> 2010 MS3 - How-To's
Like Tree25Likes
 Old 04-03-2012, 01:33 PM   #41
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
I would say something that has a temperature range well above 300F, and a dropping point closer to 400F. Judging by the film on Clint's throwout bearing shaft, I'd say the grease used before had melted and lost it lubricating properties.
GLORIFIEDBOZO (04-03-2012), TiGraySpeed6 (04-03-2012)
 Old 04-03-2012, 06:39 PM   #42
GLORIFIEDBOZO's Avatar
Posts: 1,928   (View Stats)
GLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the world
Sweet, the valvoline synthetic grease I picked up has a dropping point of 500F. I think that was the highest temp stuff at the autozone I picked it up at.
"Intelligence isn't the ability to store information, but to find it" - Albert Einstein
"When I read about the evils of drinking, I quit reading" - Henry Youngman
GLORIFIEDBOZO is offline   Reply With Quote
The Following User Says Thank You to GLORIFIEDBOZO For This Useful Post:
silvapain (04-03-2012)
 Old 09-29-2012, 06:13 PM   #43
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
excellent write up !!!
wish i would of seen this 2 years ago when pulling the trans on my friends ms3.
however, fwiw...i never removed the front subframe. i pulled the trans out with all that in place and had no issues although it does give you more room for comfort.
www.tunedbynishan.com
bertrand_CX_7 (12-02-2013)
 Old 10-01-2012, 02:26 AM   #44
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
What is a self-adjusting-PP? Could that be the reason why my OEM clutch is slipping in the first place?
Pickles Tune in progress
 Old 10-10-2012, 06:03 AM   #45
Replacing clutch, at @MATT DAMOND's request, is moved to the general how-to.
I strongly urge those who use this how to as the basis for their clutch, go VIP here after.
HOW-TO: MAZDASPEED3 REPLACE CLUTCH
GLORIFIEDBOZO (10-10-2012), MATT DAMOND (10-10-2012), ms3blackmica (10-11-2012), TiGraySpeed6 (10-10-2012)
 Old 10-10-2012, 11:51 AM   #46
silvapain's Avatar
Groans: 136
A self-adjusting pressure plate has small springs and a ratcheting device in it to slowly move the pressure plate mating surface towards the clutch disc as the disc wears. This provides a more consistent clutch pedal engagement point and clutch pressure through the clutch lifespan.
Tapadatass
The Following 6 Users Say Thank You to silvapain For This Useful Post:
3Gee Tee (10-10-2012), himurax13 (05-07-2013), MATT DAMOND (10-10-2012), ms3blackmica (10-11-2012), Nliiitend1 (10-10-2012), Tomas (09-12-2013)
 Old 11-02-2012, 03:34 PM   #47
aviator79's Avatar
Posts: 3,934   (View Stats)
What about the pilot bearing? does no one replace it? inside the crankshaft. How do you remove it anyways?
 Old 11-02-2012, 03:54 PM   #48
silvapain's Avatar
Groans: 136
Buy the pilot bearing removal attachment for a slide hammer from AutoZone, and slightly grind down the fingers to get it to fit through the bearing. Then buy/rent the slide hammer and pop it out. You can use a socket to tap the new bearing in.
aviator79 (11-02-2012)
 Old 11-24-2012, 06:46 PM   #49
aviator79's Avatar
So which way does the disc orient? Seems to me that it should orient the way the manual says, i.e. with the side with the spline that sticks out further facing the trans.
My point being u say the Manuel is wrong. My disc gives no indication on orientation.
 Old 11-26-2012, 08:30 AM   #50
aviator79's Avatar
So I looked at the manual and it shows both orientations. One for the A65M-R manual transaxle, which you say is opposite and then one for the A26MX-R, which shows it the other way. So I assume we have the A26MX-R?
 Old 11-26-2012, 08:38 AM   #51
silvapain's Avatar
Groans: 136
The MS3 transmission is the A26M-R. The part of the clutch disc that sticks out goes towards the transmission side.
Tapadatass
ms3blackmica (11-26-2012)
 Old 11-26-2012, 10:22 AM   #52
aviator79's Avatar
Tapadatass
So like the 2nd attachment for the A26MX-R with the center inner splined shaft that sticks out further going toward the engine and the side where the springs stick out further toward the Trans?
So is the X in A26MX-R for the MS6 and the MS3 has the A26M-R?
 Old 11-26-2012, 12:07 PM   #53
silvapain's Avatar
Groans: 136
It's hard to see on my phone, but it looks to me like both attachments you posted have the clutch disc facing the same way; with the part of the disc that has the second plate the houses the springs facing the transmission.
I only have the MS3 manual on my computer so I can't verify, but it seems logical to me that since the MS3 is A26M-R, then the MS6 transmission designation would be A26MX-R.
Tapadatass
aviator79 (11-26-2012), MATT DAMOND (03-13-2013), ms3blackmica (11-29-2012)
 Old 03-08-2013, 10:10 PM   #54
Kfunk's Avatar
Posts: 33   (View Stats)
Kfunk is a splendid one to beholdKfunk is a splendid one to beholdKfunk is a splendid one to beholdKfunk is a splendid one to beholdKfunk is a splendid one to beholdKfunk is a splendid one to beholdKfunk is a splendid one to behold
Excellent write up man. I don't have the balls to attempt to it but in saying that maybe I do now.
Kfunk is offline   Reply With Quote
The Following User Says Thank You to Kfunk For This Useful Post:
 Old 03-13-2013, 05:27 PM   #55
AustinK's Avatar
Posts: 175   (View Stats)
AustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the world
Good work, no thanks. haha Great photos
AustinK is offline   Reply With Quote
The Following User Says Thank You to AustinK For This Useful Post:
 Old 03-13-2013, 06:13 PM   #56
Nishan
Honestly the best part about this write up is the large peice of cardboard used for holding bolts and knowing exactly where they came from.
Something I had never thought to do before.
MATT DAMOND (03-13-2013), Nliiitend1 (03-13-2013)
 Old 05-06-2013, 04:40 PM   #57
Roddiy's Avatar
Posts: 5,388   (View Stats)
Groans: 279
@Sid3wayS;
Think we can knock this off at an install day, or do you think it's better to find a good shop? I've looked around but can't find any good recommendations on shops that know their way around a speed3.
There's reacharounds in it for you of course.
2010 LSM Speed3
#BakeryTuned
The Following User Says Thank You to Roddiy For This Useful Post:
Ace Protege (05-09-2013)
 Old 05-06-2013, 06:27 PM   #58
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Originally Posted by Roddiy View Post
@Sid3wayS;
To do it comfortably id say an all day thing, just this, in my garage, definetly do-able. You can talk with big shayne also, he took it somewhere to get done and it came out good, and his is a pita 6
TEAM LUXURY
 Old 05-06-2013, 07:13 PM   #59
Roddiy's Avatar
Groans: 279
On paper it sounded hard, but after looking at the pics half the steps I've already done for my coils, the other stuff is just the ball-joint and perhaps the subframe.
I'll talk to shayne and see about his shop, but if anything I think I'm gonna wait until I build the motor, since the engine is gonna be out anyways, it'll be easier to do it then.
2010 LSM Speed3
#BakeryTuned
 Old 05-07-2013, 01:30 AM   #60
Todd98SE's Avatar
Posts: 1,077   (View Stats)
Followed these instructions for my clutch swap this weekend. Great writeup and detail, thanks Matt. Personal observations would be to use a motorcycle lift for the front of the tranny AND a strap and hoist at the rear to get the tranny back in. I did this job alone and I needed both the lift and hoist to manhandle the tranny back into place efficiently. Also drop the subframe, you will thank yourself later.
www.MOTOIQ.com
Beater Titan
Todd98SE is offline   Reply With Quote
The Following 2 Users Say Thank You to Todd98SE For This Useful Post:
MATT DAMOND (05-09-2013), Nliiitend1 (05-07-2013)
 Old 05-09-2013, 11:04 AM   #61
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Dropping the subframe is a must IMO. The extra 10 minutes is well worth it. I bought a lifetime alignment from my local shop for $30 extra. Little do they know how much my suspension has been taken out lately. Lol.
Well they know cuz I have been back 3x.
Tappin
MATT DAMOND (05-09-2013), Nel Mazdaspeed (04-04-2015), Todd98SE (05-09-2013)
 Old 05-09-2013, 11:38 AM   #62
himurax13's Avatar
Groans: 255
Tappin
Hmm, @ekanddsm; figured out how to do it without dropping the subframe since the ACT clutch assembly is much thinner than stock.
 Old 05-09-2013, 02:02 PM   #63
Trail of Fail
Dano's Avatar
being "able" to do it and doing it "easily" are two different things. Subframe in = taking it out is a PITA [this was with my ACT clutch] due to trying to get the diff to clear the subframe on the drivers side. At that point I pulled the frame cuz I didn't want to wrangle it back in there upon re-install which is always harder.
cudos if you can do it BUT is it worth the added effort and frustration. IDK... for me its not.
BTW I was on the floor no lift...if you have a lift and a tranny jack i bet its easy
either way, to each his own of course.
 Old 05-09-2013, 02:14 PM   #64
DVM17's Avatar
Posts: 1,283   (View Stats)
So glad this was made! Great write up! Unfortunately, this will be the page I'll be on for a while. Stupid PP fingers....
12.07 @ 116 on 205 snow tires
hunting for 11's on 245's
 Old 05-09-2013, 02:50 PM   #65
Ace Protege's Avatar
Posts: 753   (View Stats)
@Sid3wayS;
I'd be down to help you guys if/when you get a clutch. They really aren't bad but I like to do them at a relaxed pace over a solid day.
Roddiy likes this.
'02 Bmw 330ci
Kinda low and really slow.
'94 Mazda Protege -SOLD
1.8 BPT Vf10
263whp 258wtq
13.1 @ 107 mph
'05 ZX-6RR - Two Brothers slip on, GPR dampener V1, More to come
Ace Protege is offline   Reply With Quote
The Following 2 Users Say Thank You to Ace Protege For This Useful Post:
Roddiy (05-09-2013), Sid3wayS (05-09-2013)
 Old 05-09-2013, 03:12 PM   #66
Sid3wayS's Avatar
Groans: 97
Totaly fucking agree. Appreciate the offer bro
TEAM LUXURY
 Old 05-09-2013, 03:18 PM   #67
I've also got air tools and all that shit. Just no where to do it as I live in a tiny apt.
'02 Bmw 330ci
1.8 BPT Vf10
263whp 258wtq
13.1 @ 107 mph
 Old 05-09-2013, 03:22 PM   #68
Roddiy's Avatar
Groans: 279
Yeah so do I haha, air compressors are fucking handy
Thanks man, ill be hitting you up for sure then haha
2010 LSM Speed3
#BakeryTuned
Last edited by Roddiy; 05-09-2013 at 03:22 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-13-2013, 11:00 AM   #69
ekanddsm's Avatar
Posts: 167   (View Stats)
ekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the world
Like john said, and someone else confirmed. you can do it without pulling the subframe, easier no, but doable.
When I do them, I have a lift and trans jack, I havent timed myself, but if I had to say, 4 hours including smoke breaks and its done.
The things I do different, I dont remove the subframe, pass side axle, starter, or knuckles. I only remove the lower arms and punch the drivers side axle out, brake caliper, and rotor stays in place......
There are 2 longer bolts for the bell housing. 1 goes by the clutch slave cylinder, and the other goes in by the 2 tricky ones by the turbo. The rest of the bolts are all the same that hold the trans to the engine.....
Overall nice write up....
Last time I did one, I didnt even remove the passenger side tire.
ekanddsm is offline   Reply With Quote
The Following 3 Users Say Thank You to ekanddsm For This Useful Post:
himurax13 (05-13-2013), someguy (03-18-2014), Todd98SE (05-13-2013)
 Old 08-06-2013, 04:50 PM   #70
Matrix311's Avatar
Posts: 2,133   (View Stats)
Thanks for the writeup. I'm putting my new southbend clutch in this weekend. This should help a lot with the install!
The Following User Says Thank You to Matrix311 For This Useful Post:
MATT DAMOND (09-10-2013)
 Old 09-09-2013, 09:04 PM   #71
scottlnt57's Avatar
Posts: 24   (View Stats)
scottlnt57 is a name known to allscottlnt57 is a name known to allscottlnt57 is a name known to allscottlnt57 is a name known to allscottlnt57 is a name known to allscottlnt57 is a name known to all
I cant get the Photos to come up. Is it just me or are the images down. thanks
2007 MazdaSpeed 3
I am A NOOB!! CHILL
scottlnt57 is offline   Reply With Quote
The Following User Says Thank You to scottlnt57 For This Useful Post:
 Old 09-10-2013, 03:40 AM   #72
Maxed his bandwidth for the month. Go here
Mobile Photobucket
 Old 09-10-2013, 10:46 AM   #73
I have candy in my van
MATT DAMOND's Avatar
Posts: 1,931   (View Stats)
Groans: 70
Fixed
Current Fail:
 Old 11-30-2013, 05:44 PM   #74
Majin~Nieve's Avatar
Posts: 11   (View Stats)
Majin~Nieve will become famous soon enough
Noob here hope I'm posting in the rite place ,This is a great write up :0) it has helped me a lot, although I'm a bit stuck I can't seem to get the 3 bolts off to get the joint shaft off. I can get a socket onto the bolts but the ratchet is too big to fit and my ratchet wrench won't go all the way on the bolt, how did you get them off Matt or is there a way I can drop the trans without removing the joint shaft and I didn't take my k frame off ether doing this all on my own could use you guys expertise :0)
Majin~Nieve is offline   Reply With Quote
 Old 11-30-2013, 08:09 PM   #75
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
There is no way to drop the transmission without taking out the joint shaft.
Try to be more concise in what your problem is. In one sentence you are saying the ratchet is too big and in the next one that ratchet won't go all the way to the bolt.
All you need to do is find the right combination of short extension and/or deep well sockets to get the right distance and clearance with the ratchet on those 3 bolts. If your tools don't fit there is nothing you can do but buy or borrow the necessary tools. If you got the bolts holding the tranny to the block on top of the engine I am sure you can handle those joint shaft bolts.
Majin~Nieve (12-01-2013), silvapain (12-01-2013)
 Old 12-01-2013, 10:50 AM   #76
Thank you for the little push I needed I figured it out and now continuing my project :0)
The Following User Says Thank You to Majin~Nieve For This Useful Post:
Tomas (10-26-2015)
 Old 03-27-2014, 09:02 AM   #77
Douggievee's Avatar
Posts: 71   (View Stats)
Douggievee is just really niceDouggievee is just really niceDouggievee is just really niceDouggievee is just really niceDouggievee is just really nice
Awesome write up! Thank you!
2006 Mazdaspeed6 GT: Autotech Fuel pump, GT3071R, Cobb AP FreakTune, 3" Custom Magnaflow Turboback Dual Exhaust, Mazdaspeeed intake/turbo inlet tube, NGK XI 1 step colder plugs, Fidanza Flywheel, EGR/VTCS Delete, Cobb EBC, Cross drilled rotors, Corksport BPV, TSW Nurburgrings, Techna-Fit SS Clutch Line
Douggievee is offline   Reply With Quote
 Old 07-08-2015, 07:40 AM   #78
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
This will be happening sometime. Lets hope she makes it through EMWNM!
Silver 2007 Speed3 GT
 Old 10-26-2015, 03:42 PM   #79
ejtjeeves's Avatar
Posts: 58   (View Stats)
ejtjeeves has much to be proud ofejtjeeves has much to be proud ofejtjeeves has much to be proud ofejtjeeves has much to be proud ofejtjeeves has much to be proud ofejtjeeves has much to be proud ofejtjeeves has much to be proud ofejtjeeves has much to be proud ofejtjeeves has much to be proud ofejtjeeves has much to be proud of
does anyone happen to know the part number for the Driveshaft Seals and Driveshaft C-Clip?
2007 MS3 - Black Mica
MSCAI | COBB AP | AUTOTECH INTERNALS | CS SSP | CS SB | CS RACE RMM | HKS EXHAUST | FORGE V1 BPV | KONI YELLOWS |
ejtjeeves is offline   Reply With Quote
 Old 02-03-2016, 09:58 PM   #80
bhigdon101's Avatar
Posts: 37   (View Stats)
bhigdon101 is just really nicebhigdon101 is just really nicebhigdon101 is just really nicebhigdon101 is just really nicebhigdon101 is just really nice
did you happen to find the part numbers for them?
2012 white ms3|G2 caliper paint|jbr shifter bushings|jbr short shift linkage|jbr shifter weight| matt damond 3some\3 bar map\3 port ebcs\3.5 htp intake\egr delete\coolant bypass\ets tmic\small batterybox\yellow top battery\autotech hpfp/accessport v3\corksport bpv\corksport springs\koini yellows\freektuned on 93\ UR race pipe\jbr com rear swaybar\ebc redstuff pads\
bhigdon101 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f429/how-mazdaspeed3-replace-clutch-102245/
What Did You Do To Your Car Today? - Page 389 This thread Refback 10-11-2015 05:13 PM
HOW-TO: MAZDASPEED3 REPLACE CLUTCH - Mazdaspeed Forums This thread Refback 11-28-2014 05:00 AM
HOW-TO: MAZDASPEED3 REPLACE CLUTCH - Mazdaspeed Forums This thread Refback 11-28-2014 04:58 AM
Rok - build and boost my MZ3 2006 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 01-08-2014 05:48 PM
Bryan's Message Board This thread Refback 07-23-2013 11:59 AM
Clutch write up. - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 05-24-2013 07:23 AM
4th Gear Temporary Power Reduction - Page 4 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 04-18-2012 05:40 PM
how to replace pcv value for gen 1 ms3? boostedms3 MazdaSpeed 3 - How-To's 17 10-14-2012 01:25 PM
clutch vibration at top of clutch PLEASE HELP livetoskate06 MazdaSpeed 3 - Engine, Transmission & Driveline 84 03-06-2010 06:53 PM
Replace Air Filter Campo MazdaSpeed 3/6 - Turbo Induction 12 02-09-2010 11:39 AM
How do i replace my fogs? speedster 3 Mazdaspeed3/6 General Discussion 16 11-02-2008 06:34 PM
Page generated in 0.60065 seconds with 44 queries
