All-Data engine TQ specs So I took the time to pull a bunch of engine torque specs from all-data. Enjoy, and let me know if you need any more and I can try and dig them up! HEAD Loosening order: http://i359.photobucket.com/albums/o...psno7kledl.jpg (I personally recommend a few loosening steps) Tightening order: http://i359.photobucket.com/albums/o...ps9grdqnjs.jpg Step 1: 3-11 Nm (27-97 in-lbf) Step 2: 13-17 Nm (116-150 in-lbf) Step 3: 43-47 Nm (32-34 ft-lbf) Step 4: 88°-92° Step 5: 88°-92° (for stock bolts only!) CAM CAPS Loosening order: http://i359.photobucket.com/albums/o...pscnuvxmmf.jpg Tightening order: http://i359.photobucket.com/albums/o...psjmwrml5u.jpg Step 1: 5-9 Nm (45-79 in-lbf) Step 2: 14-17 Nm (11-12 ft-lbf) VALVE COVER Loosening order: http://i359.photobucket.com/albums/o...pszpow92ms.jpg Tightening order: http://i359.photobucket.com/albums/o...ps94fjrnku.jpg 8-10 Nm (71-84 lb-in) OIL PAN Tightening order: http://i359.photobucket.com/albums/o...pszajxnggw.jpg 17-23 Nm (13-16 ft-lbf) CRANK BOLT Tightening: http://i359.photobucket.com/albums/o...psmznux64r.jpg Step 1: 96-104 Nm (71-76 ft-lbf) Step 2: 87°-93° TIMING COVER Tightening order: http://i359.photobucket.com/albums/o...ps1iyp8azn.jpg Bolts 1-18: 8-11 Nm (71-97 lb-in) Bolts 19-22: 40-55 Nm (30-40 lb-ft) WATER PUMP Tightening: http://i359.photobucket.com/albums/o...pshzllk95d.jpg Bolts 1: 17-23 Nm (13-16 lb-ft) Bolts 2: 8-11 Nm (71-97 lb-in) REAR MAIN SEAL Tightening order: http://i359.photobucket.com/albums/o...psoalfhxta.jpg 8-11 Nm (71-97 lb-in) EXHAUST MANIFOLD Tightening order: http://i359.photobucket.com/albums/o...psxmtlbrjb.jpg 43-64 Nm (32-47 lb-ft) OIL PUMP Tightening order: http://i359.photobucket.com/albums/o...ps0p523ex2.jpg Step 1: 8-12 Nm (71-106 in-lbf) Step 2: 17-23 Nm (13-16 ft-lbf) CAM SPROCKETS Tightening: http://i359.photobucket.com/albums/o...psbkmeuhpf.jpg http://i359.photobucket.com/albums/o...psdn2ayiyy.jpg 69-75 Nm (51-55 ft-lbf) (both sides) THROTTLE BODY Tightening order: http://i359.photobucket.com/albums/o...pshon4yjot.jpg 8-11 Nm (71-97 lb-in) FLYWHEEL Tightening order: http://i359.photobucket.com/albums/o...psvq3pbgne.jpg 108-116 Nm (80-85 ft-lbf) PRESSURE PLATE Tightening order: http://i359.photobucket.com/albums/o...psflim3fl1.jpg Tighten in a MINIMUM of 2 steps ending with 25-33 Nm (19-24 ft-lbf) FUEL RAIL COVER http://i359.photobucket.com/albums/o...psgpkaewg9.jpg 8-10 Nm (71-88 in-lbf) THERMOSTAT http://i359.photobucket.com/albums/o...psxsqjz39g.jpg 8-10 Nm (71-88 in-lbf) TIMING COMPNENTS http://i359.photobucket.com/albums/o...psmgybhwhm.jpg Bolts 1: 8-11 Nm (71-97 in-lbf) Bolts 2: 20-30 Nm (15-22 ft-lbf) HIGH PRESSURE FUEL PUMP http://i359.photobucket.com/albums/o...psusuomg0p.jpg (the E8 bolts) 9-11 Nm (80-97 in-lbf) http://i359.photobucket.com/albums/o...psleaosp8z.jpg 17-23 Nm (13-16 ft-lbf) PCV PLATE http://i359.photobucket.com/albums/o...psut61cohw.jpg 8-11 Nm (71-97 in-lbf) POWER STEERING DUMBY PULLEY http://i359.photobucket.com/albums/o...psmia7urux.jpg 19-25 Nm (15-18 ft-lbf) IDLER PULLEY http://i359.photobucket.com/albums/o...pswhvxh3zk.jpg 20-30 Nm (15-22 ft-lbf) INTAKE MANIFOLD http://i359.photobucket.com/albums/o...psjiclotcg.jpg Bolts 1: 17-23 Nm (13-16 ft-lbf) Bolts 2: 4-6 Nm (35-52 in-lbf) FUEL RAIL http://i359.photobucket.com/albums/o...ps2l14orm6.jpg 1. 17-23 Nm, 13-16 ft/lbs 2. 22-25 Nm, 17-18 ft/lbs 3. 24-35 Nm, 18-25 ft/lbs 4. 8-11 Nm, 71-97 in/lbs 5. 17-23 Nm, 13-16 ft/lbs 6. 16-24 Nm, 12-17 ft/lbs FRONT HUB http://i359.photobucket.com/albums/o...ps0kex4pm6.jpg 1. 236-275 Nm, 175-202 ft/lbs 2. 82-101 Nm, 61-74 ft/lbs 3. 64-74 Nm, 48-54 ft/lbs 4. 43-60 Nm, 32-44 ft/lbs 5. 4-6 Nm, 36-53 in/lbs 6. 38-50 Nm, 29-36 ft/lbs 7. 44-58 Nm, 33-42 ft/lb STARTER http://i359.photobucket.com/albums/o...pssl8maeqf.jpg 1. 38-51 Nm, 29-37 ft/lbs 2. 38-51 Nm, 29-37 ft/lbs 3. 10-11 Nm, 89-97 in/lbs ALTERNATOR http://i359.photobucket.com/albums/o...psvsxpr7oc.jpg 1. 38-51 Nm, 29-37 ft/lbs 2. 38-51 Nm, 29-37 ft/lbs 3. 8-10 Nm, 71-88 ft/lbs 4. 8-10 Nm, 71-88 ft/lbs 5. 10-14 Nm, 89-123 in/lbs KNOCK SENSOR http://i359.photobucket.com/albums/o...psbohke6gw.jpg 1. 16-24 Nm, 12-17 ft/lbs COIL PACKS http://i359.photobucket.com/albums/o...psezsfwvy9.jpg 1. 6-9.5 Nm, 54-84 in/lbs BLIND PLUG http://i359.photobucket.com/albums/o...psi79qzsbd.jpg 1. 18-22 Nm, 14-16 ft/lbs CRANK SENSOR http://i359.photobucket.com/albums/o...psudfcdszc.jpg http://i359.photobucket.com/albums/o...ps5a9azpp6.jpg 1. 5.5-7.5 Nm, 49-66 in/lbs CAM SENSOR http://i359.photobucket.com/albums/o...ps281q0yse.jpg 1. 5.5-7.5 Nm, 49-66 in/lbs I will be updating as I get suggestions or find more! |
updated a little bit more info @Raider; can I possibly get a sticky? |
I know I'm reviving a long dead thread, but could you specify if you use any type of threadlock on any of these? If at all? :wall: |
The only bolts that need threadlocker are the flywheel bolts, but it's already on them when you buy new oem bolts. |
3 And 4 on alternator bolts aren't converted to ft/lbs right Sent from my SM-G935P using Tapatalk |
This is God sent. I'm about to start a teardown and rebuild and this is exactly what I need. Anyway you have engine clearance specs as well? I am going to be running supertech rods and supertech pistons and running a bnr stage 3 with a boost goal of 25 PSI, so I'll spec out how much ring-gap I need to avoid butting. I'm more worried about PTW clearances. It will be bored to 88MM and 4032 alloy pistons and I'm trying to avoid piston-slap. |
supertech should supply you with "recommended" PTW clearance and ring gap specs. |
Quote:
Clearances will depend on piston design, the expansion ratio of the material, and how you intend to operate the vehicle. I emailed Manley with my details and they told me what clearances I should run. |
Quote:
Its been a while since I've checked my cylinder wall temperature sensor, but thinner cylinder walls should transfer heat faster to the coolant. Additionally, a larger bore increases the surface area in which to distibute the heat. |
Quote:
With less material to be a heatsink, it is likely the cylinder walls heat up faster, but the same goes for the coolant's ability to pull the heat away. This might not equate, but if you're too hot in the winter, wear a thinner coat. |
Quote:
Can someone update the pics or repost them.? |
Quote:
Thank you |
Quote:
Quote:
Quote:
Quote:
| All times are GMT -7. The time now is 04:44 AM. |
