Like Tree9Likes
 Old 09-04-2011, 01:02 PM   #41
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
bad news... rounded the top right 12mm ps bolt. no room for a socket and you have one shot with a wrench. got too used to all the dainty 8mm bolts and should have let these soak with pb blaster. don't know if there's enough room for a craftsman damaged bolt remover.
Craftsman 10 pc. Damaged Bolt/Nut Remover Set, Low Profile Bolt-Out Reviews - Craftsman Community
 Old 09-04-2011, 01:05 PM   #42
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
Damn failman
 Old 09-04-2011, 01:14 PM   #43
patrick failman
Groans: 74
faliure is an excuse to run to sears and buy more tools.
The Following 5 Users Say Thank You to karl-hungus For This Useful Post:
86AmishMs3 (09-05-2011), b1iNkl82 (09-07-2011), rfinkle2 (10-11-2011), ScarMS3 (12-10-2011), SLOWHATCH (03-08-2012)
 Old 09-05-2011, 08:17 AM   #44
MSP611's Avatar
Posts: 2,291   (View Stats)
+1 for above comment lol!!
In progress:
 Old 09-05-2011, 08:35 AM   #45
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Stop the user failure!! that's what scares so many people away from these manifold gaskets.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 09-05-2011, 08:45 AM   #46
patrick failman
Groans: 74
i bought the craftsman kit (saved 5 bucks buying online) so i'll try again next week. also the black electrical connector is a fucking bitch.
 Old 09-05-2011, 01:40 PM   #47
patrick failman
Groans: 74
got the ps bolt to turn using the #4 bolt remover and some more pb. will re-attack next weekend. my only remaining fears are hulking the ps pump back into place and that black electrical connector.
 Old 09-05-2011, 03:07 PM   #48
When putting the PS pump back in place grab it by the pulley; real easy to do.
 Old 10-11-2011, 06:39 AM   #49
skeurton's Avatar
Posts: 745   (View Stats)
skeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the world
Installed both TIGs on Sunday with help from @Geo13. I just wanna say how amazed we both were with the detail of the instructions. Then again, I've never seen anything less than thorough from JBR, so it was to be expected.
Didn't experience a single problem.... except for my own stupidity when I dropped a socket into the radiator. Thank god for magnets!!!
rfinkle2 and Geo13 like this.
2011 MAZDASPEED 3
BNR: 352 hp / 342 ft-lbs
K04: 296 hp / 343 ft-lbs
BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges
skeurton is offline   Reply With Quote
The Following 5 Users Say Thank You to skeurton For This Useful Post:
Geo13 (10-11-2011), JBR (10-11-2011), redboat (02-27-2014), rfinkle2 (10-11-2011), SLOWHATCH (03-08-2012)
 Old 10-11-2011, 06:42 AM   #50
hmmmm. Contemplating this daily.
 Old 10-11-2011, 07:04 AM   #51
Geo13's Avatar
Posts: 856   (View Stats)
Geo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the worldGeo13 is the leader of the world
Groans: 107
Groaned at 8 Times in 7 Posts
DO IT @rfinkle2!! You know you want too (I know I want too).....cause after hearing @skeurton talk about his lower BAT's it's worth it...
SPONSORED BY MY WIFE- 2010 Mazdaspeed3 Black Mica (DeadPool): COBB AP Stage 2+(Custom skeurHYPNOTICton Tune), JBR TRILOGY 88D DogBone, 70D TMM & PMM, RSB, OCC, EGR Block Off, Mudflaps, TURBOSMART 50/50 BOV, Tanabe Strut Tower Bar, Moddiction Anvil, TWM Full Replacement Shifter, Fortune Auto 500 Coilovers, SPC Adjustable Camber Arms, Autotech Internals, Denso ITV24, ETS TMIC, UR Catted Down Pipe & Resonated Test Pipe, Corksport 3" Power Series Intake, CBE, GrimmSpeed 3 Port EBCS, Proto Tuning AP Holder, ProSport EVO Boost & AFR Gauge, Ultragauge Classic, Block8Head Dual Vent Pod, DDM Lows: 35w/6K & Fogs: 35w/3k HIDs, Headlight Armor Yellow Fog Overlays, some SURE stuff...still iNATORva
2 Reckless By Speed + 3 Speeding = Mazdaspeed3 (no more parts and a pissed off wife)
Geo13 is offline   Reply With Quote
The Following 2 Users Say Thank You to Geo13 For This Useful Post:
rfinkle2 (10-11-2011), skeurton (10-11-2011)
 Old 10-11-2011, 08:35 AM   #52
It really is easy if you can read.
Geo13 and skeurton like this.
Geo13 (10-13-2011), skeurton (10-11-2011)
 Old 10-11-2011, 08:46 AM   #53
Well, that could be a problem... j/k.
I'm ordering soon.
Should I order through JP or your site?
 Old 10-11-2011, 09:11 AM   #54
Whom ever you prefer.
Thanks,
Jamie
 Old 10-11-2011, 09:56 AM   #55
Lost hawaiian's Avatar
Posts: 226   (View Stats)
Lost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the world
For us slow people Jamie, We can stack 1-4 with out any extra parts as long as we follow your instructions. If so I'll be ordering EGR and TB and 2-4 Mani Gasket kits.
Lost hawaiian is offline   Reply With Quote
The Following User Says Thank You to Lost hawaiian For This Useful Post:
 Old 10-11-2011, 10:20 AM   #56
Yes up to 4 with no additional hardware.
Just a word of caution when using more than 3...In step 24 it says to loosen the 2 rear fuel rail cover bolts. I would suggest removing them, then complete the remainder of the installation. Then reinstall the 2 rear bolts ensuring that they line up and thread in properly. If they don't you can remove the front 2 fuel rail cover bolts, and enlarge the two rear cover holes with a file or drill until the bolts line up and thread properly. It's super easy. You can leave the rear two bolts out if you wish as well.
Thanks,
Jamie
Lost hawaiian likes this.
The Following 7 Users Say Thank You to JBR For This Useful Post:
asall667 (10-11-2011), Geo13 (10-13-2011), Lost hawaiian (10-11-2011), redboat (02-27-2014), rfinkle2 (10-11-2011), skeurton (10-11-2011), stang9779 (10-11-2011)
 Old 10-12-2011, 09:33 AM   #57
asall667's Avatar
Posts: 1,017   (View Stats)
asall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the world
Groans: 56
Groaned at 37 Times in 18 Posts
hey jamie any pics of how thick are they? and installed?
2007 CBM MS3 GT 66K
Mods:
--Cobb SF SRI--Corksport TIP-- Speed Daddy FMIC Piping w/ TR8 Core--CPE 75A RMM--Test Pipe--Both res delete--TWM Short Shifter--Custom Fabric wrapped A pillars & Side Pillars--Gunmetal PC Genpu Wheels--Mazdaspeed Red Calipers (front & rear)--Laminx Fog Overlays--Foglight Mod--3M Gloss Black Roof--Custom Mudflaps--Evil Flying M--CPE Triple Gauge Pod--Propsort Boost-Oil Temp-Oil Pressure Gauges--Prosport Sammich Plate--SU Oil Spin On Conversion--Magnetic Drain Plug--Raceland Coilovers--SPC Rear Camber Arms--15MM H&R Spacers--Hawk HPS pads--Turbosmart Plumb Back BPV----
New VVT as of 50K miles Thanks Young Mazda
New K04 Turbo as of 57K miles Thanks Young Mazda
asall667 is offline   Reply With Quote
 Old 10-12-2011, 08:48 PM   #58
asall667's Avatar
Groans: 56
@jbarone
2007 CBM MS3 GT 66K
Mods:
 Old 10-13-2011, 05:24 AM   #59
The only pictures I have are in the install instructions... www.jamesbaroneracing/support
 Old 10-16-2011, 04:39 PM   #60
JohnMS3's Avatar
Posts: 754   (View Stats)
JohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the world
just did the tb tig and coolant bypass...10* of reduction in bats already. how big of a difference is seen if two gaskets are stacked vs one gasket?
-John
| Cobb AP | Cobb SRI/TIP | CXRacing/Godspeed FMIC | AQ Motorsports downpipe | Mazdaspeed CBE | Autotech HPFP internals | Koni Yellows | Eibach Prokit | Progress RSB | Mazdaspeed camber arms | CPE RMM | TWM shortshifter/bushings | Redlinegoods shifter/e-brake boots | Defi Red Racer boost gauge | RPM ventpod | OEM RX8 wheels | Yokohama S-drive 245/40/18 | Volt 4300K HID | Ho-en yellow fogs | Mazda5 rear rotors | Dual Fiamm horns |
JohnMS3 is offline   Reply With Quote
The Following User Says Thank You to JohnMS3 For This Useful Post:
 Old 11-28-2011, 12:46 PM   #61
NinjaT1985's Avatar
Posts: 551   (View Stats)
NinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the world
Groaned at 33 Times in 10 Posts
Just ordered TB TIG. Thanks Jamie!
2012 Toyota Tacoma
NinjaT1985 is offline   Reply With Quote
The Following User Says Thank You to NinjaT1985 For This Useful Post:
JBR (11-30-2011)
 Old 12-09-2011, 06:32 AM   #62
daztdMS6's Avatar
Posts: 214   (View Stats)
daztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond repute
I ordered and recieved my TB TIG. I can't wait to install it. Thank you Jamie.
MazdaSpeed 6
DashHawk, CorkSport TIP & SRI, CorkSport TMIC, SU RMM, CPE rear diff mount, Perrin EBCS, TurboSmart BPV, TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, JBR EGR deletion & TIG, silicone boost tubes, Bilstein HD shocks, LED light bulbs, TRS clear projectors, 35W DDM Tuning HID foglights, Hawks HPS brake pads, Amsoil in the rear diff, pto & trans, factory navi, XCarLink USB.
daztdMS6 is offline   Reply With Quote
 Old 01-31-2012, 08:58 AM   #63
speedms6's Avatar
Posts: 825   (View Stats)
speedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the world
just ordered both today installing with new injector seals
2007 Mazdaspeed 6 - Ptp SST, Cobb AP, SSP 3.5" Intake, SURE Sidewinder, Autotech HPFP Internals, PTP 2150 psi HPRV, Cp-e Injector Seals, PTP Injector Studs, Jbarone TIG's, VTCS Delete, ETS 3.25" TMIC, M2 Catless Downpipe, Magnaflow Catback Exhaust, MD OCC, Denso ITV 22, H & R springs, Energy Suspension Rear Sway Bar Bushings, Dashhawk, Hawk HPs Pads, Centric Rotors, Street Unit Rear Motor Mount, TWM Stage II Shifter with Solid Bushings and Weighted Shift Knob, Autometer Mechanical Boost Gauge
speedms6 is offline   Reply With Quote
The Following User Says Thank You to speedms6 For This Useful Post:
JBR (01-31-2012)
 Old 02-10-2012, 04:11 AM   #64
Speedie6's Avatar
Posts: 1,838   (View Stats)
It seems to me that using a hose barb for the bypass is a waste of time when you can buy 2 feet of 5/16" hose for less and not have a splice.
 Old 02-10-2012, 06:31 AM   #65
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
Or you can just reuse the stock line, no $$ necessary.
The Following User Says Thank You to wolly6973 For This Useful Post:
 Old 02-10-2012, 07:07 AM   #66
You're actually buying the gasket and getting the caps and barbed coupling for free. That Pretty cheap.
anavrinIV (09-26-2012), wolly6973 (02-10-2012)
 Old 02-10-2012, 07:18 AM   #67
Speedie6's Avatar
Nothing is "free". You presumably would charge a buck less or so if it didn't come with the barb. But I know you give good products and good prices. So its not a big deal. I think I'm more saying, in general, don't splice hoses if you can just as easily not.
 Old 03-08-2012, 08:03 PM   #68
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
I just ordered an intake mani tig. How does this compare in thickness to the 1/16" thick gaskets? Did a google search but it says its some weird number like 31/500????
 Old 09-17-2012, 07:08 PM   #69
Bump.
I wish I hadn't waited this long to install the tig (for the intake manifold).
Initial look @ BAT's show @ least a 10* drop in the gap between BAT's and IAT's.
anavrinIV (09-26-2012), Boost_creep (09-18-2012), skeurton (09-17-2012)
 Old 09-17-2012, 07:10 PM   #70
skeurton's Avatar
Bump.
I told you!
2011 MAZDASPEED 3
The Following User Says Thank You to skeurton For This Useful Post:
rfinkle2 (09-17-2012)
 Old 09-17-2012, 07:17 PM   #71
Originally Posted by skeurton View Post
I told you!
I listen to you very carefully! I just bitched out until this weekend when I saw the intake manifold debacle.
To anyone wanting to install these, it really is pretty straightforward and assuming you follow the directions, you'll be happy you put the time in to install.
@skeurton, I may even get really ballsy and put 2 on!
skeurton likes this.
08.5MS3 (09-17-2012), skeurton (09-17-2012)
 Old 09-17-2012, 10:05 PM   #72
lilred's Avatar
Posts: 5,792   (View Stats)
I have mine waiting for whenever I want to/ have time to do seals and valve cleaning while I'm in there
tapafuck
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
 Old 09-20-2012, 11:54 AM   #73
Thermal gaskets yield the best performance for the investment.
Zdraveca (09-21-2012)
 Old 09-22-2012, 04:17 PM   #74
KRNAGE's Avatar
Posts: 120   (View Stats)
KRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond repute
installed TB TIG
installing more JBR parts today
06 Black MPS3 Sport Pack - Australia edition
Cobb AP (RichTune e85 / 98 maps) - Autotech HPFP Internals, JBR WP, CorkSport DP, Catback, Forge v1 BPV, Denso ITV22, PG FMIC Pipes JDM Core - TWM SS, PG Shift Weight, JBR Heavy Knob - JBR 88 Trilogy - JBR Rear Sway bar, Yellowspeed Coilovers, Centric Slotted/Drilled Rotors, Hawk HP+ pads, RX8 gen1 wheels - HTP Battery Tray - JBR EGR delete, JBR TB TIG - Spin-on oil convert - Polarised HU Screen
EXE-Crew
KRNAGE is offline   Reply With Quote
The Following User Says Thank You to KRNAGE For This Useful Post:
JBR (09-22-2012)
 Old 09-25-2012, 07:05 PM   #75
Speedie6's Avatar
Well, hate to be a spoil sport, but, do you actually have any dyno reads to back that up? I rather doubt you do. On one hand, yeah, I think it is indeed generally worth it to have. Particularly on our cars. It does dramatically lower apparent BATs. But, the change is 99% apparent rather than real. The issue is, on our cars, the BAT sensor is attached to the IM. So, a hot IM raises the measured BAT a great deal. But, in reality, the air contact time with the IM is negligible and therefore actually transfers negligible heat to the air.
So, it is kinda neat how dramatically cooler the IM is after installing a gasket. And it is good to improve the accuracy of the BAT. Which could possibly lead to some performance gain. But if you think you are actually lowering your BAT (as opposed to mearly lowering the readings) then you are mistaken.
 Old 09-26-2012, 05:29 AM   #76
What was I thinking?
exentix (09-26-2012)
 Old 09-26-2012, 07:13 AM   #77
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
since every running parameter of this car is based off of sensor readings, I'd say having a lower BAT reading would be almost more beneficial than actually having lower BATs. So yeah...by your own admission they're pretty useful.
Blue Pu.
 Old 09-26-2012, 08:29 PM   #78
Speedie6's Avatar
Fair enough. But, many people think they are actually getting lower BATs. If, indeed, the more accurate measurement does result in more power, then great. But, I'd still like to see the claim backed up. Jamie just stated it like it is a fact that you will get performance gain. Perhaps you and he are right and you do. Fine, great. But, do you know that for a fact if you haven't dyno'ed it?
 Old 09-26-2012, 08:51 PM   #79
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
Well either way it works. If it cuts down actual heat or just helps cut down the amount of heat that actual reaches the sensor. The BATs the sensor reads are less which leads to more power. We all know that high BATs kill this car power wise. Thats no secret.
@jbarone Count me in for a order!
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 09-27-2012, 08:46 AM   #80
Speedie6's Avatar
Don't get me wrong, I think it is likely worth having, and I have one. I currently run one "from another vendor" but only because I bought it before Jamie had his.
Page generated in 0.58829 seconds with 40 queries
