 Old 08-17-2013, 04:32 PM   #1
Spawn's Avatar
Posts: 47   (View Stats)
Spawn is a splendid one to beholdSpawn is a splendid one to beholdSpawn is a splendid one to beholdSpawn is a splendid one to beholdSpawn is a splendid one to beholdSpawn is a splendid one to beholdSpawn is a splendid one to behold
Default downshift issues?
First off I have not done any adjustment to my shifter yet!! I am looking to get different opinions on what may or may not be my issue. I installed my shift plate, weight and bushings into my 2012 speed 3 with 20,000km and set it at the shortest setting. I have zero issues upshifting in any of the gears during any type of driving, be it casual or spirited. My only issue is the 3rd to 2nd downshift during a higher rpm. If i wait until the downshift would be around the 2500 to 3000 rpm range its fine. Any higher rpm and I get some resistance, or the occasional very slight grind.
Black 2012 Speed3, cobb AP, autotech internals, JBR dogbone, JBR SRI/TIP, JBR SSP, UR testpipe, CP-E triton, JBR knob, JBR OCC
Spawn is offline   Reply With Quote
 Old 08-17-2013, 04:50 PM   #2
Koke382's Avatar
Posts: 4,361   (View Stats)
Check and see if its loose? A member in here just had a similar issue with grinding in 2nd and 3rd turns out his shit was loose.
Sent from my SPH-L900 using Tapatalk 2
2007 Mazdaspeed 3 GT
18x8.75 XXR 527 225/40/18r
New fucken miata build:
1993 Red Na6
Some suspension modz yo
Coilovers// Other shit
 Old 08-17-2013, 05:28 PM   #3
Spawn's Avatar
everything is tight!! I lengthened the throw just off the shortest setting to see if anything changes.
 Old 08-17-2013, 05:42 PM   #4
motherfnmonsta's Avatar
Posts: 2,308   (View Stats)
Groans: 106
maybe it is your transmission locking you out cause you are at two high of speed and high rpm to down shift to 2nd
 Old 08-17-2013, 06:35 PM   #5
gigliotti175's Avatar
Posts: 750   (View Stats)
gigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the world
Groaned at 25 Times in 15 Posts
What he said^
gigliotti175 is offline   Reply With Quote
 Old 08-17-2013, 07:25 PM   #6
Spawn's Avatar
It is better with the lengthened throw. I'm not downshifting at some astronomical rpm! During spirited driving I try and rev match my downshift between 3k and 4k max.
 Old 08-17-2013, 10:08 PM   #7
Why would you want to down shift in to 2nd at that high an RPM? It's your trans telling you not to. Stick to below 3k and rev match.
 Old 08-18-2013, 11:50 AM   #8
Spawn's Avatar
When I downshift I rev match and aim to have second come in at the rpm I stated above. If it ever reaches 4k its my own fault and I understand that, but is there something wrong with trying to stay in the cars powerband and aim to be at 3k when second gear engages?
 Old 08-18-2013, 11:56 AM   #9
ilias's Avatar
Posts: 335   (View Stats)
ilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the worldilias is the leader of the world
Groaned at 9 Times in 2 Posts
I got the same problem on 2th gear 2500 rpm and up.
After awhile I just got used to it.
Cobb AP V3 // CPE HPFP // CS Downpipe // CS Coilovers // CS Rear Camber Arms // CS SRI and TIP // CS Oil Catch Can // CS RMM & TMInsert //
JBR RSB, Short Shift and bushing // Turbosmart BOV // NGK one step colder // ETS TMIC // STRATIFIED //
ilias is offline   Reply With Quote
 Old 08-18-2013, 01:08 PM   #10
Quigs's Avatar
Posts: 1,152   (View Stats)
Maybe you should adjust your shifter? You said you haven't done it yet, so it may be the next logical step.
2009 Mazdaspeed3
2000 Mazda Miata MX-5
NASA TTE build ongoing
 Old 08-18-2013, 03:43 PM   #11
Spawn's Avatar
Very Logical yes! But why is it only on the downshift? Upshifts are fine in every gear no matter how fast or slow my shifting is, no matter what rpm. ilias how many miles on your tranny since your install?
 Old 08-18-2013, 04:29 PM   #12
ilias's Avatar
I have 20 000 mils on it. You can try adjusting the shifter, but I don't think is going to help,
It's just the way the shifter is made.
 Old 08-18-2013, 06:09 PM   #13
Quigs's Avatar
When I put my JBR shift plate on it shifted up fine...my issues were downshifting from 6th-5th and 3rd-2nd. Adjusted the shifter and it's been fine ever since.
Just a suggestion since you haven't tried it yet. I also rev-match lower in the RPM range, so maybe that's why mine goes into second a little easier. I start my match at about 2000-2200 RPM and depending on how aggressive I'm driving sometimes it will end up being just shy of 3000 when second catches and engages. Never more than 3000 though, so maybe that's the point where the car is trying to tell you to not put it into gear at that high of a RPM. I dunno haha.
2009 Mazdaspeed3
 Old 08-18-2013, 08:32 PM   #14
Groans: 106
2013 Speed 3, Loud pop during downshift and slight power loss pwnall1337 2010 MS3 - Engine, Transmission & Driveline 59 08-06-2013 07:04 AM
Will this rim fit with no issues? punkwrock 2010 MS3 - Wheels & Tires 2 10-09-2012 01:27 PM
Downshift, neutral coast, clutch in coast? Tiltsta Gen2 MS3 General Discussion 50 03-21-2012 06:31 PM
Help Please Having Issues CruZ_MS6 Mazdaspeed3/6 General Discussion 2 12-09-2011 08:28 PM
Downshift to 1st gear grinds?? akabickle 2010 MS3 - Troubleshoot/Diagnostics 51 05-17-2011 08:32 AM
Page generated in 0.34195 seconds with 26 queries
