 Old 01-26-2014, 12:34 PM   #1
alien_sporez's Avatar
Posts: 1,199   (View Stats)
alien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the world
Default Camber arm seized
Hey Jamie. I installed coil overs and got my alignment checked and have a little too much camber. I was able to adjust the right camber arm just fine, but my left one is seized. And I mean SEIZED. I have tried the following methods:
  1. PB Blaster
  2. Propane Torch
  3. Brute force in a vice
  4. PB Blaster and Brute Force
  5. PB Blaster, torch and Brute Force
  6. PB Blaster, torch, brute force and foul language
How much brute force did it resist? So much I actually separated the top off my work bench in my garage.
Can I get a replacement for the left one? If so, how much?
Thanks!
● 2011 Jaguar XFR ● Full Resonator Delete ● Mina Cat-Back Exhaust ● Staggered Giovanna Portofinos ●
● 2010 Mazdaspeed 3 - GONE ●
alien_sporez is offline   Reply With Quote
The Following 2 Users Say Thank You to alien_sporez For This Useful Post:
Manny (01-26-2014), Polish_Eagle (01-26-2014)
 Old 01-26-2014, 03:47 PM   #2
Polish_Eagle's Avatar
Posts: 408   (View Stats)
Damn, you went full crazy on that thing! Total beast mode!
The Following User Says Thank You to Polish_Eagle For This Useful Post:
alien_sporez (01-26-2014)
 Old 01-26-2014, 05:37 PM   #3
macdiesel's Avatar
Posts: 825   (View Stats)
If you have access to a handheld map torch with a needle tip, it will burn hotter than propane. It's a yellow tank. Maybe the arms not getting hot enough to break loose?
 Old 01-26-2014, 10:10 PM   #4
A replacement is $95.00 shipped. PM me and we can make arrangements to get one out to you.
-Jamie
alien_sporez (01-27-2014)
 Old 01-27-2014, 06:21 AM   #5
King Scumbag's Avatar
Posts: 2,384   (View Stats)
OP, if you havnt tried yet, try letting it sit overnight coated in a good amount of PB blaster, try the method of trying to tighten it a little more if you can to maybe break it free and then run it back out. Also other avenues of approach you may or may not have tried. If you have access possibly a stronger bench with a vice, putting the end of the camber arm in the vice and spinning the arm itself loose and or putting the actual nut in the vice if possible.
Goodluck, I'm gonna brain storm some other methods we use here at work for it's an everyday struggle that ends up with me using an adjustable wrench or vice grips and hitting the base of it to get that shit free lol.
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
 Old 01-27-2014, 08:27 AM   #6
zenit's Avatar
Posts: 1,364   (View Stats)
When stuff is that glued on, I usually take a thin cutting blade on an angle grinder and cut a diagonal cut across the nut, right to the depth before the thread begin. A few bangs with a cold chisel later, the nut has released all pressure by splitting (and NOT damaging the threads)
If the threads are seized INSIDE the arm, well...
Penetrating oil for a couple days!
or for the impatient, this has worked for me:
http://www.crcindustries.com/files/F...20Brochure.pdf
EDIT: Seeing as how you're in Houston, I doubt that the internal threads have seized on you. I bet you cutting that nut will do the trick.
 Old 01-27-2014, 08:54 AM   #7
sidekick's Avatar
Posts: 3,093   (View Stats)
Try freezing it and then applying heat to the arm only.
 Old 01-27-2014, 09:22 AM   #8
nope, threads inside the arm are seized. The locking nut is fine. Going to put some anti-seize on the other one because it was pretty tight to adjust.
Tapa-dabba-doooo
 Old 01-27-2014, 09:54 AM   #9
JgamB's Avatar
Posts: 2,566   (View Stats)
I'm no metallurgist, but if I'd applied that much torque to the threaded rod, I would replace it for fear of metal fatigue.
 Old 01-27-2014, 10:20 AM   #10
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Try heating again and then melt some paraffin into it. It is an old machinist's trick.
Nator is what it does.
The Following 3 Users Say Thank You to kritz For This Useful Post:
King Scumbag (01-27-2014), sidekick (01-27-2014), zenit (01-27-2014)
 Old 01-27-2014, 11:58 AM   #11
zenit's Avatar
In an environment that's not conducive to huge amounts of rust/corrosion, I wonder if something didn't get bent (either the rod or the housing, or both), and that's what's causing you so much trouble.
I'll try the paraffin wax trick sometime, thanks @kritz. I hate to say it, but that $95 replacement is beginning to look good. IMHO- I'd dissect the arm with an angle grinder to find out what's wrong and post up. I'm sure Jamie and MSF'ers would appreciate your findings.
 Old 01-28-2014, 10:17 AM   #12
This method worked. Soaked it, stuck in a Ziploc bag and stuck it in the freezer over night. This morning, torched the arm, and then used brute force... And got a tiny little wiggle out of it. Slowly just muscled it back and forth until I got it completely removed (and kept track of how many turns it took to remove so I could reinstall it to the exact same camber).
Put some anti seize in the threads, painted the spots where the powder coating got damaged, and reinstalled it just a few minutes ago!
Thanks everyone!
Tapa-dabba-dooooo
The Following 3 Users Say Thank You to alien_sporez For This Useful Post:
JgamB (01-28-2014), King Scumbag (01-28-2014), sidekick (01-28-2014)
 Old 01-28-2014, 10:32 AM   #13
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Acetone/ATF mix > pb blaster.
If you come across anything stubborn again try that mix 50/50.
The Following 2 Users Say Thank You to Etipp98 For This Useful Post:
alien_sporez (01-29-2014), Nitr0EngiE (03-04-2014)
 Old 01-28-2014, 10:34 AM   #14
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
and this is why I will start using anti seize more often
The Following 2 Users Say Thank You to Nitr0EngiE For This Useful Post:
alien_sporez (01-29-2014), that1rowdyracer (01-28-2014)
 Old 01-28-2014, 10:36 AM   #15
Further to the discussion, there was corrosion on the threads inside the arm (female). The threads on the eye (male) were not corroded (probably due to the different type of steel used)
Tapa-dabba-dooooo
cp-e pump seized jomc111 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 49 04-16-2012 07:11 AM
Autotech internals seized? Renn 2010 MS3 - Troubleshoot/Diagnostics 121 01-28-2012 05:54 PM
anyone w adjustable camber links have a camber guage? ZoomByU MazdaSpeed 3/6 - Suspension & Brakes 4 12-27-2010 09:28 AM
Page generated in 0.35013 seconds with 31 queries
