Welcome to Mazdaspeed Forums
Mazda Forums / MazdaSpeed Forums - Mazdaspeed Forum with High Performance Discussions, Car Gallery, Mods Information, Street Racing Stats,
Street Racing Videos & more. The Archived MazdaspeedForums! Mazdaspeed Mazda MSF MazdaSpeedForums.org.
You are currently viewing our boards in read mode only. We are here to preserve the data and info that is useful to Mazda gear heads.
If you'd like to donate to keep this info alive, your donation will go to hosting, SSL, and domain fees.
Search Forum
 Old 02-08-2018, 12:58 PM   #1
SlamChop's Avatar
Posts: 13   (View Stats)
SlamChop has a little shameless behaviour in the past
Default Fuel pressure too high after WOT
2010 ms3 here, cpe tmic, htp 3.5 intake, Autotech internals, hks bov, corksport dp, custom Catless cbe, dizzy tuned, was running 1:3 e85 ratio mix then switched back to 93 once problems started happening. So to make a long story short (I will provide answers to any questions anyone has) I installed my htp intake replacing a crappy one that was on the car when I bought it thinking that it would fix my fuel trims because car was running lean. After I replaced it nothing really changed. Found out my maf sensor was bad so I replaced that too, trims were fixed but i noticed I was having some stuttering for a few seconds when I would let off the gas. I started paying close attention to my Hpfp act pressure, saw that it was consistently too high like between shifts, when engine was braking, things like that. Seemed the pressure would get stuck higher than it should be and my car would be slightly boggy. I then took apart my Hpfp to inspect everything and found a little (black death). Took everything apart ( including Hpfp housing) and soaked it in b12 chemtool. Everything was then clean and I re installed. Everything seemed to be okay like between shifts and engine braking the psi was normal. So I decided to give it a wot to see how things were and I hit my target fuel psi and boost psi but for 10-15 seconds after wot ( now in 4th gear ) my fuel psi is stuck at 900+ without touching the pedal, if I touch the pedal at all to shoots up to 1700-1900 with any amount of acceleration. While the lressure is high like that my car stutters and basically has no power for that 10-15 seconds. Not really sure what this could be. Maybe just my internals went bad and don’t slide as smoothly as they should? I have no idea
SlamChop is offline   Reply With Quote
 Old 02-08-2018, 02:17 PM   #2
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Nice wall of text. Makes it hard to read. FYI.
When you changed intake was it same diameter as before? If not, you need to get re-tuned/MAF calibration.
Letting off the gas you will see dips in pressure. 17-1900 is not too high. Its normal.
 Old 02-08-2018, 02:50 PM   #3
Jeff23spl's Avatar
Posts: 2,237   (View Stats)
1700-1900 with pump internals seem normal to me...stabilize around 1750 under wot and spike back a bit above when you drop de pedal.
When i put back mine, i do remember it take few km to get it stabilized.
While engine breaking i think mine is about 450psi and it goes back above 1000 very quickly to reach target as soon as i ask for some load.
have you confirmed that pedal reading read correctly ? I don't know if a special throttle table could affect this....
Why not just put back a stock tune with your actual maf cal (And map if not oem) to see if it change anything?
Is your AFR ok during that time? it should fall to 29 when you let go the pedal but get back to stoich or target as soon as you go back in load....If AFR is ok, there is no reason the fuel pressure make the engine goes bad
IMO Bad pump won't rise pressure but instead keep it lower than expected....it would be the release/spill valve in that case maybe
I remember some thread here about ethanol problems but you will have to search.
Is your o2 seem to read ok ?
I would go back to basic since your car seem to go bad from the beginning...
Check compression
Timing chain
new spark plugs
Leak test
Maf cal again and confirm your open loop afr vs target
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 02-08-2018, 08:38 PM   #4
SlamChop's Avatar
I did get a re tune when I got intake
 Old 02-08-2018, 11:59 PM   #5
SlamChop's Avatar
Also, Anytime I throw it into neutral and let the RPMs drop all the way down to idle it drops below my normal idle and my actual afr drops to 8-9 and then bobs back up to normal
 Old 02-09-2018, 10:43 AM   #6
Groans: 211
What about Bob?
 Old 02-09-2018, 11:17 AM   #7
SlamChop's Avatar
What about Bob?
He’s a nice fella
 Old 02-12-2018, 06:01 AM   #8
SlamChop's Avatar
What could cause my afr to dip like that?
 Old 02-12-2018, 03:09 PM   #9
Jeff23spl's Avatar
a bov maybe
Wife drive 2010 CX7
 Old 02-13-2018, 04:52 PM   #10
SlamChop's Avatar
@jeff23spl how would a bov cause this?
 Old 02-14-2018, 07:31 AM   #11
shamie's Avatar
Posts: 952   (View Stats)
If you are VTA.
The Following User Says Thank You to shamie For This Useful Post:
Jeff23spl (02-14-2018)
 Old 02-14-2018, 10:27 AM   #12
Jeff23spl's Avatar
as said above, when it open and flow outside, the maf continue measure flow and call to add fuel but that flow isn't going inside the engine. This is why a full VTA is fun but a BPV is better
Wife drive 2010 CX7
 Old 02-14-2018, 12:24 PM   #13
SlamChop's Avatar
Interesting... I never started having the problem until the new intake.. I did get a new map sent to me for it but could it be tuned for? Like I’m just confused on why it has started happening all of a sudden. I know it’s better for the car to go bpv I still feel like it should atleast be as smooth as it used to be. Maybe like a month ago
High Pressure Fuel Line CorkSport CorkSport 14 12-30-2016 02:34 PM
Opinion On High RPM High Pressure Fuel Pump Spring ms3brendan MazdaSpeed 3 - Engine, Transmission & Driveline 1 07-13-2010 01:04 PM
Page generated in 0.31063 seconds with 23 queries
