Welcome to Mazdaspeed Forums
Mazda Forums / MazdaSpeed Forums - Mazdaspeed Forum with High Performance Discussions, Car Gallery, Mods Information, Street Racing Stats,
Street Racing Videos & more. The Archived MazdaspeedForums! Mazdaspeed Mazda MSF MazdaSpeedForums.org.
You are currently viewing our boards in read mode only. We are here to preserve the data and info that is useful to Mazda gear heads.
If you'd like to donate to keep this info alive, your donation will go to hosting, SSL, and domain fees.
Search Forum
  • 1 Post By MSMS3
 Old 06-24-2011, 01:36 PM   #1
IPuOnU's Avatar
Posts: 399   (View Stats)
IPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the worldIPuOnU is the leader of the world
Default Backfire when shifting at WOT?
Well as of late I've noticed that my car backfires when I'm WOT and shift, it's plainly audible, not so much worried about it as I am just curious what could cause it as I am all stock other than exhaust. And that is just second cat and muffler delete. All connections are secure under the hood, and have no leaks. So what else may cause it to Backfire?
2010 CBM Speed 3 (Daily)
Muffler Delete
Sure Aeros
TRZ Poly RMM
14.11 @ 100 2.1 60'
1986 Firetird
350 Chevy (2 Bolt Main)
Stock Bottom End
Edelbrock E-tec 200 Heads (Port, Polish, Decked)
JE Pistons
Ford 9" Rear End 4.30 Gears
Stock Suspension
11.29@113.8 mph, 1.54 60'
IPuOnU is offline   Reply With Quote
 Old 06-24-2011, 01:38 PM   #2
manelscout4life's Avatar
Posts: 1,781   (View Stats)
Groans: 661
Your fp is probably shitting the bed with the cat delete. Buy something to monitor your car... And some real mods
 Old 06-24-2011, 01:43 PM   #3
oh10speed3's Avatar
Posts: 1,119   (View Stats)
oh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the world
Groaned at 74 Times in 30 Posts
My guess would be fuel pump as well
//Stage 1 & Done\\
oh10speed3 is offline   Reply With Quote
 Old 06-24-2011, 05:13 PM   #4
IPuOnU's Avatar
Meh not to worried about it right now as I said, but good thing I planned on internals and AP when I get back in 4 months.
Muffler Delete
Sure Aeros
TRZ Poly RMM
14.11 @ 100 2.1 60'
1986 Firetird
Stock Bottom End
JE Pistons
Stock Suspension
 Old 06-24-2011, 05:43 PM   #5
Groans: 661
You might not be worried but keep running your car with a dead fuel pump and you'll need a new engine in no time.
 Old 06-24-2011, 06:26 PM   #6
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Bpv or bov?
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 06-24-2011, 06:27 PM   #7
Dre
Dre's Avatar
Posts: 1,651   (View Stats)
Dre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the world
Groans: 48
Groaned at 16 Times in 14 Posts
lolol @ manel
"Pain? I ain't got time for pain.. Only pain I got time for is the pain i put on fools who don't know what time it is."
-TTT
Dre is offline   Reply With Quote
 Old 06-24-2011, 06:34 PM   #8
JS + MS3's Avatar
Posts: 1,794   (View Stats)
JS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the world
Groaned at 72 Times in 51 Posts
fp
2010 Mazdaspeed3
Cobb AP - CP-E SRI - Ultimate Racing TP - CP-E RMM 75D - JBR RSB - JBR SSP - Autotech HPFP Internal - Denso ITV22 - Advan RZ 18x8 (Conti ExtremeContact DW 235/40/18)
JS + MS3 is offline   Reply With Quote
 Old 06-24-2011, 06:56 PM   #9
Soto's Avatar
Posts: 525   (View Stats)
Soto is the leader of the worldSoto is the leader of the worldSoto is the leader of the worldSoto is the leader of the worldSoto is the leader of the worldSoto is the leader of the worldSoto is the leader of the worldSoto is the leader of the worldSoto is the leader of the worldSoto is the leader of the worldSoto is the leader of the world
my car farts too
but i have bolt ons and test pipe
and stage 2 ots map
it sounds beastly
11' Speed 3
Mods: Stock for now.
Soto is offline   Reply With Quote
 Old 06-24-2011, 07:31 PM   #10
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
Most likely AFTERFIRE. Backfire is no good.
Dre (06-24-2011)
 Old 06-24-2011, 09:21 PM   #11
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
It's not the fuel pump; it's the car going rich at throttle lift-off, and the fuel is igniting in the exhaust. It happens to all our cars (ECU runs rich to cool the engine and turbo), but the catalytic convertor absorbs the sound normally.
The Following 7 Users Say Thank You to silvapain For This Useful Post:
08.5MS3 (06-24-2011), Dre (06-25-2011), FightaX (06-24-2011), LakeSTLMS3 (06-29-2011), LiEast (06-24-2011), Soto (06-25-2011), Tokay444 (06-25-2011)
 Old 06-24-2011, 09:32 PM   #12
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
Wouldn't the car be running rich if the fuel pressure is dropping and the pump is dumping fuel?
The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post:
manelscout4life (06-24-2011)
 Old 06-24-2011, 09:40 PM   #13
silvapain's Avatar
Groans: 136
If the pressure drops then less fuel is being pumped in, not more. Plus, it's not at shifting that the pump has pressure issues; it's during WOT in the 4K RPM range (where we get max torque).
 Old 06-24-2011, 09:50 PM   #14
Groans: 134
Idk, I guess I'm missing a piece of the picture, because I am sure that the ecu responds to the pressure drop by dumping fuel... But I will be the first to admit that idk how all the pieces fit together.
 Old 06-24-2011, 10:22 PM   #15
08.5MS3's Avatar
Groans: 89
AKA = Afterfire!
 Old 06-24-2011, 11:34 PM   #16
Groans: 661
When the pressure drops the ecu adds more fuel.
I was running an atr tuned map with an 11.8 AFR that I matching pretty closely to. When my fp first started breaking down (700-800psi) my AFR would be in the 10's at wot and the car would after fire.
The Following User Says Thank You to manelscout4life For This Useful Post:
Ckmazdaspeed3 (06-25-2011)
 Old 06-24-2011, 11:39 PM   #17
08.5MS3's Avatar
Groans: 89
Backfire occurs in the induction side, such as intake valves that do not close soon enough. Afterfire occurs, as stated, with fuel being burned in the exhaust system.
Afterfire is fine. Backfire is not.
Tapawhat?
 Old 06-25-2011, 12:22 AM   #18
aanguia1's Avatar
Posts: 291   (View Stats)
aanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the world
Groaned at 32 Times in 8 Posts
Tapawhat?
Which one is worst? Afterfire or backfire???
Sent from my T-Mobile G2 using tapatalkreplace
aanguia1 is offline   Reply With Quote
The Following 2 Users Say NO Thank You to aanguia1 For This Un-useful Post:
Dre (06-25-2011), manelscout4life (06-25-2011)
 Old 06-25-2011, 03:16 AM   #19
IPuOnU's Avatar
Now that makes sense. and no, stock BPV.
And the reason I'm not worried about it even if it was fuel pump, the farthest my car is moving in the next four months is about 75 feet a couple times a week from the house to the garage. Lol no need to dump money in something that ain't being driven.
But thanks guys I didn't think to look up afterfires, that makes more sense.
Muffler Delete
Sure Aeros
TRZ Poly RMM
14.11 @ 100 2.1 60'
1986 Firetird
Stock Bottom End
JE Pistons
Stock Suspension
 Old 06-25-2011, 06:43 AM   #20
Groans: 134
@silvapain this^^^
While I agree that it is good to know the difference between afterfire and backfire, I still think most of the time on here people call it (though incorrectLy), backfire.
Last edited by Ckmazdaspeed3; 06-25-2011 at 06:43 AM. Reason: MSF Database - Automerged Doublepost
08.5MS3 (06-25-2011)
 Old 06-25-2011, 07:06 AM   #21
08.5MS3's Avatar
Groans: 89
Backfire. Your exhaust, your cats, and the heat will burn that shit up.
Tapawhat?
 Old 06-25-2011, 07:08 AM   #22
08.5MS3's Avatar
Groans: 89
Yes. I went through the same thing a few days ago, in relation to OP's problem. I searched and read around. Just for more awareness. I'm kind of a stickler with proper terminology.
Tapawhat?
 Old 06-25-2011, 08:18 AM   #23
Soto's Avatar
my car afterfires .
stupid OTS map
my AFR's are like 10.8 at WOT
11' Speed 3
The Following User Says Thank You to Soto For This Useful Post:
 Old 02-09-2018, 06:42 AM   #24
mitch11wmm's Avatar
Posts: 11   (View Stats)
mitch11wmm will become famous soon enough
My afr was hitting 10s today while on a stock tune and muffler and res delete.
Im getting it tuned soon just knocked out basic stuff first
Sent from my VS995 using tapatalkreplace
mitch11wmm is offline   Reply With Quote
 Old 02-09-2018, 07:24 AM   #25
MSMS3's Avatar
Posts: 2,829   (View Stats)
Holy seven year old dead thread revival! Stock tune will get in the high 10s under max load, WOT at redline. It's deliberate to provide cylinder cooling to control knock. It allows the stock tune to use more aggressive timing than you might think.
By all means get a good tune, but AFR that rich is normal on stock tune up high.
Check your fuel rail pressure to make sure it is 1600 or better under WOT. As these cars age the pump's piston and cylinder wear. If you are getting a tune that raises boost above stock levels, a pump internals upgrade is mandatory, anyway.
And, stop renewing 7 year old threads.
silvapain likes this.
 Old 02-09-2018, 07:31 AM   #26
mitch11wmm's Avatar
Lol I didn't even look at the date that's kind of funny.
But yeah I plan on getting hpfp anyways here soon and my fuel pressure is fine. I was just curious about pops
 Old 03-13-2018, 08:31 PM   #27
silvapain's Avatar
Groans: 136
Jesus this place has gone downhill with fucking noobs not reading shit.
Sent from my iPhone using tapatalkreplace Pro
MSMS3 (03-14-2018)
Backfire at WOT not when shifting!!! Shooter445 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 04-04-2011 06:47 PM
Backfire? danlash Mazdaspeed3/6 General Discussion 10 03-23-2011 04:25 PM
Anyone here get some serious backfire? Death-From-A-Mile Mazdaspeed3/6 General Discussion 40 10-12-2008 12:47 PM
Pop/backfire at WOT/shifting? aaronc7 MazdaSpeed 3 - Engine, Transmission & Driveline 74 05-23-2008 01:30 PM
Page generated in 0.45061 seconds with 32 queries
