Welcome to Mazdaspeed Forums
Mazda Forums / MazdaSpeed Forums - Mazdaspeed Forum with High Performance Discussions, Car Gallery, Mods Information, Street Racing Stats,
Street Racing Videos & more. The Archived MazdaspeedForums! Mazdaspeed Mazda MSF MazdaSpeedForums.org.
You are currently viewing our boards in read mode only. We are here to preserve the data and info that is useful to Mazda gear heads.
If you'd like to donate to keep this info alive, your donation will go to hosting, SSL, and domain fees.
Search Forum
Like Tree6Likes
  • 2 Post By Andjo
  • 1 Post By littleloogy
  • 3 Post By Andjo
 Old 08-09-2015, 04:27 PM   #1
Andjo's Avatar
Posts: 937   (View Stats)
Andjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the world
Default New Pump, Car won't start
So this is my second Daetchwerks fuel pump that I have installed. The first one seemed to not give me enough pressure when at idle.
So I changed it for a new one. also installed new fuel filter. Installed it put the tank back up and primed the line. Car started and idled fine, reved it and fuel pressure looks great. let it idle until it got hot then I shut it down. went to go start it again and now it won't start. It tries and will sputter but nothing else. spill valve is clean.
GT3076 and supporting mods with Kozmic Motorsports Built motor and tune
FUTURE MODS: 6266 with V-Band everything
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
2013 TROLL CHAMPION "DYLANFYHN"
Andjo is offline   Reply With Quote
 Old 08-09-2015, 04:51 PM   #2
littleloogy's Avatar
Posts: 4,005   (View Stats)
That sucks you are having problems with your fuel pump. What lead you to believe your pump went bad?
what's your key on engine off fuel pressure?
What does your fuel pressure climb to when you crank your engine without starting?
Sent from my iPhone 6
 Old 08-09-2015, 05:19 PM   #3
Andjo's Avatar
can't monitor it when i crank it and which fuel pressure should i be looking at?
 Old 08-09-2015, 05:32 PM   #4
snailD's Avatar
Posts: 3,039   (View Stats)
yes you can, turn the car to accessory, turn on your ap to the home screen, turn the car to the on position, then click gauges or monitor on the ap, you should have readings.
 Old 08-09-2015, 05:39 PM   #5
There is only one fuel pressure monitor which is the fuel rail pressure. So you don't have an AP? This should be fun...
 Old 08-09-2015, 05:43 PM   #6
Andjo's Avatar
I do have an AP and i figured out which one. I have 6psi with the car in the on position
 Old 08-09-2015, 05:58 PM   #7
That's weird. Turn the car on and off a few times without starting. Fuel pressure still only climbs to 6psi? Is there fuel moving into the Spill valve? Do you hear the fuel pump turn on when you turn the key?
 Old 08-10-2015, 05:11 AM   #8
Andjo's Avatar
there is fuel in the spill valve and the spill valve is clean. that 6psi is after several priming cycles. yes fuel pump is turning on when key is on
 Old 08-10-2015, 09:14 AM   #9
Since there is fuel in your spill valve I would bet that you car will start up. Unfortunately it will die shortly after since it appears to me that the fuel supply cannot keep up with the demand.
Furthermore, I would suspect that the itfp is still failing is some way. Either a crack in the fuel pump hose (the one that goes from the pump inside the pump housing to the top of the fuel pump) or a bad seal.
Andjo (08-10-2015)
 Old 08-10-2015, 10:33 AM   #10
Andjo's Avatar
Well it looks like I'm dropping the tank again.....
 Old 08-10-2015, 02:58 PM   #11
Fuck that. Make hole.
g00s3y (08-10-2015), SofaKingAwesome (08-10-2015)
 Old 08-10-2015, 03:18 PM   #12
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
Fuel filter installed correctly?
You should be seeing ~40psi at key on if I recall correctly.
 Old 08-10-2015, 04:39 PM   #13
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
I second the hole making...
MS3Shadow (08-10-2015), SofaKingAwesome (08-10-2015)
 Old 08-11-2015, 10:06 AM   #14
Andjo's Avatar
Its brand new and can only be installed 1 way
then I woul have to make a plate to cover the hole when I can drop the tank in under an hour.
 Old 08-15-2015, 08:16 PM   #15
Andjo's Avatar
Fixed the issue. Fuel was leaking past the o-ring on the fuel pump. used a second on and now the car starts and runs fine.
SofaKingAwesome and Spec like this.
The Following User Says Thank You to Andjo For This Useful Post:
snailD (08-16-2015)
 Old 08-16-2015, 03:25 AM   #16
Glad you got it sorted brother.
Spec likes this.
Andjo (08-16-2015)
 Old 08-16-2015, 07:02 AM   #17
Andjo's Avatar
Me too. what a pain in the ass it was to figure that out. I threw a buttload of parts at it
Spec, littleloogy and MS3Shadow like this.
 Old 08-16-2015, 09:33 AM   #18
Spec's Avatar
Posts: 4,472   (View Stats)
Glad you got it right, dick face.
Andjo (08-16-2015)
 Old 06-09-2016, 12:52 AM   #19
Xtrinsic1337's Avatar
Posts: 32   (View Stats)
Xtrinsic1337 is a splendid one to beholdXtrinsic1337 is a splendid one to beholdXtrinsic1337 is a splendid one to beholdXtrinsic1337 is a splendid one to beholdXtrinsic1337 is a splendid one to beholdXtrinsic1337 is a splendid one to beholdXtrinsic1337 is a splendid one to behold
Reviving this thread! Was it the oring on the hpfp or internal pump I just installed the dw65c and I'm having the same God damn problem
Xtrinsic1337 is offline   Reply With Quote
 Old 06-09-2016, 01:18 AM   #20
Btw my hole looks exactly like yours lol soo much quicker but now I've gotta make a plate. Mazda shit on us with the maintenance for this car
Upgraded fuel pump internals now car won't start Please Help :( kizad MazdaSpeed 3/6 - Troubleshoot/Diagnostics 18 05-27-2014 06:16 PM
Super newbie. Wanting to start working on my Car, and don't know where to start. SethxAbe Gen2 MS3 General Discussion 27 04-06-2013 08:59 PM
Issues with fuel pump pressures, aftermarket pump... ptperformance MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 10-04-2009 06:17 PM
Ford F-150 Oil Pump Problem, A/C Vents Won't Move On Astrovan, How To Figure Out Correct Tire Pressure, How To Start A C Haltech Automotive News 0 10-24-2008 03:40 PM
Page generated in 0.38348 seconds with 26 queries
