  • 1 Post By MikeCZoomZoom
 Old 01-27-2018, 01:05 PM   #1
MikeCZoomZoom's Avatar
Posts: 2   (View Stats)
MikeCZoomZoom will become famous soon enough
Default Fuel Pump Leak - 2010 MS3
Hello all, first time poster, I've read through the forums a bit in the past when I got my 2010 MazdaSpeed3, but now posting because I need help troubleshooting correct course of action.
I had a fuel smell for quite some time, had a leak on my gas tank, which appeared to be coming from the top and checked the fuel pump underneath the rear seats, sure enough, its leaking from the in line, now is there a way to reseal the end, replace oring/snapring? or do I have to replace the whole fuel line? it appears to be seeping from here, and when I went to wiggle the line, it was squirting fuel out, is there a fuel cutoff? or will it just leak fuel until the line is dry from moving it? If I take the end off? how much fuel will spill?
Attached are the images of the tank and fuel pump
File Type: jpg A7B75C53-CD80-47D1-9E15-7E94F3902539.jpg (93.5 KB, 12 views)
Bexar likes this.
MikeCZoomZoom is offline   Reply With Quote
 Old 12-31-2019, 12:47 PM   #2
GRRRRANDALL's Avatar
Posts: 1   (View Stats)
GRRRRANDALL has a little shameless behaviour in the past
Hate to restart an older thread but i'm having the same issue on my 2013speed. My fuel is spraying from the connector hose (the green clip) which i replaced and the leak is even worse now. I'm thinking its the ITFP housing that is leaking? Did you ever get this issue resolved? Not sure i want to spend a weekend dropping the tank or cutting open the backseat access hole.
GRRRRANDALL is offline   Reply With Quote
The Following 2 Users Say NO Thank You to GRRRRANDALL For This Un-useful Post:
Db09ms3 (12-31-2019), MSMS3 (01-01-2020)
 Old 01-01-2020, 05:31 PM   #3
MSMS3's Avatar
Posts: 2,825   (View Stats)
OP made one post, got no response and left two years ago. You might try to PM him, but given his lack of activity, chances are slim.
Maybe start a new thread and hang around long enough to give people a chance to see it and reply?
 Old 01-02-2020, 08:48 AM   #4
lol, apparently im still connected to these forums, I just got email notification...
there was a hairline crack on the top of the fuel pump assembly, specifically the fuel line spigot/L-connector on top of the housing had a crack. Fuel line was fine, I didn't have to buy a new fuel pump assembly, was able to purchase just the top housing separately from local mazda dealership, but unfortunately, you have to drop the tank to get to it
The Following User Says Thank You to MikeCZoomZoom For This Useful Post:
MSMS3 (01-02-2020)
BMW calls in 50,000 motorbikes over fuel pump leak Haltech Automotive News 0 01-07-2014 06:40 AM
Select 2010-2012 Jaguar XF models recalled over fuel leak fears Haltech Automotive News 0 11-08-2012 02:40 PM
2010-2011 Saab 9-3 faces recall over possible fuel pump defect Haltech Automotive News 0 01-21-2011 02:30 PM
2009-2010 Mazda5 minivans recalled over fuel pump concerns Haltech Automotive News 0 12-08-2010 04:10 PM
Audi recalls over 10,000 2006-2010 A3 and TT models over potential fuel leak Haltech Automotive News 0 10-05-2009 05:30 PM
Page generated in 0.25503 seconds with 23 queries
