Welcome to Mazdaspeed Forums
Mazda Forums / MazdaSpeed Forums - Mazdaspeed Forum with High Performance Discussions, Car Gallery, Mods Information, Street Racing Stats,
Street Racing Videos & more. The Archived MazdaspeedForums! Mazdaspeed Mazda MSF MazdaSpeedForums.org.
You are currently viewing our boards in read mode only. We are here to preserve the data and info that is useful to Mazda gear heads.
If you'd like to donate to keep this info alive, your donation will go to hosting, SSL, and domain fees.
Search Forum
Like Tree3Likes
 Old 02-10-2011, 06:51 PM   #1
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
Default Autotech Internals
Just giving all you gen2 boys a heads up...
I am ordering and installing http: http://www.autotech.com/prod_engine_fuelinj.htm
Im hoping to give us another option to the HPFP shortage.
Should have them delivered and installed by the 19th of this month.
I did alot of research on vdub forums since KMD is made for vdubs and so are autotechs, same set up just different companies and a little more expensive but i just want a damn fuel pump so i can install my downpipe and actually use the AP to its full advantage.
Many threads I moused through all pointed to Autotech > KMD, so well see how it goes
Also i called autotech and they said there internals are good up to 200 bar of pressure which equals out to 2900psi (I laughed to), but after reading some threads people have said that they see a steady 133bar, which is 19XX psi, which is excellent if you ask me.
Alrighty!!! Auto-Tech Internals installed, logs are 3rd gear pull and 4th gear pull. Enjoy!
As of now im only running Stage1+SF+TIH 93 Octane BT, for some reason the link on cobbs site for +CDHP is broken, so hopefully they will fix it monday so i can run that map and post some more logs with the higher boost map.
Thanks to BeeZa for hooking be up with the Stage1+SF+TIH+CDHP 93 Octane BT map, last two logs are with this map, Target 19psi, hold 17psi to redline. Shit feels like a whole different car now, ap rocks!
logs are obviously labeled with the map they were logged on.
860whp/677wtq
2.7 V6 Ecoboost
The Following 22 Users Say Thank You to PapaSmurf For This Useful Post:
BradX (02-10-2011), Broxer (03-14-2011), DingoDave (03-21-2011), fishin53 (02-10-2011), forcedinduktion (02-23-2011), fywdyl (02-22-2011), JS + MS3 (02-27-2011), NoTraction (03-08-2011), PunjabiPlaya (02-10-2011), rghispanic88 (03-03-2011), Seaton (02-10-2011), Spd3 (04-27-2011), Speed3eak (02-10-2011), speedms6 (02-23-2011), SpeedSixxx (03-01-2011), spoolin00 (02-23-2011), Teethkikr (02-21-2011), thepatient77 (02-19-2011), triphop631 (03-03-2011), wolly6973 (02-10-2011), xxdjfate76xx (02-19-2011)
 Old 02-10-2011, 06:55 PM   #2
Seaton's Avatar
Posts: 233   (View Stats)
Seaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the world
Good work! Keep us updated.
Seaton is offline   Reply With Quote
 Old 02-10-2011, 08:03 PM   #3
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
subbed, good luck with the new dp...I too am waiting on KMD internals so I can install my DP...
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
 Old 02-10-2011, 08:23 PM   #4
BradX's Avatar
Posts: 353   (View Stats)
BradX is the leader of the worldBradX is the leader of the worldBradX is the leader of the worldBradX is the leader of the worldBradX is the leader of the worldBradX is the leader of the worldBradX is the leader of the worldBradX is the leader of the worldBradX is the leader of the worldBradX is the leader of the worldBradX is the leader of the world
I'm very curious to see how they work. Hopefully it works out good.
BradX is offline   Reply With Quote
 Old 02-10-2011, 08:58 PM   #5
Speed3eak's Avatar
Posts: 2,290   (View Stats)
Groans: 82
curious about these and AWE.
I'm probably gonna end up getting a cp-e anyway, but I would like to see the results nonetheless.
 Old 02-10-2011, 09:13 PM   #6
PapaSmurf's Avatar
There the same exact type of internals as KMD, so I dunno why people would think they wouldnt work.
860whp/677wtq
2.7 V6 Ecoboost
IshiKage (02-11-2011), Speed3eak (02-10-2011)
 Old 02-11-2011, 05:42 PM   #7
WOT @1k RPM!
NRSpeed's Avatar
Posts: 1,570   (View Stats)
NRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the worldNRSpeed is the leader of the world
Groaned at 50 Times in 33 Posts
PTP where the same too.
MazdaSPEED3 2009 - Mica Black
http://www.mazdaspeedforum.org/forum/forum/f8/setting-avatar-new-users-other-noobs-43712/
http://www.mazdaspeedforum.org/forum/forum/f8/uploading-adding-images-your-post-43704/
No BB URL code = sux
NRSpeed is offline   Reply With Quote
 Old 02-11-2011, 08:59 PM   #8
PapaSmurf's Avatar
PTP is a scrub ass company. Auto-tech is known in the vw world and from what i have read hasent had any failures.
There is no way you can compare PTP products to any company.
860whp/677wtq
2.7 V6 Ecoboost
 Old 02-11-2011, 04:43 PM   #9
MarkGrof10's Avatar
Posts: 34   (View Stats)
MarkGrof10 will become famous soon enough
I just talked to a guy at auto tech and he didn't know if these would work for the gen 2. And I was trying to make sure that they will fit our pump. Thanks guys
MarkGrof10 is offline   Reply With Quote
 Old 02-11-2011, 04:49 PM   #10
regulator84's Avatar
Posts: 325   (View Stats)
regulator84 has disabled reputation
You need to read some of the other threads on HPFP options, because we've been through this at least a dozen times.
2011 STi | Stage 2
[SOLD] 2010 Black Mica | CS SRI + TIP | JBR SSP | TRZ RMM | OCC | DDM 6000k 35w |
regulator84 is offline   Reply With Quote
 Old 02-11-2011, 04:47 PM   #11
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
we have the same pump as vdubs, they will fit
2015 Mazda 6
 Old 02-11-2011, 04:55 PM   #12
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
i hope they seize.
wait, did i type that out loud?
AZSPEED3 (02-25-2011)
 Old 02-11-2011, 05:08 PM   #13
They are good internals and they are also local to us if you didnt know.
I know KMD made a change to the piston design and rod. The rod on the new version is longer, so this is why i decided to wait it out and give em a whirl.
TulsaVR93FD (03-08-2011)
 Old 02-11-2011, 08:18 PM   #14
DONOTBUGME's Avatar
Posts: 2,631   (View Stats)
Groans: 266
I though they were changing their coating, or is that the change that became v2.1.
DONOTBUGME is offline   Reply With Quote
 Old 02-11-2011, 05:55 PM   #15
zx2man's Avatar
Posts: 1,356   (View Stats)
zx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the world
Well ill be looking into either new internals or the cpe pump here soon...My ptp pump which has held up 1600-1800 @wot for the past year now, has decided to drop down to 900 psi from 5000-5700rpm, so im getting some cut and no wot for me at this time.
Im really looking for feedback for the awe tuning internals, since their spose to be a pretty dam good company for the vdub/audi boys. But like Haltech said, maybe ill wait for kmd, just want the best internals for my money, And do not want to wait tooo long.
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
JBARONE SHIFTERPLATE
COBB RSB
KONIG WHEELS/HANKOOK TIRES
TIM BAILEY PROTUNE 291WHP/310WTQ *AWD MUSTANG DYNO*
zx2man is offline   Reply With Quote
 Old 02-11-2011, 06:05 PM   #16
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
you realize the CPE pump has a lifetime warranty right?
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
jracer (03-02-2011)
 Old 02-11-2011, 07:31 PM   #17
zx2man's Avatar
Oh the Cp-e pump is and has been the gold standard for us speeders. Well aware of that...lifetime warranty is very nice. Gerry said it will prabaly be 3-4 weeks atleast before pumps come in, we shall see.
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
COBB RSB
 Old 02-19-2011, 03:30 PM   #18
PapaSmurf's Avatar
Op updated.
Side note, for some reason i cant download Stage1+SF+TIH+CDHP 93 Octane BT map off cobbs site, seems like the link is broken, if anyone has it and can share it with me ill be happy!
as stated below im only running Stage1+SF+TIH 93 Octane BT, but i do have my auto tech internals installed!
Enjoy!
860whp/677wtq
2.7 V6 Ecoboost
 Old 02-19-2011, 03:43 PM   #19
Speed3eak's Avatar
Groans: 82
Datalogs look great - I see you're touching 19xx psi for a while there too.
I'm really tempted by these - how much did the shop you went to charge for the installation?
 Old 02-19-2011, 03:59 PM   #20
PapaSmurf's Avatar
To much, but I didn't care cause I just wanted this done. lol about to go log the map I'm suppose to be running and I'll post those logs also
860whp/677wtq
2.7 V6 Ecoboost
Speed3eak (02-19-2011)
 Old 02-19-2011, 04:26 PM   #21
PapaSmurf's Avatar
op updated again with Stage1+SF+TIH+CDFP 93 Octane BT datalogs.
860whp/677wtq
2.7 V6 Ecoboost
 Old 02-19-2011, 06:58 PM   #22
Spoofmastafly's Avatar
Posts: 1,444   (View Stats)
Logs look good! Seeing yours will hit 2000psi as well. Good internals! Hopefully these continue perform!
 Old 02-22-2011, 12:21 PM   #23
crbalch's Avatar
Posts: 306   (View Stats)
crbalch has a reputation beyond reputecrbalch has a reputation beyond reputecrbalch has a reputation beyond reputecrbalch has a reputation beyond reputecrbalch has a reputation beyond reputecrbalch has a reputation beyond reputecrbalch has a reputation beyond reputecrbalch has a reputation beyond reputecrbalch has a reputation beyond reputecrbalch has a reputation beyond reputecrbalch has a reputation beyond repute
where did you order these from? and they were stocked?
also, I have an MS6, the pump is the same for both right
crbalch is offline   Reply With Quote
 Old 02-22-2011, 12:33 PM   #24
ebnash's Avatar
Posts: 244   (View Stats)
ebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond repute
Autotech Sport Tuning - Engine-Fuel Injection, FSI High Volume Fuel Pump, Co Mixture Tool, EHA Test Harness
Hunt Hard, Kill Swiftly, Waste Nothing, Offer No Apologies...
ebnash is offline   Reply With Quote
 Old 02-22-2011, 12:34 PM   #25
mghtymouse380's Avatar
Posts: 1,182   (View Stats)
mghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the world
Groans: 58
Just keep everyone updated. With the cpe hate that is going on now everyone will be looking for diffrent options.
nathanw81 likes this.
2013 CWP (DD)
COBB AP| JBR HSK| JBR RSB| JBR SSP| JBR Shifter Bushings| AT Internals| Ksport Kontrol Pro Coilovers| 3.5 MAF HOUSING| 3' HTP TIP| UR FMIC| TIGS| GTX2867| EBAY 3' DP
TUNE IN PROGRESS (RFINKLE2)
1999 Mazda Miata (PROJECT) (blown motor)
BEGI Cast Manifold| BEGI DP| SR20 Turbo (GT2554)| Flying Miata Silicone IC Piping| Cx Racing IC| HKS BOV| TEIN SA| Harddog Rollbar|Sparco Spint V| TRmotorsports C1 15x8
mghtymouse380 is offline   Reply With Quote
 Old 02-22-2011, 12:41 PM   #26
crbalch's Avatar
yep, I have cpe on order and I am going to cancel, I think I will wait for KMD, or go with these
 Old 02-22-2011, 12:46 PM   #27
SPEEDRAC3R's Avatar
Posts: 399   (View Stats)
SPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the world
subbing for more info...
2009 MS3GT - JBR 3.0" Wide Path Full Intake System | CorkSport TMIC |NATOR'd Test Pipe | Autotech HPFP | COBB AP (freek PERM in process) | NGK LTR7IX-11 (6510) | SURE Anchors | Bilstein B8's | 35% Tint
SPEEDRAC3R is offline   Reply With Quote
 Old 02-22-2011, 01:05 PM   #28
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
mine come in tomorrow and hopefully if i can get a fellow mwmber to help we will install saturday. i am a gen one running stage 2+sf and supporting mods. good to see good news blue
 Old 02-22-2011, 06:09 PM   #29
myslow1's Avatar
Posts: 355   (View Stats)
myslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the world
nice to see there is another fairly priced set of internals. Thank you for doing this and posting your results.
Daily - 2007 True Red Mazdaspeed3 GT.
Jack Stand Race Car - 1991 Aquamarine Pearl MR2.
myslow1 is offline   Reply With Quote
 Old 02-22-2011, 10:20 PM   #30
DONOTBUGME's Avatar
Groans: 266
ordered
The Following 2 Users Say Thank You to DONOTBUGME For This Useful Post:
myslow1 (02-23-2011), PapaSmurf (02-22-2011)
 Old 02-23-2011, 12:46 AM   #31
skeeter149's Avatar
Groans: 91
crap snow storm sat and no help sunday might be doing next week if weather doesnt "brighten" up.
 Old 02-23-2011, 06:38 PM   #32
Snotrocket's Avatar
Posts: 900   (View Stats)
ordered..... See how long it takes to get to canada... hopefully they still have stock..
2010 MS3 Black
395whp/386wtq
 Old 02-23-2011, 08:25 PM   #33
DONOTBUGME's Avatar
Groans: 266
I just got my tracking number and it say they will be here tomorrow....I think its them, nothing else I ordered could weigh only .9 pounds. Perfect timing cause my ap is getting here tomorrow.
 Old 02-23-2011, 08:46 PM   #34
Snotrocket's Avatar
How long did it take to get a tracking number after you ordered?
2010 MS3 Black
395whp/386wtq
 Old 02-23-2011, 09:04 PM   #35
DONOTBUGME's Avatar
Groans: 266
I ordered it last night, I didn't get an email from them saying it shipped It is a package that weighs .9 pounds...only other thing I ordered was a shark fin and AP. Both I think weigh more than .9 pounds
Edit: Nevermind just saw the sender was autotech.
 Old 02-23-2011, 09:18 PM   #36
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
Can you post pics of the internals?
How does the button lock onto the piston?
Good job OP!
 Old 02-23-2011, 09:21 PM   #37
PapaSmurf's Avatar
I didnt take pics of them out of the case. But it honestly is exactly the same as KMD.
860whp/677wtq
2.7 V6 Ecoboost
 Old 02-23-2011, 09:24 PM   #38
DONOTBUGME's Avatar
Groans: 266
They are just like the KMD, But here is a picture from autotech website
 Old 02-23-2011, 09:34 PM   #39
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
reminds me of the carpie dime internals that failed on me, with the different, goffy ass, valve spring clips, split the retainer in half!! luckily
it didn't trash my pump housing...
hope the retainer is harder than a hore's heart!!!
at 104000 2 bent rods
tuned by nishan
 Old 02-23-2011, 09:38 PM   #40
DONOTBUGME's Avatar
Groans: 266
well our only 2 choices other than cp-e both have this design
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f433/autotech-internals-72084/
Internals for Fuel Pump - Page 2 This thread Refback 10-27-2011 08:33 PM
2010 ms3 cobb acessport & fuelpump internals??? This thread Refback 03-02-2011 09:06 AM
Internals for Fuel Pump This thread Refback 02-25-2011 07:32 AM
kmd internals spec2k5 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 41 01-04-2011 09:09 AM
Internals 9900rpm 2010 MS3 - Engine, Transmission & Driveline 11 09-29-2009 02:00 PM
KMD V2 Internals wakeboarddude MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 7 07-10-2009 05:15 PM
Page generated in 0.68772 seconds with 44 queries
