Welcome to Mazdaspeed Forums
Mazda Forums / MazdaSpeed Forums - Mazdaspeed Forum with High Performance Discussions, Car Gallery, Mods Information, Street Racing Stats,
Street Racing Videos & more. The Archived MazdaspeedForums! Mazdaspeed Mazda MSF MazdaSpeedForums.org.
You are currently viewing our boards in read mode only. We are here to preserve the data and info that is useful to Mazda gear heads.
If you'd like to donate to keep this info alive, your donation will go to hosting, SSL, and domain fees.
Search Forum
  • 1 Post By NiL
 Old 12-12-2016, 06:04 AM   #1
NiL
NiL's Avatar
Posts: 27   (View Stats)
NiL is just really niceNiL is just really niceNiL is just really niceNiL is just really nice
Default HPFP upgraded?
Is there an easy way of spotting or perhaps a read out on the ODB that would tell me if there is a HPFP installed?
I got the car with the full Corksport Intake and there was definitely and exhaust on it at some point (I dont think the DP was removed ever) I was going to go ahead and get the DP back exhaust and accessport taken care of this weekend but I'm hoping to not have the spend the 350 on the HPFP if it's already in there.
NiL is offline   Reply With Quote
 Old 12-12-2016, 06:06 AM   #2
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Best bet is to pull the pump out and check.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
The Following 5 Users Say Thank You to CWP_MS3 For This Useful Post:
g00s3y (12-12-2016), Gerbilo (12-14-2016), MD1032 (02-11-2018), Vansquish (12-12-2016), WetzMS3 (12-12-2016)
 Old 12-12-2016, 06:23 AM   #3
NiL
NiL's Avatar
Bleh. I was hoping to avoid that.
 Old 12-12-2016, 06:27 AM   #4
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Better safe than sorry. You could try checking to see if they left a ziptie on the hardline. That won't tell you anything if its not there, but if there is one, then they probably changed it out. Then again, could have stocked it out as well.
Recommendation: Pull it and check.
Rich Tuned
330WHP and 363TQ
 Old 12-12-2016, 07:57 AM   #5
NiL
NiL's Avatar
Well I know what i'm doing this weekend!
adam.r.marshall.5 likes this.
 Old 12-12-2016, 09:11 AM   #6
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
It's very easy to do. Literally the only things you need to remove are the intercooler shroud and the valve cover breather line. You will need an inverted torx (E8?) for the pump bolts. Make sure to put a ziptie just below the nut on the HPFP hard line to prevent it from falling into an inconvenient position.
2007 Mazdaspeed3 GT
 Old 12-12-2016, 09:34 AM   #7
Bingo's Avatar
Posts: 740   (View Stats)
Groaned at 9 Times in 7 Posts
Yes, it is an E8. I picked mine up at autozone.
Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Whiteline endlinks.
Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges, Eonon G9151A.
 Old 02-10-2018, 04:41 PM   #8
MSMS3's Avatar
Posts: 2,829   (View Stats)
Aftermarket larger pump piston on left. Note large bulb on end.
Stock on the right. Straight shaft all the way to the end.
Varomnia (02-11-2018)
 Old 02-11-2018, 07:57 AM   #9
MD1032's Avatar
Groans: 143
Holy thread revival, batman.
2007 Mazdaspeed3 GT
 Old 02-11-2018, 07:23 PM   #10
Varomnia's Avatar
Posts: 459   (View Stats)
But with a meaningful showcase of evidence, i'll allow it.
Way to tell if I have an upgraded HPFP? freshmex28 MazdaSpeed 3 - Engine, Transmission & Driveline 5 01-08-2015 03:26 PM
Do I need an upgraded HPFP slowspeed3 Mazdaspeed3/6 General Discussion 28 09-11-2012 02:49 AM
Is this HPFP upgraded? rob ms6gt Mazdaspeed3/6 General Discussion 12 03-05-2012 03:43 AM
Page generated in 0.32514 seconds with 26 queries
