Welcome to Mazdaspeed Forums
Mazda Forums / MazdaSpeed Forums - Mazdaspeed Forum with High Performance Discussions, Car Gallery, Mods Information, Street Racing Stats,
Street Racing Videos & more. The Archived MazdaspeedForums! Mazdaspeed Mazda MSF MazdaSpeedForums.org.
You are currently viewing our boards in read mode only. We are here to preserve the data and info that is useful to Mazda gear heads.
If you'd like to donate to keep this info alive, your donation will go to hosting, SSL, and domain fees.
Search Forum
  • 1 Post By DISIindahead
  • 1 Post By mituc
 Old 12-23-2012, 08:19 PM   #1
DISIindahead's Avatar
Posts: 911   (View Stats)
DISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the world
Default DISIindahead's Meth Install and Review
Would like to start off by thanking @slikr; @Mortose; and @AuroraAxela; for helping me with the install. Last week I visited Snow Performance since they are not too far away from my house, and got their Stage 2 Boost Cooler Meth Kit with SafeInjection module and Solenoid. I had originally looked at the Devils Own kit but got a good deal on the SP kit. For those of you who never heard of SafeInjection, basically the solenoid allows the system to decrease the boost pressure in the event of a low flow situation. When it detects a low flow, a 12V signal is sent to the solenoid, redirecting boost pressure. This prevents boost pressure from reaching the bypass, causing it to open and reduce boost pressure to the engine.
Install:
Install was pretty straight forward. Snow Performance includes detailed instructions on how to install their system. We first started off by making custom brackets for the tank and pump. Thanks to @bioevolve; Meth install, we came up with a way to make the brackets and run the lines. Sorry if pictures are not in detail. This is not a how to.
This is the bracket made for the OCC to stay in the location I had it at originally.
Next we made brackets for the pump and the tank. Here is the pump and tank with lines attached.
After that we mounted the modules and @slikr; did his magic with the wiring and running of the hoses.
Here is the Solenoid mounted next to the EBCS
This was where we should of slowed down. I didn't realize that the kit came with 3 lights. The Green light is for when the system turns on starting at 15psi and full at 25psi. The Yellow light is the Low Fluid Indicator, and finally the Red is the Indicator from the SafeInjection. Both the Green and the Red were already mounted when I found out there was another light. So I afro engineered it until I get the new blank insert and I will redo the lights so they look a lot better than they do now.
Again, thanks to @bioevolve; again, here is the tube I ran to fill up the tank without taking off the front bumper.
Review: All-in-all it wasn't too bad of an install, just a lot of wiring. Make sure you prime the system. As of right now I'm using the smallest sized nozzle included in the kit to get use to the system which is the 175ml/min and rated for 250-350hp applications and am using Supertech -20* Windshield Washer Fluid with half a bottle of HEET. Eventually when I start running the VP M1 Methanol, I will bump up to the 375ml/min nozzle. So far BAT's have dropped considerably and NO KNOCK on my logs. I will be updating this thread once I have ran the system for a while and will post pics of the before and after effects on the intake valves since I heard that Meth injection helps with keeping the valves somewhat clean and I will also post logs to show the drop in the BATs.
Pointless likes this.
2010 Mazdaspeed 3 - Built Motor - GTX3071: SOLD
2012 Jeep Wrangler Unlimited Sport: Current DD
DISIindahead is offline   Reply With Quote
The Following 11 Users Say Thank You to DISIindahead For This Useful Post:
bioevolve (01-02-2013), CWP_MS3 (12-27-2012), faeker (12-27-2012), GunGuru727 (12-27-2012), jracer (12-27-2012), KILLER_VIZ (12-23-2012), Pointless (12-23-2012), rfinkle2 (12-24-2012), Rich990 (01-14-2013), robry (12-27-2012), tbot (12-28-2012)
 Old 12-23-2012, 08:24 PM   #2
KILLER_VIZ's Avatar
Posts: 451   (View Stats)
KILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the world
Groaned at 28 Times in 14 Posts
@DISIindahead; man I wanted to come down and help bro. Call me next time!
KILLER_VIZ is offline   Reply With Quote
 Old 12-23-2012, 08:26 PM   #3
I talked to you last night lol communication FAIL!
The Following User Says Thank You to DISIindahead For This Useful Post:
rfinkle2 (12-27-2012)
 Old 12-23-2012, 08:33 PM   #4
KILLER_VIZ's Avatar
lol You didnt call me till late a hole! LOL Next install I will be there!
The Following User Says Thank You to KILLER_VIZ For This Useful Post:
DISIindahead (12-23-2012)
 Old 12-24-2012, 03:44 AM   #5
Dust's Avatar
Posts: 192   (View Stats)
Dust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the world
if you are gonna keep the pump mounted that way, you might want to find a way to seal up the wires on the pump to keep water from getting in.
Dust is offline   Reply With Quote
The Following User Says Thank You to Dust For This Useful Post:
rfinkle2 (12-29-2012)
 Old 12-24-2012, 07:30 AM   #6
AuroraAxela's Avatar
Posts: 204   (View Stats)
AuroraAxela is the leader of the worldAuroraAxela is the leader of the worldAuroraAxela is the leader of the worldAuroraAxela is the leader of the worldAuroraAxela is the leader of the worldAuroraAxela is the leader of the worldAuroraAxela is the leader of the worldAuroraAxela is the leader of the worldAuroraAxela is the leader of the worldAuroraAxela is the leader of the worldAuroraAxela is the leader of the world
Could use the same silicone you used on the reservoir to do that.... but you'd have to take the cover off again LOL!
2009 Mazdaspeed 3 GT
POWERTRAIN: GTX3076 . Cobb AP . Cobb 3-port . Autotech internals . HTP 3" intake . cp-e FMIC . Forge v2 BPV . TWM STS . CNT Turboback
NGK 1-step colder . Bosch 3-bar . cp-e xFlex™ RMM/TMM/PMM . CorkSport recirc tube . Kosmic EGR delete
SUSPENSION: K-Sport coilovers . Whiteline RSB . custom MS6 wheels
EXTERIOR: cp-e TowPlate . DDM Tuning 5000K HID low/fog
INTERIOR: Defi boost gauge/cp-e defroster mount . NRG shift knob . CorkSport LEDs
AuroraAxela is offline   Reply With Quote
The Following 2 Users Say Thank You to AuroraAxela For This Useful Post:
Fast_Dude (12-25-2012), rfinkle2 (12-27-2012)
 Old 12-24-2012, 10:28 AM   #7
If you look closely, you can see the wires run into the wire loom when they go up into the engine bay. Nothing is exposed which would cause a short from water. Eventually if I hsve to take off the numper for something then I might put some more wire loom or silicone for the wires.
Sent from my Motorola DynaTAC 8000X
 Old 12-24-2012, 11:36 PM   #8
Here's the video of one of the pulls.
 Old 12-25-2012, 12:07 AM   #9
Dust's Avatar
Aquamist suggested sealing up where the wires enter the pump when mounted outside the trunk. Just wanted to pass it along.
 Old 12-27-2012, 06:04 AM   #10
GunGuru727's Avatar
Posts: 3,486   (View Stats)
GunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the world
Groans: 38
Groaned at 20 Times in 14 Posts
Originally Posted by AuroraAxela View Post
Here's the video of one of the pulls. MS3 gen 2 meth injection 4th gear pull - YouTube
Nice stretch of road right there man
FreekTuned 2006 CWP MazdaSpeed6
ATP EWG GTX3076r - HTP 3" Intake System - CPE Single Exit Exhaust
ATP Catless Down Pipe - CPE Differential Mount - CPE Top Mount Intercooler
JBR 80D Trilogy Mount Package - Grimmspeed EBCS Autotech Internals
Bosch 3 Bar Map Sensor - Bit Wise Plug n Play - GFB Hybrid BOV
Bilstein Struts - H&R Sport Lowering Springs - Cobb v3 - e85
Granite State Dyno 4/3/15: 363hp/370trq
2013 Plasma Blue Subaru STI Hatch
E85 FreekTune - Full Bolt-ons
5/14/14 - 12.4@110
2010 NASA Space Shuttle Silver GenPu
E85 FreekTune
EWG GTX3071r: 401HP/386TRQ
K04: 323HP/TachFail SAE
GunGuru727 is offline   Reply With Quote
 Old 12-27-2012, 06:34 AM   #11
Guys, Dust (posting in this thread) is good peeps and has a good deal of experience running methanol (I believe both pre and post turbo).
I just wanted to poke my head in because although new to our forums, he isn't new to meth injection and I've learned quite a bit from him in his posts from other forums.
jracer (12-27-2012)
 Old 12-27-2012, 06:37 AM   #12
robry's Avatar
Posts: 862   (View Stats)
robry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the worldrobry is the leader of the world
Groans: 27
Groaned at 9 Times in 7 Posts
haha that road looks slightly downhill, we know he's padding his virtual dyno logs now
looks good man, I need to get myself a kit as well.
2014 Mustang GT Premium 6MT - GT Track Pack/Leather Recaros/Glass roof in Sterling Grey Metallic | Barton SS/2 Post | J&M LCA | Steeda Street UCA | JBA 3" O/R X | GT500 ABs | JLT plastic CAI | SCT xcal with AED HP custom tune
SOLD2011 Mazdaspeed3 Celestial Blue Mica
robry is offline   Reply With Quote
The Following User Says Thank You to robry For This Useful Post:
 Old 12-28-2012, 07:31 PM   #13
qweedqwag's Avatar
Posts: 233   (View Stats)
qweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the world
Groaned at 22 Times in 10 Posts
Noob here, had no real idea what meth injection really did, for you other posers here is a really good video explaining the benefits.
qweedqwag is offline   Reply With Quote
The Following 2 Users Say Thank You to qweedqwag For This Useful Post:
AZSPEED3 (06-24-2013), KILLER_VIZ (12-29-2012)
 Old 06-24-2013, 03:57 PM   #14
coasttime's Avatar
Posts: 163   (View Stats)
coasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond reputecoasttime has a reputation beyond repute
Groaned at 19 Times in 8 Posts
I know this post is old, but this is a nice setup. I really am looking forward to installing my snow.
coasttime is offline   Reply With Quote
 Old 02-20-2018, 01:50 AM   #15
hdragster's Avatar
Posts: 30   (View Stats)
hdragster is a splendid one to beholdhdragster is a splendid one to beholdhdragster is a splendid one to beholdhdragster is a splendid one to beholdhdragster is a splendid one to beholdhdragster is a splendid one to beholdhdragster is a splendid one to behold
No pictures?
hdragster is offline   Reply With Quote
The Following 3 Users Say NO Thank You to hdragster For This Un-useful Post:
g00s3y (03-03-2018), JSmith (03-03-2018), Thor Hammer (02-20-2018)
 Old 02-20-2018, 05:45 AM   #16
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Originally Posted by hdragster View Post
No pictures?
You're 5 centuries late. The pictures expired from that free picture hosting site.
PapaBruno likes this.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 03-03-2018, 12:39 PM   #17
hdragster's Avatar
HAHA apparently so
 Old 03-03-2018, 01:12 PM   #18
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
No pictures?
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
Stratified Meth kit install using stock washer reservoir Lex Stratified Automotive Controls 196 07-10-2017 09:16 AM
Meth Install wdautrem MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 6 04-08-2011 02:48 PM
p3 meth install quickspeed6 Mazdaspeed3/6 General Discussion 10 07-21-2009 06:50 PM
Meth Install Doc badams118 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 7 05-16-2009 03:20 AM
Page generated in 0.39064 seconds with 31 queries
