I prefer a light, notchy feel so I use the stock knob with no weight at all on the shifter arm at the transmission.
Play around with different knob/weight combos and find the balance that works best for you.
Tapadatass
 Old 10-10-2011, 09:28 AM   #13
Vater's Avatar
I didn't think it was possible to remove the weight entirely, though I don't remember exactly how it mounts. I thought the screws mounted directly to the weight; did you use nuts to keep the plate on the shifter arm?
NoVA's first pu
 Old 10-10-2011, 11:00 AM   #14
silvapain's Avatar
Groans: 136
Yes. Nylocks specifically, and I used lockwashers as well for added safety.
Tapadatass
TRex (10-10-2011), Vater (10-10-2011)
 Old 10-10-2011, 11:17 AM   #15
TRex's Avatar
do you remember what size off hand...i have wanted to try no weight
 Old 10-10-2011, 11:33 AM   #16
silvapain's Avatar
Groans: 136
No, I'm afraid I don't. I'd guess offhand they are M8's.
I bought longer bolts along with the nuts and washers to ensure there were enough threads for everything.
Tapadatass
 Old 10-10-2011, 11:50 AM   #17
Vater's Avatar
Unacceptable. I suggest you go measure them and tell me exactly what I need to get. Some people...
NoVA's first pu
The Following User Says Thank You to Vater For This Useful Post:
Page generated in 0.35215 seconds with 27 queries
