Welcome to Mazdaspeed Forums
Mazda Forums / MazdaSpeed Forums - Mazdaspeed Forum with High Performance Discussions, Car Gallery, Mods Information, Street Racing Stats,
Street Racing Videos & more. The Archived MazdaspeedForums! Mazdaspeed Mazda MSF MazdaSpeedForums.org.
You are currently viewing our boards in read mode only. We are here to preserve the data and info that is useful to Mazda gear heads.
If you'd like to donate to keep this info alive, your donation will go to hosting, SSL, and domain fees.
Search Forum
  • 1 Post By csmaan12
 Old 04-26-2016, 02:16 AM   #1
StevenPThomas's Avatar
Posts: 201   (View Stats)
StevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant future
Groaned at 9 Times in 5 Posts
Default Fuel injector cleaner
I was just wondering if there's any reason I shouldn't use some of that fuel injector cleaner that you add to your gas tank when filling up. Thanks guys
Sent from my iPhone using tapatalkreplace
StevenPThomas is offline   Reply With Quote
 Old 04-26-2016, 08:46 AM   #2
csmaan12's Avatar
Posts: 325   (View Stats)
csmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond reputecsmaan12 has a reputation beyond repute
Well you can, just buy a bottle of Redline SI1, dump it in the gas tank on your next fill up. They do work, but you won't notice much difference or any "hidden power" coming back from the abyss.
2011 Mazdaspeed3 Mod List:
FREEKTUNED
ETS TMIC
Autotech HPFP Internals
CS Stage II SRI + TIP
Tial QR
UR Catback
UR Catless Test Pipe
Damond RMM
Damond SSP
csmaan12 is offline   Reply With Quote
 Old 04-26-2016, 10:47 AM   #3
Haha I figured I wouldn't but I've got almost 50,000 miles on the car and It seemed like time to do something.
 Old 04-26-2016, 10:58 AM   #4
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
You would be better off taking your intake manifold off and cleaning out the valves, installing an OCC while doing that also.
Any mods on the car at all?
MS3Shadow (04-26-2016), WetzMS3 (04-26-2016)
 Old 04-26-2016, 11:00 AM   #5
Yeah, CS SRI + TIP, Cobb SS CBE, CS TMIC, Autotech HPFP Internals. No DP yet.
 Old 04-26-2016, 01:30 PM   #6
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
The injectors in DI engines will clog only if the car sits for too long or if it makes short trips at low loads which will allow the soot to accumulate on the injector tip and also on the nozzle. Otherwise having soot on the injector tip is fine because the nozzle will clean anything that stays in the way of the fuel spray.
If you don't have any problems with the car I'd say don't think about doing anything extreme. Pouring solvents in the engine is not necessarily the best way of taking care of the car.
As someone else stated above, if you really want to allow your car to breathe better just pull the IM and clean the intake valves.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 04-26-2016, 01:53 PM   #7
Ok thanks guys for the much needed clarification. Someone had recommended I use the in tank stuff but I figured that was just a lazy half ass way to clean them and wasn't sure of any possible harmful effects they may have.
 Old 04-26-2016, 04:01 PM   #8
csmaan12's Avatar
Well being a direct injected engine, that stuff wouldn't actually do anything to the valves because the injector is spraying directly into the cylinder so no fuel ever gets sprayed over the valves. So the only thing it COULD potentially, maybe, possibly do is get like a tiny bit of carbon build up off the top of the pistons, but even that seems unlikely.
Though I'll say it did help to band aid a misfire I had until I replaced the injector entirely with a new one. Best bet, as others have said is to take out the intake manifold and clean your valves. Search on here and you'll see there's a really good write up of how to do this.
StevenPThomas likes this.
FREEKTUNED
ETS TMIC
Tial QR
UR Catback
Damond RMM
Damond SSP
Injector seals - need to replace injector/fuel line O-rings? TheRealDefman 2010 MS3 - Engine, Transmission & Driveline 3 03-02-2014 09:35 PM
Octane Booster or Fuel Injector Cleaner? treyclash 2010 MS3 - Engine, Transmission & Driveline 6 07-22-2010 07:59 AM
How To Replace A Ball Joint, Transmission Has No Power, Toyota Tundra Check Engine Light, When To Use Injector Cleaner, Haltech Automotive News 0 06-05-2009 03:40 PM
Maintenance on a 1973 I.H. Scout, Dangerous Car Has Exhaust Leak, Fuel Injector Cleaner, Ethanol and Fuel Grade, Is The Haltech Automotive News 0 07-10-2008 11:10 AM
Maintenance on a 1973 I.H. Scout, Dangerous Car Has Exhaust Leak, Fuel Injector Cleaner, Ethanol and Fuel Grade, Is The Haltech Automotive News 0 06-10-2008 02:12 AM
Page generated in 0.28958 seconds with 23 queries
