Like Tree4Likes
  • 4 Post By Raider
 Old 04-26-2013, 10:02 PM   #1
torq's Avatar
Posts: 82   (View Stats)
torq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond reputetorq has a reputation beyond repute
Groaned at 6 Times in 3 Posts
Default Confused, just swapped from 70 duro to 88 molly
As the title says, I just swapped from a 70 duro billet RMM to an 88 chrome-molly, and I've getting a lot less NVH now. Idle below 1k now doesn't feel like I don't want to be there, I expected the opposite.
The 70 duro had about 6k kms on it, no visible damage when I took it out. A tiny bit deformed but nothing major.
What gives?
Cobb AP Autotech HPFP Internals JBR RMM,SSP,Stage2 OCC. RSB CS Racepipe, SSB ETS TMIC Stratified Guardian Angel NGK Step Colder Plugs HTP 3" full intake. Michelin 245/40/18 Pilot Super Sports TSW 18x8.5+45 Nurburgring Wheels Swift Spec-R Springs Koni Yellow Struts/Shocks GFB BOV
torq is offline   Reply With Quote
 Old 04-26-2013, 10:04 PM   #2
manila's Avatar
Posts: 1,767   (View Stats)
I like my dog bone, get mounted or go home! @jbarone;
'12 MS3 Black Mica w/ Tech
The Following 2 Users Say Thank You to manila For This Useful Post:
danosrk (05-02-2013), Rokusek (04-29-2013)
 Old 04-26-2013, 10:37 PM   #3
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
I have JBR's 70 and I experience almost no vibes since it broke in.
 Old 04-27-2013, 05:58 AM   #4
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
What was the 70duro RMM ?
 Old 04-27-2013, 06:06 AM   #5
Mfinlay04's Avatar
Posts: 827   (View Stats)
Same brand of mounts?
2006 MS6 Titanium Grey
Tuned with
 Old 04-27-2013, 07:24 AM   #6
What gives?
I bet the 70 was a little loose.
5doorsoffury (04-27-2013), ABolewski (04-27-2013)
 Old 04-27-2013, 07:31 AM   #7
I say that after visiting nursing homes.
The Following 29 Users Say Thank You to Raider For This Useful Post:
5doorsoffury (04-27-2013), ABolewski (04-27-2013), ABSpeed3 (04-27-2013), Apacheguy1584 (04-28-2013), AZSPEED3 (04-28-2013), BobbleHead (04-28-2013), caesura (04-27-2013), Code Monkey (04-27-2013), CrawlingMS3 (04-27-2013), danosrk (05-02-2013), El_Diablo (04-27-2013), GODspeed7 (04-27-2013), GunGuru727 (04-27-2013), Hush (04-27-2013), JBR (04-27-2013), Kfunk (04-27-2013), KusteLokal (04-27-2013), Kyle Undefined (04-27-2013), meelo88 (04-30-2013), Menace1 (04-27-2013), Micha (04-28-2013), MizzyMS3 (04-27-2013), motherfnmonsta (04-29-2013), Playaj (04-27-2013), pzr2874 (04-27-2013), RevolverRob (04-27-2013), Rokusek (04-29-2013), SarcasticOne (05-08-2013), stevenlapensee (04-28-2013)
 Old 04-27-2013, 08:30 AM   #8
ABolewski's Avatar
Posts: 1,279   (View Stats)
@Raider; finally a kick ass signature that I don't have to avoid, thank you.
And yes the 70 was probably lose. Either the bolt was loose or you were hard enough on it to actually oval out the center like the SURE mounts (not as bad, probably not visually noticeable) even just a little will let it vibe the shit out of your car.
(sold)
The Following 2 Users Say Thank You to ABolewski For This Useful Post:
Raider (04-27-2013), Rokusek (04-29-2013)
 Old 04-27-2013, 09:30 AM   #9
torq's Avatar
Thanks for the insights,
I don't think it was loose, I had to rank on a breaker bar to get the vertical bolt out. It's a little bit deformed on the bottom poly, wonder if that's the cause.
Here's a pic, it's a little bit subtle, near the back edge, someone wanted to buy it off me and I don't want to screw them which is why I'm asking.
https://docs.google.com/file/d/0B__6...it?usp=sharing
 Old 04-27-2013, 09:39 AM   #10
Looks pretty much like new.
 Old 04-27-2013, 10:14 AM   #11
If you plan to sell the 70, let me know. Local is looking for one.
 Old 04-27-2013, 12:09 PM   #12
JgamB's Avatar
Posts: 2,566   (View Stats)
Should've used a different duro mount.
"Some resonant objects have more than one resonance frequency, particularly at harmonics (multiples) of the strongest resonance. It will vibrate easily at those frequencies, and less so at other frequencies. It will "pick out" its resonance frequency from a complex excitation, such as an impulse or a wideband noise excitation. In effect, it is filtering out all frequencies other than its resonance."
I suspect every mod you put on your car, particularly on the exhaust side, can change your mechanical resonance.
 Old 04-27-2013, 01:09 PM   #13
Cheapspeed's Avatar
I'm looking for someone to tune my mechanical resonance.
 Old 04-28-2013, 07:37 AM   #14
I still think it was loose even though the bolts were tough to remove.
88 Chrome Molly MazdaSpeedBoi JAMES BARONE RACING 10 03-09-2013 07:19 PM
JBR Chrome Molly 88 Duro RMM curlyface JAMES BARONE RACING 9 08-02-2012 11:33 AM
Who has the Chrome Molly for MS6??? Fatguy729 JAMES BARONE RACING 3 09-15-2011 06:32 AM
JBR Molly 88 Duro dogbone RMM PapaSmurf JAMES BARONE RACING 9 05-16-2011 09:47 AM
Page generated in 0.34155 seconds with 28 queries
