Welcome to Mazdaspeed Forums
Mazda Forums / MazdaSpeed Forums - Mazdaspeed Forum with High Performance Discussions, Car Gallery, Mods Information, Street Racing Stats,
Street Racing Videos & more. The Archived MazdaspeedForums! Mazdaspeed Mazda MSF MazdaSpeedForums.org.
You are currently viewing our boards in read mode only. We are here to preserve the data and info that is useful to Mazda gear heads.
If you'd like to donate to keep this info alive, your donation will go to hosting, SSL, and domain fees.
Search Forum
  • 1 Post By Db09ms3
 Old 08-01-2019, 08:09 PM   #1
AaronLoun's Avatar
Posts: 1   (View Stats)
AaronLoun is an unknown quantity at this point
Default HPFP ??
I am very new to the modding scene with my purchase of a 2010 MS3 completely stock. I was wondering if i will blow by running lean if i don’t have the HPFP upgrade and add a cold air intake and a bypass valve.
AaronLoun is offline   Reply With Quote
 Old 08-01-2019, 08:39 PM   #2
MSMS3's Avatar
Posts: 2,829   (View Stats)
Have you done any reading here? You might find a hundred or more threads discussing your issue in detail. It is reasonable to expect some effort to find things first rather than calling on others to keep answering the same basic questions over and over and over and over. . .
Just do a Google search with the term Mazdaspeedforums included with your other search terms and it will search for every available thread here.
Vansquish (08-02-2019)
 Old 08-01-2019, 09:39 PM   #3
Db09ms3's Avatar
Posts: 536   (View Stats)
Read your welcome email and follow that shit to the introduction section. I believe in you
danb likes this.
Stockish
 Old 08-02-2019, 04:35 AM   #4
tripppleP's Avatar
Posts: 97   (View Stats)
tripppleP is a splendid one to beholdtripppleP is a splendid one to beholdtripppleP is a splendid one to beholdtripppleP is a splendid one to beholdtripppleP is a splendid one to beholdtripppleP is a splendid one to behold
As far as I know it won't hurt your car not to have the HPFP but you should get it to optimize the full benefit of this two items.
tripppleP is offline   Reply With Quote
The Following User Says NO Thank You to tripppleP For This Un-useful Post:
 Old 08-02-2019, 06:29 AM   #5
Police - Grammarhead
Vansquish's Avatar
That, right there, is dangerous advice.
The Gen2 MS3 is significantly more sensitive to any air/exhaust flow modifications than the Gen1 MS3 or MS6. I would urge the OP strongly to install upgraded HPFP internals before going any farther down the modding path.
 Old 08-06-2019, 12:23 AM   #6
CA_MS3's Avatar
Posts: 22   (View Stats)
CA_MS3 has a spectacular aura aboutCA_MS3 has a spectacular aura about
$0.02 for the OP...
I had Corksport HPFP internals installed a couple months ago and was stunned by the difference. Transitional throttle behavior is much smoother now; it eliminated the jerky sensation which occasionally occurred when rolling on the throttle from coasting. Monitoring the car with an Accessport, I recorded a peak pressure of 1750psi during acceleration runs with the factory internals. With Corksport internals, peak pressure rose to 2075psi.
My car's motor is basically stock (K&N panel filter, CBE).
I am the original owner and find it hard to fathom (a) that Mazda sold this car with such a substandard pump, and (b) that I waited so long to trust the aftermarket advice and replace it. I highly recommend the upgrade, even for a factory tune.
CA_MS3 is offline   Reply With Quote
Corksport HPFP or Autotech HPFP? El Beaner Gen2 MS3 General Discussion 76 05-25-2017 07:55 PM
Hpfp tick with pressure issues WITH HPFP INTERNALS Juschiln19 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 9 11-21-2016 09:47 AM
HPFP internals or new HPFP? JAGspeed6 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 11 11-26-2011 02:34 PM
Page generated in 0.27728 seconds with 25 queries
